[QGIS Commit] r12069 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Tue Nov 10 09:42:43 EST 2009
Author: timlinux
Date: 2009-11-10 09:42:42 -0500 (Tue, 10 Nov 2009)
New Revision: 12069
trunk/qgis/src/ui/qgscomposerbase.ui
trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
UI cleanups
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2009-11-10 14:09:36 UTC (rev 12068)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2009-11-10 14:42:42 UTC (rev 12069)
@@ -21,7 +21,7 @@
<bool>true</bool>
</property>
<layout class="QGridLayout">
- <item row="0" column="0">
+ <item row="1" column="0">
<widget class="QSplitter" name="mSplitter">
<property name="mouseTracking">
<bool>true</bool>
@@ -133,13 +133,6 @@
</widget>
</widget>
</item>
- <item row="1" column="0">
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="standardButtons">
- <set>QDialogButtonBox::Help</set>
- </property>
- </widget>
- </item>
</layout>
</widget>
<widget class="QToolBar" name="toolBar">
@@ -445,27 +438,9 @@
</action>
</widget>
<tabstops>
- <tabstop>buttonBox</tabstop>
<tabstop>mCompositionNameComboBox</tabstop>
<tabstop>mOptionsTabWidget</tabstop>
</tabstops>
<resources/>
- <connections>
- <connection>
- <sender>buttonBox</sender>
- <signal>rejected()</signal>
- <receiver>QgsComposerBase</receiver>
- <slot>close()</slot>
- <hints>
- <hint type="sourcelabel">
- <x>612</x>
- <y>583</y>
- </hint>
- <hint type="destinationlabel">
- <x>735</x>
- <y>567</y>
- </hint>
- </hints>
- </connection>
- </connections>
+ <connections/>
</ui>
Modified: trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2009-11-10 14:09:36 UTC (rev 12068)
+++ trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2009-11-10 14:42:42 UTC (rev 12069)
@@ -26,13 +26,13 @@
<widget class="QToolBox" name="toolBox">
<property name="currentIndex">
- <number>0</number>
+ <number>1</number>
</property>
<widget class="QWidget" name="page">
<property name="geometry">
<rect>
<x>0</x>
- <y>0</y>
+ <y>-68</y>
<width>386</width>
<height>419</height>
</rect>
@@ -172,6 +172,19 @@
</item>
</layout>
</item>
+ <item row="10" column="0">
+ <spacer name="verticalSpacer">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</item>
@@ -182,8 +195,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>404</width>
- <height>351</height>
+ <width>386</width>
+ <height>352</height>
</rect>
</property>
<attribute name="label">
@@ -279,9 +292,30 @@
</layout>
</widget>
</item>
+ <spacer name="verticalSpacer_3">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="page_3">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>-448</y>
+ <height>805</height>
+ </rect>
+ </property>
<string>Grid</string>
</attribute>
@@ -556,6 +590,19 @@
</property>
</widget>
</item>
+ <item row="37" column="0">
+ <spacer name="verticalSpacer_2">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui 2009-11-10 14:09:36 UTC (rev 12068)
+++ trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui 2009-11-10 14:42:42 UTC (rev 12069)
@@ -34,7 +34,7 @@
<x>0</x>
<y>0</y>
<width>307</width>
- <height>714</height>
+ <height>616</height>
</rect>
</property>
@@ -85,35 +85,20 @@
</widget>
</item>
<item row="4" column="0">
- <widget class="QLabel" name="mNumbereOfSegmentsLabel">
- <property name="text">
- <string>Number of segments</string>
+ <widget class="QSpinBox" name="mNumberOfSegmentsSpinBox">
+ <property name="suffix">
+ <string> Right segments</string>
</property>
- <property name="wordWrap">
- <bool>true</bool>
- </property>
- <property name="buddy">
- <cstring>mNumberOfSegmentsSpinBox</cstring>
- </property>
</widget>
</item>
<item row="5" column="0">
- <widget class="QSpinBox" name="mNumberOfSegmentsSpinBox"/>
- </item>
- <item row="6" column="0">
- <widget class="QLabel" name="mSegmentsLeftLabel">
- <string>Segments left</string>
+ <widget class="QSpinBox" name="mSegmentsLeftSpinBox">
+ <string> Left segments</string>
</property>
- <cstring>mSegmentsLeftSpinBox</cstring>
- </property>
</widget>
</item>
- <item row="7" column="0">
- <widget class="QSpinBox" name="mSegmentsLeftSpinBox"/>
- </item>
- <item row="8" column="0">
+ <item row="6" column="0">
<widget class="QLabel" name="mStyleLabel">
<string>Style</string>
@@ -123,10 +108,10 @@
</property>
</widget>
</item>
- <item row="9" column="0">
+ <item row="7" column="0">
<widget class="QComboBox" name="mStyleComboBox"/>
</item>
- <item row="10" column="0">
+ <item row="8" column="0">
<widget class="QLabel" name="mMapLabel">
<property name="sizePolicy">
<sizepolicy hsizetype="Expanding" vsizetype="Fixed">
@@ -145,7 +130,7 @@
</property>
</widget>
</item>
- <item row="11" column="0">
+ <item row="9" column="0">
<widget class="QComboBox" name="mMapComboBox">
<property name="enabled">
<bool>true</bool>
@@ -158,33 +143,17 @@
</property>
</widget>
</item>
- <item row="12" column="0">
- <widget class="QLabel" name="mHeightLabel">
- <string>Height (mm)</string>
+ <widget class="QSpinBox" name="mHeightSpinBox">
+ <string> mm</string>
</property>
- <cstring>mHeightSpinBox</cstring>
+ <property name="prefix">
+ <string>Height </string>
</property>
</widget>
</item>
- <item row="13" column="0">
- <widget class="QSpinBox" name="mHeightSpinBox"/>
- </item>
- <item row="14" column="0">
- <widget class="QLabel" name="mLineWidthLabel">
- <string>Line width</string>
- </property>
- <bool>true</bool>
- </property>
- <cstring>mLineWidthSpinBox</cstring>
- </property>
- </widget>
- </item>
- <item row="15" column="0">
+ <item row="11" column="0">
<widget class="QDoubleSpinBox" name="mLineWidthSpinBox">
@@ -192,6 +161,12 @@
<verstretch>0</verstretch>
</sizepolicy>
</property>
+ <string>Line width </string>
+ </property>
+ </property>
<property name="minimum">
<double>0.010000000000000</double>
</property>
@@ -203,33 +178,27 @@
</property>
</widget>
</item>
- <item row="16" column="0">
- <widget class="QLabel" name="mLabelBarSpaceLabel">
- <string>Label space</string>
+ <item row="12" column="0">
+ <widget class="QDoubleSpinBox" name="mLabelBarSpaceSpinBox">
+ <string>Label space </string>
</property>
- <cstring>mLabelBarSpaceSpinBox</cstring>
</property>
</widget>
</item>
- <item row="17" column="0">
- <widget class="QDoubleSpinBox" name="mLabelBarSpaceSpinBox"/>
- </item>
- <item row="18" column="0">
- <widget class="QLabel" name="mBoxSpaceLabel">
- <string>Box space</string>
+ <item row="13" column="0">
+ <widget class="QDoubleSpinBox" name="mBoxSizeSpinBox">
+ <string>Box space </string>
</property>
- <cstring>mBoxSizeSpinBox</cstring>
</property>
</widget>
</item>
- <item row="19" column="0">
- <widget class="QDoubleSpinBox" name="mBoxSizeSpinBox"/>
- </item>
- <item row="20" column="0">
+ <item row="14" column="0">
<widget class="QLabel" name="mUnitLabelLabel">
<string>Unit label</string>
@@ -242,10 +211,10 @@
</property>
</widget>
</item>
- <item row="21" column="0">
+ <item row="15" column="0">
<widget class="QLineEdit" name="mUnitLabelLineEdit"/>
</item>
- <item row="22" column="0">
+ <item row="16" column="0">
<widget class="QPushButton" name="mFontButton">
<sizepolicy hsizetype="Preferred" vsizetype="Fixed">
@@ -258,13 +227,26 @@
</property>
</widget>
</item>
- <item row="23" column="0">
+ <item row="17" column="0">
<widget class="QPushButton" name="mColorPushButton">
<string>Color...</string>
</property>
</widget>
</item>
+ <item row="18" column="0">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</widget>
