[QGIS Commit] r12099 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Nov 13 07:16:52 EST 2009
Author: dassau
Date: 2009-11-13 07:16:51 -0500 (Fri, 13 Nov 2009)
New Revision: 12099
Added:
docs/trunk/english_us/user_guide/plugins_openstreetmap.tex
docs/trunk/english_us/user_guide/plugins_openstreetmap_images/
docs/trunk/english_us/user_guide/user_guide.tex
added osm plugin text - clean up and images follow
Added: docs/trunk/english_us/user_guide/plugins_openstreetmap.tex
--- docs/trunk/english_us/user_guide/plugins_openstreetmap.tex (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_openstreetmap.tex 2009-11-13 12:16:51 UTC (rev 12099)
@@ -0,0 +1,513 @@
+% vim: set textwidth=78 autoindent:
+\subsection{OpenStreetMap Plugin}
+% when the revision of a section has been finalized,
+% comment out the following line:
+% \updatedisclaimer
+In recent years OpenStreetMap project has gained popularity because in many
+countries there were no freely available digital roadmaps. Target of the OSM
+project is to create a free editable map of the world from GPS data, aerial
+photography or simply from local knowledge. To support this idea we decided
+to create a plugin for QuantumGIS software that enables its users to work
+with OSM data.
+The plugin is a part of Qgis-mapper project and provides all basic
+functionalities for OSM data manipulation, such as data loading, importing,
+saving, downloading, editing and uploading back to OpenStreetMap server.
+While implementing OSM plugin an inspiration was taken from existing OSM data
+editors. The purpose was to combine their functionalities to get the best
+possible result.
+The following two sections gives you brief introduction to principles of both
+aforementioned projects. If you are not interested in information on OSM and
+QGIS just skip both sections. Parts of the following few paragraphs are
+copied from the OpenStreetMap web site.
+\minisec{The OpenStreetMap project}
+OpenStreetMap is a project to create a free editable map of the world. The
+maps are created using data from portable GPS devices, aerial photography,
+other free sources or simply from local knowledge. The project was started
+because most maps have legal or technical restrictions on their use, holding
+back people from using them in creative, productive, or unexpected ways. Both
+rendered images and the vector dataset of OSM are available for download
+under a Creative Commons Attribution ShareAlike 2.0 licence.
+OpenStreetMap was inspired by sites such as Wikipedia - the map display
+features a prominent 'Edit' tab and a full revision history is maintained.
+Registered users can upload GPS track logs and edit the vector data using the
+given editing tools.
+OSM data primitive is an object class that can be stored via the API in the
+server. Three types of data primitives are supported: Node, Way and Relation.
+A node is a latitude/longitude pair. It is used as building block for other
+features and as features themselves (Points Of Interest) if they're tagged as
+required. A way is a list of at least two nodes that describe a linear
+feature such as a street, or similar. Nodes can be members of multiple ways.
+A relation is a group of zero or more primitives with associated roles. It is
+used to specify relationships between objects, and may also model an abstract
+object.
+Several different logical things in common map (like 'Point Of Interest',
+'Street', 'Tram Line', 'Bus Stop' etc.) are defined out of these primitives
+by specifying appropriate "Map Features". Map features are well-known in OSM
+community and are stored as pairs of a key and a value - tags. OSM is
+usually distibuted in XML format. XML payload is used for communication with
+OSM server also.
+For more information visit the project website at:
+\url{http://www.openstreetmap.org}.
+\subsubsection{QGIS - OSM Connection}\label{qgis-osm-connection}
+There were some questions while designing OSM and QGIS connection. In
+this guide first of all we show the way how OSM data primitives are displayed
+in QGIS vector layers.
+OSM data consists of Nodes, Ways and Relations. In our design they are
+displayed in three QGIS layers: Point layer, Line layer and Polygon layer.
+It's not possible to remove any of these layers and work with the other ones.
+Point layer displays all features of type Node that stands alone. That means
+that only Nodes that are not included in any Way belongs to the Point layer.
+Line layer displays those OSM features of type Way that are not closed. That
+means that none of these Ways starts and ends with the same Node.
+Polygon layer displayes all Ways that are not included in Line layer.
+OpenStreetMap has one more data primitive except for the three mentioned
+above - Relation. In our design there is purposely no vector layer to display
+Relations. Relation defines relation between any number of data primitives.
+After Point, Line or Polygon is identified on map, plugin shows a list of all
+relations the identified feature is part of.
+A problem was discovered when designing interconnection between OSM data and
+standard QGIS editing tools. Those tools are made to edit single vector layer
+at a time, no matter of what feature types it displays. It means that if OSM
+data are loaded to QGIS through the plugin, you could (theoretically) edit
+Point layer, Line layer or Polygon layer with these standard tools
+separately.
+The problem is that Line layer consists of two different types of OSM
+features - Ways and Nodes. Why? Because in OSM format Way is composed of
+Nodes. If you start editing of Line layer and change the shape of some line,
+your action must affect not only the OSM Way but also OSM Nodes that are part
+of it. But QGIS standard editing cannot tell the OSM Provider which members
+of which line has changed and how. It can tell only what's the new geometry
+of which line and that's not enough to propagate changes to OSM database
+correctly. The Line layer doesn't even know identifiers of line members.
+The same problem occurs when you try to edit the Polygon layer.
+For this reason plugin has its own simple tools for editing OSM data. While
+they are used plugin can react on every moving, removing or adding of
+line/polygon member and so it can change OSM data correctly. Plugin editing
+set consists of tools for Point, Line, Polygon and Relation creation,
+deletion and moving.
+To create the real connection between OSM plugin and standard editing tools,
+changes in QuantumGIS core code would be necessary.
+\subsubsection{Installation}
+Plugin is used inside QuantumGIS environment, so obviously it's necessary to
+install QGIS first. After that you must build some parts of the plugin. Here
+are the steps required to use OpenStreetMap plugin:
+\begin{enumerate}
+\item You have to have python support enabled in QuantumGIS
+\item Download the plugin package and unpack it to ~/.qgis/python/plugins.
+You should have the plugin inside the directory now.
+\item cd ~/.qgis/python/plugins/osmplugin
+\item make
+\end{enumerate}
+Now you should be able to use the plugin by starting QGIS and enabling it in
+the Plugin manager. Just search for the name: "OpenStreetMap plugin".
+\subsubsection{Basic user interface}
+The first time OSM plugin is started (and after the first data are loaded),
+something like the following should show up:
+As you can see plugin consists of few graphic components.
+Here is brief information on them:
+\textbf{OSM Features}
+Dockable widget that helps QGIS user with OSM feature identification. It
+shows basic information on features type and identifier as well as info on
+who and when changed feature lately. OSM Feature widget holds all editing
+tools also (in the top part of it). More information on those tools can be
+found in section focused on editing. Widget is initially disabled. It
+activates itself after successfull loading of some OSM data.
+\textbf{OSM Undo / Redo}
+Dockable widget intended to help user with reverting edit actions. It
+consists not only of clasical Undo button and Redo button, it shows even list
+of brief description of edit actions that were done. OSM Undo / Redo widget
+is initially closed. You can show it using special button on OSM Feature
+widget.
+\textbf{Tool buttons}
+\begin{description}
+\item Load OSM from file: used to show dialog for loading data from special
+OpenStreetMap XML file
+\item Show/Hide OSM Feature Manager: to show or hide OSM Feature widget; OSM
+Feature widget is panel that helps with OSM feature identification and with
+OSM data editing
+\item Download OSM data: used to show dialog purpose of which is to help user
+to download data from the OpenStreetMap server
+\item Upload OSM data: to show dialog for uploading changes (on current data)
+Import data from a layer: to show dialog for importing data from a vector
+layer; at least one vector layer must be loaded and current OSM data must be
+selected
+\item Save OSM to file: to show dialog purpose of which is to help user with
+saving OSM data back to XML file
+\end{description}
+More detailed information on all the widgets, buttons and dialogs can be
+found in appropriate sections of this Guide according to their functionality
+(editing, identification, etc.).
+\subsubsection{Loading OSM data}
+The first action that should be done after starting OSM Plugin is opening
+data from OSM file, import them from the shapefile or downloading data from
+OpenStreetMap server. Here we are focusing on the first mentioned action.
+To load data from file use the 'Load OSM from file' tool button. If there
+is no such button, maybe someone disabled OpenStreetMap toolbar in your QGIS
+instalation. You can enable it at Settings -> Toolbars -> OpenStreetMap.
+After using the button following dialog should show up.
+Purpose of its elements is explained below.
+\item OpenStreetMap file to load: Click on the button to select the .osm file you want to load data from.
+\item Add columns for tags: This option determines inter-connection between OSM and QGIS data. Each
+feature of OSM data has some tags (pairs of key and value), that define
+feature properties. Each feature of QGIS vector layer has its attributes (key
+and value also). With this option you can define which properties of OSM
+objects should be visible when displaying detailed info about QGIS features.
+\item Replace current data
+Checking this option means that new data should replace current data user is
+working with. Layers of current data will be removed and new ones will be
+loaded. When loading first OSM data, this option is not active, because there
+is nothing to replace.
+\item Use custom renderer
+Option determines how rich will be the map in detail. The are three
+pre-defined OSM styles for map displaying. Use 'Small scale' if you want to
+view OSM data at low level, to see all details and to edit something. If not
+you can use 'Medium scale' or 'Large scale'. At present days QGIS doesn't
+support changing renderer style dynamically.
+\end{description}
+Click \button{Ok} to load your data. If this is the first time OSM
+file is loaded, plugin must first parse it into database.
+This may take few seconds or minutes - it depends on amount of loaded data.
+\subsubsection{Viewing OSM data}
+After OSM data were loaded you can identify map features using the
+appropriate tool. Use Identify feature button on the top-left of OSM
+Feature widget. Using this tool you can easily explore map objects.
+When mouse cursor is over an object, you can see all information on it
+directly in the OSM Feature widget. There is also dynamic rubberband
+displayed on the map so that user was able to determine which feature is
+currently identified.
+Properties table of the widget contains of all feature tags.
+Clicking on the Relation tab shows you list of all relations connected with
+identified feature.
+If you want to hold a feature for a while to be able to read it's properties,
+relations and move mouse cursor at the same time, try left-clicking while you
+are over it. Identifyication process will become paused til next
+left-clicking.
+Sometimes there are more than one feature at the point where left-clicking
+was performed. This happens especially when clicking on cross-roads or if map
+is not zoomed-in sufficiently. In this situation only one of such features is
+identified (and marked with rubberband) but plugin remembers all of them.
+Then (still in the pause mode) you can change identified features cyclical
+with right-clicking.
+\subsubsection{Editing basic OSM data}
+In the title of this section 'basic data' means non-relation OSM features -
+nodes and ways. If you prefer reading information on relations editing just
+skip this section and read the next one.
+Basic data editing is key part of OSM Plugin. You can change property,
+position or shape of any existing basic feature, you can remove features or
+add some new ones. All such changes on nodes and ways are remembered - both
+for comfortable usage of Undo/Redo operations and for easy upload of changes
+to OpenStreetMap server.
+\minisec{Changing feature tags}
+Changing property/tag of OSM feature can be done directly in table of feature
+tags. Tags table of basic feature can be found on OSM Feature widget. Don't
+forget to identify feature first.
+If you want to change tag value, just double-click in the appropriate row of
+column Value and type or select new value. If you want to remove tag click in
+its row, then use button on the right under the table - "Remove selected
+tags"
+To add new tag just type its key and value into the last row of the table -
+where "<next tag value>" is written. Notice that you cannot change key of
+existing tag pair. For comfortable usage there are some combo boxes of all
+existing tag keys and their typical values.
+\minisec{Point creation}
+For point creation there is a 'Create point' button on OSM Feature widget
+To create some points just click on the button and start clicking on the map.
+If your cursor is over some map feature, the feature is marked/identified
+immediately. If you click on the map when line/polygon is marked, new point
+is created directly on such line/polygon - as its new member.
+If your cursor is over an existing point, new point cannot be created.
+In such case OSM plugin will tell you:
+The mechanism of helping user to hit the line or polygon is called snapping
+and is enabled by default. If you want to create point very close to some
+line (but not on it) you must disable snapping by holding Ctrl key first.
+\minisec{Line creation}
+For line creation there is 'Create line' button on OSM Feature widget
+To create a line just click the button and start left-clicking on the map.
+Each your left-click is remembered as member vertex of new line. Line
+creation ends when first right-click is performed. New line will immediately
+appear on the map.
+Line with less than two members cannot be created. In such case operation is
+ignored.
+Snapping is performed to all map vertexes - points from Point vector layer
+and all Line and Polygon members.
+Snapping can be disabled by holding Ctrl key.
+\minisec{Polygon creation}
+For polygon creation there is 'Create polygon' button on OSM Feature widget
+To create a polygon just click the button and start left-clicking on the map.
+Each your left-click is remembered as member vertex of new polygon. Polygon
+creation ends when first right-click is performed. New polygon will
+immediately appear on the map.
+Polygon with less than three members cannot be created. In such case
+operation is ignored.
+Snapping is performed to all map vertexes - points (from Point vector layer)
+\minisec{Map feature moving}
+If you want to move a feature (no matter what's its type) please use the
+"Move feature" button from OSM Feature widget menu. Then you can browse the
+map (features are identified dynamically when you go over them) and click
+on the feature you want to move. If wrong feature is
+selected after your click, don't move from the place. Repeat right-clicking
+till the right feature is identified. When selection is done and you move
+cursor you are no more able to change your decision what to move.
+To confirm moving click with left mouse button.
+To cancel moving click with another one.
+If you are moving a feature that is connected to other features, these
+connections won't be damaged. Other features will just adapt themselves to
+new position of moved feature.
+Snapping is supported in this operation.
+When moving a standalone (not part of any line/polygon) point, snapping to
+all map segments and vertexes is performed.
+When moving a point that is member of some lines/polygons, snapping to all
+map segments and vertexes is performed, except for vertexes of point parents.
+When moving a line/polygon, snapping to all map vertexes is performed. Note
+that OSM Plugin tries to snap only 3 closest-to-cursor vertexes of moved
+line/polygon, otherwise operation would by very slow.
+Snapping can be disabled by holding Ctrl key during the operation.
+\minisec{Map feature removing}
+If you want to remove feature, you must identify it first.
+To remove identified feature use "Remove this feature" button on OSM Feature
+widget
+When removing a line/polygon, the line/polygon itself is deleted, so are all
+its member points that doesn't belong to any other line/polygon.
+When removing a point that is member of some lines/polygons, point is deleted
+and geometries of parent lines/polygons are changed. New parent geometries
+has less vertexes than the old ones.
+If parent was a polygon with three vertexes, its new geometry has only two
+vertexes. And because there cannot exist polygon with only two vertexes,
+feature type is automatically changed to Line.
+If parent was a line with two vertexes, its new geometry has only one vertex.
+And because there cannot exist line with only one vertex, feature type is
+automatically changed to Point.
+\minisec{Editing relations}
+Thanks to existency of OSM relations we can join OSM features into groups and
+give them common properties - in such way we can model any possible map
+object: borders of a region (as group of ways and points), road of a bus,
+etc. Each member of relation has its specific role.
+There is a pretty good support for OSM Relations in our plugin.
+Let's see how to examine, create, update or remove them.
+\minisec{Examining relation}
+If you want to see relation properties, first identify one of its members.
+After that open tab "Relations" on OSM Feature widget. At the top of the tab
+you can see a list of all relations the identified feature is part of. Please
+choose the one you want to examine and look at information thereunder.
+In the first table called "Relation tags" there are properties of selected
+relation.
+In table called "Relation members" you can see brief info on relation
+members.
+If you click on a member, plugin will make a rubberband on it in map.
+\minisec{Relation creation}
+There are 2 ways of creating a relation.
+First you can use the button on OSM Feature widget
+Second you can create it from the Relation tab of OSM Feature widget by using
+special button
+In both cases dialog will appear. In second case feature that is currently
+identified is automatically considered to be the first relation member, so
+dialog is pre-filled a little.
+When creating relation please select its type first. You can select one of
+predefined relation types or write your own type. After that fill relation
+tags and choose its members.
+If you have relation type already selected try using button with "Generate
+tags" label . It will generate typical tags to your relation type. Then you
+are expected to enter values to the keys.
+Choosing relation members can be done either simply by writting member
+identifiers, types and roles or by using an identify tool and clicking
+on map.
+Finally when type, tags and members are chosen dialog can be submitted - in
+such case plugin creates new relation for you.
+\minisec{Changing relation}
+If you want to change an existing relation, identify it first (follow steps
+written above in Examining relation). After that click the "Edit relation"
+button, you will find it on OSM Feature widget
+Special dialog appears, nearly the same as for Create relation action.
+The dialog is pre-filled with information on given relation. You can change
+relation tags, members or even its type. After submiting the dialog your
+changes will be commited.
+\subsubsection{Downloading OSM data}
+To download data from OpenStreetMap server click 'Download OSM data' button
+If there is no such button, OSM toolbar is disabled in your QGIS instalation.
+You can enable it again at Settings->Toolbars->OpenStreetMap.
+After clicking the button following dialog will appear:
+\item Extent: Specifies area to download data from - intervals of latitude
+and longitude degrees. Because there is some restriction of OpenStreetMap
+server on how much data can be downloaded, the intervals mustn't be too
+wide. More detailed info on extent specification can is shown after
+clicking the help button on the right.
+\item Download to:
+Here you are expected to write path to the file where data will be stored. If
+you can't remember structure of your disk, don't panic. The browse button
+will help you.
+\item Open data automatically after download
+Determines if download process should be followed by loading data process or
+not. If you prefer not to load data now, you can do it later by using 'Load
+OSM from file'.
+This option is active only if the 'Open data automatically after download' is
+checked. Checking this option means that downloaded data should replace
+current data we are working with now. Layers of current data will be removed
+and new ones will be loaded. When starting QGIS and downloading first data
+this option is initially inactive, because there is nothing to replace.
+checkbox is checked. It determines how rich will be the map in detail. The
+are three predefined OSM styles for map displaying. Use 'Small scale' if you
+want to view OSM data at low level, to see all details and to edit something.
+If not you can use 'Medium scale' or 'Large scale'. At present days QGIS
+doesn't support changing renderer style dynamically.
+\end{description}
+Click Download to start download process.
+A progress dialog will continuously inform you about how much of data is
+already downloaded. When an error occure during download process dialog tell
+you its details. When action finishes succesfully both the progress dialog
+and download dialog will close themselves.
+\subsubsection{Uploading OSM data}
+Note that upload is always done on current OSM data. Before opening OSM
+Upload dialog, please be sure that you really have the right active layer ~
+OSM data.
+To upload current data to OSM server click on \button{Upload OSM data} button .
+If there is no such button, OSM toolbar in your QuantumGIS instalation is
+disabled. You can enable it again at Settings->Toolbars->OpenStreetMap.
+After clicking on upload button following dialog will appear:
+At the top of dialog you can check if you are uploading correct data. There
+is a short name of current database. In the table there is information on how
+many changes will be uploaded. Statistics are displayed separately for each
+feature type.
+In 'Comment on your changes' box you can write brief information on meaning
+of your upload operation. Just write in brief what data changes you've done
+or let the box empty.
+Fill 'OSM account' arrays so that server could authenticate you. If you don't
+have account on OSM server, it's the best time to create one. Please visit
+www.openstreetmap.org.
+Use Upload to start an upload operation.
+\subsubsection{Saving OSM data}
+To save data from current map extent to XML file click on
+\button{Save OSM to file} button.
+disabled. You can enable it again at Settings -> Toolbars -> OpenStreetMap.
+After click on the button the following dialog will appear:
+Select features you want to save into XML file and the file itself.
+Use Ok button to start the operation.
+The process will create an XML file, in which OSM data from your current map
+extent are represented. OSM version of the output file is 0.6. Elements of
+OSM data (<node>, <way>, <relation>) do not contain information on their
+changesets and uids. These informations are not compulsory yet, see DTD for
+OSM XML version 0.6.
+In the output file OSM elements are not ordered.
+Notice that not only data from current extent are saved. Into the output file
+the whole polygons and lines are saved even if only small part of them is
+visible in current extent. For each saved line/polygon all its member nodes
+are saved too.
+\subsubsection{Import OSM data}
+To import OSM data from opened non-OSM vector layer follow this instructions:
+Choose current OSM data by clicking on one of their layers.
+Click on \button{Import data from a layer} button .
+If there is no such button, someone has disable OpenStreetMap toolbar in your
+QuantumGIS instalation. You can enable it again at
+Settings -> Toolbars -> OpenStreetMap.
+After clicking on button following message may show up:
+In such case there is no vector layer currently loaded. Import must be done
+from an opened layer - please open vector layer from which you want to import
+data. After layer is opened your second try should give you better result
+(don't forget to mark current OSM layer again):
+Submit dialog to start the process of OSM data importing.
+Reject it if you are not sure you want to import something.
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2009-11-13 08:47:58 UTC (rev 12098)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2009-11-13 12:16:51 UTC (rev 12099)
@@ -26,20 +26,21 @@
%in the plugins chapter
\include{plugins}
\include{core_plugins}
-\include{plugins_delimited_text}
\include{plugins_coordinate_capture}
\include{plugins_decorations}
+\include{plugins_delimited_text}
\include{plugins_dxf2shape_converter}
+\include{plugins_evis}
+\include{plugins_ftools}
\include{plugins_georeferencer}
-\include{plugins_quick_print}
\include{plugins_gps}
-\include{plugins_ftools}
\include{plugins_interpolation}
-\include{plugins_raster_terrain}
\include{plugins_mapserver_export}
\include{plugins_ogr_converter}
\include{plugins_oracle_raster}
-\include{plugins_evis}
+\include{plugins_openstreetmap}
+\include{plugins_raster_terrain}
+\include{plugins_quick_print}
\include{other_core_plugins}
\include{external_plugins}
%\include{plugins_ftools}
