[QGIS Commit] r11934 - in branches/symbology-ng-branch: python/core src/app/legend src/core/symbology-ng
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 6 08:04:20 EST 2009
Author: wonder
Date: 2009-11-06 08:04:20 -0500 (Fri, 06 Nov 2009)
New Revision: 11934
   branches/symbology-ng-branch/python/core/symbology-ng-core.sip
   branches/symbology-ng-branch/src/app/legend/qgslegendlayer.cpp
   branches/symbology-ng-branch/src/app/legend/qgslegendlayer.h
   branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.cpp
   branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.h
   branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
   branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h
   branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.cpp
   branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.h
   branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp
   branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.h
   branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp
   branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h
generic solution for legend symbology items
Modified: branches/symbology-ng-branch/python/core/symbology-ng-core.sip
--- branches/symbology-ng-branch/python/core/symbology-ng-core.sip	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/python/core/symbology-ng-core.sip	2009-11-06 13:04:20 UTC (rev 11934)
@@ -1,6 +1,8 @@
 typedef QList<QgsSymbolV2*> QgsSymbolV2List;
+typedef QList< QPair<QString, QPixmap> > QgsLegendSymbologyList;
@@ -60,6 +62,15 @@
   bool usingSymbolLevels() const;
   void setUsingSymbolLevels(bool usingSymbolLevels);
+  //! create a renderer from XML element
+  static QgsFeatureRendererV2* load(QDomElement& symbologyElem);
+  //! store renderer info to XML element
+  virtual QDomElement save(QDomDocument& doc);
+  //! return a list of symbology items for the legend
+  virtual QgsLegendSymbologyList legendSymbologyItems(QSize iconSize);
 protected:
   QgsFeatureRendererV2(QString type);
@@ -93,6 +104,16 @@
   virtual QString dump();
   virtual QgsFeatureRendererV2* clone() /Factory/;
+  static QgsFeatureRendererV2* load(QDomElement& symbologyElem) /Factory/;
@@ -159,9 +180,24 @@
   bool deleteCategory(int catIndex);
   void deleteAllCategories();
   QString classAttribute() const;
   void setClassAttribute(QString attr);
+  QgsSymbolV2* sourceSymbol();
+  void setSourceSymbol(QgsSymbolV2* sym /Transfer/);
+  QgsVectorColorRampV2* sourceColorRamp();
+  void setSourceColorRamp(QgsVectorColorRampV2* ramp /Transfer/);
 protected:
   QgsSymbolV2* symbolForValue(QVariant value);
@@ -244,6 +280,21 @@
                   QgsSymbolV2* symbol,
                   QgsVectorColorRampV2* ramp);
 protected:
   QgsSymbolV2* symbolForValue(double value);
Modified: branches/symbology-ng-branch/src/app/legend/qgslegendlayer.cpp
--- branches/symbology-ng-branch/src/app/legend/qgslegendlayer.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/app/legend/qgslegendlayer.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -369,7 +369,7 @@
     QPixmap pix = QPixmap::fromImage( img ); // convert to pixmap
-    itemList.push_back( std::make_pair( values, pix ) );
+    itemList.append( qMakePair( values, pix ) );
@@ -388,7 +388,7 @@
           classfieldname = fields[*it].name();
-        itemList.push_front( std::make_pair( classfieldname, QPixmap() ) );
+        itemList.append( qMakePair( classfieldname, QPixmap() ) );
@@ -396,73 +396,16 @@
   changeSymbologySettings( layer, itemList );
-static QPixmap _symbolPreviewPixmap(QgsSymbolV2* sym, QSize iconSize)
-  QPainter p;
-  QPixmap pix(iconSize);
-  pix.fill(Qt::white);
-  p.begin(&pix);
-  p.setRenderHint(QPainter::Antialiasing);
-  sym->drawPreviewIcon(&p, iconSize);
-  p.end();
-  return pix;
 void QgsLegendLayer::vectorLayerSymbologyV2( QgsVectorLayer* layer )
-  SymbologyList itemList;
   QSize iconSize(16,16);
   QSettings settings;
   bool showClassifiers = settings.value( "/qgis/showLegendClassifiers", false ).toBool();
-  QgsFeatureRendererV2* renderer = layer->rendererV2();
-  QString rendererType = renderer->type();
-  if (rendererType == "singleSymbol")
-   QgsSingleSymbolRendererV2* r = static_cast<QgsSingleSymbolRendererV2*>(renderer);
-    QPixmap pix = _symbolPreviewPixmap(r->symbol(), iconSize);
+  SymbologyList itemList = layer->rendererV2()->legendSymbologyItems(iconSize);
-    itemList.push_back( std::make_pair( "", pix ) );
-  else if (rendererType == "categorizedSymbol")
-    QgsCategorizedSymbolRendererV2* r = static_cast<QgsCategorizedSymbolRendererV2*>(renderer);
-    if (showClassifiers)
-      itemList.push_back( std::make_pair( r->classAttribute(), QPixmap() ) );
-    int count = r->categories().count();
-    for (int i = 0; i < count; i++)
-      const QgsRendererCategoryV2& cat = r->categories()[i];
-      QPixmap pix = _symbolPreviewPixmap( cat.symbol(), iconSize );
-      itemList.push_back( std::make_pair( cat.label(), pix ) );
-  else if (rendererType == "graduatedSymbol")
-    QgsGraduatedSymbolRendererV2* r = static_cast<QgsGraduatedSymbolRendererV2*>(renderer);
-    int count = r->ranges().count();
-      const QgsRendererRangeV2& range = r->ranges()[i];
-      QPixmap pix = _symbolPreviewPixmap( range.symbol(), iconSize );
-      itemList.push_back( std::make_pair( range.label(), pix ) );
-  else
-    // nothing for unknown renderers
@@ -470,7 +413,7 @@
   QPixmap legendpixmap = layer->legendAsPixmap( true ).scaled( 20, 20, Qt::KeepAspectRatio );
-  itemList.push_back( std::make_pair( "", legendpixmap ) );
+  itemList.append( qMakePair( QString(), legendpixmap ) );
Modified: branches/symbology-ng-branch/src/app/legend/qgslegendlayer.h
--- branches/symbology-ng-branch/src/app/legend/qgslegendlayer.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/app/legend/qgslegendlayer.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -33,7 +33,7 @@
 class QTreeWidget;
-typedef std::list< std::pair<QString, QPixmap> > SymbologyList;
+typedef QList< QPair<QString, QPixmap> > SymbologyList;
 Container for layer, including layer file(s), symbology class breaks and properties
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -10,6 +10,7 @@
 #include <QDomDocument>
 #include <QDomElement>
+#include <QSettings> // for legend
 QgsRendererCategoryV2::QgsRendererCategoryV2(QVariant value, QgsSymbolV2* symbol, QString label)
   : mValue(value), mSymbol(symbol), mLabel(label)
@@ -335,6 +336,28 @@
   return rendererElem;
+QgsLegendSymbologyList QgsCategorizedSymbolRendererV2::legendSymbologyItems(QSize iconSize)
+  QSettings settings;
+  bool showClassifiers = settings.value( "/qgis/showLegendClassifiers", false ).toBool();
+  QgsLegendSymbologyList lst;
+  if (showClassifiers)
+    lst << qMakePair( classAttribute(), QPixmap() );
+  int count = categories().count();
+  for (int i = 0; i < count; i++)
+    const QgsRendererCategoryV2& cat = categories()[i];
+    QPixmap pix = QgsSymbolLayerV2Utils::symbolPreviewPixmap( cat.symbol(), iconSize );
+    lst << qMakePair( cat.label(), pix );
+  return lst;
 QgsSymbolV2* QgsCategorizedSymbolRendererV2::sourceSymbol()
   return mSourceSymbol;
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgscategorizedsymbolrendererv2.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -79,6 +79,9 @@
   void setSourceSymbol(QgsSymbolV2* sym);
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -10,6 +10,7 @@
 QgsRendererRangeV2::QgsRendererRangeV2(double lowerValue, double upperValue, QgsSymbolV2* symbol, QString label)
   : mLowerValue(lowerValue), mUpperValue(upperValue), mSymbol(symbol), mLabel(label)
@@ -432,6 +433,27 @@
+QgsLegendSymbologyList QgsGraduatedSymbolRendererV2::legendSymbologyItems(QSize iconSize)
+  int count = ranges().count();
+    const QgsRendererRangeV2& range = ranges()[i];
+    QPixmap pix = QgsSymbolLayerV2Utils::symbolPreviewPixmap( range.symbol(), iconSize );
+    lst << qMakePair( range.label(), pix );
+  return lst;
 QgsSymbolV2* QgsGraduatedSymbolRendererV2::sourceSymbol()
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsgraduatedsymbolrendererv2.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -87,6 +87,9 @@
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -281,6 +281,13 @@
   return doc.createElement(RENDERER_TAG_NAME);
+QgsLegendSymbologyList QgsFeatureRendererV2::legendSymbologyItems(QSize iconSize)
+  // empty list by default
+  return QgsLegendSymbologyList();
 int QgsFeatureRendererV2::fieldNameIndex( const QgsFieldMap& fields, const QString& fieldName )
   for ( QgsFieldMap::const_iterator it = fields.constBegin(); it != fields.constEnd(); ++it )
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsrendererv2.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -8,6 +8,8 @@
 #include <QList>
 #include <QString>
 #include <QVariant>
+#include <QPair>
+#include <QPixmap>
 class QDomDocument;
 class QDomElement;
@@ -19,6 +21,8 @@
 typedef QMap<QString, QgsSymbolV2* > QgsSymbolV2Map;
 #define RENDERER_TAG_NAME   "renderer-v2"
@@ -84,6 +88,9 @@
   /** Returns the index of a field name or -1 if the field does not exist
     * copied from QgsVectorDataProvider... d'oh... probably should be elsewhere
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -100,3 +100,12 @@
+QgsLegendSymbologyList QgsSingleSymbolRendererV2::legendSymbologyItems(QSize iconSize)
+  QPixmap pix = QgsSymbolLayerV2Utils::symbolPreviewPixmap(mSymbol, iconSize);
+  lst << qMakePair( QString(), pix );
+  return lst;
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssinglesymbolrendererv2.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -34,6 +34,9 @@
 protected:
   QgsSymbolV2* mSymbol;
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp	2009-11-06 13:04:20 UTC (rev 11934)
@@ -146,6 +146,11 @@
 QIcon QgsSymbolLayerV2Utils::symbolPreviewIcon(QgsSymbolV2* symbol, QSize size)
+  return QIcon(symbolPreviewPixmap(symbol, size));
+QPixmap QgsSymbolLayerV2Utils::symbolPreviewPixmap(QgsSymbolV2* symbol, QSize size)
   QPixmap pixmap(size);
   QPainter painter;
   painter.begin(&pixmap);
@@ -153,9 +158,10 @@
   painter.eraseRect(QRect(QPoint(0,0),size));
   symbol->drawPreviewIcon(&painter, size);
   painter.end();
-  return QIcon(pixmap);
+  return pixmap;
 QIcon QgsSymbolLayerV2Utils::symbolLayerPreviewIcon(QgsSymbolLayerV2* layer, QSize size)
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h	2009-11-06 11:50:01 UTC (rev 11933)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h	2009-11-06 13:04:20 UTC (rev 11934)
@@ -47,6 +47,7 @@
   static QIcon symbolLayerPreviewIcon(QgsSymbolLayerV2* layer, QSize size);
   static QIcon colorRampPreviewIcon(QgsVectorColorRampV2* ramp, QSize size);
+  static QPixmap symbolPreviewPixmap(QgsSymbolV2* symbol, QSize size);
   static QPixmap colorRampPreviewPixmap(QgsVectorColorRampV2* ramp, QSize size);
   static QgsSymbolV2* loadSymbol(QDomElement& element);
More information about the QGIS-commit mailing list
