[QGIS Commit] r12123 - in trunk/qgis/src: plugins/diagram_overlay ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 15 10:19:44 EST 2009
Author: timlinux
Date: 2009-11-15 10:19:43 -0500 (Sun, 15 Nov 2009)
New Revision: 12123
   trunk/qgis/src/plugins/diagram_overlay/qgsdiagramdialogbase.ui
   trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui
   trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
   trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
UI tidy ups
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramdialogbase.ui
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramdialogbase.ui	2009-11-15 14:47:17 UTC (rev 12122)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramdialogbase.ui	2009-11-15 15:19:43 UTC (rev 12123)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>398</width>
-    <height>441</height>
+    <width>338</width>
+    <height>324</height>
    </rect>
   </property>
   <property name="windowTitle">
Modified: trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui
--- trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui	2009-11-15 14:47:17 UTC (rev 12122)
+++ trunk/qgis/src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui	2009-11-15 15:19:43 UTC (rev 12123)
@@ -20,7 +20,7 @@
    <item row="0" column="0">
     <widget class="QLabel" name="mTitleLabel">
      <property name="text">
-      <string>Scale linearly between 0 and the following attribute value/ diagram size:</string>
+      <string>Scale linearly between 0 and the following attribute value / diagram size:</string>
      </property>
      <property name="wordWrap">
       <bool>true</bool>
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-11-15 14:47:17 UTC (rev 12122)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-11-15 15:19:43 UTC (rev 12123)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>703</width>
-    <height>518</height>
+    <width>360</width>
+    <height>470</height>
    </rect>
   </property>
   <property name="sizePolicy">
@@ -19,210 +19,146 @@
    <string>Single Symbol</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout_5">
+  <layout class="QGridLayout" name="gridLayout_6">
    <property name="margin">
     <number>0</number>
    </property>
-    <widget class="QLabel" name="mLabel">
-     <property name="minimumSize">
-      <size>
-       <width>0</width>
-       <height>22</height>
-      </size>
+    <widget class="QScrollArea" name="scrollArea">
+     <property name="widgetResizable">
+      <bool>true</bool>
      </property>
-     <property name="text">
-      <string>Label</string>
-     </property>
-     <property name="buddy">
-      <cstring>mLabelEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="1">
-    <widget class="QLineEdit" name="mLabelEdit">
-      <size>
-       <width>0</width>
-      </size>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="0" colspan="2">
-    <widget class="QGroupBox" name="mGroupPoint">
-     <property name="sizePolicy">
-      <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-     <property name="title">
-      <string>Point Symbol</string>
-     </property>
-     <layout class="QGridLayout" name="gridLayout_4">
-      <item row="0" column="0" colspan="3">
-       <widget class="QListWidget" name="lstSymbols">
-         <sizepolicy hsizetype="Expanding" vsizetype="MinimumExpanding">
-         </sizepolicy>
-        </property>
-        <property name="dragDropMode">
-         <enum>QAbstractItemView::DragDrop</enum>
-        </property>
-        <property name="alternatingRowColors">
-         <bool>false</bool>
-        </property>
-        <property name="iconSize">
-         <size>
-          <width>0</width>
-          <height>-1</height>
-         </size>
-        </property>
-        <property name="resizeMode">
-         <enum>QListView::Adjust</enum>
-        </property>
-        <property name="viewMode">
-         <enum>QListView::IconMode</enum>
-        </property>
-        <property name="uniformItemSizes">
-         <bool>true</bool>
-        </property>
-        <property name="wordWrap">
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="0">
-       <widget class="QLabel" name="textLabel1_2">
-         <string>Size</string>
-        </property>
-         <cstring>mPointSizeSpinBox</cstring>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="1">
-       <widget class="QDoubleSpinBox" name="mPointSizeSpinBox">
-        <property name="decimals">
-         <number>5</number>
-        </property>
-        <property name="maximum">
-         <double>1000000.000000000000000</double>
-        </property>
-        <property name="singleStep">
-         <double>0.100000000000000</double>
-        </property>
-        <property name="value">
-         <double>1.000000000000000</double>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="2">
-       <widget class="QCheckBox" name="mPointSizeUnitsCheckBox">
-         <string>In map units</string>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="2">
-       <layout class="QHBoxLayout" name="horizontalLayout"/>
-      </item>
-     </layout>
-    </widget>
-   </item>
-   <item row="2" column="0" colspan="2">
-    <layout class="QHBoxLayout" name="horizontalLayout_2">
-     <item>
-      <widget class="QGroupBox" name="mGroupDrawingByField">
-        <string>Drawing by field</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout">
-        <item row="0" column="0">
-         <widget class="QLabel" name="mLblRotationField">
-           <string>Rotation</string>
-          </property>
-           <cstring>mRotationClassificationComboBox</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="mRotationClassificationComboBox">
-           <size>
-            <width>0</width>
-            <height>20</height>
-           </size>
-          </property>
-         </widget>
-        </item>
-         <widget class="QLabel" name="textLabel9">
-           <string>Area scale</string>
-          </property>
-           <cstring>mScaleClassificationComboBox</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="mScaleClassificationComboBox">
-           <size>
-            <width>0</width>
-           </size>
-          </property>
-         </widget>
-        </item>
-        <item row="2" column="0">
-         <widget class="QLabel" name="label">
-           <string>Symbol</string>
-          </property>
-           <cstring>mSymbolComboBox</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="2" column="1">
-         <widget class="QComboBox" name="mSymbolComboBox"/>
-        </item>
-        <item row="3" column="0">
-         <spacer name="verticalSpacer_2">
-          <property name="orientation">
-           <enum>Qt::Vertical</enum>
-          </property>
-          <property name="sizeHint" stdset="0">
-           <size>
-            <width>20</width>
-            <height>40</height>
-           </size>
-          </property>
-         </spacer>
-        </item>
-       </layout>
-      </widget>
-     </item>
-     <item>
-      <layout class="QVBoxLayout" name="verticalLayout">
-       <item>
+     <widget class="QWidget" name="scrollAreaWidgetContents">
+      <property name="geometry">
+       <rect>
+        <x>0</x>
+        <y>0</y>
+        <width>337</width>
+        <height>616</height>
+       </rect>
+      </property>
+      <layout class="QGridLayout" name="gridLayout_5">
+       <item row="0" column="0">
+        <widget class="QGroupBox" name="mGroupPoint">
+         <property name="sizePolicy">
+          <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+           <horstretch>0</horstretch>
+           <verstretch>0</verstretch>
+          </sizepolicy>
+         </property>
+         <property name="title">
+          <string>Point Symbol</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_4">
+          <item row="0" column="0" colspan="3">
+           <widget class="QListWidget" name="lstSymbols">
+             <sizepolicy hsizetype="Expanding" vsizetype="MinimumExpanding">
+             </sizepolicy>
+            </property>
+            <property name="dragDropMode">
+             <enum>QAbstractItemView::DragDrop</enum>
+            </property>
+            <property name="alternatingRowColors">
+             <bool>false</bool>
+            </property>
+            <property name="iconSize">
+             <size>
+              <width>0</width>
+              <height>-1</height>
+             </size>
+            </property>
+            <property name="resizeMode">
+             <enum>QListView::Adjust</enum>
+            </property>
+            <property name="viewMode">
+             <enum>QListView::IconMode</enum>
+            </property>
+            <property name="uniformItemSizes">
+             <bool>true</bool>
+            </property>
+            <property name="wordWrap">
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="0">
+           <widget class="QLabel" name="textLabel1_2">
+            <property name="text">
+             <string>Size</string>
+            </property>
+            <property name="buddy">
+             <cstring>mPointSizeSpinBox</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="1">
+           <widget class="QDoubleSpinBox" name="mPointSizeSpinBox">
+            <property name="decimals">
+             <number>5</number>
+            </property>
+            <property name="maximum">
+             <double>1000000.000000000000000</double>
+            </property>
+            <property name="singleStep">
+             <double>0.100000000000000</double>
+            </property>
+            <property name="value">
+             <double>1.000000000000000</double>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="2">
+           <widget class="QCheckBox" name="mPointSizeUnitsCheckBox">
+             <string>In map units</string>
+            </property>
+           </widget>
+          </item>
+          <item row="2" column="2">
+           <layout class="QHBoxLayout" name="horizontalLayout"/>
+          </item>
+         </layout>
+        </widget>
+       </item>
+        <widget class="QLabel" name="mLabel">
+         <property name="minimumSize">
+          <size>
+           <width>0</width>
+           <height>22</height>
+          </size>
+         </property>
+          <string>Label</string>
+         </property>
+          <cstring>mLabelEdit</cstring>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="0">
+        <widget class="QLineEdit" name="mLabelEdit">
+          <size>
+           <width>0</width>
+          </size>
+         </property>
+        </widget>
+       </item>
+       <item row="3" column="0">
         <widget class="QGroupBox" name="groupBox">
           <string>Fill options</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout_3">
+         <layout class="QHBoxLayout" name="horizontalLayout_2">
+          <item>
            <widget class="QComboBox" name="cboFillStyle">
+             <sizepolicy hsizetype="Minimum" vsizetype="Fixed">
              </sizepolicy>
@@ -239,16 +175,22 @@
               <height>16777215</height>
              </size>
             </property>
+             <size>
+              <width>32</width>
+              <height>32</height>
+             </size>
+            </property>
            </widget>
           </item>
+          <item>
            <widget class="QToolButton" name="toolSelectTexture">
              <string>...</string>
             </property>
            </widget>
           </item>
-          <item row="0" column="2">
+          <item>
            <widget class="QgsColorButton" name="btnFillColor">
@@ -259,7 +201,7 @@
              <size>
               <width>32</width>
+              <height>0</height>
              </size>
             </property>
             <property name="maximumSize">
@@ -273,7 +215,7 @@
             </property>
            </widget>
           </item>
-          <item row="0" column="3">
+          <item>
            <spacer name="horizontalSpacer">
              <enum>Qt::Horizontal</enum>
@@ -289,7 +231,7 @@
          </layout>
         </widget>
        </item>
-       <item>
+       <item row="4" column="0">
         <widget class="QGroupBox" name="groupBox_3">
@@ -300,11 +242,14 @@
           <string>Outline options</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout_2">
+         <layout class="QHBoxLayout" name="horizontalLayout_3">
+          <item>
+           <layout class="QHBoxLayout"/>
+          </item>
+          <item>
            <widget class="QComboBox" name="cboOutlineStyle">
-             <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
              </sizepolicy>
@@ -315,15 +260,15 @@
               <height>20</height>
              </size>
             </property>
-            <property name="maximumSize">
              <size>
-              <width>172</width>
-              <height>16777215</height>
+              <width>32</width>
              </size>
             </property>
            </widget>
           </item>
+          <item>
            <widget class="QgsColorButton" name="btnOutlineColor">
@@ -334,7 +279,7 @@
              <size>
               <width>32</width>
              </size>
             </property>
@@ -348,7 +293,7 @@
             </property>
            </widget>
           </item>
+          <item>
            <widget class="QLabel" name="outlinewidthlabel">
              <string>Width</string>
@@ -358,8 +303,14 @@
             </property>
            </widget>
           </item>
+          <item>
            <widget class="QDoubleSpinBox" name="outlinewidthspinbox">
+             </sizepolicy>
+            </property>
              <size>
               <width>0</width>
@@ -377,10 +328,7 @@
             </property>
            </widget>
           </item>
-           <layout class="QHBoxLayout"/>
-          </item>
-          <item row="0" column="4">
+          <item>
            <spacer name="horizontalSpacer_2">
@@ -396,22 +344,57 @@
          </layout>
         </widget>
        </item>
-       <item>
-        <spacer name="verticalSpacer">
+       <item row="5" column="0">
+        <widget class="QGroupBox" name="mGroupDrawingByField">
+          <string>Drawing by field</string>
          </property>
-          <size>
-           <width>20</width>
-          </size>
-         </property>
-        </spacer>
+         <layout class="QGridLayout" name="gridLayout">
+           <widget class="QLabel" name="mLblRotationField">
+             <string>Rotation</string>
+            </property>
+             <cstring>mRotationClassificationComboBox</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="0" column="1">
+           <widget class="QComboBox" name="mRotationClassificationComboBox"/>
+          </item>
+           <widget class="QLabel" name="textLabel9">
+             <string>Area scale</string>
+            </property>
+             <cstring>mScaleClassificationComboBox</cstring>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="mScaleClassificationComboBox"/>
+          </item>
+           <widget class="QLabel" name="label">
+             <string>Symbol</string>
+            </property>
+             <cstring>mSymbolComboBox</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="2" column="1">
+           <widget class="QComboBox" name="mSymbolComboBox"/>
+          </item>
+         </layout>
+        </widget>
        </item>
       </layout>
-     </item>
-    </layout>
+     </widget>
+    </widget>
    </item>
   </layout>
  </widget>
@@ -424,14 +407,20 @@
   </customwidget>
  </customwidgets>
  <tabstops>
-  <tabstop>mLabelEdit</tabstop>
   <tabstop>lstSymbols</tabstop>
-  <tabstop>mRotationClassificationComboBox</tabstop>
-  <tabstop>mSymbolComboBox</tabstop>
-  <tabstop>mScaleClassificationComboBox</tabstop>
+  <tabstop>mPointSizeSpinBox</tabstop>
+  <tabstop>mPointSizeUnitsCheckBox</tabstop>
+  <tabstop>mLabelEdit</tabstop>
+  <tabstop>cboFillStyle</tabstop>
+  <tabstop>toolSelectTexture</tabstop>
+  <tabstop>btnFillColor</tabstop>
   <tabstop>cboOutlineStyle</tabstop>
   <tabstop>btnOutlineColor</tabstop>
   <tabstop>outlinewidthspinbox</tabstop>
+  <tabstop>mRotationClassificationComboBox</tabstop>
+  <tabstop>mScaleClassificationComboBox</tabstop>
+  <tabstop>mSymbolComboBox</tabstop>
+  <tabstop>scrollArea</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui	2009-11-15 14:47:17 UTC (rev 12122)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui	2009-11-15 15:19:43 UTC (rev 12123)
@@ -74,7 +74,7 @@
    <item row="0" column="2" colspan="3">
     <widget class="QStackedWidget" name="stackedWidget">
      <property name="currentIndex">
-      <number>3</number>
+      <number>0</number>
      </property>
      <widget class="QWidget" name="page_3">
More information about the QGIS-commit mailing list
