[QGIS Commit] r12140 - in trunk/qgis: python/core src/core src/core/renderer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Nov 16 06:53:52 EST 2009
Author: wonder
Date: 2009-11-16 06:53:50 -0500 (Mon, 16 Nov 2009)
New Revision: 12140
   trunk/qgis/python/core/qgsapplication.sip
   trunk/qgis/python/core/qgsmaplayer.sip
   trunk/qgis/python/core/qgsrenderer.sip
   trunk/qgis/python/core/qgsvectorlayer.sip
   trunk/qgis/src/core/qgsapplication.h
   trunk/qgis/src/core/qgsmaplayer.h
   trunk/qgis/src/core/qgsvectorlayer.h
   trunk/qgis/src/core/renderer/qgsrenderer.h
Updated version of QGIS when the new function were added to 1.4
Modified: trunk/qgis/python/core/qgsapplication.sip
--- trunk/qgis/python/core/qgsapplication.sip	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/python/core/qgsapplication.sip	2009-11-16 11:53:50 UTC (rev 12140)
@@ -156,10 +156,10 @@
     //! @note deprecated
     static const QString svgPath();
-    //! Returns the path to user's style. Added in QGIS 1.2
+    //! Returns the path to user's style. Added in QGIS 1.4
     static const QString userStyleV2Path();
-    //! Returns the path to default style (works as a starting point). Added in QGIS 1.2
+    //! Returns the path to default style (works as a starting point). Added in QGIS 1.4
     static const QString defaultStyleV2Path();
     //! Returns the path to the application prefix directory.
Modified: trunk/qgis/python/core/qgsmaplayer.sip
--- trunk/qgis/python/core/qgsmaplayer.sip	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/python/core/qgsmaplayer.sip	2009-11-16 11:53:50 UTC (rev 12140)
@@ -145,13 +145,13 @@
     bool writeXML(QDomNode & layer_node, QDomDocument & document) const;
     /** Set a custom property for layer. Properties are stored in a map and saved in project file.
-     *  @note Added in v1.3 */
+     *  @note Added in v1.4 */
     void setCustomProperty( const QString& key, const QVariant& value );
     /** Read a custom property from layer. Properties are stored in a map and saved in project file.
     QVariant customProperty( const QString& value, const QVariant& defaultValue = QVariant() ) const;
     /** Remove a custom property from layer. Properties are stored in a map and saved in project file.
     void removeCustomProperty( const QString& key );
     /** Read the symbology for the current layer from the Dom node supplied.
Modified: trunk/qgis/python/core/qgsrenderer.sip
--- trunk/qgis/python/core/qgsrenderer.sip	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/python/core/qgsrenderer.sip	2009-11-16 11:53:50 UTC (rev 12140)
@@ -52,7 +52,7 @@
     virtual QgsRenderer* clone() const=0;
     /** Change selection color */
     static void setSelectionColor(QColor color);
-    /** Get selection color */
+    /** Get selection color. Added in QGIS v1.4 */
     static QColor selectionColor();
     /**Returns true if this renderer returns a pixmap in the render method (e.g. for point data or diagrams)*/
     virtual bool containsPixmap() const;
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/python/core/qgsvectorlayer.sip	2009-11-16 11:53:50 UTC (rev 12140)
@@ -101,16 +101,18 @@
   /** Sets the renderer. If a renderer is already present, it is deleted */
   void setRenderer(QgsRenderer * r /Transfer/);
-  /** Return renderer V2. Added in QGIS 1.2 */
+  /** Return renderer V2. Added in QGIS 1.4 */
   QgsFeatureRendererV2* rendererV2();
-  /** Set renderer V2. Added in QGIS 1.2 */
+  /** Set renderer V2. Added in QGIS 1.4 */
   void setRendererV2(QgsFeatureRendererV2* r);
-  /** Return whether using renderer V2. Added in QGIS 1.2 */
+  /** Return whether using renderer V2. Added in QGIS 1.4 */
   bool isUsingRendererV2();
-  /** set whether to use renderer V2 for drawing. Added in QGIS 1.2 */
+  /** set whether to use renderer V2 for drawing. Added in QGIS 1.4 */
   void setUsingRendererV2(bool usingRendererV2);
+  /** Draw layer with renderer V2. Added in QGIS 1.4 */
   void drawRendererV2( QgsRenderContext& rendererContext, bool labeling );
+  /** Draw layer with renderer V2 using symbol levels. Added in QGIS 1.4 */
   void drawRendererV2Levels( QgsRenderContext& rendererContext, bool labeling );
   /** Returns point, line or polygon */
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/src/core/qgsapplication.h	2009-11-16 11:53:50 UTC (rev 12140)
@@ -127,10 +127,10 @@
     //! Returns the path to the default theme directory.
     static const QString defaultThemePath();
     //! Alters prefix path - used by 3rd party apps
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/src/core/qgsmaplayer.h	2009-11-16 11:53:50 UTC (rev 12140)
@@ -162,13 +162,13 @@
     bool writeXML( QDomNode & layer_node, QDomDocument & document );
     /** Copies the symbology settings from another layer. Returns true in case of success */
@@ -348,10 +348,10 @@
     virtual bool writeXml( QDomNode & layer_node, QDomDocument & document );
-    /** Read custom properties from project file. Added in v1.3 */
+    /** Read custom properties from project file. Added in v1.4 */
     void readCustomProperties( QDomNode & layerNode );
-    /** Write custom properties to project file. Added in v1.3 */
+    /** Write custom properties to project file. Added in v1.4 */
     void writeCustomProperties( QDomNode & layerNode, QDomDocument & doc );
     /** debugging member - invoked when a connect() is made to this object */
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2009-11-16 11:53:50 UTC (rev 12140)
@@ -177,16 +177,18 @@
     void setRenderer( QgsRenderer * r );
@@ -359,6 +361,7 @@
     /** Label is on */
     bool hasLabelsEnabled( void ) const;
+    /** Assign a custom labeling engine with layer. Added in v1.4 */
     void setLabelingEngine(QgsLabelingEngineInterface* engine);
     /** Returns true if the provider is in editing mode */
Modified: trunk/qgis/src/core/renderer/qgsrenderer.h
--- trunk/qgis/src/core/renderer/qgsrenderer.h	2009-11-16 10:36:24 UTC (rev 12139)
+++ trunk/qgis/src/core/renderer/qgsrenderer.h	2009-11-16 11:53:50 UTC (rev 12140)
@@ -101,7 +101,7 @@
     virtual QgsRenderer* clone() const = 0;
     static void setSelectionColor( QColor color );
More information about the QGIS-commit mailing list
