[QGIS Commit] r11939 - trunk/qgis/src/plugins/coordinate_capture
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 6 10:26:20 EST 2009
Author: timlinux
Date: 2009-11-06 10:26:20 -0500 (Fri, 06 Nov 2009)
New Revision: 11939
Removed:
   trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
   trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt
Removed redundant ui file
Modified: trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt
--- trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt	2009-11-06 14:51:56 UTC (rev 11938)
+++ trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt	2009-11-06 15:26:20 UTC (rev 11939)
@@ -8,8 +8,6 @@
      coordinatecapturemaptool.cpp
-SET (coordinatecapture_UIS coordinatecaptureguibase.ui)
 SET (coordinatecapture_MOC_HDRS
      coordinatecapture.h
      coordinatecapturegui.h
@@ -21,8 +19,6 @@
 # Build
-QT4_WRAP_UI (coordinatecapture_UIS_H  ${coordinatecapture_UIS})
 QT4_WRAP_CPP (coordinatecapture_MOC_SRCS  ${coordinatecapture_MOC_HDRS})
 QT4_ADD_RESOURCES(coordinatecapture_RCC_SRCS ${coordinatecapture_RCCS})
Deleted: trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
--- trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui	2009-11-06 14:51:56 UTC (rev 11938)
+++ trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui	2009-11-06 15:26:20 UTC (rev 11939)
@@ -1,78 +0,0 @@
-<ui version="4.0" >
- <class>CoordinateCaptureGuiBase</class>
- <widget class="QDialog" name="CoordinateCaptureGuiBase" >
-  <property name="geometry" >
-   <rect>
-    <x>0</x>
-    <y>0</y>
-    <width>584</width>
-    <height>435</height>
-   </rect>
-  </property>
-  <property name="windowTitle" >
-   <string>QGIS Plugin Template</string>
-  </property>
-  <property name="windowIcon" >
-   <iconset>
-    <normaloff/>
-   </iconset>
-  </property>
-  <layout class="QGridLayout" >
-   <property name="margin" >
-    <number>9</number>
-   </property>
-   <property name="spacing" >
-    <number>6</number>
-   </property>
-   <item row="0" column="0" >
-    <widget class="QLabel" name="txtHeading" >
-     <property name="sizePolicy" >
-      <sizepolicy>
-       <hsizetype>5</hsizetype>
-       <vsizetype>1</vsizetype>
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-     <property name="font" >
-      <font>
-       <family>Sans Serif</family>
-       <pointsize>24</pointsize>
-       <weight>75</weight>
-       <italic>false</italic>
-       <bold>true</bold>
-       <underline>false</underline>
-       <strikeout>false</strikeout>
-      </font>
-     </property>
-     <property name="text" >
-      <string>Plugin Template</string>
-     </property>
-     <property name="alignment" >
-      <set>Qt::AlignCenter</set>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="0" >
-    <widget class="QTextBrowser" name="textBrowser" >
-     <property name="openExternalLinks" >
-      <bool>true</bool>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="0" >
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="orientation" >
-      <enum>Qt::Horizontal</enum>
-     </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok|QDialogButtonBox::SaveAll</set>
-     </property>
-    </widget>
-   </item>
-  </layout>
- </widget>
- <layoutdefault spacing="6" margin="11" />
- <resources/>
- <connections/>
-</ui>
More information about the QGIS-commit mailing list
