[QGIS Commit] r12106 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sat Nov 14 12:24:40 EST 2009
Author: timlinux
Date: 2009-11-14 12:24:39 -0500 (Sat, 14 Nov 2009)
New Revision: 12106
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
First implementation of property lists for vector props dialog. Still needs icon for the property list and vertical resizing is currently not working as it should (on my todo list to fix).
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-11-14 17:11:45 UTC (rev 12105)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-11-14 17:24:39 UTC (rev 12106)
@@ -137,12 +137,13 @@
for ( ; it != overlayPluginList.constEnd(); ++it )
QgsApplyDialog* d = ( *it )->dialog( lyr );
- position = tabWidget->addTab( d, ( *it )->name() );
- tabWidget->setCurrentIndex( position ); //ugly, but otherwise the properties dialog is a mess
+ position = stackedWidget->insertWidget( stackedWidget->count(), qobject_cast<QDialog*>( d ) );
+ stackedWidget->setCurrentIndex( position ); //ugly, but otherwise the properties dialog is a mess
mOverlayDialogs.push_back( d );
+ listWidget->insertItem( stackedWidget->count(), ( *it )->name() );
- tabWidget->setCurrentIndex( 0 );
+ stackedWidget->setCurrentIndex( 0 );
} // QgsVectorLayerProperties ctor
void QgsVectorLayerProperties::loadRows()
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2009-11-14 17:11:45 UTC (rev 12105)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2009-11-14 17:24:39 UTC (rev 12106)
@@ -6,29 +6,22 @@
<rect>
<x>0</x>
<y>0</y>
- <width>678</width>
- <height>500</height>
+ <width>768</width>
+ <height>498</height>
</rect>
</property>
- <property name="minimumSize">
- <size>
- <width>0</width>
- </size>
- </property>
<property name="windowTitle">
<string>Layer Properties</string>
</property>
<property name="windowIcon">
<iconset>
- <normaloff/>
- </iconset>
+ <normaloff>../../../../../.designer/backup</normaloff>../../../../../.designer/backup</iconset>
</property>
<property name="modal">
<bool>true</bool>
</property>
- <layout class="QGridLayout">
- <item row="1" column="0">
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0" rowspan="2" colspan="2">
<layout class="QHBoxLayout">
<property name="spacing">
<number>3</number>
@@ -36,77 +29,77 @@
<property name="margin">
<number>1</number>
</property>
- <item>
- <widget class="QPushButton" name="pbnLoadDefaultStyle">
- <property name="text">
- <string>Restore Default Style</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="pbnSaveDefaultStyle">
- <string>Save As Default</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="pbnLoadStyle">
- <string>Load Style ...</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="pbnSaveStyleAs">
- <string>Save Style ...</string>
- </property>
- </widget>
- </item>
</layout>
</item>
- <item row="3" column="0">
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
+ <item row="1" column="1">
+ <widget class="QScrollArea" name="scrollArea">
+ <property name="widgetResizable">
+ <bool>true</bool>
</property>
- <property name="standardButtons">
- <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
- </property>
+ <widget class="QWidget" name="scrollAreaWidgetContents">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>194</width>
+ <height>404</height>
+ </rect>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_10">
+ <property name="margin">
+ <number>0</number>
+ </property>
+ <item row="0" column="0">
+ <widget class="QListWidget" name="listWidget">
+ <property name="iconSize">
+ <size>
+ <width>64</width>
+ <height>64</height>
+ </size>
+ </property>
+ <item>
+ <property name="text">
+ <string>Symbology</string>
+ </property>
+ </item>
+ <item>
+ <string>Labels</string>
+ </property>
+ </item>
+ <item>
+ <string>Attributes</string>
+ </property>
+ </item>
+ <item>
+ <string>General</string>
+ </property>
+ </item>
+ <item>
+ <string>Metadata</string>
+ </property>
+ </item>
+ <item>
+ <string>Actions</string>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
- <item row="0" column="0">
- <widget class="QTabWidget" name="tabWidget">
- <property name="enabled">
- <bool>true</bool>
- </property>
- <property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="autoFillBackground">
- <bool>false</bool>
- </property>
- <property name="tabShape">
- <enum>QTabWidget::Rounded</enum>
- </property>
+ <item row="0" column="2" rowspan="2" colspan="4">
+ <widget class="QStackedWidget" name="stackedWidget">
<property name="currentIndex">
<number>3</number>
</property>
- <widget class="QWidget" name="tab2">
- </sizepolicy>
- </property>
- <attribute name="title">
- <string>Symbology</string>
- </attribute>
+ <widget class="QWidget" name="page_3">
+ <layout class="QGridLayout" name="gridLayout_4">
<widget class="QLabel" name="legendtypelabel">
@@ -209,11 +202,8 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab4">
- <string>Labels</string>
- </attribute>
+ <widget class="QWidget" name="page_4">
+ <layout class="QGridLayout" name="gridLayout_5">
<widget class="QCheckBox" name="labelCheckBox">
@@ -248,101 +238,94 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab6">
- <string>Attributes</string>
- </attribute>
- <layout class="QGridLayout" name="gridLayout">
+ <widget class="QWidget" name="page_5">
+ <layout class="QGridLayout" name="gridLayout_6">
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QToolButton" name="mAddAttributeButton">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
- </sizepolicy>
- </property>
- <property name="toolTip">
- <string>New column</string>
- </property>
- <string/>
- </property>
- <property name="icon">
- <iconset>
- <normaloff>../xpm/new_attribute.png</normaloff>../xpm/new_attribute.png</iconset>
- </property>
- <property name="shortcut">
- <string>Ctrl+N</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mDeleteAttributeButton">
- <string>Delete column</string>
- </property>
- <string/>
- </property>
- <iconset>
- <normaloff>../xpm/delete_attribute.png</normaloff>../xpm/delete_attribute.png</iconset>
- </property>
- <string>Ctrl+X</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mToggleEditingButton">
- <string>Toggle editing mode</string>
- </property>
- <property name="whatsThis">
- <string>Click to toggle table editing</string>
- </property>
- <string/>
- </property>
- <property name="checkable">
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mCalculateFieldButton">
- <string>Field calculator</string>
- </property>
- </property>
- <string/>
- </property>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>658</width>
- <height>19</height>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
+ <widget class="QToolButton" name="mAddAttributeButton">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="toolTip">
+ <string>New column</string>
+ </property>
+ <string/>
+ </property>
+ <property name="icon">
+ <iconset>
+ <normaloff>../../../../../.designer/xpm/new_attribute.png</normaloff>../../../../../.designer/xpm/new_attribute.png</iconset>
+ </property>
+ <property name="shortcut">
+ <string>Ctrl+N</string>
+ </property>
+ </widget>
</item>
+ <item row="0" column="1">
+ <widget class="QToolButton" name="mDeleteAttributeButton">
+ <string>Delete column</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>
+ <normaloff>../../../../../.designer/xpm/delete_attribute.png</normaloff>../../../../../.designer/xpm/delete_attribute.png</iconset>
+ </property>
+ <string>Ctrl+X</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2">
+ <widget class="QToolButton" name="mToggleEditingButton">
+ <string>Toggle editing mode</string>
+ </property>
+ <property name="whatsThis">
+ <string>Click to toggle table editing</string>
+ </property>
+ <string/>
+ </property>
+ <property name="checkable">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3">
+ <widget class="QToolButton" name="mCalculateFieldButton">
+ <string>Field calculator</string>
+ </property>
+ </property>
+ <string/>
+ </property>
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="4">
+ <spacer>
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>658</width>
+ <height>19</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="1" column="0" colspan="5">
<widget class="QTableWidget" name="tblAttributes">
@@ -363,219 +346,245 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab1">
- <string>General</string>
- </attribute>
+ <widget class="QWidget" name="page_6">
+ <layout class="QGridLayout" name="gridLayout_7">
+ <property name="leftMargin">
+ </property>
+ <property name="topMargin">
+ <number>9</number>
+ </property>
+ <property name="rightMargin">
+ </property>
+ <property name="bottomMargin">
+ </property>
- <widget class="QGroupBox" name="indexGroupBox">
- <property name="title">
- <string>Options</string>
- </property>
- <widget class="QLabel" name="textLabel3">
- <string>Display name</string>
- </property>
- <property name="buddy">
- <cstring>txtDisplayName</cstring>
- </property>
- </widget>
- </item>
- <item row="0" column="1" colspan="2">
- <widget class="QLineEdit" name="txtDisplayName"/>
- </item>
- <widget class="QLabel" name="textLabel2">
- <string>Display field for the Identify Results dialog box</string>
- </property>
- <string>This sets the display field for the Identify Results dialog box</string>
- </property>
- <string>Display field</string>
- </property>
- <cstring>displayFieldComboBox</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1" colspan="2">
- <widget class="QComboBox" name="displayFieldComboBox">
- <string>Use this control to set which field is placed at the top level of the Identify Results dialog box.</string>
- </property>
- </widget>
- </item>
- <item row="3" column="0" colspan="3">
- <widget class="QLineEdit" name="leSpatialRefSys">
- <property name="readOnly">
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="4" column="1">
- <widget class="QPushButton" name="pbnIndex">
- <string>Create Spatial Index</string>
- </property>
- </widget>
- </item>
- <item row="4" column="2">
- <widget class="QPushButton" name="pbnChangeSpatialRefSys">
- <string>Specify the coordinate reference system of the layer's geometry.</string>
- </property>
- </property>
- <string>Specify CRS</string>
- </property>
- </widget>
- </item>
- <item row="2" column="0">
- <widget class="QLabel" name="label">
- <string>Edit UI</string>
- </property>
- </widget>
- </item>
- <item row="2" column="1">
- <widget class="QLineEdit" name="leEditForm"/>
- </item>
- <item row="2" column="2">
- <widget class="QPushButton" name="pbnSelectEditForm">
- <string>...</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <widget class="QGroupBox" name="chkUseScaleDependentRendering">
- <string>Use scale dependent rendering</string>
- </property>
+ <widget class="QScrollArea" name="scrollArea_2">
<bool>true</bool>
</property>
- <property name="margin">
- <number>11</number>
+ <widget class="QWidget" name="scrollAreaWidgetContents_2">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>540</width>
+ <height>401</height>
+ </rect>
</property>
- <item row="0" column="2">
- <widget class="QLabel" name="textLabel1_2_2">
- <string>Maximum</string>
- </property>
- <cstring>spinMaximumScale</cstring>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="textLabel1">
- <string>Minimum</string>
- </property>
- <cstring>spinMinimumScale</cstring>
- </property>
- </widget>
- </item>
- <item row="0" column="1">
- <widget class="QSpinBox" name="spinMinimumScale">
- <string>Minimum scale at which this layer will be displayed. </string>
- </property>
- <property name="minimum">
- <number>1</number>
- </property>
- <property name="maximum">
- <number>100000000</number>
- </property>
- </widget>
- </item>
- <item row="0" column="3">
- <widget class="QSpinBox" name="spinMaximumScale">
- <string>Maximum scale at which this layer will be displayed. </string>
- </property>
- </property>
- </property>
- </widget>
- </item>
- </layout>
+ <layout class="QGridLayout" name="gridLayout_3">
+ <widget class="QGroupBox" name="indexGroupBox">
+ <property name="title">
+ <string>Options</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_2">
+ <widget class="QLabel" name="textLabel3">
+ <string>Display name</string>
+ </property>
+ <property name="buddy">
+ <cstring>txtDisplayName</cstring>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLineEdit" name="txtDisplayName"/>
+ </item>
+ <widget class="QLabel" name="textLabel2">
+ <string>Display field for the Identify Results dialog box</string>
+ </property>
+ <string>This sets the display field for the Identify Results dialog box</string>
+ </property>
+ <string>Display field</string>
+ </property>
+ <cstring>displayFieldComboBox</cstring>
+ </property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="displayFieldComboBox">
+ <string>Use this control to set which field is placed at the top level of the Identify Results dialog box.</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label">
+ <string>Edit UI</string>
+ </property>
+ </widget>
+ </item>
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
+ <item>
+ <widget class="QLineEdit" name="leEditForm"/>
+ </item>
+ <item>
+ <widget class="QToolButton" name="pbnSelectEditForm">
+ <string>...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="2">
+ <widget class="QPushButton" name="pbnChangeSpatialRefSys">
+ <string>Specify the coordinate reference system of the layer's geometry.</string>
+ </property>
+ </property>
+ <string>Specify CRS</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="3">
+ <widget class="QPushButton" name="pbnIndex">
+ <string>Create Spatial Index</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0" colspan="4">
+ <widget class="QLineEdit" name="leSpatialRefSys">
+ <property name="readOnly">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="chkUseScaleDependentRendering">
+ <string>Use scale dependent rendering</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ <layout class="QGridLayout">
+ <number>11</number>
+ </property>
+ <widget class="QLabel" name="textLabel1_2_2">
+ <string>Maximum</string>
+ </property>
+ <cstring>spinMaximumScale</cstring>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="textLabel1">
+ <string>Minimum</string>
+ </property>
+ <cstring>spinMinimumScale</cstring>
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="spinMinimumScale">
+ <string>Minimum scale at which this layer will be displayed. </string>
+ </property>
+ <property name="minimum">
+ <number>1</number>
+ </property>
+ <property name="maximum">
+ <number>100000000</number>
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="spinMaximumScale">
+ <string>Maximum scale at which this layer will be displayed. </string>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item row="2" column="0">
+ <widget class="QGroupBox" name="grpSubset">
+ <string>Subset</string>
+ </property>
+ </property>
+ <item row="0" column="0" colspan="2">
+ <widget class="QTextEdit" name="txtSubsetSQL">
+ <property name="enabled">
+ </property>
+ <property name="acceptDrops">
+ </property>
+ <property name="acceptRichText">
+ </property>
+ </widget>
+ </item>
+ <spacer>
+ </property>
+ <property name="sizeType">
+ <enum>QSizePolicy::Expanding</enum>
+ </property>
+ <size>
+ <width>480</width>
+ <height>21</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <widget class="QPushButton" name="pbnQueryBuilder">
+ <string>Query Builder</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
- <widget class="QGroupBox" name="grpSubset">
- <string>Subset</string>
- </property>
- </property>
- <item row="0" column="0" colspan="2">
- <widget class="QTextEdit" name="txtSubsetSQL">
- </property>
- <property name="acceptDrops">
- </property>
- <property name="acceptRichText">
- </property>
- </widget>
- </item>
- <spacer>
- </property>
- <property name="sizeType">
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <size>
- <width>480</width>
- <height>21</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="1" column="1">
- <widget class="QPushButton" name="pbnQueryBuilder">
- <string>Query Builder</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
</layout>
</widget>
- <widget class="QWidget" name="tab3">
- <string>Metadata</string>
- </attribute>
- </property>
+ <widget class="QWidget" name="page_7">
+ <layout class="QGridLayout" name="gridLayout_8">
<widget class="QTextEdit" name="teMetadata">
<property name="lineWidth">
@@ -588,11 +597,8 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab5">
- <string>Actions</string>
- </attribute>
+ <widget class="QWidget" name="page_8">
+ <layout class="QGridLayout" name="gridLayout_9">
<widget class="QFrame" name="actionOptionsFrame">
@@ -613,30 +619,58 @@
</widget>
</widget>
</item>
+ <item row="2" column="1" colspan="2">
+ <widget class="QPushButton" name="pbnLoadDefaultStyle">
+ <string>Restore Default Style</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="3">
+ <widget class="QPushButton" name="pbnSaveDefaultStyle">
+ <string>Save As Default</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="4">
+ <widget class="QPushButton" name="pbnLoadStyle">
+ <string>Load Style ...</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="5">
+ <widget class="QPushButton" name="pbnSaveStyleAs">
+ <string>Save Style ...</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" colspan="6">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11"/>
<tabstops>
- <tabstop>legendtypecombobox</tabstop>
- <tabstop>sliderTransparency</tabstop>
<tabstop>txtDisplayName</tabstop>
<tabstop>displayFieldComboBox</tabstop>
<tabstop>leSpatialRefSys</tabstop>
<tabstop>pbnIndex</tabstop>
<tabstop>pbnChangeSpatialRefSys</tabstop>
- <tabstop>chkUseScaleDependentRendering</tabstop>
<tabstop>spinMinimumScale</tabstop>
<tabstop>spinMaximumScale</tabstop>
<tabstop>txtSubsetSQL</tabstop>
<tabstop>pbnQueryBuilder</tabstop>
- <tabstop>teMetadata</tabstop>
- <tabstop>labelCheckBox</tabstop>
- <tabstop>pbnLoadDefaultStyle</tabstop>
- <tabstop>pbnSaveDefaultStyle</tabstop>
- <tabstop>pbnLoadStyle</tabstop>
- <tabstop>pbnSaveStyleAs</tabstop>
<tabstop>buttonBox</tabstop>
- <tabstop>tabWidget</tabstop>
</tabstops>
<resources/>
<connections>
@@ -647,14 +681,30 @@
<slot>setEnabled(bool)</slot>
<hints>
<hint type="sourcelabel">
- <x>60</x>
- <y>53</y>
+ <x>201</x>
+ <y>20</y>
</hint>
<hint type="destinationlabel">
- <x>61</x>
- <y>68</y>
+ <x>201</x>
+ <y>49</y>
</hint>
</hints>
</connection>
+ <connection>
+ <sender>listWidget</sender>
+ <signal>currentRowChanged(int)</signal>
+ <receiver>stackedWidget</receiver>
+ <slot>setCurrentIndex(int)</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>93</x>
+ <y>19</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>119</x>
+ <y>16</y>
+ </hint>
+ </hints>
+ </connection>
</connections>
</ui>
