[QGIS Commit] r11931 - in trunk/qgis/src/analysis: . vector
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 6 06:23:18 EST 2009
Author: mhugent
Date: 2009-11-06 06:23:17 -0500 (Fri, 06 Nov 2009)
New Revision: 11931
Added:
   trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
   trunk/qgis/src/analysis/vector/qgszonalstatistics.h
   trunk/qgis/src/analysis/CMakeLists.txt
Added zonal statistics class to analysis lib
Modified: trunk/qgis/src/analysis/CMakeLists.txt
--- trunk/qgis/src/analysis/CMakeLists.txt	2009-11-06 10:55:35 UTC (rev 11930)
+++ trunk/qgis/src/analysis/CMakeLists.txt	2009-11-06 11:23:17 UTC (rev 11931)
@@ -25,6 +25,7 @@
   raster/qgsaspectfilter.cpp
   raster/qgstotalcurvaturefilter.cpp
   vector/qgsgeometryanalyzer.cpp
+  vector/qgszonalstatistics.cpp
 SET(QGIS_ANALYSIS_MOC_HDRS
@@ -93,7 +94,7 @@
 # Added by Tim to install headers
-SET(QGIS_ANALYSIS_HDRS vector/qgsgeometryanalyzer.h
+SET(QGIS_ANALYSIS_HDRS vector/qgsgeometryanalyzer.h vector/qgszonalstatistics.h
 INSTALL(CODE "MESSAGE(\"Installing ANALYSIS headers...\")")
Added: trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp	                        (rev 0)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp	2009-11-06 11:23:17 UTC (rev 11931)
@@ -0,0 +1,252 @@
+                          qgszonalstatistics.cpp  -  description
+    begin                : August 29th, 2009
+    copyright            : (C) 2009 by Marco Hugentobler
+    email                : marco at hugis dot net
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+#include "qgszonalstatistics.h"
+#include "qgsgeometry.h"
+#include "qgsvectordataprovider.h"
+#include "qgsvectorlayer.h"
+#include "gdal.h"
+#include "cpl_string.h"
+#include <QProgressDialog>
+QgsZonalStatistics::QgsZonalStatistics(QgsVectorLayer* polygonLayer, const QString& rasterFile, const QString& attributePrefix, int rasterBand): \
+    mRasterFilePath(rasterFile), mRasterBand(rasterBand), mPolygonLayer(polygonLayer), mAttributePrefix(attributePrefix), mInputNodataValue( -1 )
+QgsZonalStatistics::QgsZonalStatistics(): mRasterBand(0), mPolygonLayer(0)
+QgsZonalStatistics::~QgsZonalStatistics()
+int QgsZonalStatistics::calculateStatistics(QProgressDialog* p)
+  if(!mPolygonLayer || !mPolygonLayer->geometryType() == QGis::Polygon)
+    return 1;
+  QgsVectorDataProvider* vectorProvider = mPolygonLayer->dataProvider();
+  if(!vectorProvider)
+    return 2;
+  //open the raster layer and the raster band
+  GDALAllRegister();
+  GDALDatasetH inputDataset = GDALOpen(mRasterFilePath.toLocal8Bit().data(), GA_ReadOnly );
+  if ( inputDataset == NULL )
+    return 3;
+  if ( GDALGetRasterCount( inputDataset ) < (mRasterBand - 1) )
+      GDALClose( inputDataset );
+      return 4;
+  GDALRasterBandH rasterBand = GDALGetRasterBand( inputDataset, mRasterBand );
+  if ( rasterBand == NULL )
+    return 5;
+  mInputNodataValue = GDALGetRasterNoDataValue( rasterBand, NULL );
+  //get geometry info about raster layer
+  int nCellsX = GDALGetRasterXSize( inputDataset );
+  int nCellsY = GDALGetRasterYSize( inputDataset );
+  double geoTransform[6];
+  if ( GDALGetGeoTransform( inputDataset, geoTransform ) != CE_None )
+    return 6;
+  double cellsizeX = geoTransform[1];
+  if(cellsizeX < 0)
+    cellsizeX = -cellsizeX;
+  double cellsizeY = geoTransform[5];
+  if(cellsizeY < 0)
+    cellsizeY = -cellsizeY;
+  QgsRectangle rasterBBox(geoTransform[0], geoTransform[3] - (nCellsY * cellsizeY), geoTransform[0] + (nCellsX * cellsizeX), geoTransform[3]);
+  //add the new count, sum, mean fields to the provider
+  QList<QgsField> newFieldList;
+  QgsField countField(mAttributePrefix + "count", QVariant::Int);
+  QgsField sumField(mAttributePrefix + "sum", QVariant::Double);
+  QgsField meanField(mAttributePrefix + "mean", QVariant::Double);
+  newFieldList.push_back(countField);
+  newFieldList.push_back(sumField);
+  newFieldList.push_back(meanField);
+  if(!vectorProvider->addAttributes( newFieldList ))
+    return 7;
+  //index of the new fields
+  int countIndex = vectorProvider->fieldNameIndex(mAttributePrefix + "count");
+  int sumIndex = vectorProvider->fieldNameIndex(mAttributePrefix + "sum");
+  int meanIndex = vectorProvider->fieldNameIndex(mAttributePrefix + "mean");
+  if (countIndex == -1 || sumIndex == -1 || meanIndex == -1)
+    return 8;
+  //progress dialog
+  long featureCount = vectorProvider->featureCount();
+  if(p)
+    p->setMaximum(featureCount);
+  //iterate over each polygon
+  vectorProvider->select(QgsAttributeList(), QgsRectangle(), true, false);
+  vectorProvider->rewind();
+  QgsFeature f;
+  double count = 0;
+  double sum = 0;
+  double mean = 0;
+  float* scanLine;
+  int featureCounter = 0;
+  //x- and y- coordinate of current cell
+  double cellCenterX = 0;
+  double cellCenterY = 0;
+  QgsPoint currentCellCenter;
+  while(vectorProvider->nextFeature(f))
+    if(p)
+      p->setValue(featureCounter);
+    if(p && p->wasCanceled())
+      break;
+    QgsGeometry* featureGeometry = f.geometry();
+    if(!featureGeometry)
+      ++featureCounter;
+      continue;
+    int offsetX, offsetY, nCellsX, nCellsY;
+    if(cellInfoForBBox(rasterBBox, featureGeometry->boundingBox(), cellsizeX, cellsizeY, offsetX, offsetY, nCellsX, nCellsY) != 0)
+      ++featureCounter;
+      continue;
+    scanLine = ( float * ) CPLMalloc( sizeof( float ) * nCellsX );
+    cellCenterY = rasterBBox.yMaximum() - offsetY * cellsizeY - cellsizeY / 2;
+    count = 0;
+    sum = 0;
+    float currentValue;
+    for(int i = 0; i < nCellsY; ++i)
+      GDALRasterIO( rasterBand, GF_Read, offsetX, offsetY + i, nCellsX, 1, scanLine, nCellsX, 1, GDT_Float32, 0, 0 );
+      cellCenterX = rasterBBox.xMinimum() + offsetX * cellsizeX + cellsizeX / 2;
+      for(int j = 0; j < nCellsX; ++j)
+        currentCellCenter = QgsPoint(cellCenterX, cellCenterY);
+        if(featureGeometry->contains(&currentCellCenter))
+          if(scanLine[j] != mInputNodataValue) //don't consider nodata values
+            sum += scanLine[j];
+            ++count;
+        cellCenterX += cellsizeX;
+      cellCenterY -= cellsizeY;
+    if(count == 0)
+      mean = 0;
+    else
+      mean = sum / count;
+    //write the new AEY value to the vector data provider
+    QgsChangedAttributesMap changeMap;
+    QgsAttributeMap changeAttributeMap;
+    changeAttributeMap.insert(countIndex, QVariant(count));
+    changeAttributeMap.insert(sumIndex, QVariant(sum));
+    changeAttributeMap.insert(meanIndex, QVariant(mean));
+    changeMap.insert(f.id(), changeAttributeMap);
+    vectorProvider->changeAttributeValues(changeMap);
+    CPLFree(scanLine);
+    ++featureCounter;
+  if(p)
+    p->setValue(featureCount);
+  return 0;
+int QgsZonalStatistics::cellInfoForBBox(const QgsRectangle& rasterBBox, const QgsRectangle& featureBBox, double cellSizeX, double cellSizeY, \
+                                        int& offsetX, int& offsetY, int& nCellsX, int& nCellsY) const
+  //get intersecting bbox
+  QgsRectangle intersectBox = rasterBBox.intersect(&featureBBox);
+  if(intersectBox.isEmpty())
+    nCellsX = 0; nCellsY = 0; offsetX = 0; offsetY = 0;
+    return 0;
+  //get offset in pixels in x- and y- direction
+  offsetX = (int)( (intersectBox.xMinimum() - rasterBBox.xMinimum()) / cellSizeX);
+  offsetY = (int)( (rasterBBox.yMaximum() - intersectBox.yMaximum()) / cellSizeY);
+  int maxColumn = (int) ( (intersectBox.xMaximum() - rasterBBox.xMinimum()) / cellSizeX) + 1;
+  int maxRow = (int) ( (rasterBBox.yMaximum() - intersectBox.yMinimum()) / cellSizeY ) + 1;
+  nCellsX = maxColumn - offsetX;
+  nCellsY = maxRow - offsetY;
+  return 0;
Added: trunk/qgis/src/analysis/vector/qgszonalstatistics.h
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.h	                        (rev 0)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.h	2009-11-06 11:23:17 UTC (rev 11931)
@@ -0,0 +1,54 @@
+                          qgszonalstatistics.h  -  description
+#ifndef QGSZONALSTATISTICS_H
+#define QGSZONALSTATISTICS_H
+#include "qgsrectangle.h"
+#include <QString>
+class QgsVectorLayer;
+class QProgressDialog;
+/**A class that calculates raster statistics (count, sum, mean) for a polygon or multipolygon layer and appends the results as attributes*/
+class ANALYSIS_EXPORT QgsZonalStatistics
+  public:
+    QgsZonalStatistics(QgsVectorLayer* polygonLayer, const QString& rasterFile, const QString& attributePrefix = "", int rasterBand = 1);
+    ~QgsZonalStatistics();
+    /**Starts the calculation
+      @return 0 in case of success*/
+    int calculateStatistics(QProgressDialog* p);
+  private:
+    QgsZonalStatistics();
+    /**Analysis what cells need to be considered to cover the bounding box of a feature
+    int cellInfoForBBox(const QgsRectangle& rasterBBox, const QgsRectangle& featureBBox, double cellSizeX, double cellSizeY, \
+                        int& offsetX, int& offsetY, int& nCellsX, int& nCellsY) const;
+    QString mRasterFilePath;
+    /**Raster band to calculate statistics from (defaults to 1)*/
+    int mRasterBand;
+    QgsVectorLayer* mPolygonLayer;
+    QString mAttributePrefix;
+    /**The nodata value of the input layer*/
+    float mInputNodataValue;
+#endif // QGSZONALSTATISTICS_H
More information about the QGIS-commit mailing list
