[QGIS Commit] r11993 - in trunk/qgis/src: app/composer ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 7 18:41:52 EST 2009
Author: timlinux
Date: 2009-11-07 18:41:52 -0500 (Sat, 07 Nov 2009)
New Revision: 11993
   trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
   trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
   trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
ui cleanups for composer (vertical orientation for props pages)
Modified: trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2009-11-07 23:33:41 UTC (rev 11992)
+++ trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2009-11-07 23:41:52 UTC (rev 11993)
@@ -28,7 +28,7 @@
   //add widget for general composer item properties
   QgsComposerItemWidget* itemPropertiesWidget = new QgsComposerItemWidget( this, scaleBar );
-  gridLayout->addWidget( itemPropertiesWidget, 14, 0, 1, 5 );
+  gridLayout->addWidget( itemPropertiesWidget );
   blockMemberSignals( true );
   mStyleComboBox->insertItem( 0, tr( "Single Box" ) );
Modified: trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui	2009-11-07 23:33:41 UTC (rev 11992)
+++ trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui	2009-11-07 23:41:52 UTC (rev 11993)
@@ -6,12 +6,12 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>299</width>
-    <height>613</height>
+    <width>347</width>
+    <height>540</height>
    </rect>
   </property>
   <property name="sizePolicy">
-   <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+   <sizepolicy hsizetype="Minimum" vsizetype="Expanding">
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
@@ -19,217 +19,252 @@
   <property name="windowTitle">
    <string>Picture Options</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout">
-   <item row="0" column="0" colspan="2">
-    <widget class="QGroupBox" name="mSearchDirectoriesGroupBox">
-     <property name="sizePolicy">
-      <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-     <property name="title">
-      <string>Search directories</string>
-     </property>
-     <layout class="QGridLayout">
-      <item row="0" column="0" colspan="3">
-       <widget class="QComboBox" name="mSearchDirectoriesComboBox">
-         <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="0">
-       <spacer>
-        <property name="orientation">
-         <enum>Qt::Horizontal</enum>
-        </property>
-        <property name="sizeHint" stdset="0">
-         <size>
-          <width>101</width>
-          <height>20</height>
-         </size>
-        </property>
-       </spacer>
-      </item>
-      <item row="1" column="1">
-       <widget class="QPushButton" name="mAddDirectoryButton">
-        <property name="text">
-         <string>Add...</string>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="2">
-       <widget class="QPushButton" name="mRemoveDirectoryButton">
-         <string>Remove</string>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
-   <item row="1" column="0" colspan="2">
-    <widget class="QGroupBox" name="mPreviewGroupBox">
-      </sizepolicy>
-     </property>
-      <string>Preview</string>
-     </property>
-      <item row="0" column="0">
-       <widget class="QListWidget" name="mPreviewListWidget">
-        <property name="showDropIndicator" stdset="0">
-         <bool>false</bool>
-        </property>
-        <property name="dragDropMode">
-         <enum>QAbstractItemView::DragDrop</enum>
-        </property>
-        <property name="movement">
-         <enum>QListView::Free</enum>
-        </property>
-        <property name="flow">
-         <enum>QListView::LeftToRight</enum>
-        </property>
-        <property name="isWrapping" stdset="0">
-         <bool>true</bool>
-        </property>
-        <property name="gridSize">
-         <size>
-          <width>30</width>
-          <height>30</height>
-         </size>
-        </property>
-        <property name="viewMode">
-         <enum>QListView::IconMode</enum>
-        </property>
-        <property name="wordWrap">
-         <bool>true</bool>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
-   <item row="2" column="0" colspan="2">
-    <layout class="QHBoxLayout" name="horizontalLayout">
-     <item>
-      <widget class="QLabel" name="label">
-        <string>Load</string>
-       </property>
-       <property name="buddy">
-        <cstring>mPictureLineEdit</cstring>
-       </property>
-      </widget>
-     </item>
-     <item>
-      <widget class="QLineEdit" name="mPictureLineEdit"/>
-     </item>
-     <item>
-      <widget class="QPushButton" name="mPictureBrowseButton">
-        </sizepolicy>
-       </property>
-       <property name="maximumSize">
-        <size>
-         <width>150</width>
-         <height>32767</height>
-        </size>
-       </property>
-        <string>...</string>
-       </property>
-      </widget>
-     </item>
-    </layout>
-   </item>
-   <item row="3" column="0">
-    <widget class="QLabel" name="textLabel3">
-      <sizepolicy hsizetype="Minimum" vsizetype="Preferred">
-      </sizepolicy>
-     </property>
-      <string>Width</string>
-     </property>
+  <layout class="QGridLayout" name="gridLayout_3">
+   <property name="margin">
+    <number>0</number>
+   </property>
+   <item row="0" column="0">
+    <widget class="QScrollArea" name="scrollArea">
+     <property name="widgetResizable">
       <bool>true</bool>
      </property>
-      <cstring>mWidthLineEdit</cstring>
-     </property>
+     <widget class="QWidget" name="scrollAreaWidgetContents">
+      <property name="geometry">
+       <rect>
+        <x>0</x>
+        <y>0</y>
+        <width>324</width>
+        <height>679</height>
+       </rect>
+      </property>
+      <layout class="QGridLayout" name="gridLayout_2">
+        <widget class="QGroupBox" name="mSearchDirectoriesGroupBox">
+         <property name="sizePolicy">
+          <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+           <horstretch>0</horstretch>
+           <verstretch>0</verstretch>
+          </sizepolicy>
+         </property>
+         <property name="title">
+          <string>Search directories</string>
+         </property>
+         <layout class="QGridLayout">
+          <item row="0" column="0" colspan="3">
+           <widget class="QComboBox" name="mSearchDirectoriesComboBox">
+             <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+             </sizepolicy>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="0">
+           <spacer>
+            <property name="orientation">
+             <enum>Qt::Horizontal</enum>
+            </property>
+            <property name="sizeHint" stdset="0">
+             <size>
+              <width>101</width>
+              <height>20</height>
+             </size>
+            </property>
+           </spacer>
+          </item>
+          <item row="1" column="1">
+           <widget class="QPushButton" name="mAddDirectoryButton">
+            <property name="text">
+             <string>Add...</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="2">
+           <widget class="QPushButton" name="mRemoveDirectoryButton">
+             <string>Remove</string>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+        <widget class="QGroupBox" name="mPreviewGroupBox">
+          <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+          </sizepolicy>
+         </property>
+          <string>Preview</string>
+         </property>
+           <widget class="QListWidget" name="mPreviewListWidget">
+            <property name="showDropIndicator" stdset="0">
+             <bool>false</bool>
+            </property>
+            <property name="dragDropMode">
+             <enum>QAbstractItemView::DragDrop</enum>
+            </property>
+            <property name="movement">
+             <enum>QListView::Free</enum>
+            </property>
+            <property name="flow">
+             <enum>QListView::LeftToRight</enum>
+            </property>
+            <property name="isWrapping" stdset="0">
+             <bool>true</bool>
+            </property>
+            <property name="gridSize">
+             <size>
+              <width>30</width>
+              <height>30</height>
+             </size>
+            </property>
+            <property name="viewMode">
+             <enum>QListView::IconMode</enum>
+            </property>
+            <property name="wordWrap">
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+       <item row="2" column="0">
+        <widget class="QGroupBox" name="groupBox">
+          <string>Options</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout">
+           <widget class="QLabel" name="label">
+             <string>Load</string>
+            </property>
+            <property name="buddy">
+             <cstring>mPictureLineEdit</cstring>
+            </property>
+           </widget>
+          </item>
+           <layout class="QHBoxLayout" name="horizontalLayout_2">
+            <item>
+             <widget class="QLineEdit" name="mPictureLineEdit"/>
+            </item>
+            <item>
+             <widget class="QPushButton" name="mPictureBrowseButton">
+               <sizepolicy hsizetype="Minimum" vsizetype="Fixed">
+               </sizepolicy>
+              </property>
+              <property name="maximumSize">
+               <size>
+                <width>150</width>
+                <height>32767</height>
+               </size>
+              </property>
+               <string>...</string>
+              </property>
+             </widget>
+            </item>
+           </layout>
+          </item>
+           <widget class="QLabel" name="textLabel3">
+             <sizepolicy hsizetype="Minimum" vsizetype="Preferred">
+             </sizepolicy>
+            </property>
+             <string>Width</string>
+            </property>
+             <bool>true</bool>
+            </property>
+             <cstring>mWidthLineEdit</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="3" column="0">
+           <widget class="QLineEdit" name="mWidthLineEdit"/>
+          </item>
+          <item row="4" column="0">
+           <widget class="QLabel" name="textLabel4">
+             </sizepolicy>
+            </property>
+             <string>Height</string>
+            </property>
+             <bool>true</bool>
+            </property>
+             <cstring>mHeightLineEdit</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="5" column="0">
+           <layout class="QHBoxLayout" name="horizontalLayout">
+            <item>
+             <widget class="QLineEdit" name="mHeightLineEdit"/>
+            </item>
+           </layout>
+          </item>
+          <item row="6" column="0">
+           <widget class="QLabel" name="mRotationLabel">
+             </sizepolicy>
+            </property>
+             <string>Rotation</string>
+            </property>
+             <bool>true</bool>
+            </property>
+             <cstring>mRotationSpinBox</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="7" column="0">
+           <widget class="QDoubleSpinBox" name="mRotationSpinBox"/>
+          </item>
+          <item row="8" column="0">
+           <widget class="QCheckBox" name="mRotationFromComposerMapCheckBox">
+             <string>Take rotation from composer map</string>
+            </property>
+           </widget>
+          </item>
+          <item row="9" column="0">
+           <widget class="QComboBox" name="mComposerMapComboBox"/>
+          </item>
+         </layout>
+        </widget>
+       </item>
+      </layout>
+     </widget>
     </widget>
    </item>
-   <item row="3" column="1">
-    <widget class="QLineEdit" name="mWidthLineEdit"/>
-   </item>
-   <item row="4" column="0">
-    <widget class="QLabel" name="textLabel4">
-      </sizepolicy>
-     </property>
-      <string>Height</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mHeightLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="1">
-    <widget class="QLineEdit" name="mHeightLineEdit"/>
-   </item>
-   <item row="5" column="0">
-    <widget class="QLabel" name="mRotationLabel">
-      </sizepolicy>
-     </property>
-      <string>Rotation</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mRotationSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="1">
-    <widget class="QDoubleSpinBox" name="mRotationSpinBox"/>
-   </item>
-   <item row="6" column="0" colspan="2">
-    <widget class="QCheckBox" name="mRotationFromComposerMapCheckBox">
-      <string>Take rotation from composer map</string>
-     </property>
-    </widget>
-   </item>
-   <item row="7" column="0" colspan="2">
-    <widget class="QComboBox" name="mComposerMapComboBox"/>
-   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
@@ -243,6 +278,9 @@
   <tabstop>mWidthLineEdit</tabstop>
   <tabstop>mHeightLineEdit</tabstop>
   <tabstop>mRotationSpinBox</tabstop>
+  <tabstop>mRotationFromComposerMapCheckBox</tabstop>
+  <tabstop>mComposerMapComboBox</tabstop>
+  <tabstop>scrollArea</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2009-11-07 23:33:41 UTC (rev 11992)
+++ trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2009-11-07 23:41:52 UTC (rev 11993)
@@ -1,252 +1,276 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsComposerScaleBarWidgetBase</class>
- <widget class="QWidget" name="QgsComposerScaleBarWidgetBase" >
-  <property name="geometry" >
+ <widget class="QWidget" name="QgsComposerScaleBarWidgetBase">
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>561</width>
-    <height>228</height>
+    <width>212</width>
+    <height>537</height>
    </rect>
   </property>
-  <property name="sizePolicy" >
-   <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
    </sizepolicy>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Barscale Options</string>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QLabel" name="mSegmentSizeLabel" >
-     <property name="text" >
-      <string>Segment size (map units)</string>
-     </property>
-     <property name="wordWrap" >
+   </property>
       <bool>true</bool>
      </property>
-     <property name="buddy" >
-      <cstring>mSegmentSizeSpinBox</cstring>
-     </property>
+       <rect>
+        <x>0</x>
+        <y>-179</y>
+        <width>189</width>
+        <height>714</height>
+       </rect>
+      </property>
+        <widget class="QLabel" name="mSegmentSizeLabel">
+          <string>Segment size (map units)</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mSegmentSizeSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+        <widget class="QDoubleSpinBox" name="mSegmentSizeSpinBox">
+         <property name="decimals">
+          <number>4</number>
+         </property>
+         <property name="maximum">
+          <double>9999999999999.000000000000000</double>
+         </property>
+        </widget>
+       </item>
+        <widget class="QLabel" name="mMapUnitsPerBarUnitLabel">
+          <string>Map units per bar unit</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mMapUnitsPerBarUnitSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+        <widget class="QDoubleSpinBox" name="mMapUnitsPerBarUnitSpinBox">
+         </property>
+        </widget>
+       </item>
+        <widget class="QLabel" name="mNumbereOfSegmentsLabel">
+          <string>Number of segments</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mNumberOfSegmentsSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+        <widget class="QSpinBox" name="mNumberOfSegmentsSpinBox"/>
+       </item>
+        <widget class="QLabel" name="mSegmentsLeftLabel">
+          <string>Segments left</string>
+         </property>
+          <cstring>mSegmentsLeftSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+        <widget class="QSpinBox" name="mSegmentsLeftSpinBox"/>
+       </item>
+        <widget class="QLabel" name="mStyleLabel">
+          <string>Style</string>
+         </property>
+          <cstring>mStyleComboBox</cstring>
+         </property>
+        </widget>
+       </item>
+        <widget class="QComboBox" name="mStyleComboBox"/>
+       </item>
+       <item row="10" column="0">
+        <widget class="QLabel" name="mMapLabel">
+          </sizepolicy>
+         </property>
+          <string>Map</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mMapComboBox</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="11" column="0">
+        <widget class="QComboBox" name="mMapComboBox">
+         <property name="enabled">
+          <bool>true</bool>
+         </property>
+          </sizepolicy>
+         </property>
+        </widget>
+       </item>
+       <item row="12" column="0">
+        <widget class="QLabel" name="mHeightLabel">
+          <string>Height (mm)</string>
+         </property>
+          <cstring>mHeightSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="13" column="0">
+        <widget class="QSpinBox" name="mHeightSpinBox"/>
+       </item>
+       <item row="14" column="0">
+        <widget class="QLabel" name="mLineWidthLabel">
+          <string>Line width</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mLineWidthSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="15" column="0">
+        <widget class="QDoubleSpinBox" name="mLineWidthSpinBox">
+          </sizepolicy>
+         </property>
+         <property name="minimum">
+          <double>0.010000000000000</double>
+         </property>
+         <property name="singleStep">
+          <double>0.100000000000000</double>
+         </property>
+         <property name="value">
+          <double>0.200000000000000</double>
+         </property>
+        </widget>
+       </item>
+       <item row="16" column="0">
+        <widget class="QLabel" name="mLabelBarSpaceLabel">
+          <string>Label space</string>
+         </property>
+          <cstring>mLabelBarSpaceSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="17" column="0">
+        <widget class="QDoubleSpinBox" name="mLabelBarSpaceSpinBox"/>
+       </item>
+       <item row="18" column="0">
+        <widget class="QLabel" name="mBoxSpaceLabel">
+          <string>Box space</string>
+         </property>
+          <cstring>mBoxSizeSpinBox</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="19" column="0">
+        <widget class="QDoubleSpinBox" name="mBoxSizeSpinBox"/>
+       </item>
+       <item row="20" column="0">
+        <widget class="QLabel" name="mUnitLabelLabel">
+          <string>Unit label</string>
+         </property>
+          <bool>true</bool>
+         </property>
+          <cstring>mUnitLabelLineEdit</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="21" column="0">
+        <widget class="QLineEdit" name="mUnitLabelLineEdit"/>
+       </item>
+       <item row="22" column="0">
+        <widget class="QPushButton" name="mFontButton">
+          </sizepolicy>
+         </property>
+          <string>Font...</string>
+         </property>
+        </widget>
+       </item>
+       <item row="23" column="0">
+        <widget class="QPushButton" name="mColorPushButton">
+          <string>Color...</string>
+         </property>
+        </widget>
+       </item>
+      </layout>
+     </widget>
     </widget>
    </item>
-   <item row="0" column="1" >
-    <widget class="QDoubleSpinBox" name="mSegmentSizeSpinBox" >
-     <property name="decimals" >
-      <number>4</number>
-     </property>
-     <property name="maximum" >
-      <double>9999999999999.000000000000000</double>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="2" colspan="2" >
-    <widget class="QLabel" name="mMapUnitsPerBarUnitLabel" >
-      <string>Map units per bar unit</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mMapUnitsPerBarUnitSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="4" >
-    <widget class="QDoubleSpinBox" name="mMapUnitsPerBarUnitSpinBox" >
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="0" >
-    <widget class="QLabel" name="mNumbereOfSegmentsLabel" >
-      <string>Number of segments</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mNumberOfSegmentsSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="1" >
-    <widget class="QSpinBox" name="mNumberOfSegmentsSpinBox" />
-   </item>
-   <item row="1" column="2" colspan="2" >
-    <widget class="QLabel" name="mSegmentsLeftLabel" >
-      <string>Segments left</string>
-     </property>
-      <cstring>mSegmentsLeftSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="4" >
-    <widget class="QSpinBox" name="mSegmentsLeftSpinBox" />
-   </item>
-   <item row="2" column="0" >
-    <widget class="QLabel" name="mStyleLabel" >
-      <string>Style</string>
-     </property>
-      <cstring>mStyleComboBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="1" >
-    <widget class="QComboBox" name="mStyleComboBox" />
-   </item>
-   <item row="2" column="2" >
-    <widget class="QLabel" name="mMapLabel" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
-      </sizepolicy>
-     </property>
-      <string>Map</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mMapComboBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="4" >
-    <widget class="QComboBox" name="mMapComboBox" >
-     <property name="enabled" >
-      <bool>true</bool>
-     </property>
-      </sizepolicy>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="0" >
-    <widget class="QLabel" name="mHeightLabel" >
-      <string>Height (mm)</string>
-     </property>
-      <cstring>mHeightSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="1" >
-    <widget class="QSpinBox" name="mHeightSpinBox" />
-   </item>
-   <item row="3" column="2" colspan="2" >
-    <widget class="QLabel" name="mLineWidthLabel" >
-      <string>Line width</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mLineWidthSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="4" >
-    <widget class="QDoubleSpinBox" name="mLineWidthSpinBox" >
-      </sizepolicy>
-     </property>
-     <property name="minimum" >
-      <double>0.010000000000000</double>
-     </property>
-     <property name="singleStep" >
-      <double>0.100000000000000</double>
-     </property>
-     <property name="value" >
-      <double>0.200000000000000</double>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="0" >
-    <widget class="QLabel" name="mLabelBarSpaceLabel" >
-      <string>Label space</string>
-     </property>
-      <cstring>mLabelBarSpaceSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="1" >
-    <widget class="QDoubleSpinBox" name="mLabelBarSpaceSpinBox" />
-   </item>
-   <item row="4" column="2" colspan="2" >
-    <widget class="QLabel" name="mBoxSpaceLabel" >
-      <string>Box space</string>
-     </property>
-      <cstring>mBoxSizeSpinBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="4" >
-    <widget class="QDoubleSpinBox" name="mBoxSizeSpinBox" />
-   </item>
-   <item row="5" column="0" >
-    <widget class="QLabel" name="mUnitLabelLabel" >
-      <string>Unit label</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mUnitLabelLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="1" >
-    <widget class="QLineEdit" name="mUnitLabelLineEdit" />
-   </item>
-   <item row="5" column="2" >
-    <widget class="QPushButton" name="mFontButton" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
-      </sizepolicy>
-     </property>
-      <string>Font...</string>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="3" colspan="2" >
-    <widget class="QPushButton" name="mColorPushButton" >
-      <string>Color...</string>
-     </property>
-    </widget>
-   </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <tabstops>
   <tabstop>mSegmentSizeSpinBox</tabstop>
   <tabstop>mMapUnitsPerBarUnitSpinBox</tabstop>
   <tabstop>mNumberOfSegmentsSpinBox</tabstop>
More information about the QGIS-commit mailing list
