[QGIS Commit] r12165 - in trunk/qgis: python/core src/app src/core
src/ui
svn_qgis at osgeo.org
Tue Nov 17 13:47:48 EST 2009
Author: jef
Date: 2009-11-17 13:47:47 -0500 (Tue, 17 Nov 2009)
New Revision: 12165
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/src/app/qgsattributeeditor.cpp
trunk/qgis/src/app/qgsattributetypedialog.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/ui/qgsattributetypeedit.ui
add support for multiline edit widget
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2009-11-17 18:47:47 UTC (rev 12165)
@@ -16,7 +16,9 @@
CheckBox, /* @note added in 1.4 */
FileName,
Enumeration, /* @note added in 1.4 */
- Immutable /* @note added in 1.4 */
+ Immutable, /* @note added in 1.4 */
+ Hidden, /* @note added in 1.4 */
+ TextEdit /* @note added in 1.4 */
struct RangeData {
Modified: trunk/qgis/src/app/qgsattributeeditor.cpp
--- trunk/qgis/src/app/qgsattributeeditor.cpp 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/src/app/qgsattributeeditor.cpp 2009-11-17 18:47:47 UTC (rev 12165)
@@ -242,7 +242,7 @@
if ( editor )
cb = qobject_cast<QCheckBox*>( editor );
else
- cb = new QCheckBox();
+ cb = new QCheckBox( parent );
if ( cb )
@@ -254,8 +254,8 @@
// fall-through
case QgsVectorLayer::LineEdit:
+ case QgsVectorLayer::TextEdit:
case QgsVectorLayer::UniqueValuesEditable:
- default:
QLineEdit *le = NULL;
QTextEdit *te = NULL;
@@ -267,6 +267,10 @@
te = qobject_cast<QTextEdit *>( editor );
pte = qobject_cast<QPlainTextEdit *>( editor );
+ else if ( editType == QgsVectorLayer::TextEdit )
+ pte = new QPlainTextEdit( parent );
else
le = new QLineEdit( parent );
Modified: trunk/qgis/src/app/qgsattributetypedialog.cpp
--- trunk/qgis/src/app/qgsattributetypedialog.cpp 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/src/app/qgsattributetypedialog.cpp 2009-11-17 18:47:47 UTC (rev 12165)
@@ -249,6 +249,9 @@
setPage( 9 );
break;
+ setPage( 10 );
setPage( 0 );
break;
@@ -459,6 +462,7 @@
//store data to output variables
switch ( selectionComboBox->currentIndex() )
+ default:
case 0:
mEditType = QgsVectorLayer::LineEdit;
break;
@@ -530,8 +534,9 @@
case 9:
mEditType = QgsVectorLayer::CheckBox;
break;
- default:
- mEditType = QgsVectorLayer::LineEdit;
+ case 10:
+ mEditType = QgsVectorLayer::TextEdit;
+ break;
QDialog::accept();
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-11-17 18:47:47 UTC (rev 12165)
@@ -579,6 +579,7 @@
editTypeMap.insert( QgsVectorLayer::Immutable, tr( "Immutable" ) );
editTypeMap.insert( QgsVectorLayer::Hidden, tr( "Hidden" ) );
editTypeMap.insert( QgsVectorLayer::CheckBox, tr( "Checkbox" ) );
+ editTypeMap.insert( QgsVectorLayer::TextEdit, tr( "Text edit" ) );
QString QgsVectorLayerProperties::editTypeButtonText( QgsVectorLayer::EditType type )
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2009-11-17 18:47:47 UTC (rev 12165)
@@ -55,12 +55,12 @@
class QgsLabelingEngineInterface
-public:
- virtual ~QgsLabelingEngineInterface() {}
- virtual int prepareLayer(QgsVectorLayer* layer, int& attrIndex) = 0;
- virtual void registerFeature(QgsVectorLayer* layer, QgsFeature& feat) = 0;
- //void calculateLabeling() = 0;
- //void drawLabeling(QgsRenderContext& context) = 0;
+ public:
+ virtual ~QgsLabelingEngineInterface() {}
+ virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex ) = 0;
+ virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat ) = 0;
+ //void calculateLabeling() = 0;
+ //void drawLabeling(QgsRenderContext& context) = 0;
@@ -86,7 +86,8 @@
FileName,
Enumeration,
Immutable, /*The attribute value should not be changed in the attribute form*/
- Hidden /*The attribute value should not be shown in the attribute form @added in 1.4 */
+ Hidden, /*The attribute value should not be shown in the attribute form @added in 1.4 */
+ TextEdit /*multiline edit @added in 1.4*/
struct RangeData
@@ -176,15 +177,15 @@
/** Sets the renderer. If a renderer is already present, it is deleted */
void setRenderer( QgsRenderer * r );
/** Return renderer V2. Added in QGIS 1.4 */
QgsFeatureRendererV2* rendererV2();
/** Set renderer V2. Added in QGIS 1.4 */
- void setRendererV2(QgsFeatureRendererV2* r);
+ void setRendererV2( QgsFeatureRendererV2* r );
/** Return whether using renderer V2. Added in QGIS 1.4 */
bool isUsingRendererV2();
/** set whether to use renderer V2 for drawing. Added in QGIS 1.4 */
- void setUsingRendererV2(bool usingRendererV2);
+ void setUsingRendererV2( bool usingRendererV2 );
/** Draw layer with renderer V2. Added in QGIS 1.4 */
void drawRendererV2( QgsRenderContext& rendererContext, bool labeling );
@@ -362,7 +363,7 @@
bool hasLabelsEnabled( void ) const;
/** Assign a custom labeling engine with layer. Added in v1.4 */
- void setLabelingEngine(QgsLabelingEngineInterface* engine);
+ void setLabelingEngine( QgsLabelingEngineInterface* engine );
/** Returns true if the provider is in editing mode */
virtual bool isEditable() const;
@@ -477,10 +478,10 @@
/**set edit type*/
void setEditType( int idx, EditType edit );
/** set string representing 'true' for a checkbox (added in 1.4) */
void setCheckedState( int idx, QString checked, QString notChecked );
/** return string representing 'true' for a checkbox (added in 1.4) */
QPair<QString, QString> checkedState( int idx );
@@ -736,10 +737,10 @@
/** Renderer object which holds the information about how to display the features */
QgsRenderer *mRenderer;
/** Renderer V2 */
QgsFeatureRendererV2 *mRendererV2;
/** whether to use V1 or V2 renderer */
bool mUsingRendererV2;
@@ -769,7 +770,7 @@
QMap< QString, EditType > mEditTypes;
QMap< QString, QMap<QString, QVariant> > mValueMaps;
QMap< QString, RangeData > mRanges;
- QMap< QString, QPair<QString,QString> > mCheckedStates;
+ QMap< QString, QPair<QString, QString> > mCheckedStates;
QString mEditForm;
bool mFetching;
Modified: trunk/qgis/src/ui/qgsattributetypeedit.ui
--- trunk/qgis/src/ui/qgsattributetypeedit.ui 2009-11-17 16:08:09 UTC (rev 12164)
+++ trunk/qgis/src/ui/qgsattributetypeedit.ui 2009-11-17 18:47:47 UTC (rev 12165)
@@ -66,6 +66,11 @@
<string>Checkbox</string>
</property>
</item>
+ <item>
+ <property name="text">
+ <string>Text edit</string>
+ </property>
+ </item>
</widget>
</item>
<item>
@@ -77,7 +82,7 @@
</sizepolicy>
</property>
<property name="currentIndex">
- <number>9</number>
+ <number>0</number>
</property>
<widget class="QWidget" name="lineEditPage">
<layout class="QVBoxLayout" name="verticalLayout_1">
@@ -544,6 +549,33 @@
</item>
</layout>
</widget>
+ <widget class="QWidget" name="textEditPage">
+ <layout class="QVBoxLayout" name="verticalLayout_25">
+ <item>
+ <widget class="QLabel" name="hiddenLabel_3">
+ <string>A text edit field that accepts multiple lines will be used.</string>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="verticalSpacer_17">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>302</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
<item>
