[QGIS Commit] r12095 - in trunk/qgis/src: app plugins/diagram_overlay ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 11 17:06:34 EST 2009
Author: timlinux
Date: 2009-11-11 17:06:32 -0500 (Wed, 11 Nov 2009)
New Revision: 12095
   trunk/qgis/src/app/qgslabeldialog.cpp
   trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui
   trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui
   trunk/qgis/src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui
   trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
   trunk/qgis/src/ui/qgslabeldialogbase.ui
   trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
   trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
[FEATURE] UI cleanups in prep of using property lists. Main visual difference is that labels dont have property lists no in vec props
Modified: trunk/qgis/src/app/qgslabeldialog.cpp
--- trunk/qgis/src/app/qgslabeldialog.cpp	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/app/qgslabeldialog.cpp	2009-11-11 22:06:32 UTC (rev 12095)
@@ -264,7 +264,6 @@
   spinBufferSize->setValue( myLabelAttributes->bufferSize() );
   //TODO - transparency attributes for buffers
-  listWidget->setItemSelected( listWidget->item( 0 ), true );
Modified: trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui
--- trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -14,11 +14,17 @@
    <string>Form</string>
   </property>
   <layout class="QGridLayout">
+   <property name="margin">
+    <number>0</number>
+   </property>
    <item row="0" column="0">
     <widget class="QLabel" name="mTitleLabel">
      <property name="text">
       <string>Scale linearly between 0 and the following attribute value/ diagram size:</string>
      </property>
+     <property name="wordWrap">
+      <bool>true</bool>
+     </property>
     </widget>
    </item>
    <item row="1" column="0">
Modified: trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui
--- trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsSVGDiagramFactoryWidgetBase</class>
- <widget class="QWidget" name="QgsSVGDiagramFactoryWidgetBase" >
-  <property name="geometry" >
+ <widget class="QWidget" name="QgsSVGDiagramFactoryWidgetBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,28 +10,31 @@
     <height>342</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QGroupBox" name="mSearchDirectoriesGroupBox" >
-     <property name="sizePolicy" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+  <layout class="QGridLayout">
+   </property>
+   <item row="0" column="0">
+    <widget class="QGroupBox" name="mSearchDirectoriesGroupBox">
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
        <horstretch>0</horstretch>
        <verstretch>0</verstretch>
       </sizepolicy>
      </property>
-     <property name="title" >
+     <property name="title">
       <string>Search directories</string>
      </property>
        <spacer>
-        <property name="orientation" >
+        <property name="orientation">
          <enum>Qt::Horizontal</enum>
         </property>
-        <property name="sizeHint" >
+        <property name="sizeHint" stdset="0">
          <size>
           <width>101</width>
           <height>20</height>
@@ -38,24 +42,24 @@
         </property>
        </spacer>
       </item>
-      <item row="0" column="1" >
-       <widget class="QPushButton" name="mAddDirectoryButton" >
-        <property name="text" >
+      <item row="0" column="1">
+       <widget class="QPushButton" name="mAddDirectoryButton">
+        <property name="text">
          <string>Add...</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="2" >
-       <widget class="QPushButton" name="mRemoveDirectoryButton" >
+      <item row="0" column="2">
+       <widget class="QPushButton" name="mRemoveDirectoryButton">
          <string>Remove</string>
         </property>
        </widget>
       </item>
-      <item row="1" column="0" colspan="3" >
-       <widget class="QComboBox" name="mSearchDirectoriesComboBox" >
-         <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+      <item row="1" column="0" colspan="3">
+       <widget class="QComboBox" name="mSearchDirectoriesComboBox">
+         <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
          </sizepolicy>
@@ -65,39 +69,39 @@
      </layout>
     </widget>
    </item>
-   <item row="1" column="0" >
-    <widget class="QGroupBox" name="mPreviewGroupBox" >
-      <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+   <item row="1" column="0">
+    <widget class="QGroupBox" name="mPreviewGroupBox">
+      <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
       </sizepolicy>
      </property>
       <string>SVG Preview</string>
      </property>
-       <widget class="QListWidget" name="mPreviewListWidget" >
-        <property name="movement" >
+       <widget class="QListWidget" name="mPreviewListWidget">
+        <property name="movement">
          <enum>QListView::Free</enum>
         </property>
-        <property name="flow" >
+        <property name="flow">
          <enum>QListView::LeftToRight</enum>
         </property>
-        <property name="isWrapping" stdset="0" >
+        <property name="isWrapping" stdset="0">
          <bool>true</bool>
         </property>
-        <property name="gridSize" >
+        <property name="gridSize">
          <size>
           <width>30</width>
           <height>30</height>
          </size>
         </property>
-        <property name="viewMode" >
+        <property name="viewMode">
          <enum>QListView::IconMode</enum>
         </property>
-        <property name="wordWrap" >
          <bool>true</bool>
         </property>
        </widget>
@@ -105,43 +109,22 @@
      </layout>
     </widget>
    </item>
-   <item row="2" column="0" >
-    <layout class="QHBoxLayout" >
-     <property name="spacing" >
+   <item row="2" column="0">
+    <layout class="QHBoxLayout">
+     <property name="spacing">
       <number>6</number>
      </property>
-     <property name="leftMargin" >
       <number>0</number>
      </property>
-     <property name="topMargin" >
-      <number>0</number>
-     </property>
-     <property name="rightMargin" >
-     </property>
-     <property name="bottomMargin" >
-     </property>
      <item>
-      <widget class="QLineEdit" name="mPictureLineEdit" />
+      <widget class="QLineEdit" name="mPictureLineEdit"/>
      </item>
      <item>
-      <widget class="QPushButton" name="mPictureBrowseButton" >
-         <horstretch>0</horstretch>
-         <verstretch>0</verstretch>
-        </sizepolicy>
+      <widget class="QToolButton" name="mPictureBrowseButton">
+        <string>...</string>
        </property>
-       <property name="maximumSize" >
-        <size>
-         <width>150</width>
-         <height>32767</height>
-        </size>
-       </property>
-        <string>Browse...</string>
-       </property>
       </widget>
      </item>
     </layout>
Modified: trunk/qgis/src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui
--- trunk/qgis/src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -6,14 +6,17 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>342</width>
+    <width>412</width>
     <height>277</height>
    </rect>
   </property>
   </property>
-  <layout class="QGridLayout">
+  <layout class="QGridLayout" name="gridLayout">
+   </property>
@@ -30,51 +33,48 @@
       </widget>
      </item>
      <item>
-      <widget class="QComboBox" name="mAttributesComboBox"/>
+      <widget class="QComboBox" name="mAttributesComboBox">
+         <horstretch>0</horstretch>
+         <verstretch>0</verstretch>
+        </sizepolicy>
+       </property>
+      </widget>
      </item>
     </layout>
    </item>
-   <item row="1" column="0">
-     <property name="margin">
+    <widget class="QPushButton" name="mAddPushButton">
+      <string>Add</string>
      </property>
-     <property name="spacing">
-      <number>6</number>
+    </widget>
+   </item>
+    <widget class="QPushButton" name="mRemovePushButton">
+      <string>Remove</string>
      </property>
-     <item row="1" column="0" colspan="2">
-      <widget class="QTreeWidget" name="mAttributesTreeWidget">
-       <property name="columnCount">
-        <number>2</number>
-       </property>
-       <column>
-        <property name="text">
-         <string>1</string>
-        </property>
-       </column>
-       <column>
-        </property>
-       </column>
-      </widget>
-     </item>
-     <item row="0" column="1">
-      <widget class="QPushButton" name="mRemovePushButton">
-        <string>Remove attribute</string>
-       </property>
-      </widget>
-     </item>
-     <item row="0" column="0">
-      <widget class="QPushButton" name="mAddPushButton">
-        <string>Add attribute</string>
-       </property>
-      </widget>
-     </item>
-    </layout>
+    </widget>
    </item>
+    <widget class="QTreeWidget" name="mAttributesTreeWidget">
+     <property name="columnCount">
+      <number>2</number>
+     </property>
+     <column>
+       <string>1</string>
+      </property>
+     </column>
+     <column>
+      </property>
+     </column>
+    </widget>
+   </item>
   </layout>
  </widget>
  <tabstops>
Modified: trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
--- trunk/qgis/src/ui/qgsattributeactiondialogbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/ui/qgsattributeactiondialogbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>424</width>
-    <height>339</height>
+    <width>552</width>
+    <height>432</height>
    </rect>
   </property>
@@ -19,16 +19,16 @@
    <string>Attribute Actions</string>
   </property>
+  <layout class="QGridLayout" name="gridLayout_3">
     <number>0</number>
    </property>
-   <item row="0" column="0" colspan="2">
     <widget class="QGroupBox" name="groupBox">
       <string>Action properties</string>
      </property>
        <widget class="QLabel" name="textLabel1">
         <property name="whatsThis">
@@ -42,7 +42,7 @@
         </property>
        </widget>
       </item>
-      <item row="0" column="1" colspan="3">
        <widget class="QLineEdit" name="actionName">
         <property name="toolTip">
          <string>Enter the action name here</string>
@@ -65,184 +65,201 @@
         </property>
        </widget>
       </item>
-      <item row="1" column="1" colspan="2">
-       <widget class="QLineEdit" name="actionAction">
+      <item row="1" column="1">
+       <layout class="QHBoxLayout" name="horizontalLayout">
+        <item>
+         <widget class="QLineEdit" name="actionAction">
+          <property name="toolTip">
+           <string>Enter the action command here</string>
+          </property>
+          <property name="whatsThis">
+           <string>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if prefixed with a backslash</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QToolButton" name="browseButton">
+           <string>Browse for action</string>
+          </property>
+          <property name="statusTip">
+           <string>Click to browse for an action</string>
+          </property>
+           <string>Clicking the button will let you select an application to use as the action</string>
+          </property>
+          </property>
+         </widget>
+        </item>
+       </layout>
+      </item>
+       <widget class="QCheckBox" name="captureCB">
-         <string>Enter the action command here</string>
+         <string>Captures any output from the action</string>
         </property>
-         <string>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if prefixed with a backslash</string>
+         <string>Captures the standard output or error generated by the action and displays it in a dialog box</string>
         </property>
+         <string>Capture output</string>
+        </property>
        </widget>
       </item>
-      <item row="1" column="3">
-       <widget class="QToolButton" name="browseButton">
+      <item row="2" column="1">
+       <layout class="QHBoxLayout" name="horizontalLayout_2">
+        <item>
+         <widget class="QComboBox" name="fieldComboBox">
+           <string>The valid attribute names for this layer</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QPushButton" name="insertFieldButton">
+           <string>Inserts the selected field into the action, prepended with a %</string>
+          </property>
+           <string>Insert field</string>
+          </property>
+         </widget>
+        </item>
+       </layout>
+      </item>
+     </layout>
+    </widget>
+   </item>
+    <widget class="QGroupBox" name="groupBox_2">
+      <string>Action list</string>
+     </property>
+     <layout class="QGridLayout" name="gridLayout_2">
+      <item row="0" column="0" rowspan="7">
+       <widget class="QTableWidget" name="attributeActionTable">
+         </sizepolicy>
+        </property>
+         <string>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</string>
+        </property>
+        <property name="selectionMode">
+         <enum>QAbstractItemView::SingleSelection</enum>
+        </property>
+        <property name="selectionBehavior">
+         <enum>QAbstractItemView::SelectRows</enum>
+        </property>
+         <number>3</number>
+        </property>
+        <column>
+          <string>Name</string>
+         </property>
+        </column>
+        <column>
+          <string>Action</string>
+         </property>
+        </column>
+        <column>
+          <string>Capture</string>
+         </property>
+        </column>
+       </widget>
+      </item>
+       <widget class="QPushButton" name="insertButton">
-         <string>Browse for action</string>
+         <string>Inserts the action into the list above</string>
         </property>
-        <property name="statusTip">
-         <string>Click to browse for an action</string>
+         <string>Insert action</string>
         </property>
-        <property name="whatsThis">
-         <string>Clicking the button will let you select an application to use as the action</string>
+       </widget>
+      </item>
+       <widget class="QPushButton" name="updateButton">
+         <string>Update the selected action</string>
         </property>
-         <string>...</string>
+         <string>Update action</string>
         </property>
        </widget>
       </item>
-       <widget class="QComboBox" name="fieldComboBox">
+       <spacer>
+         <enum>Qt::Vertical</enum>
+        </property>
+        <property name="sizeType">
+         <enum>QSizePolicy::Expanding</enum>
+        </property>
+         <size>
+          <width>85</width>
+          <height>35</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="3" column="1">
+       <widget class="QPushButton" name="moveUpButton">
-         <string>The valid attribute names for this layer</string>
+         <string>Move the selected action up</string>
         </property>
+         <string>Move up</string>
+        </property>
        </widget>
       </item>
-      <item row="2" column="2" colspan="2">
-       <widget class="QPushButton" name="insertFieldButton">
+      <item row="4" column="1">
+       <widget class="QPushButton" name="moveDownButton">
-         <string>Inserts the selected field into the action, prepended with a %</string>
+         <string>Move the selected action down</string>
         </property>
-         <string>Insert field</string>
+         <string>Move down</string>
         </property>
        </widget>
       </item>
-      <item row="3" column="1" colspan="2">
-       <widget class="QCheckBox" name="captureCB">
+      <item row="5" column="1">
+       <spacer>
+        </property>
+        </property>
+         <size>
+          <width>85</width>
+          <height>41</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="6" column="1">
+       <widget class="QPushButton" name="removeButton">
-         <string>Captures any output from the action</string>
+         <string>Remove the selected action</string>
         </property>
-         <string>Captures the standard output or error generated by the action and displays it in a dialog box</string>
-        </property>
-         <string>Capture output</string>
         </property>
        </widget>
       </item>
      </layout>
     </widget>
    </item>
-   <item row="1" column="0" rowspan="7">
-    <widget class="QTableWidget" name="attributeActionTable">
-     <property name="sizePolicy">
-      <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
-      </sizepolicy>
-     </property>
-      <string>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</string>
-     </property>
-     <property name="selectionMode">
-      <enum>QAbstractItemView::SingleSelection</enum>
-     </property>
-     <property name="selectionBehavior">
-      <enum>QAbstractItemView::SelectRows</enum>
-     </property>
-      <number>3</number>
-     </property>
-     <column>
-       <string>Name</string>
-      </property>
-     </column>
-     <column>
-       <string>Action</string>
-      </property>
-     </column>
-     <column>
-       <string>Capture</string>
-      </property>
-     </column>
-    </widget>
-   </item>
-   <item row="1" column="1">
-    <widget class="QPushButton" name="insertButton">
-     <property name="toolTip">
-      <string>Inserts the action into the list above</string>
-     </property>
-      <string>Insert action</string>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="1">
-    <widget class="QPushButton" name="updateButton">
-      <string>Update the selected action</string>
-     </property>
-      <string>Update action</string>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="1">
-    <spacer>
-     <property name="orientation">
-      <enum>Qt::Vertical</enum>
-     </property>
-     <property name="sizeType">
-      <enum>QSizePolicy::Expanding</enum>
-     </property>
-     <property name="sizeHint" stdset="0">
-      <size>
-       <width>85</width>
-       <height>20</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
-   <item row="4" column="1">
-    <widget class="QPushButton" name="moveUpButton">
-      <string>Move the selected action up</string>
-     </property>
-      <string>Move up</string>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="1">
-    <widget class="QPushButton" name="moveDownButton">
-      <string>Move the selected action down</string>
-     </property>
-      <string>Move down</string>
-     </property>
-    </widget>
-   </item>
-   <item row="6" column="1">
-    <spacer>
-     </property>
-     </property>
-      <size>
-       <width>85</width>
-       <height>41</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
-   <item row="7" column="1">
-    <widget class="QPushButton" name="removeButton">
-      <string>Remove the selected action</string>
-     </property>
-      <string>Remove</string>
-     </property>
-    </widget>
-   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
@@ -250,14 +267,14 @@
   <tabstop>actionName</tabstop>
   <tabstop>actionAction</tabstop>
   <tabstop>browseButton</tabstop>
+  <tabstop>captureCB</tabstop>
   <tabstop>fieldComboBox</tabstop>
   <tabstop>insertFieldButton</tabstop>
-  <tabstop>captureCB</tabstop>
+  <tabstop>attributeActionTable</tabstop>
   <tabstop>insertButton</tabstop>
   <tabstop>updateButton</tabstop>
   <tabstop>moveUpButton</tabstop>
   <tabstop>moveDownButton</tabstop>
-  <tabstop>attributeActionTable</tabstop>
   <tabstop>removeButton</tabstop>
  </tabstops>
  <resources/>
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>516</width>
-    <height>487</height>
+    <width>668</width>
+    <height>516</height>
    </rect>
   </property>
@@ -19,11 +19,11 @@
    <string>Form1</string>
   </property>
+  <layout class="QGridLayout" name="gridLayout_7">
     <number>0</number>
    </property>
+   <item row="0" column="0" rowspan="2" colspan="2">
      <item>
       <widget class="QLabel" name="textLabel5">
@@ -79,96 +79,22 @@
      </item>
     </layout>
    </item>
-    <widget class="QListWidget" name="listWidget">
-      </sizepolicy>
-     </property>
-     <item>
-       <string>General</string>
-      </property>
-     </item>
-     <item>
-       <string>Buffer</string>
-      </property>
-     </item>
-     <item>
-       <string>Position</string>
-      </property>
-     </item>
-     <item>
-       <string>Data defined style</string>
-      </property>
-     </item>
-     <item>
-       <string>Data defined alignment</string>
-      </property>
-     </item>
-     <item>
-       <string>Data defined buffer</string>
-      </property>
-     </item>
-     <item>
-       <string>Data defined position</string>
-      </property>
-     </item>
-    </widget>
-   </item>
-   <item row="2" column="0" colspan="2">
-    <widget class="QGroupBox" name="groupBox5">
-      <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
-      </sizepolicy>
-     </property>
-     <property name="maximumSize">
-      <size>
-       <width>800</width>
-       <height>200</height>
-      </size>
-     </property>
-     <property name="title">
-      <string>Preview:</string>
-     </property>
-       <number>11</number>
-      </property>
-       <widget class="QLabel" name="lblSample">
-         <string>QGIS Rocks!</string>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
-    <widget class="QStackedWidget" name="stackedWidget">
-      <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
-      </sizepolicy>
+    <widget class="QScrollArea" name="scrollArea">
+     <property name="widgetResizable">
+      <bool>true</bool>
      </property>
-     <property name="currentIndex">
-     </property>
-     <widget class="QWidget" name="page">
+     <widget class="QWidget" name="scrollAreaWidgetContents_2">
+       <rect>
+        <x>0</x>
+        <y>0</y>
+        <width>639</width>
+        <height>1455</height>
+       </rect>
+      </property>
+       <item row="0" column="0" colspan="2">
           <widget class="QPushButton" name="btnDefaultFont">
@@ -259,7 +185,7 @@
          </item>
         </layout>
        </item>
+       <item row="1" column="0" colspan="2">
           <string>Placement</string>
@@ -337,7 +263,7 @@
          </layout>
         </widget>
        </item>
-       <item row="2" column="0">
+       <item row="2" column="0" colspan="2">
         <widget class="QGroupBox" name="groupBox_3">
           <string>Font size units</string>
@@ -360,20 +286,7 @@
          </layout>
         </widget>
        </item>
-       <item row="3" column="0">
-        <spacer>
-         </property>
-          <size>
-           <width>20</width>
-           <height>40</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-       <item row="4" column="0">
+       <item row="3" column="0" colspan="2">
         <widget class="QGroupBox" name="chkUseScaleDependentRendering">
           <string>Use scale dependent rendering</string>
@@ -434,7 +347,7 @@
          </layout>
         </widget>
        </item>
-       <item row="5" column="0">
+       <item row="4" column="0" colspan="2">
         <widget class="QCheckBox" name="chkUseMultiline">
           <string>Multiline labels?</string>
@@ -444,11 +357,7 @@
          </property>
         </widget>
        </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="page_2">
+       <item row="5" column="0">
         <widget class="QCheckBox" name="chkUseBuffer">
           <string>Buffer labels?</string>
@@ -458,17 +367,17 @@
          </property>
         </widget>
        </item>
+       <item row="6" column="0">
         <widget class="QLabel" name="textLabel4_3_2_2">
           <string>Buffer size</string>
          </property>
         </widget>
        </item>
         <widget class="QDoubleSpinBox" name="spinBufferSize"/>
        </item>
+       <item row="7" column="0">
         <widget class="QLabel" name="textLabel5_2_2_3">
          <property name="enabled">
           <bool>false</bool>
@@ -481,7 +390,7 @@
          </property>
         </widget>
        </item>
+       <item row="7" column="1">
         <widget class="QSpinBox" name="spinBufferTransparency">
           <bool>false</bool>
@@ -509,14 +418,14 @@
          </property>
         </widget>
        </item>
-       <item row="3" column="0" colspan="2">
+       <item row="8" column="0" colspan="2">
         <widget class="QPushButton" name="pbnDefaultBufferColor_2">
           <string>Color</string>
          </property>
         </widget>
        </item>
-       <item row="4" column="0" colspan="2">
+       <item row="9" column="0" colspan="2">
         <widget class="QGroupBox" name="groupBox_4">
           <string>Buffer size units</string>
@@ -539,475 +448,440 @@
          </layout>
         </widget>
        </item>
-        <spacer>
-         </property>
-          <size>
-           <width>20</width>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="page_3">
-        <widget class="QLabel" name="textLabel1_2_3_2">
-          <string>X Offset (pts)</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QDoubleSpinBox" name="spinXOffset">
-         <property name="minimum">
-          <double>-99.000000000000000</double>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel1_2_2_2_3">
-          <string>Y Offset (pts)</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QDoubleSpinBox" name="spinYOffset">
-         </property>
-        </widget>
-       </item>
+       <item row="10" column="0">
         <widget class="QGroupBox" name="buttonGroup10">
           <string>Offset units</string>
          </property>
+           <widget class="QDoubleSpinBox" name="spinXOffset">
+            <property name="minimum">
+             <double>-99.000000000000000</double>
+            </property>
+           </widget>
+          </item>
+          <item row="3" column="0">
+           <widget class="QLabel" name="textLabel1_2_3_2">
+             <string>X Offset (pts)</string>
+            </property>
+           </widget>
+          </item>
+          <item row="4" column="0">
+           <widget class="QDoubleSpinBox" name="spinYOffset">
+            </property>
+           </widget>
+          </item>
            <widget class="QRadioButton" name="radioOffsetUnitsPoints">
              <string>Points</string>
             </property>
            </widget>
           </item>
            <widget class="QRadioButton" name="radioOffsetUnitsMap">
              <string>Map units</string>
             </property>
            </widget>
           </item>
+           <widget class="QLabel" name="textLabel1_2_2_2_3">
+             <string>Y Offset (pts)</string>
+            </property>
+           </widget>
+          </item>
          </layout>
         </widget>
        </item>
-        <spacer>
+       <item row="12" column="0">
+        <widget class="QGroupBox" name="groupBox_5">
+          <string>Data defined placement</string>
          </property>
-          <size>
-           <width>20</width>
-           <height>181</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="page_4">
-      <layout class="QGridLayout" name="gridLayout_1">
-        <widget class="QLabel" name="lblFont">
-          <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
-          </sizepolicy>
-         </property>
-          <string>&amp;Font family</string>
-         </property>
-         <property name="buddy">
-          <cstring>cboFontField</cstring>
-         </property>
+         <layout class="QGridLayout" name="gridLayout_4">
+           <widget class="QLabel" name="textLabel1_2_2_2_2_3">
+             <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+             </sizepolicy>
+            </property>
+             <string>Placement</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboAlignmentField"/>
+          </item>
+           <widget class="QLabel" name="textLabel1_2_2_2_2">
+             </sizepolicy>
+            </property>
+             <string>Angle (deg)</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboAngleField"/>
+          </item>
+         </layout>
         </widget>
        </item>
-        <widget class="QComboBox" name="cboFontField">
-         <property name="minimumSize">
-          <size>
-           <width>0</width>
-          </size>
+       <item row="14" column="0">
+        <widget class="QGroupBox" name="groupBox_6">
+          <string>Data defined buffer</string>
          </property>
+         <layout class="QGridLayout" name="gridLayout_5">
+           <widget class="QLabel" name="textLabel1_3_2_2_2">
+            <property name="enabled">
+             <bool>false</bool>
+            </property>
+             </sizepolicy>
+            </property>
+            <property name="minimumSize">
+             <size>
+              <width>70</width>
+              <height>0</height>
+             </size>
+            </property>
+             <string>Transparency:</string>
+            </property>
+            <property name="buddy">
+             <cstring>cboBufferTransparencyField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboBufferTransparencyField">
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="textLabel4_3_2_2_2">
+             </sizepolicy>
+            </property>
+             <string>Size:</string>
+            </property>
+             <cstring>cboBufferSizeField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboBufferSizeField"/>
+          </item>
+         </layout>
         </widget>
        </item>
-        <widget class="QLabel" name="textLabel4">
-          </sizepolicy>
+       <item row="15" column="0">
+        <widget class="QGroupBox" name="groupBox_7">
+          <string>Data defined position</string>
          </property>
-          <string>&amp;Bold</string>
-         </property>
-          <cstring>cboBoldField</cstring>
-         </property>
+         <layout class="QGridLayout" name="gridLayout_6">
+           <widget class="QLabel" name="textLabel1_2">
+             </sizepolicy>
+            </property>
+             <string>X Coordinate</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboXCoordinateField"/>
+          </item>
+           <widget class="QLabel" name="textLabel1_2_2">
+             </sizepolicy>
+            </property>
+             <string>Y Coordinate</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboYCoordinateField"/>
+          </item>
+           <widget class="QLabel" name="textLabel1_2_3">
+             </sizepolicy>
+            </property>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboXOffsetField"/>
+          </item>
+           <widget class="QLabel" name="textLabel1_2_2_2">
+             </sizepolicy>
+            </property>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboYOffsetField"/>
+          </item>
+         </layout>
         </widget>
        </item>
-        <widget class="QComboBox" name="cboBoldField">
-          <size>
-           <width>0</width>
-          </size>
+       <item row="13" column="0">
+        <widget class="QGroupBox" name="groupBox">
+          <string>Data defined properties</string>
          </property>
+           <widget class="QLabel" name="lblFont">
+             </sizepolicy>
+            </property>
+             <string>&amp;Font family</string>
+            </property>
+             <cstring>cboFontField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboFontField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4">
+             </sizepolicy>
+            </property>
+             <string>&amp;Bold</string>
+            </property>
+             <cstring>cboBoldField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboBoldField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4_2_4">
+             </sizepolicy>
+            </property>
+             <string>&amp;Italic</string>
+            </property>
+             <cstring>cboItalicField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboItalicField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4_3">
+             </sizepolicy>
+            </property>
+             <string>&amp;Underline</string>
+            </property>
+             <cstring>cboUnderlineField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboUnderlineField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4_3_2">
+             </sizepolicy>
+            </property>
+             <string>&amp;Size</string>
+            </property>
+             <cstring>cboFontSizeField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboFontSizeField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4_3_2_4">
+             </sizepolicy>
+            </property>
+             <string>Size units</string>
+            </property>
+             <cstring>cboFontSizeTypeField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboFontSizeTypeField"/>
+          </item>
+           <widget class="QLabel" name="textLabel4_3_2_3">
+            </property>
+             </sizepolicy>
+            </property>
+             <string>Transparency</string>
+            </property>
+             <cstring>cboFontTransparencyField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboFontTransparencyField">
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="textLabel4_3_2_5">
+             </sizepolicy>
+            </property>
+             <string>&amp;Color</string>
+            </property>
+             <cstring>cboFontColorField</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="cboFontColorField"/>
+          </item>
+         </layout>
         </widget>
        </item>
-        <widget class="QLabel" name="textLabel4_2_4">
-          </sizepolicy>
-         </property>
-          <string>&amp;Italic</string>
-         </property>
-          <cstring>cboItalicField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboItalicField">
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel4_3">
-          </sizepolicy>
-         </property>
-          <string>&amp;Underline</string>
-         </property>
-          <cstring>cboUnderlineField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboUnderlineField">
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel4_3_2">
-          </sizepolicy>
-         </property>
-          <string>&amp;Size</string>
-         </property>
-          <cstring>cboFontSizeField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboFontSizeField">
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel4_3_2_4">
-          </sizepolicy>
-         </property>
-          <string>Size units</string>
-         </property>
-          <cstring>cboFontSizeTypeField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboFontSizeTypeField">
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="0">
-        <widget class="QLabel" name="textLabel4_3_2_3">
-         <property name="enabled">
-          <bool>false</bool>
-         </property>
-          </sizepolicy>
-         </property>
-          <string>Transparency</string>
-         </property>
-          <cstring>cboFontTransparencyField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboFontTransparencyField">
-         </property>
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
-       <item row="7" column="0">
-        <widget class="QLabel" name="textLabel4_3_2_5">
-          </sizepolicy>
-         </property>
-          <string>&amp;Color</string>
-         </property>
-          <cstring>cboFontColorField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboFontColorField">
-          <size>
-           <width>0</width>
-          </size>
-         </property>
-        </widget>
-       </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="page_5">
-        <widget class="QLabel" name="textLabel1_2_2_2_2_3">
-          </sizepolicy>
-         </property>
-          <string>Placement</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboAlignmentField"/>
-       </item>
-        <widget class="QLabel" name="textLabel1_2_2_2_2">
-          </sizepolicy>
-         </property>
-          <string>Angle (deg)</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboAngleField"/>
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="page_6">
-        <widget class="QLabel" name="textLabel1_3_2_2_2">
-         </property>
-          </sizepolicy>
-         </property>
-          <size>
-           <width>70</width>
-           <height>0</height>
-          </size>
-         </property>
-          <string>Transparency:</string>
-         </property>
-          <cstring>cboBufferTransparencyField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboBufferTransparencyField">
-         </property>
-        </widget>
-       </item>
-        <widget class="QLabel" name="textLabel4_3_2_2_2">
-          </sizepolicy>
-         </property>
-          <string>Size:</string>
-         </property>
-          <cstring>cboBufferSizeField</cstring>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboBufferSizeField"/>
-       </item>
-      </layout>
-     </widget>
-     <widget class="QWidget" name="page_7">
-        <widget class="QLabel" name="textLabel1_2">
-          </sizepolicy>
-         </property>
-          <string>X Coordinate</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboXCoordinateField"/>
-       </item>
-        <widget class="QLabel" name="textLabel1_2_2">
-          </sizepolicy>
-         </property>
-          <string>Y Coordinate</string>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboYCoordinateField"/>
-       </item>
-        <widget class="QLabel" name="textLabel1_2_3">
-          </sizepolicy>
-         </property>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboXOffsetField"/>
-       </item>
-        <widget class="QLabel" name="textLabel1_2_2_2">
-          </sizepolicy>
-         </property>
-         </property>
-        </widget>
-       </item>
-        <widget class="QComboBox" name="cboYOffsetField"/>
-       </item>
-      </layout>
-     </widget>
     </widget>
    </item>
+    <widget class="QGroupBox" name="groupBox5">
+      </sizepolicy>
+     </property>
+     <property name="maximumSize">
+      <size>
+       <width>800</width>
+       <height>200</height>
+      </size>
+     </property>
+      <string>Preview:</string>
+     </property>
+       <number>11</number>
+      </property>
+       <widget class="QLabel" name="lblSample">
+         <string>QGIS Rocks!</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
   </layout>
  </widget>
  <tabstops>
   <tabstop>cboLabelField</tabstop>
   <tabstop>leDefaultLabel</tabstop>
-  <tabstop>listWidget</tabstop>
   <tabstop>btnDefaultFont</tabstop>
   <tabstop>spinFontSize</tabstop>
   <tabstop>pbnDefaultFontColor</tabstop>
@@ -1023,56 +897,16 @@
   <tabstop>radioBelowRight</tabstop>
   <tabstop>radioFontSizeUnitsPoints</tabstop>
   <tabstop>radioFontSizeUnitsMap</tabstop>
-  <tabstop>chkUseScaleDependentRendering</tabstop>
   <tabstop>spinMinimumScale</tabstop>
   <tabstop>spinMaximumScale</tabstop>
-  <tabstop>chkUseMultiline</tabstop>
-  <tabstop>spinXOffset</tabstop>
-  <tabstop>spinYOffset</tabstop>
   <tabstop>radioOffsetUnitsPoints</tabstop>
   <tabstop>radioOffsetUnitsMap</tabstop>
-  <tabstop>cboFontField</tabstop>
-  <tabstop>cboBoldField</tabstop>
-  <tabstop>cboItalicField</tabstop>
-  <tabstop>cboUnderlineField</tabstop>
-  <tabstop>cboFontSizeField</tabstop>
-  <tabstop>cboFontTransparencyField</tabstop>
-  <tabstop>cboAlignmentField</tabstop>
-  <tabstop>cboAngleField</tabstop>
-  <tabstop>cboBufferTransparencyField</tabstop>
-  <tabstop>cboBufferSizeField</tabstop>
-  <tabstop>cboXCoordinateField</tabstop>
-  <tabstop>cboYCoordinateField</tabstop>
-  <tabstop>cboXOffsetField</tabstop>
-  <tabstop>cboYOffsetField</tabstop>
-  <tabstop>chkUseBuffer</tabstop>
-  <tabstop>spinBufferSize</tabstop>
-  <tabstop>spinBufferTransparency</tabstop>
   <tabstop>radioBufferUnitsPoints</tabstop>
   <tabstop>radioBufferUnitsMap</tabstop>
-  <tabstop>pbnDefaultBufferColor_2</tabstop>
-  <tabstop>cboFontSizeTypeField</tabstop>
-  <tabstop>cboFontColorField</tabstop>
  </tabstops>
  <resources/>
  <connections>
   <connection>
-   <sender>listWidget</sender>
-   <signal>currentRowChanged(int)</signal>
-   <receiver>stackedWidget</receiver>
-   <slot>setCurrentIndex(int)</slot>
-   <hints>
-    <hint type="sourcelabel">
-     <x>121</x>
-     <y>72</y>
-    </hint>
-    <hint type="destinationlabel">
-     <x>269</x>
-     <y>54</y>
-    </hint>
-   </hints>
-  </connection>
-  <connection>
    <sender>chkUseBuffer</sender>
    <signal>clicked(bool)</signal>
    <receiver>spinBufferTransparency</receiver>
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -7,7 +7,7 @@
     <x>0</x>
     <y>0</y>
     <width>703</width>
-    <height>494</height>
+    <height>518</height>
    </rect>
   </property>
@@ -195,6 +195,19 @@
          <widget class="QComboBox" name="mSymbolComboBox"/>
         </item>
+         <spacer name="verticalSpacer_2">
+          </property>
+           <size>
+            <width>20</width>
+            <height>40</height>
+           </size>
+          </property>
+         </spacer>
+        </item>
        </layout>
       </widget>
      </item>
@@ -383,6 +396,19 @@
          </layout>
         </widget>
        </item>
+       <item>
+        <spacer name="verticalSpacer">
+         </property>
+          <size>
+           <width>20</width>
+          </size>
+         </property>
+        </spacer>
+       </item>
       </layout>
      </item>
     </layout>
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui	2009-11-11 21:37:52 UTC (rev 12094)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui	2009-11-11 22:06:32 UTC (rev 12095)
@@ -7,13 +7,13 @@
     <x>0</x>
     <y>0</y>
     <width>678</width>
-    <height>600</height>
+    <height>500</height>
    </rect>
   </property>
    <size>
     <width>0</width>
    </size>
   </property>
More information about the QGIS-commit mailing list
