[QGIS Commit] r12111 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 14 17:39:10 EST 2009
Author: timlinux
Date: 2009-11-14 17:39:07 -0500 (Sat, 14 Nov 2009)
New Revision: 12111
   trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
Layout cleanups for actions widget
Modified: trunk/qgis/src/ui/qgsattributeactiondialogbase.ui
--- trunk/qgis/src/ui/qgsattributeactiondialogbase.ui	2009-11-14 21:45:08 UTC (rev 12110)
+++ trunk/qgis/src/ui/qgsattributeactiondialogbase.ui	2009-11-14 22:39:07 UTC (rev 12111)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>552</width>
-    <height>432</height>
+    <width>695</width>
+    <height>449</height>
    </rect>
   </property>
   <property name="sizePolicy">
@@ -19,11 +19,107 @@
   <property name="windowTitle">
    <string>Attribute Actions</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout_3">
+  <layout class="QGridLayout" name="gridLayout_2">
    <property name="margin">
     <number>0</number>
    </property>
    <item row="0" column="0">
+    <widget class="QGroupBox" name="groupBox_2">
+     <property name="title">
+      <string>Action list</string>
+     </property>
+     <layout class="QGridLayout" name="gridLayout_3">
+      <item row="0" column="0" colspan="5">
+       <widget class="QTableWidget" name="attributeActionTable">
+        <property name="sizePolicy">
+         <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+        <property name="whatsThis">
+         <string>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</string>
+        </property>
+        <property name="selectionMode">
+         <enum>QAbstractItemView::SingleSelection</enum>
+        </property>
+        <property name="selectionBehavior">
+         <enum>QAbstractItemView::SelectRows</enum>
+        </property>
+        <property name="columnCount">
+         <number>3</number>
+        </property>
+        <column>
+         <property name="text">
+          <string>Name</string>
+         </property>
+        </column>
+        <column>
+          <string>Action</string>
+         </property>
+        </column>
+        <column>
+          <string>Capture</string>
+         </property>
+        </column>
+       </widget>
+      </item>
+      <item row="1" column="0">
+       <widget class="QPushButton" name="insertButton">
+        <property name="toolTip">
+         <string>Inserts the action into the list above</string>
+        </property>
+         <string>Insert action</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1">
+       <widget class="QPushButton" name="updateButton">
+         <string>Update the selected action</string>
+        </property>
+         <string>Update action</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="2">
+       <widget class="QPushButton" name="moveUpButton">
+         <string>Move the selected action up</string>
+        </property>
+         <string>Move up</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="3">
+       <widget class="QPushButton" name="moveDownButton">
+         <string>Move the selected action down</string>
+        </property>
+         <string>Move down</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="4">
+       <widget class="QPushButton" name="removeButton">
+         <string>Remove the selected action</string>
+        </property>
+         <string>Remove</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
     <widget class="QGroupBox" name="groupBox">
       <string>Action properties</string>
@@ -132,150 +228,22 @@
      </layout>
     </widget>
    </item>
-   <item row="1" column="0">
-    <widget class="QGroupBox" name="groupBox_2">
-     <property name="title">
-      <string>Action list</string>
-     </property>
-     <layout class="QGridLayout" name="gridLayout_2">
-      <item row="0" column="0" rowspan="7">
-       <widget class="QTableWidget" name="attributeActionTable">
-        <property name="sizePolicy">
-         <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
-          <horstretch>0</horstretch>
-          <verstretch>0</verstretch>
-         </sizepolicy>
-        </property>
-        <property name="whatsThis">
-         <string>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</string>
-        </property>
-        <property name="selectionMode">
-         <enum>QAbstractItemView::SingleSelection</enum>
-        </property>
-        <property name="selectionBehavior">
-         <enum>QAbstractItemView::SelectRows</enum>
-        </property>
-        <property name="columnCount">
-         <number>3</number>
-        </property>
-        <column>
-         <property name="text">
-          <string>Name</string>
-         </property>
-        </column>
-        <column>
-          <string>Action</string>
-         </property>
-        </column>
-        <column>
-          <string>Capture</string>
-         </property>
-        </column>
-       </widget>
-      </item>
-      <item row="0" column="1">
-       <widget class="QPushButton" name="insertButton">
-        <property name="toolTip">
-         <string>Inserts the action into the list above</string>
-        </property>
-         <string>Insert action</string>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="1">
-       <widget class="QPushButton" name="updateButton">
-         <string>Update the selected action</string>
-        </property>
-         <string>Update action</string>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="1">
-       <spacer>
-        <property name="orientation">
-         <enum>Qt::Vertical</enum>
-        </property>
-        <property name="sizeType">
-         <enum>QSizePolicy::Expanding</enum>
-        </property>
-        <property name="sizeHint" stdset="0">
-         <size>
-          <width>85</width>
-          <height>35</height>
-         </size>
-        </property>
-       </spacer>
-      </item>
-      <item row="3" column="1">
-       <widget class="QPushButton" name="moveUpButton">
-         <string>Move the selected action up</string>
-        </property>
-         <string>Move up</string>
-        </property>
-       </widget>
-      </item>
-      <item row="4" column="1">
-       <widget class="QPushButton" name="moveDownButton">
-         <string>Move the selected action down</string>
-        </property>
-         <string>Move down</string>
-        </property>
-       </widget>
-      </item>
-      <item row="5" column="1">
-       <spacer>
-        </property>
-        </property>
-         <size>
-          <width>85</width>
-          <height>41</height>
-         </size>
-        </property>
-       </spacer>
-      </item>
-      <item row="6" column="1">
-       <widget class="QPushButton" name="removeButton">
-         <string>Remove the selected action</string>
-        </property>
-         <string>Remove</string>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
  <tabstops>
-  <tabstop>actionName</tabstop>
-  <tabstop>actionAction</tabstop>
-  <tabstop>browseButton</tabstop>
-  <tabstop>captureCB</tabstop>
-  <tabstop>fieldComboBox</tabstop>
-  <tabstop>insertFieldButton</tabstop>
   <tabstop>attributeActionTable</tabstop>
   <tabstop>insertButton</tabstop>
   <tabstop>updateButton</tabstop>
   <tabstop>moveUpButton</tabstop>
   <tabstop>moveDownButton</tabstop>
   <tabstop>removeButton</tabstop>
+  <tabstop>actionName</tabstop>
+  <tabstop>actionAction</tabstop>
+  <tabstop>browseButton</tabstop>
+  <tabstop>captureCB</tabstop>
+  <tabstop>fieldComboBox</tabstop>
+  <tabstop>insertFieldButton</tabstop>
  </tabstops>
  <resources/>
  <connections/>
More information about the QGIS-commit mailing list
