[QGIS Commit] r11915 - trunk/qgis/src/plugins/interpolation
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 4 03:28:48 EST 2009
Author: timlinux
Date: 2009-11-04 03:28:47 -0500 (Wed, 04 Nov 2009)
New Revision: 11915
   trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
Allow more decimal places in interpolator plugin (fixes issue with building dems in decimal degree datasets)
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
--- trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui	2009-11-04 08:28:18 UTC (rev 11914)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui	2009-11-04 08:28:47 UTC (rev 11915)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsInterpolationDialogBase</class>
- <widget class="QDialog" name="QgsInterpolationDialogBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsInterpolationDialogBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,266 +10,180 @@
     <height>733</height>
    </rect>
   </property>
-  <property name="sizePolicy" >
-   <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+  <property name="sizePolicy">
+   <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Interpolation plugin</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout_3" >
-   <item row="0" column="0" >
-    <widget class="QGroupBox" name="mInputGroupBox" >
-      <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+  <layout class="QGridLayout" name="gridLayout_3">
+   <item row="1" column="0">
+    <widget class="QGroupBox" name="mOutputGroupBox">
+      <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
       </sizepolicy>
      </property>
-     <property name="title" >
-      <string>Input</string>
-     </property>
-     <layout class="QGridLayout" name="gridLayout" >
-       <widget class="QLabel" name="label_2" >
-        <property name="text" >
-         <string>Vector layers:</string>
-        </property>
-       </widget>
-      </item>
-      <item row="0" column="1" colspan="2" >
-       <widget class="QComboBox" name="mInputLayerComboBox" >
-         <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
-          <horstretch>0</horstretch>
-          <verstretch>0</verstretch>
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="0" >
-       <widget class="QLabel" name="mInterpolationAttributeLabel" >
-         <string>Interpolation attribute:</string>
-        </property>
-        <property name="buddy" >
-         <cstring>mInterpolationAttributeComboBox</cstring>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="1" colspan="2" >
-       <widget class="QComboBox" name="mInterpolationAttributeComboBox" >
-         <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="0" colspan="3" >
-       <widget class="QCheckBox" name="mUseZCoordCheckBox" >
-         <string>Use z-Coordinate for interpolation</string>
-        </property>
-       </widget>
-      </item>
-      <item row="3" column="1" >
-       <widget class="QPushButton" name="mAddPushButton" >
-         <string>Add</string>
-        </property>
-       </widget>
-      </item>
-      <item row="3" column="2" >
-       <widget class="QPushButton" name="mRemovePushButton" >
-         <string>Remove</string>
-        </property>
-       </widget>
-      </item>
-      <item row="4" column="0" colspan="3" >
-       <widget class="QTreeWidget" name="mLayersTreeWidget" >
-        <column>
-          <string>Vector layer</string>
-         </property>
-        </column>
-        <column>
-          <string>Attribute</string>
-         </property>
-        </column>
-        <column>
-          <string>Type</string>
-         </property>
-        </column>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
-    <widget class="QGroupBox" name="mOutputGroupBox" >
-      </sizepolicy>
-     </property>
+     <property name="title">
       <string>Output</string>
      </property>
-     <layout class="QGridLayout" name="gridLayout_2" >
-       <widget class="QLabel" name="mInterpolationLabel" >
+     <layout class="QGridLayout" name="gridLayout_2">
+      <item row="0" column="0">
+       <widget class="QLabel" name="mInterpolationLabel">
+        <property name="text">
          <string>Interpolation method</string>
         </property>
+        <property name="buddy">
          <cstring>mInterpolationMethodComboBox</cstring>
         </property>
        </widget>
       </item>
-      <item row="0" column="1" >
-       <widget class="QComboBox" name="mInterpolationMethodComboBox" />
+      <item row="0" column="1">
+       <widget class="QComboBox" name="mInterpolationMethodComboBox"/>
       </item>
-      <item row="0" column="2" >
-       <widget class="QToolButton" name="mConfigureInterpolationButton" >
+      <item row="0" column="2">
+       <widget class="QToolButton" name="mConfigureInterpolationButton">
          <string>...</string>
         </property>
-        <property name="icon" >
-         <iconset resource="interpolator.qrc" >
+        <property name="icon">
+         <iconset resource="interpolator.qrc">
           <normaloff>:/options.png</normaloff>:/options.png</iconset>
         </property>
        </widget>
       </item>
-       <widget class="QLabel" name="mNumberOfColumnsLabel" >
+       <widget class="QLabel" name="mNumberOfColumnsLabel">
          <string>Number of columns</string>
         </property>
          <cstring>mNumberOfColumnsSpinBox</cstring>
         </property>
        </widget>
       </item>
-       <widget class="QSpinBox" name="mNumberOfColumnsSpinBox" >
-        <property name="maximum" >
+      <item row="1" column="1" colspan="2">
+       <widget class="QSpinBox" name="mNumberOfColumnsSpinBox">
+        <property name="maximum">
          <number>10000000</number>
         </property>
        </widget>
       </item>
-      <item row="2" column="0" >
-       <widget class="QLabel" name="mNumberOfRowsLabel" >
+      <item row="2" column="0">
+       <widget class="QLabel" name="mNumberOfRowsLabel">
          <string>Number of rows</string>
         </property>
          <cstring>mNumberOfRowsSpinBox</cstring>
         </property>
        </widget>
       </item>
-      <item row="2" column="1" colspan="2" >
-       <widget class="QSpinBox" name="mNumberOfRowsSpinBox" >
+      <item row="2" column="1" colspan="2">
+       <widget class="QSpinBox" name="mNumberOfRowsSpinBox">
         </property>
        </widget>
       </item>
-      <item row="3" column="0" colspan="3" >
-       <layout class="QHBoxLayout" name="horizontalLayout_3" >
+      <item row="3" column="0" colspan="3">
+       <layout class="QHBoxLayout" name="horizontalLayout_3">
         <item>
-         <widget class="QLabel" name="mCellsizeXLabel" >
+         <widget class="QLabel" name="mCellsizeXLabel">
            <string>Cellsize X:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QDoubleSpinBox" name="mCellsizeXSpinBox" >
+         <widget class="QDoubleSpinBox" name="mCellsizeXSpinBox">
+          <property name="decimals">
+           <number>5</number>
+          </property>
            <double>999999.000000000000000</double>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLabel" name="mCellsizeYLabel" >
+         <widget class="QLabel" name="mCellsizeYLabel">
            <string>Cellsize Y:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QDoubleSpinBox" name="mCellSizeYSpinBox" >
+         <widget class="QDoubleSpinBox" name="mCellSizeYSpinBox">
+          </property>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-       <layout class="QHBoxLayout" name="horizontalLayout" >
+      <item row="4" column="0" colspan="3">
+       <layout class="QHBoxLayout" name="horizontalLayout">
         <item>
-         <widget class="QLabel" name="mXMinLabel" >
+         <widget class="QLabel" name="mXMinLabel">
            <string>X Min:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="mXMinLineEdit" />
+         <widget class="QLineEdit" name="mXMinLineEdit"/>
         </item>
         <item>
-         <widget class="QLabel" name="mXMaxLabel" >
+         <widget class="QLabel" name="mXMaxLabel">
            <string>X Max:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="mXMaxLineEdit" />
+         <widget class="QLineEdit" name="mXMaxLineEdit"/>
         </item>
        </layout>
       </item>
-      <item row="5" column="0" colspan="3" >
-       <layout class="QHBoxLayout" name="horizontalLayout_2" >
+      <item row="5" column="0" colspan="3">
+       <layout class="QHBoxLayout" name="horizontalLayout_2">
         <item>
-         <widget class="QLabel" name="mYMinLabel" >
+         <widget class="QLabel" name="mYMinLabel">
            <string>Y Min:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="mYMinLineEdit" />
+         <widget class="QLineEdit" name="mYMinLineEdit"/>
         </item>
         <item>
-         <widget class="QLabel" name="mYMaxLabel" >
+         <widget class="QLabel" name="mYMaxLabel">
            <string>Y Max:</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="mYMaxLineEdit" />
+         <widget class="QLineEdit" name="mYMaxLineEdit"/>
         </item>
        </layout>
       </item>
-      <item row="6" column="0" colspan="3" >
-       <layout class="QHBoxLayout" name="horizontalLayout_4" >
+      <item row="6" column="0" colspan="3">
+       <layout class="QHBoxLayout" name="horizontalLayout_4">
         <item>
-         <spacer name="horizontalSpacer" >
-          <property name="orientation" >
+         <spacer name="horizontalSpacer">
+          <property name="orientation">
            <enum>Qt::Horizontal</enum>
           </property>
-          <property name="sizeHint" stdset="0" >
+          <property name="sizeHint" stdset="0">
            <size>
             <width>298</width>
             <height>20</height>
@@ -277,30 +192,30 @@
          </spacer>
         </item>
         <item>
-         <widget class="QPushButton" name="mBBoxToCurrentExtent" >
+         <widget class="QPushButton" name="mBBoxToCurrentExtent">
            <string>Set to current extent</string>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="7" column="0" >
-       <widget class="QLabel" name="mOutputFileLabel" >
+      <item row="7" column="0">
+       <widget class="QLabel" name="mOutputFileLabel">
          <string>Output file </string>
         </property>
          <cstring>mOutputFileLineEdit</cstring>
         </property>
        </widget>
       </item>
-      <item row="7" column="1" >
-       <widget class="QLineEdit" name="mOutputFileLineEdit" />
+      <item row="7" column="1">
+       <widget class="QLineEdit" name="mOutputFileLineEdit"/>
       </item>
-      <item row="7" column="2" >
-       <widget class="QToolButton" name="mOutputFileButton" >
+      <item row="7" column="2">
+       <widget class="QToolButton" name="mOutputFileButton">
         </property>
        </widget>
@@ -308,16 +223,108 @@
      </layout>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox" >
+    <widget class="QDialogButtonBox" name="buttonBox">
      </property>
-     <property name="standardButtons" >
+     <property name="standardButtons">
       <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
+    <widget class="QGroupBox" name="mInputGroupBox">
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+      <string>Input</string>
+     </property>
+     <layout class="QGridLayout" name="gridLayout">
+       <widget class="QLabel" name="label_2">
+         <string>Vector layers:</string>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="1" colspan="2">
+       <widget class="QComboBox" name="mInputLayerComboBox">
+         <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="mInterpolationAttributeLabel">
+         <string>Interpolation attribute:</string>
+        </property>
+         <cstring>mInterpolationAttributeComboBox</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QComboBox" name="mInterpolationAttributeComboBox">
+         <sizepolicy hsizetype="MinimumExpanding" vsizetype="Fixed">
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="0" colspan="3">
+       <widget class="QCheckBox" name="mUseZCoordCheckBox">
+         <string>Use z-Coordinate for interpolation</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="1">
+       <widget class="QPushButton" name="mAddPushButton">
+         <string>Add</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2">
+       <widget class="QPushButton" name="mRemovePushButton">
+         <string>Remove</string>
+        </property>
+       </widget>
+      </item>
+       <widget class="QTreeWidget" name="mLayersTreeWidget">
+        <column>
+          <string>Vector layer</string>
+         </property>
+        </column>
+        <column>
+          <string>Attribute</string>
+         </property>
+        </column>
+        <column>
+          <string>Type</string>
+         </property>
+        </column>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
   </layout>
  </widget>
  <tabstops>
@@ -330,7 +337,7 @@
   <tabstop>buttonBox</tabstop>
  </tabstops>
  <resources>
-  <include location="interpolator.qrc" />
+  <include location="interpolator.qrc"/>
  </resources>
  <connections>
   <connection>
@@ -339,11 +346,11 @@
    <receiver>QgsInterpolationDialogBase</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>257</x>
      <y>362</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>157</x>
      <y>274</y>
     </hint>
@@ -355,11 +362,11 @@
    <slot>reject()</slot>
    <hints>
      <x>325</x>
      <y>362</y>
     </hint>
      <x>286</x>
      <y>274</y>
     </hint>
More information about the QGIS-commit mailing list
