[QGIS Commit] r11917 - trunk/qgis/src/plugins/interpolation
svn_qgis at osgeo.org
Wed Nov 4 04:08:36 EST 2009
Author: timlinux
Date: 2009-11-04 04:08:34 -0500 (Wed, 04 Nov 2009)
New Revision: 11917
trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
Use horizontal layout for interp plugin so that it fits more easily on low res displays
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui
--- trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui 2009-11-04 08:58:25 UTC (rev 11916)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolationdialogbase.ui 2009-11-04 09:08:34 UTC (rev 11917)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>538</width>
- <height>733</height>
+ <width>748</width>
+ <height>409</height>
</rect>
</property>
<property name="sizePolicy">
@@ -20,7 +20,102 @@
<string>Interpolation plugin</string>
</property>
<layout class="QGridLayout" name="gridLayout_3">
- <item row="1" column="0">
+ <item row="0" column="0">
+ <widget class="QGroupBox" name="mInputGroupBox">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="title">
+ <string>Input</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <widget class="QLabel" name="label_2">
+ <property name="text">
+ <string>Vector layers:</string>
+ </property>
+ <property name="buddy">
+ <cstring>mInputLayerComboBox</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" colspan="2">
+ <widget class="QComboBox" name="mInputLayerComboBox">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="mInterpolationAttributeLabel">
+ <string>Interpolation attribute:</string>
+ </property>
+ <cstring>mInterpolationAttributeComboBox</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" colspan="2">
+ <widget class="QComboBox" name="mInterpolationAttributeComboBox">
+ <sizepolicy hsizetype="MinimumExpanding" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0" colspan="3">
+ <widget class="QCheckBox" name="mUseZCoordCheckBox">
+ <string>Use z-Coordinate for interpolation</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
+ <widget class="QPushButton" name="mAddPushButton">
+ <string>Add</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="2">
+ <widget class="QPushButton" name="mRemovePushButton">
+ <string>Remove</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0" colspan="3">
+ <widget class="QTreeWidget" name="mLayersTreeWidget">
+ <column>
+ <string>Vector layer</string>
+ </property>
+ </column>
+ <column>
+ <string>Attribute</string>
+ </property>
+ </column>
+ <column>
+ <string>Type</string>
+ </property>
+ </column>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item row="0" column="1">
<widget class="QGroupBox" name="mOutputGroupBox">
@@ -97,6 +192,9 @@
<string>Cellsize X:</string>
</property>
+ <cstring>mCellsizeXSpinBox</cstring>
+ </property>
</widget>
</item>
<item>
@@ -114,6 +212,9 @@
<string>Cellsize Y:</string>
</property>
+ <cstring>mCellSizeYSpinBox</cstring>
+ </property>
</widget>
</item>
<item>
@@ -135,6 +236,9 @@
<string>X Min:</string>
</property>
+ <cstring>mXMinLineEdit</cstring>
+ </property>
</widget>
</item>
<item>
@@ -145,6 +249,9 @@
<string>X Max:</string>
</property>
+ <cstring>mXMaxLineEdit</cstring>
+ </property>
</widget>
</item>
<item>
@@ -159,6 +266,9 @@
<string>Y Min:</string>
</property>
+ <cstring>mYMinLineEdit</cstring>
+ </property>
</widget>
</item>
<item>
@@ -169,6 +279,9 @@
<string>Y Max:</string>
</property>
+ <cstring>mYMaxLineEdit</cstring>
+ </property>
</widget>
</item>
<item>
@@ -223,7 +336,7 @@
</layout>
</widget>
</item>
- <item row="2" column="0">
+ <item row="1" column="0" colspan="2">
<widget class="QDialogButtonBox" name="buttonBox">
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -233,105 +346,26 @@
</property>
</widget>
</item>
- <item row="0" column="0">
- <widget class="QGroupBox" name="mInputGroupBox">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="title">
- <string>Input</string>
- </property>
- <layout class="QGridLayout" name="gridLayout">
- <widget class="QLabel" name="label_2">
- <property name="text">
- <string>Vector layers:</string>
- </property>
- </widget>
- </item>
- <item row="0" column="1" colspan="2">
- <widget class="QComboBox" name="mInputLayerComboBox">
- <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
- </sizepolicy>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="mInterpolationAttributeLabel">
- <string>Interpolation attribute:</string>
- </property>
- <property name="buddy">
- <cstring>mInterpolationAttributeComboBox</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1" colspan="2">
- <widget class="QComboBox" name="mInterpolationAttributeComboBox">
- <sizepolicy hsizetype="MinimumExpanding" vsizetype="Fixed">
- </sizepolicy>
- </property>
- </widget>
- </item>
- <item row="2" column="0" colspan="3">
- <widget class="QCheckBox" name="mUseZCoordCheckBox">
- <string>Use z-Coordinate for interpolation</string>
- </property>
- </widget>
- </item>
- <item row="3" column="1">
- <widget class="QPushButton" name="mAddPushButton">
- <string>Add</string>
- </property>
- </widget>
- </item>
- <item row="3" column="2">
- <widget class="QPushButton" name="mRemovePushButton">
- <string>Remove</string>
- </property>
- </widget>
- </item>
- <item row="4" column="0" colspan="3">
- <widget class="QTreeWidget" name="mLayersTreeWidget">
- <column>
- <string>Vector layer</string>
- </property>
- </column>
- <column>
- <string>Attribute</string>
- </property>
- </column>
- <column>
- <string>Type</string>
- </property>
- </column>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
</layout>
</widget>
<tabstops>
+ <tabstop>mInputLayerComboBox</tabstop>
+ <tabstop>mInterpolationAttributeComboBox</tabstop>
+ <tabstop>mUseZCoordCheckBox</tabstop>
+ <tabstop>mAddPushButton</tabstop>
+ <tabstop>mRemovePushButton</tabstop>
+ <tabstop>mLayersTreeWidget</tabstop>
<tabstop>mInterpolationMethodComboBox</tabstop>
<tabstop>mConfigureInterpolationButton</tabstop>
<tabstop>mNumberOfColumnsSpinBox</tabstop>
<tabstop>mNumberOfRowsSpinBox</tabstop>
+ <tabstop>mCellsizeXSpinBox</tabstop>
+ <tabstop>mCellSizeYSpinBox</tabstop>
+ <tabstop>mXMinLineEdit</tabstop>
+ <tabstop>mXMaxLineEdit</tabstop>
+ <tabstop>mYMinLineEdit</tabstop>
+ <tabstop>mYMaxLineEdit</tabstop>
+ <tabstop>mBBoxToCurrentExtent</tabstop>
<tabstop>mOutputFileLineEdit</tabstop>
<tabstop>mOutputFileButton</tabstop>
<tabstop>buttonBox</tabstop>
@@ -347,8 +381,8 @@
<slot>accept()</slot>
<hints>
<hint type="sourcelabel">
- <x>257</x>
- <y>362</y>
+ <x>266</x>
+ <y>723</y>
</hint>
<hint type="destinationlabel">
<x>157</x>
@@ -363,8 +397,8 @@
<slot>reject()</slot>
<hints>
- <x>325</x>
- <y>362</y>
+ <x>334</x>
+ <y>723</y>
</hint>
<x>286</x>
