[QGIS Commit] r12080 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Tue Nov 10 17:06:24 EST 2009
Author: macho
Date: 2009-11-10 17:06:24 -0500 (Tue, 10 Nov 2009)
New Revision: 12080
trunk/qgis/src/app/qgswmssourceselect.cpp
trunk/qgis/src/app/qgswmssourceselect.h
trunk/qgis/src/ui/qgswmssourceselectbase.ui
last ui cleanups from my list -> buttonbox
Modified: trunk/qgis/src/app/qgswmssourceselect.cpp
--- trunk/qgis/src/app/qgswmssourceselect.cpp 2009-11-10 21:27:18 UTC (rev 12079)
+++ trunk/qgis/src/app/qgswmssourceselect.cpp 2009-11-10 22:06:24 UTC (rev 12080)
@@ -56,10 +56,17 @@
mWmsProvider( 0 )
setupUi( this );
+ mAddButton = new QPushButton( tr( "&Add" ) );
+ buttonBox->addButton( mAddButton, QDialogButtonBox::ActionRole );
+ connect( mAddButton,SIGNAL( clicked() ), this, SLOT( addClicked() ) );
+ connect( buttonBox,SIGNAL( helpRequested() ), this, SLOT( helpClicked() ) );
mLayerUpButton->setIcon( QgisApp::getThemeIcon( "/mActionArrowUp.png" ) );
mLayerDownButton->setIcon( QgisApp::getThemeIcon( "/mActionArrowDown.png" ) );
- connect( btnCancel, SIGNAL( clicked() ), this, SLOT( reject() ) );
+ mAddButton->setEnabled( false );
+ populateConnectionList();
// Qt Designer 4.1 doesn't let us use a QButtonGroup, so it has to
// be done manually... Unless I'm missing something, it's a whole
// lot harder to do groups of radio buttons in Qt4 than Qt3.
@@ -201,7 +208,7 @@
-void QgsWMSSourceSelect::on_btnHelp_clicked()
+void QgsWMSSourceSelect::helpClicked()
QgsContextHelp::run( context_id );
@@ -283,7 +290,7 @@
// If we got some layers, let the user add them to the map
if ( lstLayers->topLevelItemCount() > 0 )
- btnAdd->setEnabled( TRUE );
+ mAddButton->setEnabled( TRUE );
if ( lstLayers->topLevelItemCount() == 1 )
@@ -292,7 +299,7 @@
else
- btnAdd->setEnabled( FALSE );
+ mAddButton->setEnabled( FALSE );
return TRUE;
@@ -427,7 +434,7 @@
-void QgsWMSSourceSelect::on_btnAdd_clicked()
+void QgsWMSSourceSelect::addClicked()
if ( selectedLayers().empty() == TRUE )
Modified: trunk/qgis/src/app/qgswmssourceselect.h
--- trunk/qgis/src/app/qgswmssourceselect.h 2009-11-10 21:27:18 UTC (rev 12079)
+++ trunk/qgis/src/app/qgswmssourceselect.h 2009-11-10 22:06:24 UTC (rev 12080)
@@ -22,6 +22,7 @@
#include "qgisgui.h"
#include <QStringList>
+#include <QPushButton>
class QgisApp;
class QgsWmsProvider;
@@ -103,13 +104,14 @@
void on_btnConnect_clicked();
//! Determines the layers the user selected
- void on_btnAdd_clicked();
+ void addClicked();
//! Opens the Spatial Reference System dialog.
void on_btnChangeSpatialRefSys_clicked();
//! Opens help application
- void on_btnHelp_clicked();
+ void helpClicked();
//! Signaled when a layer selection is changed. Ensures that only one style is selected per layer.
void on_lstLayers_itemSelectionChanged();
@@ -182,6 +184,8 @@
QButtonGroup* m_imageFormatGroup;
QHBoxLayout* m_imageFormatLayout;
+ QPushButton * mAddButton;
//! The WMS provider that retrieves information for this dialog
QgsWmsProvider * mWmsProvider;
Modified: trunk/qgis/src/ui/qgswmssourceselectbase.ui
--- trunk/qgis/src/ui/qgswmssourceselectbase.ui 2009-11-10 21:27:18 UTC (rev 12079)
+++ trunk/qgis/src/ui/qgswmssourceselectbase.ui 2009-11-10 22:06:24 UTC (rev 12080)
@@ -1,88 +1,89 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsWMSSourceSelectBase</class>
- <widget class="QDialog" name="QgsWMSSourceSelectBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsWMSSourceSelectBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
- <width>510</width>
+ <width>555</width>
<height>508</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Add Layer(s) from a Server</string>
</property>
- <property name="windowIcon" >
+ <property name="windowIcon">
<iconset>
- <normaloff/>
+ <normaloff/>
</iconset>
</property>
- <property name="sizeGripEnabled" >
+ <property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <property name="modal" >
+ <property name="modal">
<bool>true</bool>
</property>
- <layout class="QGridLayout" >
- <item row="0" column="0" colspan="4" >
- <widget class="QTabWidget" name="tabWidget" >
- <property name="currentIndex" >
- <number>0</number>
+ <layout class="QGridLayout">
+ <item row="0" column="0" colspan="2">
+ <widget class="QTabWidget" name="tabWidget">
+ <property name="currentIndex">
+ <number>2</number>
</property>
- <widget class="QWidget" name="tab" >
- <attribute name="title" >
+ <widget class="QWidget" name="tab">
+ <attribute name="title">
<string>Servers</string>
</attribute>
- <item row="0" column="0" colspan="6" >
- <widget class="QComboBox" name="cmbConnections" />
+ <item row="0" column="0" colspan="6">
+ <widget class="QComboBox" name="cmbConnections"/>
</item>
- <item row="1" column="0" >
- <widget class="QPushButton" name="btnConnect" >
- <property name="enabled" >
+ <item row="1" column="0">
+ <widget class="QPushButton" name="btnConnect">
+ <property name="enabled">
<bool>false</bool>
</property>
- <property name="text" >
+ <property name="text">
<string>C&onnect</string>
</property>
</widget>
</item>
- <item row="1" column="1" >
- <widget class="QPushButton" name="btnNew" >
+ <item row="1" column="1">
+ <widget class="QPushButton" name="btnNew">
<string>&New</string>
</property>
</widget>
</item>
- <item row="1" column="2" >
- <widget class="QPushButton" name="btnEdit" >
+ <item row="1" column="2">
+ <widget class="QPushButton" name="btnEdit">
<bool>false</bool>
</property>
<string>Edit</string>
</property>
</widget>
</item>
- <item row="1" column="3" >
- <widget class="QPushButton" name="btnDelete" >
+ <item row="1" column="3">
+ <widget class="QPushButton" name="btnDelete">
<bool>false</bool>
</property>
<string>Delete</string>
</property>
</widget>
</item>
- <item row="1" column="4" >
+ <item row="1" column="4">
<spacer>
- <property name="orientation" >
+ <property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
- <property name="sizeType" >
+ <property name="sizeType">
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0">
<size>
<width>16</width>
<height>31</height>
@@ -90,50 +91,50 @@
</property>
</spacer>
</item>
- <item row="1" column="5" >
- <widget class="QPushButton" name="btnAddDefault" >
- <property name="statusTip" >
+ <item row="1" column="5">
+ <widget class="QPushButton" name="btnAddDefault">
+ <property name="statusTip">
<string>Adds a few example WMS servers</string>
</property>
- <property name="whatsThis" >
- <string comment="Adds several example WMS servers to the list" />
+ <property name="whatsThis">
+ <string comment="Adds several example WMS servers to the list"/>
</property>
<string>Add default servers</string>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="6" >
- <widget class="QTreeWidget" name="lstLayers" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+ <item row="2" column="0" colspan="6">
+ <widget class="QTreeWidget" name="lstLayers">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
- <property name="selectionMode" >
+ <property name="selectionMode">
<enum>QAbstractItemView::MultiSelection</enum>
</property>
- <property name="allColumnsShowFocus" >
+ <property name="allColumnsShowFocus">
<bool>true</bool>
</property>
<column>
<string>ID</string>
</property>
</column>
<column>
<string>Name</string>
</property>
</column>
<column>
<string>Title</string>
</property>
</column>
<column>
<string>Abstract</string>
</property>
</column>
@@ -141,31 +142,31 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabLayerOrder" >
+ <widget class="QWidget" name="tabLayerOrder">
<string>Layer Order</string>
</attribute>
- <item row="0" column="0" >
- <widget class="QPushButton" name="mLayerUpButton" >
+ <item row="0" column="0">
+ <widget class="QPushButton" name="mLayerUpButton">
<string/>
</property>
</widget>
</item>
- <item row="0" column="1" >
- <widget class="QPushButton" name="mLayerDownButton" >
+ <item row="0" column="1">
+ <widget class="QPushButton" name="mLayerDownButton">
<string/>
</property>
</widget>
</item>
- <item row="0" column="2" >
+ <item row="0" column="2">
<spacer>
</property>
<size>
<width>391</width>
<height>30</height>
@@ -173,18 +174,18 @@
</property>
</spacer>
</item>
- <item row="1" column="0" colspan="3" >
- <widget class="QTreeWidget" name="mLayerOrderTreeWidget" >
- <property name="columnCount" >
+ <item row="1" column="0" colspan="3">
+ <widget class="QTreeWidget" name="mLayerOrderTreeWidget">
+ <property name="columnCount">
<number>2</number>
</property>
<column>
<string>Layer</string>
</property>
</column>
<column>
<string>Style</string>
</property>
</column>
@@ -192,55 +193,55 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab_2" >
+ <widget class="QWidget" name="tab_2">
<string>Server Search</string>
</attribute>
- <widget class="QLineEdit" name="leSearchTerm" />
+ <widget class="QLineEdit" name="leSearchTerm"/>
</item>
- <widget class="QPushButton" name="btnSearch" >
+ <widget class="QPushButton" name="btnSearch">
<string>Search</string>
</property>
- <property name="default" >
+ <property name="default">
<bool>true</bool>
</property>
</widget>
</item>
- <item row="1" column="0" colspan="2" >
- <widget class="QTableWidget" name="tableWidgetWMSList" >
+ <item row="1" column="0" colspan="2">
+ <widget class="QTableWidget" name="tableWidgetWMSList">
<enum>QAbstractItemView::SingleSelection</enum>
</property>
- <property name="selectionBehavior" >
+ <property name="selectionBehavior">
<enum>QAbstractItemView::SelectRows</enum>
</property>
- <property name="cornerButtonEnabled" >
+ <property name="cornerButtonEnabled">
<bool>false</bool>
</property>
<column>
</property>
</column>
<column>
<string>URL</string>
</property>
</column>
<column>
<string>Description</string>
</property>
</column>
</widget>
</item>
- <item row="2" column="0" colspan="2" >
- <widget class="QPushButton" name="btnAddWMS" >
+ <item row="2" column="0" colspan="2">
+ <widget class="QPushButton" name="btnAddWMS">
<string>Add selected row to WMS list</string>
</property>
</widget>
@@ -249,54 +250,60 @@
</widget>
</widget>
</item>
- <item row="1" column="0" colspan="4" >
- <widget class="QGroupBox" name="btnGrpImageEncoding" >
- <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+ <widget class="QGroupBox" name="btnGrpImageEncoding">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
</sizepolicy>
</property>
- <property name="minimumSize" >
+ <property name="minimumSize">
<size>
<width>16</width>
<height>64</height>
</size>
</property>
- <property name="title" >
+ <property name="title">
<string>Image encoding</string>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="4" >
- <widget class="QGroupBox" name="gbCRS" >
+ <widget class="QGroupBox" name="gbCRS">
<string>Options</string>
</property>
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
<string>Layer name</string>
</property>
+ <property name="buddy">
+ <cstring>leLayerName</cstring>
+ </property>
</widget>
</item>
- <item row="0" column="1" colspan="2" >
- <widget class="QLineEdit" name="leLayerName" />
+ <item row="0" column="1" colspan="2">
+ <widget class="QLineEdit" name="leLayerName"/>
</item>
- <widget class="QLabel" name="labelCoordRefSys" >
+ <widget class="QLabel" name="labelCoordRefSys">
<string>Coordinate Reference System</string>
</property>
+ <cstring>btnChangeSpatialRefSys</cstring>
+ </property>
</widget>
</item>
- <widget class="QPushButton" name="btnChangeSpatialRefSys" >
+ <widget class="QPushButton" name="btnChangeSpatialRefSys">
<bool>false</bool>
</property>
<string>Change ...</string>
</property>
</widget>
@@ -304,89 +311,32 @@
</layout>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QPushButton" name="btnHelp" >
- <bool>true</bool>
- </property>
- <string>Help</string>
- </property>
- <property name="shortcut" >
- <string>F1</string>
- </property>
- <property name="autoDefault" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="3" column="1" >
- <spacer>
- <enum>Qt::Horizontal</enum>
- </property>
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <size>
- <width>284</width>
- <height>31</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="3" column="2" >
- <widget class="QPushButton" name="btnAdd" >
- <bool>false</bool>
- </property>
- <string>&Add</string>
- </property>
- <string>Alt+A</string>
- </property>
- <bool>true</bool>
- </property>
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="3" column="3" >
- <widget class="QPushButton" name="btnCancel" >
- <string>C&lose</string>
- </property>
- <string>Alt+L</string>
- </property>
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="4" column="0" colspan="4" >
- <widget class="QLabel" name="labelStatus" >
- <sizepolicy vsizetype="Preferred" hsizetype="Ignored" >
+ <item row="4" column="0" colspan="2">
+ <widget class="QLabel" name="labelStatus">
+ <sizepolicy hsizetype="Ignored" vsizetype="Preferred">
</sizepolicy>
</property>
<string>Ready</string>
</property>
- <property name="wordWrap" >
+ <property name="wordWrap">
<bool>false</bool>
</property>
</widget>
</item>
+ <item row="3" column="0" colspan="2">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Close|QDialogButtonBox::Help</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
<tabstops>
<tabstop>cmbConnections</tabstop>
<tabstop>btnConnect</tabstop>
@@ -394,10 +344,24 @@
<tabstop>btnEdit</tabstop>
<tabstop>btnDelete</tabstop>
<tabstop>btnChangeSpatialRefSys</tabstop>
- <tabstop>btnHelp</tabstop>
- <tabstop>btnAdd</tabstop>
- <tabstop>btnCancel</tabstop>
</tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>rejected()</signal>
+ <receiver>QgsWMSSourceSelectBase</receiver>
+ <slot>reject()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>509</x>
+ <y>461</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>551</x>
+ <y>370</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
