[QGIS Commit] r12186 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Nov 19 06:19:33 EST 2009
Author: mhugent
Date: 2009-11-19 06:19:32 -0500 (Thu, 19 Nov 2009)
New Revision: 12186
   trunk/qgis/src/core/composer/qgscomposerpicture.cpp
   trunk/qgis/src/core/composer/qgscomposerpicture.h
Better preview for composer picture
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.cpp
--- trunk/qgis/src/core/composer/qgscomposerpicture.cpp	2009-11-19 10:55:58 UTC (rev 12185)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.cpp	2009-11-19 11:19:32 UTC (rev 12186)
@@ -26,12 +26,13 @@
 #include <QPainter>
 #include <QSvgRenderer>
 QgsComposerPicture::QgsComposerPicture( QgsComposition *composition ): QgsComposerItem( composition ), mMode( Unknown ), \
-    mSvgCacheUpToDate( false ), mCachedDpi( 0 ), mCachedRotation( 0 ), mRotationMap( 0 )
+    mSvgCacheUpToDate( false ), mCachedDpi( 0 ), mCachedRotation( 0 ), mCachedViewScaleFactor( -1 ), mRotationMap( 0 )
-QgsComposerPicture::QgsComposerPicture(): QgsComposerItem( 0 ), mMode( Unknown ), mSvgCacheUpToDate( false ), mCachedRotation( 0 ), mRotationMap( 0 )
+QgsComposerPicture::QgsComposerPicture(): QgsComposerItem( 0 ), mMode( Unknown ), mSvgCacheUpToDate( false ), mCachedRotation( 0 ), mCachedViewScaleFactor( -1 ), mRotationMap( 0 )
@@ -51,7 +52,9 @@
   drawBackground( painter );
   int newDpi = ( painter->device()->logicalDpiX() + painter->device()->logicalDpiY() ) / 2;
-  if ( newDpi != mCachedDpi || mCachedRotation != mRotation )
+  double viewScaleFactor = horizontalViewScaleFactor();
+  if ( newDpi != mCachedDpi || mCachedRotation != mRotation || mCachedViewScaleFactor != viewScaleFactor )
     mSvgCacheUpToDate = false;
@@ -82,6 +85,12 @@
       if ( !mSvgCacheUpToDate )
+        //make nicer preview
+        if ( mComposition && mComposition->plotStyle() == QgsComposition::Preview )
+          rotatedBoundImageWidth *= std::min( viewScaleFactor, 10.0 );
+          rotatedBoundImageHeight *= std::min( viewScaleFactor, 10.0 );
         mImage = QImage( rotatedBoundImageWidth, rotatedBoundImageHeight, QImage::Format_ARGB32 );
         updateImageFromSvg();
@@ -91,6 +100,12 @@
     painter->translate( boundRectWidthMM / 2.0, boundRectHeightMM / 2.0 );
     painter->rotate( mRotation );
     painter->translate( -rotatedBoundImageWidthMM / 2.0, -rotatedBoundImageHeightMM / 2.0 );
+    /*if ( mComposition && mComposition->plotStyle() == QgsComposition::Preview )
+      rotatedBoundImageWidthMM /= std::min( viewScaleFactor, 10.0 );
+      rotatedBoundImageHeightMM /= std::min( viewScaleFactor, 10.0 );
     painter->drawImage( QRectF( 0, 0, rotatedBoundImageWidthMM,  rotatedBoundImageHeightMM ), mImage, QRectF( 0, 0, mImage.width(), mImage.height() ) );
     painter->restore();
@@ -98,6 +113,7 @@
   mCachedDpi = newDpi;
   mCachedRotation = mRotation;
+  mCachedViewScaleFactor = viewScaleFactor;
   //frame and selection boxes
   drawFrame( painter );
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.h
--- trunk/qgis/src/core/composer/qgscomposerpicture.h	2009-11-19 10:55:58 UTC (rev 12185)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.h	2009-11-19 11:19:32 UTC (rev 12186)
@@ -89,6 +89,8 @@
     bool mSvgCacheUpToDate;
     int mCachedDpi; //store dpis for which the svg cache is valid
     double mCachedRotation; //store last rotation value to generate new pixmap from svg on change
+    double mCachedViewScaleFactor;
     QSize mDefaultSvgSize;
     /**Map that sets the rotation (or 0 if this picture uses map independent rotation)*/
     const QgsComposerMap* mRotationMap;
More information about the QGIS-commit mailing list
