[QGIS Commit] r11954 - in docs/trunk/english_us/user_guide: .
material_wonder
svn_qgis at osgeo.org
Sat Nov 7 10:10:58 EST 2009
Author: dassau
Date: 2009-11-07 10:10:57 -0500 (Sat, 07 Nov 2009)
New Revision: 11954
docs/trunk/english_us/user_guide/material_wonder/user.odt
docs/trunk/english_us/user_guide/working_with_vector.tex
extended manual for map tools (node and redo/undo tool)
Modified: docs/trunk/english_us/user_guide/material_wonder/user.odt
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2009-11-07 14:08:14 UTC (rev 11953)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2009-11-07 15:10:57 UTC (rev 11954)
@@ -1400,9 +1400,23 @@
\index{vector layers!redo}
The \toolbtntwo{mActionUndo}{Undo} and \toolbtntwo{mActionRedo}{Redo} tools
-allow the user to undo or redo the last or a certain step within the
-digitizing process.
+allow the user to undo or redo the last or a certain step within the vector editing
+operations. Basic view of Undo/Redo operations is a widget, where all operations
+are shown (see Figure~\ref{fig:vector_redoundo}). This widget is not displayed by
+default. Widget can be displayed by right clicking on toolbar and activating the
+Undo/Redo check box. Undo/Redo is however active, even if the widget is not
+displayed.
+When Undo is hit, the state of all features and attributes are reverted to the
+state before the reverted operation happened. Changes which are done elsewhere
+(for example from some plugin), can show unspecific behavior for some operations
+which appears in this box. The operations can be reverted or they stay the same.
+An action can be triggered by clicking on Undo or Redo buttons or by clicking
+directly on the item to which you want to return to. Another possibility to
+trigger an undo operation is to click on the \button{undo/redo} buttons in
+the advanced digitizing tool bar.
\begin{figure}[ht]
\begin{center}
\caption{Redo and Undo digitizing steps \nixcaption}\label{fig:vector_redoundo}\smallskip
@@ -1461,11 +1475,46 @@
\index{vector layers!node!tool}
The \toolbtntwo{mActionNodeTool}{Node Tool} provides manipulation capabilites
-of feature vertices similar to CAD programs. It is possible to select
-multiple vertices at once and to move or delete them alltogether. The node
+of feature vertices similar to CAD programs. It is possible to simply select
+multiple vertices at once and to move, add or delete them alltogether. The node
tool also works with 'on the fly' projection turned on and supports
-the topological editing feature.
+the topological editing feature. This tool is, unlike other tools in Quantum GIS,
+persistent, so when some operation is done, selection stays active for this
+feature and tool.
+\minisec{Basic operations}\index{vector layers!Node Tool}
+Start by activating the \toolbtntwo{mActionNodeTool}{Node Tool} and selecting
+some features by clicking on it. Red boxes appear at each vertex of this feature.
+This is basic select of the feature. Functionalities are:
+\begin{itemize}
+\item \textbf{Selecting vertex}: Selecting is easy just click on vertex and
+color of this vertex will change to blue. When selecting more vertices
+\keystroke{Shift} key can be used to select more vertices. Or also the
+\keystroke{Ctrl} key can be used to invert selection of vertices (if selected then
+it will be unselected and when not selected vertex will be selected). Also more
+vertices can be selected at once when clicking somewhere outside feature and opening a rectangle where all vertices inside will be selected. Or just click on an edge and
+both adjacent vertices should be selected.
+\item \textbf{Adding vertex}: Adding vertex is simple, too. Just double click near
+some edge and a new vertex will appear on the edge near to the cursor. Note that
+vertex will appear on edge not on cursor position, there it has to be moved if
+necessary.
+\item \textbf{Deleting vertex}: After selecting vertices for deletion, click the
+\keystroke{Delete} key and vertices will be deleted. Note that according to
+standard Quantum GIS behavior, it will leave a necessary number of vertices for
+the feature type you are working on. To delete a complete feature, another tool
+has to be used.
+\item \textbf{Moving vertex}: Select all vertices you want to move. All selected
+vertices are moving in the same direction as the cursor. If snapping is enabled,
+the whole selection can jump to the nearest vertex or line.
+\end{itemize}
+The \button{Release} button stores all changes and a new entry appears in the undo
+dialog. Remember that all operations support topological editing when turned on. On
+the fly projections are also supported.
%%FIXME (not yet implemented in QGIS 1.2)
%\minisec{Reshape Tool}
