[QGIS Commit] r11964 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 7 12:09:07 EST 2009
Author: jef
Date: 2009-11-07 12:09:06 -0500 (Sat, 07 Nov 2009)
New Revision: 11964
   trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2009-11-07 17:03:50 UTC (rev 11963)
+++ trunk/qgis/i18n/qgis_de.ts	2009-11-07 17:09:06 UTC (rev 11964)
@@ -68,12 +68,12 @@
     <message>
         <location filename="../src/plugins/coordinate_capture/coordinatecaptureguibase.ui" line="13"/>
         <source>QGIS Plugin Template</source>
-        <translation type="unfinished">QGIS-Erweiterungsvorlage</translation>
+        <translation>QGIS-Erweiterungsvorlage</translation>
     </message>
     <message>
         <location filename="../src/plugins/coordinate_capture/coordinatecaptureguibase.ui" line="49"/>
         <source>Plugin Template</source>
-        <translation type="unfinished">Erweiterungsvorlage</translation>
+        <translation>Erweiterungsvorlage</translation>
     </message>
 </context>
 <context>
@@ -2724,7 +2724,7 @@
     <message>
         <location filename="../src/python/qgspythonutilsimpl.cpp" line="89"/>
         <source>Couldn&apos;t load QGIS utils.</source>
-        <translation type="unfinished"></translation>
+        <translation>Konnte QGIS-Utils nicht öffnen</translation>
     </message>
     <message>
         <source>An error has occured while executing Python code:</source>
@@ -21111,7 +21111,7 @@
     <message>
         <location filename="../src/ui/qgssinglesymboldialogbase.ui" line="142"/>
         <source>Drawing by field</source>
+        <translation>Zeichnen nach Attribut</translation>
     </message>
     <message>
         <location filename="../src/ui/qgssinglesymboldialogbase.ui" line="148"/>
@@ -22019,13 +22019,13 @@
     <message>
         <location filename="../src/plugins/interpolation/qgstininterpolatordialog.cpp" line="33"/>
         <source>Linear</source>
-        <translation type="unfinished">Linear</translation>
+        <translation>Linear</translation>
     </message>
     <message>
         <location filename="../src/plugins/interpolation/qgstininterpolatordialog.cpp" line="34"/>
         <location filename="../src/plugins/interpolation/qgstininterpolatordialog.cpp" line="46"/>
         <source>Clough-Toucher (cubic)</source>
+        <translation>Clough-Toucher (kubisch)</translation>
     </message>
     <message>
         <location filename="../src/plugins/interpolation/qgstininterpolatordialog.cpp" line="86"/>
@@ -23869,7 +23869,7 @@
     <message>
         <location filename="../src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui" line="37"/>
         <source>Input and output</source>
+        <translation>Ein- und Ausgabe</translation>
     </message>
     <message>
         <location filename="../src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui" line="43"/>
@@ -23885,7 +23885,7 @@
     <message>
         <location filename="../src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui" line="63"/>
         <source>Output file</source>
+        <translation type="unfinished">Ausgabedatei</translation>
     </message>
     <message>
         <source>&lt;html&gt;&lt;head&gt;&lt;meta name=&quot;qrichtext&quot; content=&quot;1&quot; /&gt;&lt;style type=&quot;text/css&quot;&gt;
@@ -24865,7 +24865,7 @@
     </message>
     <message>
         <source>&amp;Vector</source>
+        <translation>&amp;Vektor</translation>
     </message>
     <message>
         <source>fTools Information</source>
More information about the QGIS-commit mailing list
