[QGIS Commit] r12120 - trunk/qgis/python/plugins/mapserver_export
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 15 07:42:38 EST 2009
Author: rduivenvoorde
Date: 2009-11-15 07:42:37 -0500 (Sun, 15 Nov 2009)
New Revision: 12120
   trunk/qgis/python/plugins/mapserver_export/__init__.py
   trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
   trunk/qgis/python/plugins/mapserver_export/ms_export.py
   trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui
New, smaller dialog. More defaults, checks and failovers. Merged work of Stephan Meissl
Modified: trunk/qgis/python/plugins/mapserver_export/__init__.py
--- trunk/qgis/python/plugins/mapserver_export/__init__.py	2009-11-15 12:28:53 UTC (rev 12119)
+++ trunk/qgis/python/plugins/mapserver_export/__init__.py	2009-11-15 12:42:37 UTC (rev 12120)
@@ -24,7 +24,7 @@
 def description():
   return "Export a saved QGIS project file to a MapServer map file"
 def version():
-  return "Version 0.4"
+  return "Version 0.4.1"
 def qgisMinimumVersion():
   return "1.0"
 def authorName():
Modified: trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
--- trunk/qgis/python/plugins/mapserver_export/mapserverexport.py	2009-11-15 12:28:53 UTC (rev 12119)
+++ trunk/qgis/python/plugins/mapserver_export/mapserverexport.py	2009-11-15 12:42:37 UTC (rev 12120)
@@ -16,7 +16,7 @@
  *   (at your option) any later version.                                   *
-/* Adapted by Erik van de Pol, B3Partners BV. */
+/* Adapted by Erik van de Pol */
 # Import the PyQt and QGIS libraries
 from PyQt4.QtCore import *
@@ -55,6 +55,7 @@
     else:
       return QIcon()
   def initGui(self):
     # Create action that will start plugin configuration
     self.action = QAction(self.getThemeIcon("mapserver_export.png"), \
@@ -63,26 +64,31 @@
     # connect the action to the run method
     QObject.connect(self.action, SIGNAL("activated()"), self.run)
     QObject.connect(self.iface, SIGNAL("currentThemeChanged ( QString )"), self.setCurrentTheme)
     # Add toolbar button and menu item
     self.iface.addToolBarIcon(self.action)
     self.iface.addPluginToMenu("&MapServer Export...", self.action)
   def unload(self):
     # Remove the plugin menu item and icon
     self.iface.removePluginMenu("&MapServer Export...",self.action)
     self.iface.removeToolBarIcon(self.action)
   # run method that performs all the real work
   def run(self):
     # create and show the MapServerExport dialog
     self.dlg = MapServerExportDialog()
-    #dlg.setupUi(self)
+    # TODO: should come from settings
+    self.dlg.ui.txtMapFilePath.setText('/usr/lib/cgi-bin/kaas.map')
+    # project defaults to current instance
     project = QgsProject.instance()
     # question: save project on loading export dialog?
     if project.isDirty():
-      shouldSave = QMessageBox.question(None,
+      shouldSave = QMessageBox.question(self.dlg,
                       "Save?",
                       "Save project to \"" + project.fileName() + "\" before exporting? Only the last saved version of your project will be exported.",
                       QMessageBox.Yes,
@@ -97,14 +103,31 @@
                       "QGIS Project Files (*.qgs)",
                       "Filter list for selecting files from a dialog box")
-          project.setFileName(saveAsFileName)
-        project.write()
+          # Check that a file was selected
+          if saveAsFileName.size() == 0:
+            QMessageBox.warning(self.dlg, "Not saved!", "QGis project file not saved because no file name was given.")
+            # fall back to using current project if available
+            self.dlg.ui.txtQgisFilePath.setText(project.fileName())
+          else:
+            project.setFileName(saveAsFileName)
+            project.write()
+        else:
+          project.write()
       elif shouldSave == QMessageBox.Cancel:
         return # do not show the export dialog
+    # set title, or set default one if none available
+    title = project.title()
+    if title == "":
+      title = "QGisGeneratedMapfile"
     self.dlg.ui.txtMapName.setText(project.title())
+    if self.dlg.ui.txtMapFilePath.text().size() == 0:
+      btnOk = self.dlg.ui.buttonBox.button(QDialogButtonBox.Ok)
+      btnOk.setEnabled(False)
     # TODO: fetch unit used from QSettings
     # TODO: fetch width/height guess from QSettings:
@@ -119,94 +142,149 @@
     #self.dlg.ui.spinBoxScale.setValue(scale.toInt()[0])
     QObject.connect(self.dlg.ui.btnChooseFile, SIGNAL("clicked()"), self.setSaveFile)
+    QObject.connect(self.dlg.ui.txtMapFilePath, SIGNAL("textChanged(QString)"), self.mapfileChanged)
     QObject.connect(self.dlg.ui.btnChooseProjectFile, SIGNAL("clicked()"), self.setProjectFile)
     QObject.connect(self.dlg.ui.chkExpLayersOnly, SIGNAL("clicked(bool)"), self.toggleLayersOnly)
+    QObject.connect(self.dlg.ui.checkBoxCurrentProject, SIGNAL("clicked(bool)"), self.toggleUseCurrentProject)
     QObject.connect(self.dlg.ui.btnChooseFooterFile, SIGNAL("clicked()"), self.setFooterFile)
     QObject.connect(self.dlg.ui.btnChooseHeaderFile, SIGNAL("clicked()"), self.setHeaderFile)
     QObject.connect(self.dlg.ui.btnChooseTemplateFile, SIGNAL("clicked()"), self.setTemplateFile)
+    QObject.connect(self.dlg.ui.buttonBox, SIGNAL("accepted()"), self.ok_clicked)
     self.dlg.show()
-    result = self.dlg.exec_()
-    # See if OK was pressed
-    if result == 1:
-      # get the settings from the dialog and export the map file
-      print "Creating exporter using %s and %s" % (self.dlg.ui.txtQgisFilePath.text(), self.dlg.ui.txtMapFilePath.text())
-      exporter = Qgis2Map(unicode(self.dlg.ui.txtQgisFilePath.text()), unicode(self.dlg.ui.txtMapFilePath.text()))
-      print "Setting options"
-      exporter.setOptions(
-          unicode(self.dlg.ui.txtMapServerUrl.text()),
-          unicode(self.dlg.ui.cmbMapUnits.itemData( self.dlg.ui.cmbMapUnits.currentIndex() ).toString()),
-          unicode(self.dlg.ui.cmbMapImageType.currentText()),
-          unicode(self.dlg.ui.txtMapName.text()),
-          unicode(self.dlg.ui.txtMapWidth.text()),
-          unicode(self.dlg.ui.txtMapHeight.text()),
-          unicode(self.dlg.ui.txtWebTemplate.text()),
-          unicode(self.dlg.ui.txtWebFooter.text()),
-          unicode(self.dlg.ui.txtWebHeader.text()),
-          self.dlg.ui.checkBoxDump.isChecked(),
-          self.dlg.ui.checkBoxForce.isChecked(),
-          self.dlg.ui.checkBoxAntiAlias.isChecked(),
-          self.dlg.ui.checkBoxPartials.isChecked(),
-          self.dlg.ui.chkExpLayersOnly.isChecked(),
-          unicode(self.dlg.ui.txtFontsetPath.text()),
-          unicode(self.dlg.ui.txtSymbolsetPath.text())
-      print "Calling writeMapFile"
+  def ok_clicked(self):
+    # Check if map file name is provided
+      saveAsFileName = QFileDialog.getSaveFileName(self.dlg,
+                    "Please choose to save map file as...",
+                    "Map files (*.map)",
+                    "Filter list for selecting files from a dialog box")
+        QMessageBox.warning(self.dlg, "Not saved!", "Map file not saved because no file name was given")
+        return
+      else:
+        self.dlg.ui.txtMapFilePath.setText(saveAsFileName)
+        self.saveMapFile()
+    # Check if map file exists and we should overwrite it
+    elif QFile(self.dlg.ui.txtMapFilePath.text()).exists():
+      shouldOverwrite = QMessageBox.question(self.dlg,
+                    "Overwrite?",
+                    "Map file \"" + self.dlg.ui.txtMapFilePath.text() + "\" already exists. \nShould we overwrite it?",
+                    QMessageBox.Yes,
+                    QMessageBox.Cancel
+      if shouldOverwrite == QMessageBox.Yes:
+      elif shouldOverwrite == QMessageBox.Cancel:
+        return
+    else:
+  def toggleUseCurrentProject(self, boolUseCurrent):
+    self.dlg.ui.txtQgisFilePath.setEnabled(not boolUseCurrent)
+    self.dlg.ui.btnChooseProjectFile.setEnabled(not boolUseCurrent)
+    if boolUseCurrent:
+      if self.dlg.ui.txtQgisFilePath.text().size() == 0:
+        # reload path of current project
+        self.dlg.ui.txtQgisFilePath.setText(QgsProject.instance().fileName())
+        # check if current project is saved and/or dirty? Nope: will be done when Ok clicked
+    else:
+      # open dialog to choose project file
+      self.setProjectFile()
+  def saveMapFile(self):
+    # get the settings from the dialog and export the map file
+    print "Creating exporter using %s and %s" % (self.dlg.ui.txtQgisFilePath.text(), self.dlg.ui.txtMapFilePath.text())
+                    "Please choose to save QGis project file as...",
+                    "QGis files (*.qgs)",
+        QMessageBox.warning(self.dlg, "Not saved!", "QGis project file not saved because no file name was given")
+        return
+      else:
+        self.dlg.ui.txtQgisFilePath.setText(saveAsFileName)
+    exporter = Qgis2Map(unicode(self.dlg.ui.txtMapFilePath.text()))
+    # Parse qgis project file and check success
+    if not(exporter.setQgsProject(self.dlg.ui.txtQgisFilePath.text())):
+      QMessageBox.warning(self.dlg, "Not saved!", "File not saved because no valid qgis project file was given.")
+      return
+    self.dlg.hide()
+    print "Setting options"
+    exporter.setOptions(
+        unicode(self.dlg.ui.txtMapServerUrl.text()),
+        unicode(self.dlg.ui.cmbMapUnits.itemData( self.dlg.ui.cmbMapUnits.currentIndex() ).toString()),
+        unicode(self.dlg.ui.cmbMapImageType.currentText()),
+        unicode(self.dlg.ui.txtMapName.text()),
+        unicode(self.dlg.ui.txtMapWidth.text()),
+        unicode(self.dlg.ui.txtMapHeight.text()),
+        unicode(self.dlg.ui.txtWebTemplate.text()),
+        unicode(self.dlg.ui.txtWebHeader.text()),
+        unicode(self.dlg.ui.txtWebFooter.text()),
+        self.dlg.ui.checkBoxDump.isChecked(),
+        self.dlg.ui.checkBoxForce.isChecked(),
+        self.dlg.ui.checkBoxAntiAlias.isChecked(),
+        self.dlg.ui.checkBoxPartials.isChecked(),
+        self.dlg.ui.chkExpLayersOnly.isChecked(),
+        unicode(self.dlg.ui.txtFontsetPath.text()),
+        unicode(self.dlg.ui.txtSymbolsetPath.text())
+    print "Calling writeMapFile"
+    try:
       result = exporter.writeMapFile()
-      QMessageBox.information(None, "MapServer Export Results", result)
+    except Exception, err:
+      QMessageBox.information(self.dlg, "MapServer Export Error", str(err))
+      return
+    QMessageBox.information(self.dlg, "MapServer Export Results", result)
+  def mapfileChanged(self, text):
+    # Enable OK button
+    if text.size() > 0:
+      btnOk.setEnabled(True)
+    else:
   def setSaveFile(self):
     mapFile = QFileDialog.getSaveFileName(self.dlg, "Name for the map file", \
       ".", "MapServer map files (*.map);;All files (*.*)","Filter list for selecting files from a dialog box")
     self.dlg.ui.txtMapFilePath.setText(mapFile)
   def setProjectFile(self):
-    qgisProjectFile = QFileDialog.getOpenFileName(self.dlg, "Choose the QGIS Project file", \
-        ".", "QGIS Project Files (*.qgs);;All files (*.*)", "Filter list for selecting files from a dialog box")
+    qgisProjectFile = QFileDialog.getOpenFileName(self.dlg, "Choose a QGIS Project file", \
+      ".", "QGIS Project Files (*.qgs);;All files (*.*)", "Filter list for selecting files from a dialog box")
     self.dlg.ui.txtQgisFilePath.setText(qgisProjectFile)
   def setTemplateFile(self):
-    templateFile = QFileDialog.getOpenFileName(self.dlg,
-        "Choose the MapServer template file",
-        "All files (*.*)",
-        "Filter list for selecting files from a dialog box")
+    templateFile = QFileDialog.getOpenFileName(self.dlg, "Choose the MapServer template file", \
+      ".", "All files (*.*)", "Filter list for selecting files from a dialog box")
     self.dlg.ui.txtWebTemplate.setText(templateFile)
   def setHeaderFile(self):
-    headerFile = QFileDialog.getOpenFileName(self.dlg,
-        "Choose the MapServer header file",
+    headerFile = QFileDialog.getOpenFileName(self.dlg, "Choose the MapServer header file", \
     self.dlg.ui.txtWebHeader.setText(headerFile)
   def setFooterFile(self):
-    footerFile = QFileDialog.getOpenFileName(self.dlg,
-        "Choose the MapServer footer file",
+    footerFile = QFileDialog.getOpenFileName(self.dlg, "Choose the MapServer footer file", \
     self.dlg.ui.txtWebFooter.setText(footerFile)
-  def apply(self):
-    # create the map file
-    foo = 'bar'
   def toggleLayersOnly(self, isChecked):
     # disable other sections if only layer export is desired
-    self.dlg.ui.txtMapName.setEnabled(not isChecked)
-    self.dlg.ui.txtMapWidth.setEnabled(not isChecked)
-    self.dlg.ui.txtMapHeight.setEnabled(not isChecked)
-    self.dlg.ui.cmbMapUnits.setEnabled(not isChecked)
-    self.dlg.ui.cmbMapImageType.setEnabled(not isChecked)
-    self.dlg.ui.txtMapServerUrl.setEnabled(not isChecked)
-    self.dlg.ui.txtFontsetPath.setEnabled(not isChecked)
-    self.dlg.ui.txtSymbolsetPath.setEnabled(not isChecked)
-    self.dlg.ui.txtWebTemplate.setEnabled(not isChecked)
-    self.dlg.ui.txtWebHeader.setEnabled(not isChecked)
-    self.dlg.ui.txtWebFooter.setEnabled(not isChecked)
-    self.dlg.ui.btnChooseFooterFile.setEnabled(not isChecked)
-    self.dlg.ui.btnChooseHeaderFile.setEnabled(not isChecked)
-    self.dlg.ui.btnChooseTemplateFile.setEnabled(not isChecked)
+    self.dlg.ui.grpPaths.setEnabled(not isChecked)
+    self.dlg.ui.grpMap.setEnabled(not isChecked)
Modified: trunk/qgis/python/plugins/mapserver_export/ms_export.py
--- trunk/qgis/python/plugins/mapserver_export/ms_export.py	2009-11-15 12:28:53 UTC (rev 12119)
+++ trunk/qgis/python/plugins/mapserver_export/ms_export.py	2009-11-15 12:42:37 UTC (rev 12120)
@@ -17,7 +17,7 @@
 # presents a Qt based GUI that collects the needed information for this
 # script.
 # Matthew Perry contributed major portions of this work.
-# Adapted by Erik van de Pol, B3Partners BV.
+# Adapted by Erik van de Pol
 # CHANGES SHOULD NOT BE MADE TO THE writeMapFile METHOD UNLESS YOU
 # ARE CHANGING THE QgsMapserverExport CLASS AND YOU KNOW WHAT YOU ARE
@@ -25,6 +25,7 @@
 from xml.dom import minidom
 from string import *
+import platform
 from qgis.core import QgsDataSourceURI
 from qgis.core import QgsMapLayerRegistry
 #from qgis.core import QgsProject
@@ -89,7 +90,10 @@
 defaults.fontsPath = "./fonts/fonts.txt"
 defaults.symbolsPath = "./symbols/symbols.txt"
-defaults.mapServerUrl = "http://my.host.com/cgi-bin/mapserv.exe"
+if platform.system() == "Windows":
+  defaults.mapServerUrl = "http://my.host.com/cgi-bin/mapserv.exe"
+else:
+  defaults.mapServerUrl = "http://localhost/cgi-bin/mapserv"
 defaults.width = "100"
 defaults.height = "100"
@@ -101,11 +105,8 @@
 class Qgis2Map:
-  def __init__(self, projectFile, mapFile):
-    self.project = projectFile
+  def __init__(self, mapFile):
     self.mapFile = mapFile
-    # create the DOM
-    self.qgs = minidom.parse(projectFile)
     # init the other members that are not set by the constructor
     self.mapServerUrl = defaults.mapServerUrl
     self.fontsPath = defaults.fontsPath
@@ -126,6 +127,14 @@
     self.partials = bool2str[defaults.partials]
     self.symbolQueue = {}
+  def setQgsProject(self, projectFileName):
+    try:
+      self.projectFileName = projectFileName
+      # create the DOM
+      self.qgs = minidom.parse(unicode(self.projectFileName))
+      return True
+    except:
+      return False
   # Set the options collected from the GUI
   def setOptions(self, msUrl, units, image, mapname, width, height, template, header, footer, dump, force, antialias, partials, exportLayersOnly, fontsPath, symbolsPath):
@@ -150,15 +159,20 @@
     #self.minimumScale = minscale
     #self.maximumScale = maxscale
-    self.template = template.encode('utf-8')
+    # TEMPLATE is needed for getFeatureInfo requests in WMS:
+    # always set someting ...
+    template = template.encode('utf-8')
+    if template == "":
+      template = "fooOnlyForWMSGetFeatureInfo"
+    self.template = template
     self.header = header.encode('utf-8')
     self.footer = footer.encode('utf-8')
     #print units, image, mapname, width, height, template, header, footer
-    self.dump            = bool2str[dump]
-    self.force           = bool2str[force]
-    self.antialias       = bool2str[antialias]
-    self.partials        = bool2str[partials]
+    self.dump               = bool2str[dump]
+    self.force              = bool2str[force]
+    self.antialias          = bool2str[antialias]
+    self.partials           = bool2str[partials]
     self.exportLayersOnly   = exportLayersOnly
@@ -218,13 +232,19 @@
         self.outFile.write("END")
         self.outFile.close()
-    logmsg += "Map file completed for " + self.project + "\n"
+    logmsg += "Map file completed for " + self.projectFileName + "\n"
     logmsg += "Map file saved as " + self.mapFile + "\n"
+    if self.exportLayersOnly:
+      logmsg += "\n> We only saved the LAYER portion of the map file. Merge this into an excisting mapfile to see it working\n"
+    else:
+      logmsg += "\n> If this mapfile is accessible by your mapserver, you\nshould be able to see the capabilities by firing this url:\n" + self.mapServerUrl + "?MAP="+self.mapFile+"&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities\n"
+      logmsg += "\n> if this mapfile is accessible by your mapserver, you\nshould be able to see a map by firing this url:\n" + self.mapServerUrl + "?MAP="+self.mapFile+"&SERVICE=WMS&LAYERS=ALL&MODE=MAP\n"
     return logmsg
   # Write the general parts of the map section
   def writeMapSection(self):
-    self.outFile.write("# Map file created from QGIS project file " + self.project.encode('utf-8') + "\n")
+    print "writeMapSection, projNaam = %s en type = %s" % (self.projectFileName, type(self.projectFileName))
+    self.outFile.write("# Map file created from QGIS project file " + str(self.projectFileName).encode('utf-8') + "\n")
     self.outFile.write("# Edit this file to customize for your map interface\n")
     self.outFile.write("# (Created with PyQgis MapServer Export plugin)\n")
     self.outFile.write("MAP\n")
@@ -241,14 +261,14 @@
     self.outFile.write(self.getExtentString())
     self.outFile.write("  FONTSET '" + self.fontsPath + "'\n")
-    # B3Partners uses external symbol set
+    # use of external symbol set
     self.outFile.write("  SYMBOLSET '" + self.symbolsPath + "'\n")
   def getExtentString(self):
     stringToAddTo = ""
     xmin = self.qgs.getElementsByTagName("xmin")
-    stringToAddTo += "  EXTENT "
+    stringToAddTo += "    EXTENT "
     stringToAddTo += xmin[0].childNodes[0].nodeValue.encode('utf-8')
     stringToAddTo += " "
@@ -346,9 +366,9 @@
     self.outFile.write("    # WMS server settings\n")
     self.outFile.write("    METADATA\n")
-    self.outFile.write("      'wms_title'           '" + self.mapName + "'\n")
-    self.outFile.write("      'wms_onlineresource'  '" + self.mapServerUrl + "?" + "map" + "=" + self.mapFile + "'\n")
-    self.outFile.write("      'wms_srs'             'EPSG:" + epsg + "'\n")
+    self.outFile.write("      'ows_title'           '" + self.mapName + "'\n")
+    self.outFile.write("      'ows_onlineresource'  '" + self.mapServerUrl + "?" + "map" + "=" + self.mapFile + "'\n")
+    self.outFile.write("      'ows_srs'             'EPSG:" + epsg + "'\n")
     self.outFile.write("    END\n\n")
     self.outFile.write("    #Scale range at which web interface will operate\n")
@@ -375,10 +395,11 @@
     # get the list of legend nodes so the layers can be written in the
     # proper order
     resultMsg = ''
     legend_nodes = self.qgs.getElementsByTagName("legendlayer")
     self.z_order = list()
     for legend_node in legend_nodes:
-        self.z_order.append(legend_node.getAttribute("name").encode('utf-8').replace("\"", ""))
+        self.z_order.append(legend_node.getAttribute("name").encode('utf-8').replace("\"", "").replace(" ","_"))
     # get the list of maplayer nodes
     maplayers = self.qgs.getElementsByTagName("maplayer")
@@ -440,7 +461,8 @@
         #layer_def += "    DATA '" + uri.geometryColumn() + " FROM " + uri.quotedTablename() + "'\n"
         layer_id = lyr.getElementsByTagName("id")[0].childNodes[0].nodeValue.encode("utf-8")
+        # TODO: check if this project is actually loaded in QGis
+        # only in loaded project files it's possible to determine the primary key of a postgis table
         uniqueId = self.getPrimaryKey(layer_id, uri.table())
         # %tablename% is returned when no uniqueId is found: inform user
         if uniqueId.find("%") >= 0:
@@ -471,16 +493,17 @@
         # Create necesssary wms metadata
         format = rasterProp.getElementsByTagName('wmsFormat')[0].childNodes[0].nodeValue.encode('utf-8')
         layer_def += "    METADATA\n"
-        layer_def += "      'wms_name' '" + ','.join(wmsNames) + "'\n"
+        layer_def += "      'ows_name' '" + ','.join(wmsNames) + "'\n"
         layer_def += "      'wms_server_version' '1.1.1'\n"
         try:
           #ct = lyr.getElementsByTagName('coordinatetransform')[0]
           #srs = ct.getElementsByTagName('sourcesrs')[0].getElementsByTagName('spatialrefsys')[0]
           #epsg = srs.getElementsByTagName('epsg')[0].childNodes[0].nodeValue.encode('utf-8')
           #layer_def += "      'wms_srs' 'EPSG:4326 EPSG:" + epsg + "'\n"
-          layer_def += "      'wms_srs' 'EPSG:" + self.getEpsg(lyr) + "'\n"
+          layer_def += "      'ows_srs' 'EPSG:" + self.getEpsg(lyr) + "'\n"
           # TODO: add epsg to all METADATA tags??
         except:
+          print "ERROR while trying to write ows_srs METADATA"
 	  pass
         layer_def += "      'wms_format' '" + format + "'\n"
         layer_def += "      'wms_style' '" + ','.join(wmsStyles) + "'\n"
@@ -492,7 +515,7 @@
       # WMS settings for all layers
-      layer_def += "      'wms_title' '" + lyr.getElementsByTagName("layername")[0].childNodes[0].nodeValue.encode('utf-8').replace("\"", "") + "'\n"
+      layer_def += "      'ows_title' '" + lyr.getElementsByTagName("layername")[0].childNodes[0].nodeValue.encode('utf-8').replace("\"", "") + "'\n"
       layer_def += "    END\n"
       layer_def += "    STATUS OFF\n"
@@ -511,9 +534,18 @@
       layer_def += "    TRANSPARENCY " + str(opacity) + "\n"
       layer_def += "    PROJECTION\n"
-      # Get the data srs for this layer and use it to create the projection section
-      datasrs = lyr.getElementsByTagName("srs")[0]
-      proj4Text = datasrs.getElementsByTagName("proj4")[0].childNodes[0].nodeValue.encode('utf-8')
+       # Get the destination srs for this layer and use it to create the projection section
+      destsrs = self.qgs.getElementsByTagName("destinationsrs")[0]
+      proj4Text = destsrs.getElementsByTagName("proj4")[0].childNodes[0].nodeValue.encode('utf-8')
+      # TODO: you would think: take DATA-srs here, but often projected
+      # shapefiles do not contain srs data ... If we want to do this
+      # we should take make the map-srs the qgs-project srs first
+      # instead of taking the srs of the first layer
+      # Get the data srs for this layer and use it to create the projection section
+      # datasrs = lyr.getElementsByTagName("srs")[0]
+      # proj4Text = datasrs.getElementsByTagName("proj4")[0].childNodes[0].nodeValue.encode('utf-8')
       # the proj4 text string needs to be reformatted to make mapserver happy
       layer_def += self.formatProj4(proj4Text)
@@ -556,7 +588,7 @@
       layer_list[layer_name] = layer_def
     # all layers have been processed, reverse the list and write
     # not necessary since z-order is mapped by the legend list order
-#    self.z_order.reverse()
+    self.z_order.reverse()
     for layer in self.z_order:
       self.outFile.write(layer_list[layer])
     return resultMsg
@@ -573,11 +605,17 @@
     we approximate the primary key by finding an integer type field containing "fid" or "id"
     This is obviously a lousy solution at best.
-    This script requires the project you export to be open in QGis.
+    This script requires the project you export to be open in QGis!!
     mlr = QgsMapLayerRegistry.instance()
     layers = mlr.mapLayers()
+    if not QString(layerId) in layers:
+      # layerId of this postgis layer NOT in the layerlist... probably
+      # the project is not loaded in qgis (to be able to find the primary
+      # key, one should load the project in QGis
+      raise Exception("ERROR: layer not found in project layers.... \nThis happens with postgis layers in a project which \nis not loaded in QGis.\nDid you load this project into QGis? \nIf not please load project first, and then export it to mapserver.")
     layer = layers[QString(layerId)]
     dataProvider = layer.dataProvider()
     fields = dataProvider.fields()
Modified: trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui
--- trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui	2009-11-15 12:28:53 UTC (rev 12119)
+++ trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui	2009-11-15 12:42:37 UTC (rev 12120)
@@ -7,375 +7,474 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>400</width>
-    <height>522</height>
+    <width>609</width>
+    <height>507</height>
    </rect>
   </property>
   <property name="windowTitle">
-   <string>Export to Mapserver</string>
+   <string>MapServer Export: Save project to MapFile</string>
   </property>
   <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout">
-   <property name="margin">
-    <number>9</number>
-   </property>
-   <property name="spacing">
-    <number>6</number>
-   </property>
-   <item row="5" column="0" colspan="3">
-    <widget class="QGroupBox" name="grpWeb">
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0">
+    <widget class="QCheckBox" name="checkBoxCurrentProject">
+     <property name="text">
+      <string>Use current project</string>
+     </property>
+     <property name="checked">
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="1">
+    <widget class="QLineEdit" name="txtQgisFilePath">
+     <property name="enabled">
+      <bool>false</bool>
+     </property>
+     <property name="toolTip">
+      <string>Full path to the QGIS project file to export to MapServer map format</string>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="2">
+    <widget class="QPushButton" name="btnChooseProjectFile">
+     </property>
+      <string>Browse...</string>
+     </property>
+    </widget>
+   </item>
+   <item row="1" column="0" colspan="3">
+    <widget class="QGroupBox" name="groupBox">
      <property name="title">
-      <string>Web Interface Definition</string>
+      <string>Map file</string>
      </property>
-       <number>0</number>
-      </property>
-      </property>
+     <layout class="QGridLayout" name="gridLayout_3">
-       <layout class="QHBoxLayout">
+       <widget class="QLabel" name="textLabel7">
         </property>
-         <number>4</number>
+        <property name="buddy">
+         <cstring>txtMapFilePath</cstring>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabel5_2">
-          <property name="minimumSize">
-           <size>
-            <width>60</width>
-            <height>0</height>
-           </size>
-          </property>
-          <property name="text">
-           <string>Template</string>
-          </property>
-          <property name="buddy">
-           <cstring>txtWebTemplate</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtWebTemplate">
-          <property name="toolTip">
-           <string>Path to the MapServer template file</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QPushButton" name="btnChooseTemplateFile">
-           <string>Browse...</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+       </widget>
       </item>
-      <item row="1" column="0">
+       <widget class="QLineEdit" name="txtMapFilePath">
+         <string>Name for the map file to be created from the QGIS project file</string>
         </property>
+       </widget>
+      </item>
+       <widget class="QPushButton" name="btnChooseFile">
+         <string>Save As...</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabel5">
-           <size>
-            <width>60</width>
-           </size>
-          </property>
-           <string>Header</string>
-          </property>
-           <cstring>txtWebHeader</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtWebHeader"/>
-        </item>
-        <item>
-         <widget class="QPushButton" name="btnChooseHeaderFile">
-          </property>
-         </widget>
-        </item>
-       </layout>
+       </widget>
       </item>
-      <item row="2" column="0">
+      <item row="0" column="3">
+       <widget class="QCheckBox" name="chkExpLayersOnly">
+         <string>If checked, only the layer information will be processed</string>
         </property>
+         <string>LAYER information only</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabel5_3">
-           <size>
-            <width>60</width>
-           </size>
-          </property>
-           <string>Footer</string>
-          </property>
-           <cstring>txtWebFooter</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtWebFooter"/>
-        </item>
-        <item>
-         <widget class="QPushButton" name="btnChooseFooterFile">
-          </property>
-         </widget>
-        </item>
-       </layout>
+       </widget>
       </item>
      </layout>
     </widget>
    </item>
-   <item row="3" column="0" colspan="3">
+   <item row="2" column="0" colspan="3">
     <widget class="QGroupBox" name="grpMap">
       <string>Map</string>
      </property>
-      </property>
-      </property>
+     <layout class="QGridLayout" name="gridLayout_2">
+       <widget class="QLabel" name="textLabel1">
+         <string/>
         </property>
+         <string>Name</string>
         </property>
+         <cstring>txtMapName</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="txtMapName">
+         <string>Prefix attached to map, scalebar and legend GIF filenames created using this MapFile</string>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="textLabel4">
+         <string>Image type</string>
+        </property>
+        <property name="alignment">
+         <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+        </property>
+         <cstring>cmbMapImageType</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QComboBox" name="cmbMapImageType">
         <item>
-         <widget class="QLabel" name="textLabel3">
-           <string>Units</string>
-          </property>
-          <property name="alignment">
-           <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
-          </property>
-           <cstring>cmbMapUnits</cstring>
-          </property>
-         </widget>
+          <string>png</string>
+         </property>
         </item>
         <item>
-         <widget class="QComboBox" name="cmbMapUnits"/>
+          <string>gif</string>
+         </property>
         </item>
         <item>
-         <widget class="QLabel" name="textLabel4">
-           <string>Image type</string>
-          </property>
-          </property>
-           <cstring>cmbMapImageType</cstring>
-          </property>
-         </widget>
+          <string>gtiff</string>
+         </property>
         </item>
         <item>
-         <widget class="QComboBox" name="cmbMapImageType">
-          <item>
-            <string>png</string>
-           </property>
-          </item>
-          <item>
-            <string>gif</string>
-           </property>
-          </item>
-          <item>
-            <string>gtiff</string>
-           </property>
-          </item>
-          <item>
-            <string>jpeg</string>
-           </property>
-          </item>
-          <item>
-            <string>swf</string>
-           </property>
-          </item>
-          <item>
-            <string>userdefined</string>
-           </property>
-          </item>
-          <item>
-            <string>wbmp</string>
-           </property>
-          </item>
-         </widget>
+          <string>jpeg</string>
+         </property>
         </item>
-       </layout>
-      </item>
-        </property>
-        </property>
         <item>
-         <widget class="QLabel" name="textLabel2">
-           <string>Width</string>
-          </property>
-           <cstring>txtMapWidth</cstring>
-          </property>
-         </widget>
+          <string>swf</string>
+         </property>
         </item>
         <item>
-         <widget class="QLineEdit" name="txtMapWidth"/>
+          <string>userdefined</string>
+         </property>
         </item>
         <item>
-         <widget class="QLabel" name="textLabel2_2">
-           <string>Height</string>
-          </property>
-           <cstring>txtMapHeight</cstring>
-          </property>
-         </widget>
+          <string>wbmp</string>
+         </property>
         </item>
-        <item>
-         <widget class="QLineEdit" name="txtMapHeight"/>
-        </item>
-       </layout>
+       </widget>
       </item>
-      <item row="0" column="0">
+      <item row="0" column="4">
+       <widget class="QLabel" name="label">
         </property>
+         <string>Rendering</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabel1">
-           <string/>
-          </property>
-           <string>Name</string>
-          </property>
-           <cstring>txtMapName</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtMapName">
-           <string>Prefix attached to map, scalebar and legend GIF filenames created using this MapFile</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+       </widget>
       </item>
+      <item row="0" column="5">
+       <widget class="QComboBox" name="comboBox">
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="0">
+       <widget class="QLabel" name="textLabel2">
+         <string>Width</string>
+        </property>
+         <cstring>txtMapWidth</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1">
+       <widget class="QLineEdit" name="txtMapWidth"/>
+      </item>
+      <item row="1" column="2">
+       <widget class="QLabel" name="textLabel2_2">
+         <string>Height</string>
+        </property>
+         <cstring>txtMapHeight</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="3">
+       <widget class="QLineEdit" name="txtMapHeight"/>
+      </item>
+      <item row="1" column="4">
+       <widget class="QLabel" name="textLabel3">
+         <string>Units</string>
+        </property>
+        </property>
+         <cstring>cmbMapUnits</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="5">
+       <widget class="QComboBox" name="cmbMapUnits"/>
+      </item>
+      <item row="2" column="0">
+       <widget class="QLabel" name="textLabelMapServerUrl">
+        <property name="minimumSize">
+         <size>
+          <width>80</width>
+          <height>0</height>
+         </size>
+        </property>
+         <string>MapServer url</string>
+        </property>
+         <cstring>txtMapServerUrl</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" colspan="5">
+       <widget class="QLineEdit" name="txtMapServerUrl">
+         <string>The URL to the mapserver executable.
+For example:
+http://my.host.com/cgi-bin/mapserv.exe</string>
+        </property>
+         <string/>
+        </property>
+       </widget>
+      </item>
      </layout>
     </widget>
    </item>
-    <widget class="QLabel" name="textLabel7">
-      <string>Map file</string>
+   <item row="3" column="0" colspan="3">
+    <widget class="QGroupBox" name="grpPaths">
+     <property name="title">
+      <string>Paths</string>
      </property>
-      <cstring>txtMapFilePath</cstring>
-     </property>
+     <layout class="QGridLayout" name="gridLayout_4">
+       <widget class="QCheckBox" name="checkBoxInlineFontAndSymbol">
+        </property>
+         <string>Inline</string>
+        </property>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="textLabelSymbolsetPath">
+         <bool>true</bool>
+        </property>
+         <size>
+          <width>80</width>
+         </size>
+        </property>
+         <string>Symbolset</string>
+        </property>
+         <cstring>txtSymbolsetPath</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QCheckBox" name="checkBoxUseTemplates">
+        </property>
+         <string>Use templates</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="2" colspan="3">
+       <widget class="QLineEdit" name="txtWebTemplate">
+         <bool>true</bool>
+        </property>
+         <string>Path to the MapServer template file</string>
+        </property>
+       </widget>
+      </item>
+       <widget class="QPushButton" name="btnChooseTemplateFile">
+         <bool>true</bool>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="2" colspan="3">
+       <widget class="QLineEdit" name="txtWebHeader">
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="5">
+       <widget class="QPushButton" name="btnChooseHeaderFile">
+         <bool>true</bool>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2" colspan="3">
+       <widget class="QLineEdit" name="txtWebFooter">
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="5">
+       <widget class="QPushButton" name="btnChooseFooterFile">
+         <bool>true</bool>
+        </property>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="txtFontsetPath">
+         <bool>true</bool>
+        </property>
+         <string>The file name of the fonts file.</string>
+        </property>
+         <string/>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="textLabelFontsetPath">
+         <bool>true</bool>
+        </property>
+         <size>
+          <width>80</width>
+         </size>
+        </property>
+         <string>Fontset</string>
+        </property>
+         <cstring>txtFontsetPath</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="txtSymbolsetPath">
+         <bool>true</bool>
+        </property>
+         <string>The file name of the symbols file.</string>
+        </property>
+         <string/>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLabel" name="textLabel5_2">
+         <bool>true</bool>
+        </property>
+         <size>
+          <width>60</width>
+         </size>
+        </property>
+         <string>Template</string>
+        </property>
+         <cstring>txtWebTemplate</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1">
+       <widget class="QLabel" name="textLabel5">
+         <bool>true</bool>
+        </property>
+         <size>
+          <width>60</width>
+         </size>
+        </property>
+         <string>Header</string>
+        </property>
+         <cstring>txtWebHeader</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="1">
+       <widget class="QLabel" name="textLabel5_3">
+         <bool>true</bool>
+        </property>
+         <size>
+          <width>60</width>
+         </size>
+        </property>
+         <string>Footer</string>
+        </property>
+         <cstring>txtWebFooter</cstring>
+        </property>
+       </widget>
+      </item>
+     </layout>
     </widget>
    </item>
-   <item row="0" column="1">
-    <widget class="QLineEdit" name="txtMapFilePath">
-      <string>Name for the map file to be created from the QGIS project file</string>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="2">
-    <widget class="QPushButton" name="btnChooseProjectFile">
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="1">
-    <widget class="QLineEdit" name="txtQgisFilePath">
-      <string>Full path to the QGIS project file to export to MapServer map format</string>
-     </property>
-    </widget>
-   </item>
-    <widget class="QLabel" name="textLabel7_2">
-      <string>QGIS project file</string>
-     </property>
-      <cstring>txtQgisFilePath</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="2">
-    <widget class="QPushButton" name="btnChooseFile">
-      <string>Save As...</string>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="1" colspan="2">
-    <widget class="QCheckBox" name="chkExpLayersOnly">
-      <string>If checked, only the layer information will be processed</string>
-     </property>
-      <string>Export LAYER information only</string>
-     </property>
-    </widget>
-   </item>
-   <item row="7" column="0" colspan="3">
+   <item row="6" column="0" colspan="3">
     <widget class="QDialogButtonBox" name="buttonBox">
      <property name="standardButtons">
       <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
-   <item row="6" column="0" colspan="3">
+   <item row="4" column="0" colspan="3">
     <widget class="QGroupBox" name="grpOptions">
      <property name="sizePolicy">
       <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
@@ -384,211 +483,60 @@
       </sizepolicy>
      </property>
-      <string>Options</string>
+      <string>Layer/label options</string>
      </property>
-     <layout class="QGridLayout" name="gridLayout" rowstretch="0" rowminimumheight="0">
-      </property>
-      </property>
+     <layout class="QGridLayout" name="gridLayout_5">
-       <layout class="QHBoxLayout" name="optionsLayout" stretch="0,0,0,0">
-        <property name="sizeConstraint">
-         <enum>QLayout::SetDefaultConstraint</enum>
+       <widget class="QCheckBox" name="checkBoxForce">
+         <string>Forces labels on, regardless of collisions. Available only for cached labels.</string>
         </property>
+         <string>Force</string>
         </property>
-        <item>
-         <widget class="QCheckBox" name="checkBoxForce">
-           <string>Forces labels on, regardless of collisions. Available only for cached labels.</string>
-          </property>
-           <string>Force</string>
-          </property>
-          <property name="checked">
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QCheckBox" name="checkBoxAntiAlias">
-           <string>Should text be antialiased? Note that this requires more available colors, decreases drawing performance, and results in slightly larger output images.</string>
-          </property>
-           <string>Anti-alias</string>
-          </property>
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QCheckBox" name="checkBoxPartials">
-           <string>Can text run off the edge of the map?</string>
-          </property>
-           <string>Partials</string>
-          </property>
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QCheckBox" name="checkBoxDump">
-           <string>Check to allow MapServer to return data in GML format. Useful when used with WMS GetFeatureInfo operations.</string>
-          </property>
-           <string>Dump</string>
-          </property>
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-       </layout>
+         <bool>true</bool>
+        </property>
+       </widget>
       </item>
-     </layout>
-    </widget>
-   </item>
-   <item row="4" column="0" colspan="3">
-    <widget class="QGroupBox" name="grpPaths">
-     <property name="title">
-      <string>Paths</string>
-     </property>
-     <layout class="QGridLayout" name="gridLayout_2">
-      </property>
-      </property>
-       <layout class="QHBoxLayout" name="horizontalLayout">
+       <widget class="QCheckBox" name="checkBoxAntiAlias">
+         <string>Should text be antialiased? Note that this requires more available colors, decreases drawing performance, and results in slightly larger output images.</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabelMapServerUrl">
-           <size>
-            <width>80</width>
-           </size>
-          </property>
-           <string>MapServer url</string>
-          </property>
-           <cstring>txtMapServerUrl</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtMapServerUrl">
-           <string>&lt;!DOCTYPE HTML PUBLIC &quot;-//W3C//DTD HTML 4.0//EN&quot; &quot;http://www.w3.org/TR/REC-html40/strict.dtd&quot;&gt;
-&lt;html&gt;&lt;head&gt;&lt;meta name=&quot;qrichtext&quot; content=&quot;1&quot; /&gt;&lt;style type=&quot;text/css&quot;&gt;
-p, li { white-space: pre-wrap; }
-&lt;/style&gt;&lt;/head&gt;&lt;body style=&quot; font-family:'MS Shell Dlg 2'; font-size:8.25pt; font-weight:400; font-style:normal;&quot;&gt;
-&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-size:8pt;&quot;&gt;The URL to the mapserver executable.&lt;/span&gt;&lt;/p&gt;
-&lt;p style=&quot;-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-size:8pt;&quot;&gt;&lt;/p&gt;
-&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-size:8pt;&quot;&gt;For example: &lt;/span&gt;&lt;/p&gt;
-&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-size:8pt;&quot;&gt;http://my.host.com/cgi-bin/mapserv.exe&lt;/span&gt;&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</string>
-          </property>
-           <string/>
-          </property>
-         </widget>
-        </item>
-       </layout>
+         <string>Anti-alias</string>
+        </property>
+         <bool>true</bool>
+        </property>
+       </widget>
       </item>
-       <layout class="QHBoxLayout" name="horizontalLayout_2">
+       <widget class="QCheckBox" name="checkBoxPartials">
+         <string>Can text run off the edge of the map?</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabelFontsetPath">
-           <size>
-            <width>80</width>
-           </size>
-          </property>
-           <string>Fontset path</string>
-          </property>
-           <cstring>txtFontsetPath</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtFontsetPath">
-          </property>
-           <string/>
-          </property>
-         </widget>
-        </item>
-       </layout>
+         <string>Partials</string>
+        </property>
+         <bool>true</bool>
+        </property>
+       </widget>
       </item>
-       <layout class="QHBoxLayout" name="horizontalLayout_3">
+       <widget class="QCheckBox" name="checkBoxDump">
+         <string>Check to allow MapServer to return data in GML format. Useful when used with WMS GetFeatureInfo operations.</string>
         </property>
-        <item>
-         <widget class="QLabel" name="textLabelSymbolsetPath">
-           <size>
-            <width>80</width>
-           </size>
-          </property>
-           <string>Symbolset path</string>
-          </property>
-           <cstring>txtSymbolsetPath</cstring>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="txtSymbolsetPath">
-          </property>
-           <string/>
-          </property>
-         </widget>
-        </item>
-       </layout>
+         <string>Dump</string>
+        </property>
+         <bool>true</bool>
+        </property>
+       </widget>
       </item>
      </layout>
     </widget>
@@ -598,43 +546,14 @@
  <layoutdefault spacing="6" margin="11"/>
  <pixmapfunction>qPixmapFromMimeSource</pixmapfunction>
  <tabstops>
-  <tabstop>txtMapFilePath</tabstop>
-  <tabstop>btnChooseFile</tabstop>
-  <tabstop>txtQgisFilePath</tabstop>
-  <tabstop>btnChooseProjectFile</tabstop>
-  <tabstop>chkExpLayersOnly</tabstop>
   <tabstop>txtMapName</tabstop>
   <tabstop>txtMapWidth</tabstop>
   <tabstop>txtMapHeight</tabstop>
-  <tabstop>cmbMapUnits</tabstop>
-  <tabstop>cmbMapImageType</tabstop>
-  <tabstop>txtWebTemplate</tabstop>
-  <tabstop>btnChooseTemplateFile</tabstop>
-  <tabstop>txtWebHeader</tabstop>
-  <tabstop>btnChooseHeaderFile</tabstop>
-  <tabstop>txtWebFooter</tabstop>
-  <tabstop>btnChooseFooterFile</tabstop>
  </tabstops>
  <resources/>
  <connections>
   <connection>
    <sender>buttonBox</sender>
-   <signal>accepted()</signal>
-   <receiver>QgsMapserverExportBase</receiver>
-   <slot>accept()</slot>
-   <hints>
-    <hint type="sourcelabel">
-     <x>335</x>
-     <y>422</y>
-    </hint>
-    <hint type="destinationlabel">
-     <x>240</x>
-     <y>223</y>
-    </hint>
-   </hints>
-  </connection>
-  <connection>
-   <sender>buttonBox</sender>
    <signal>rejected()</signal>
    <slot>reject()</slot>
More information about the QGIS-commit mailing list
