[QGIS Commit] r12195 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Nov 19 11:58:12 EST 2009
Author: timlinux
Date: 2009-11-19 11:58:10 -0500 (Thu, 19 Nov 2009)
New Revision: 12195
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Implement property list ui for raster props dialog
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2009-11-19 15:00:25 UTC (rev 12194)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2009-11-19 16:58:10 UTC (rev 12195)
@@ -149,7 +149,7 @@
   mColormapTreeWidget->setHeaderLabels( headerLabels );
   //disable colormap tab completely until 'Colormap' is selected (and only for type GrayOrUndefined)
-  tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), FALSE );
+  tabPageColormap->setEnabled( false );
   // Set up the combo boxes that contain band lists using the qstring list generated above
@@ -295,10 +295,10 @@
   else if ( mRasterLayerIsWms )
     // disable Pyramids tab completely
-    tabBar->setTabEnabled( tabBar->indexOf( tabPagePyramids ), FALSE );
+    tabPagePyramids->setEnabled( false );
     // disable Histogram tab completely
-    tabBar->setTabEnabled( tabBar->indexOf( tabPageHistogram ), FALSE );
+    tabPageHistogram->setEnabled( false );
   leSpatialRefSys->setText( mRasterLayer->srs().toProj4() );
@@ -550,13 +550,13 @@
-    tabBar->setCurrentIndex( tabBar->indexOf( tabPageMetadata ) );
-    tabBar->removeTab( tabBar->indexOf( tabPageColormap ) );
-    tabBar->removeTab( tabBar->indexOf( tabPageSymbology ) );
+    tabBar->setCurrentWidget( tabPageMetadata );
+    tabBar->removeWidget( tabPageColormap );
+    tabBar->removeWidget( tabPageSymbology );
     gboxNoDataValue->setEnabled( false );
     gboxCustomTransparency->setEnabled( false );
-    tabBar->removeTab( tabBar->indexOf( tabPageHistogram ) );
-    tabBar->removeTab( tabBar->indexOf( tabPagePyramids ) );
+    tabBar->removeWidget( tabPageHistogram );
+    tabBar->removeWidget( tabPagePyramids );
 #if 0
   if ( mRasterLayer->rasterType() == QgsRasterLayer::Multiband )
@@ -1690,7 +1690,7 @@
   if ( mRasterLayerIsGdal && ( theText == tr( "Pseudocolor" ) || theText == tr( "Freak Out" ) ) )
     rbtnSingleBandMinMax->setEnabled( false );
     rbtnSingleBandStdDev->setEnabled( true );
     sboxSingleBandStdDev->setEnabled( true );
@@ -1700,7 +1700,7 @@
   else if ( mRasterLayerIsGdal && theText == tr( "Colormap" ) )
-    tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), TRUE );
+    tabPageColormap->setEnabled( true );
     rbtnSingleBandStdDev->setEnabled( false );
     sboxSingleBandStdDev->setEnabled( false );
@@ -1710,7 +1710,7 @@
   else if ( mRasterLayerIsGdal && theText == tr( "User Defined" ) )
     rbtnSingleBandMinMax->setEnabled( true );
@@ -1720,7 +1720,7 @@
   else if ( mRasterLayerIsGdal )
@@ -2354,7 +2354,7 @@
     if ( cboxColorMap->currentText() == tr( "Pseudocolor" ) )
-      tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), true );
+      tabPageColormap->setEnabled ( true );
     if ( cboxColorMap->currentText() == tr( "Pseudocolor" ) || cboxColorMap->currentText() == tr( "Color Ramp" ) || cboxColorMap->currentText() == tr( "Freak Out" ) || mRasterLayer->rasterType() == QgsRasterLayer::Palette )
@@ -2424,7 +2424,7 @@
     stackedWidget->setCurrentIndex( 0 );
     rbtnSingleBand->setChecked( false );
     cboxColorMap->setEnabled( false );
-    tabBar->setTabEnabled( tabBar->indexOf( tabPageColormap ), false );
     grpRgbBands->setEnabled( true );
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2009-11-19 15:00:25 UTC (rev 12194)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2009-11-19 16:58:10 UTC (rev 12195)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>568</width>
-    <height>660</height>
+    <width>757</width>
+    <height>648</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -24,17 +24,56 @@
   <property name="modal">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout">
-   <item row="0" column="0" colspan="4">
-    <widget class="QTabWidget" name="tabBar">
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0">
+    <widget class="QListWidget" name="listWidget">
+     <item>
+      <property name="text">
+       <string>Symbology</string>
+      </property>
+     </item>
+     <item>
+       <string>Transparency</string>
+      </property>
+     </item>
+     <item>
+       <string>Colormap</string>
+      </property>
+     </item>
+     <item>
+       <string>General</string>
+      </property>
+     </item>
+     <item>
+       <string>Metadata</string>
+      </property>
+     </item>
+     <item>
+       <string>Pyramids</string>
+      </property>
+     </item>
+     <item>
+       <string>Histogram</string>
+      </property>
+     </item>
+    </widget>
+   </item>
+   <item row="0" column="1" rowspan="2" colspan="4">
+    <widget class="QStackedWidget" name="tabBar">
      <property name="currentIndex">
-      <number>0</number>
+      <number>2</number>
      </property>
-     <widget class="QWidget" name="tabPageSymbology">
-      <attribute name="title">
-       <string>Symbology</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageSymbology" native="true">
+       <property name="margin">
+        <number>0</number>
+       </property>
        <item row="0" column="0" colspan="2">
         <widget class="QGroupBox" name="groupBox_3">
          <property name="title">
@@ -124,9 +163,6 @@
                  <string>Red band</string>
                 </property>
-                <property name="buddy">
-                 <cstring>cboRed</cstring>
-                </property>
                </widget>
               </item>
               <item row="0" column="1" colspan="4">
@@ -156,9 +192,6 @@
                  <string>Green band</string>
                 </property>
-                 <cstring>cboGreen</cstring>
-                </property>
                </widget>
               </item>
               <item row="1" column="1" colspan="4">
@@ -188,9 +221,6 @@
                  <string>Blue band</string>
                 </property>
-                 <cstring>cboBlue</cstring>
-                </property>
                </widget>
               </item>
               <item row="2" column="1" colspan="4">
@@ -884,11 +914,11 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPageTransparency">
-       <string>Transparency</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageTransparency" native="true">
+       </property>
         <widget class="QGroupBox" name="groupBox_4">
@@ -1165,153 +1195,13 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPageColormap">
-       <string>Colormap</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageColormap" native="true">
-       <item row="0" column="0" colspan="2">
-        <widget class="QLabel" name="mColorInterpolationLabel">
-         <property name="text">
-          <string>Color interpolation</string>
-         </property>
-        </widget>
-       </item>
-       <item row="0" column="2" colspan="2">
-        <widget class="QComboBox" name="cboxColorInterpolation"/>
-       </item>
-       <item row="0" column="4" colspan="7">
-        <spacer>
-         <property name="orientation">
-          <enum>Qt::Horizontal</enum>
-         </property>
-         <property name="sizeHint" stdset="0">
-          <size>
-           <width>321</width>
-           <height>45</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-       <item row="1" column="0">
-        <widget class="QPushButton" name="pbtnAddColorMapEntry">
-          <string>Add entry</string>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="1" colspan="2">
-        <widget class="QPushButton" name="mDeleteEntryButton">
-          <string>Delete entry</string>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="3" colspan="2">
-        <widget class="QPushButton" name="pbtnSortColorMap">
-          <string>Sort</string>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="5">
-        <spacer>
-         </property>
-          <size>
-           <width>41</width>
-           <height>27</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-       <item row="1" column="6">
-        <widget class="QComboBox" name="cboxColorMapBand"/>
-       </item>
-       <item row="1" column="7">
-        <widget class="QToolButton" name="pbtnLoadColorMapFromBand">
-         <property name="toolTip">
-          <string>Load color map from band</string>
-         </property>
-          <string>...</string>
-         </property>
-         <property name="icon">
-          <iconset>
-           <normaloff>../../images/themes/default/mActionNewAttribute.png</normaloff>../../images/themes/default/mActionNewAttribute.png</iconset>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="8">
-        <spacer>
-         </property>
-         <property name="sizeType">
-          <enum>QSizePolicy::Minimum</enum>
-         </property>
-          <size>
-           <width>20</width>
-           <height>20</height>
-          </size>
-         </property>
-        </spacer>
-       </item>
-       <item row="1" column="9">
-        <widget class="QToolButton" name="pbtnLoadColorMapFromFile">
-          <string>Load color map from file</string>
-         </property>
-         </property>
-          <iconset>
-           <normaloff>../../images/themes/default/mActionFolder.png</normaloff>../../images/themes/default/mActionFolder.png</iconset>
-         </property>
-        </widget>
-       </item>
-       <item row="1" column="10">
-        <widget class="QToolButton" name="pbtnExportColorMapToFile">
-          <string>Export color map to file</string>
-         </property>
-         </property>
-          <iconset>
-           <normaloff>../../images/themes/default/mActionFileSave.png</normaloff>../../images/themes/default/mActionFileSave.png</iconset>
-         </property>
-        </widget>
-       </item>
-       <item row="2" column="0" colspan="11">
-        <widget class="QTreeWidget" name="mColormapTreeWidget">
-         <property name="columnCount">
-          <number>3</number>
-         </property>
-         <column>
-           <string>1</string>
-          </property>
-         </column>
-         <column>
-          </property>
-         </column>
-         <column>
-           <string>2</string>
-          </property>
-         </column>
-        </widget>
-       </item>
-       <item row="3" column="0" colspan="11">
-        <widget class="QGroupBox" name="groupBox_9">
+       </property>
+       <item row="1" column="0" colspan="2">
+        <widget class="QGroupBox" name="grpGenerateColorMap">
           <string>Generate new color map</string>
          </property>
@@ -1356,21 +1246,167 @@
          </layout>
         </widget>
        </item>
+        <widget class="QGroupBox" name="grpColorMap">
+         <property name="title">
+          <string>Color map</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_2">
+          <item row="0" column="0" colspan="2">
+           <widget class="QLabel" name="mColorInterpolationLabel">
+             <string>Color interpolation</string>
+            </property>
+           </widget>
+          </item>
+          <item row="0" column="2" colspan="2">
+           <widget class="QComboBox" name="cboxColorInterpolation"/>
+          </item>
+          <item row="0" column="4" colspan="7">
+           <spacer>
+            <property name="orientation">
+             <enum>Qt::Horizontal</enum>
+            </property>
+            <property name="sizeHint" stdset="0">
+             <size>
+              <width>321</width>
+              <height>45</height>
+             </size>
+            </property>
+           </spacer>
+          </item>
+          <item row="1" column="0">
+           <widget class="QPushButton" name="pbtnAddColorMapEntry">
+             <string>Add entry</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="1" colspan="2">
+           <widget class="QPushButton" name="mDeleteEntryButton">
+             <string>Delete entry</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="3" colspan="2">
+           <widget class="QPushButton" name="pbtnSortColorMap">
+             <string>Sort</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="5">
+           <spacer>
+            </property>
+             <size>
+              <width>41</width>
+              <height>27</height>
+             </size>
+            </property>
+           </spacer>
+          </item>
+          <item row="1" column="6">
+           <widget class="QComboBox" name="cboxColorMapBand"/>
+          </item>
+          <item row="1" column="7">
+           <widget class="QToolButton" name="pbtnLoadColorMapFromBand">
+            <property name="toolTip">
+             <string>Load color map from band</string>
+            </property>
+             <string>...</string>
+            </property>
+            <property name="icon">
+             <iconset>
+              <normaloff>../../images/themes/default/mActionNewAttribute.png</normaloff>../../images/themes/default/mActionNewAttribute.png</iconset>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="8">
+           <spacer>
+            </property>
+            <property name="sizeType">
+             <enum>QSizePolicy::Minimum</enum>
+            </property>
+             <size>
+              <width>20</width>
+              <height>20</height>
+             </size>
+            </property>
+           </spacer>
+          </item>
+          <item row="1" column="9">
+           <widget class="QToolButton" name="pbtnLoadColorMapFromFile">
+             <string>Load color map from file</string>
+            </property>
+            </property>
+             <iconset>
+              <normaloff>../../images/themes/default/mActionFolder.png</normaloff>../../images/themes/default/mActionFolder.png</iconset>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="10">
+           <widget class="QToolButton" name="pbtnExportColorMapToFile">
+             <string>Export color map to file</string>
+            </property>
+            </property>
+             <iconset>
+              <normaloff>../../images/themes/default/mActionFileSave.png</normaloff>../../images/themes/default/mActionFileSave.png</iconset>
+            </property>
+           </widget>
+          </item>
+          <item row="2" column="0" colspan="11">
+           <widget class="QTreeWidget" name="mColormapTreeWidget">
+            <property name="columnCount">
+             <number>3</number>
+            </property>
+            <column>
+              <string>1</string>
+             </property>
+            </column>
+            <column>
+             </property>
+            </column>
+            <column>
+              <string>2</string>
+             </property>
+            </column>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPageGeneral">
-       <string>General</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageGeneral" native="true">
+       </property>
         <widget class="QLabel" name="lblDisplayName">
           <string>Display name</string>
          </property>
-          <cstring>leDisplayName</cstring>
-         </property>
         </widget>
        </item>
        <item row="0" column="2" colspan="4">
@@ -1381,9 +1417,6 @@
           <string>Layer source</string>
          </property>
-          <cstring>leLayerSource</cstring>
-         </property>
         </widget>
        </item>
        <item row="1" column="2" colspan="4">
@@ -1466,9 +1499,6 @@
              <string>Maximum</string>
             </property>
-             <cstring>spinMaximumScale</cstring>
-            </property>
            </widget>
           </item>
           <item row="0" column="1">
@@ -1489,9 +1519,6 @@
              <string>Minimum</string>
             </property>
-             <cstring>spinMinimumScale</cstring>
-            </property>
            </widget>
           </item>
          </layout>
@@ -1668,24 +1695,21 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPageMetadata">
-       <string>Metadata</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageMetadata" native="true">
-        <number>11</number>
        </property>
         <widget class="QTextBrowser" name="txtbMetadata"/>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPagePyramids">
-       <string>Pyramids</string>
-      </attribute>
+     <widget class="QWidget" name="tabPagePyramids" native="true">
+       </property>
         <widget class="QLabel" name="label_3">
@@ -1748,9 +1772,6 @@
           <string>Resampling method</string>
          </property>
-          <cstring>cboResamplingMethod</cstring>
-         </property>
         </widget>
        </item>
        <item row="3" column="1">
@@ -1783,11 +1804,11 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tabPageHistogram">
-       <string>Histogram</string>
-      </attribute>
+     <widget class="QWidget" name="tabPageHistogram" native="true">
+       </property>
         <widget class="QLabel" name="pixHistogram">
          <property name="sizePolicy">
@@ -1947,35 +1968,35 @@
      </widget>
     </widget>
    </item>
-    <widget class="QPushButton" name="pbnLoadDefaultStyle">
+   <item row="1" column="2" rowspan="2">
+    <widget class="QPushButton" name="pbnSaveDefaultStyle">
-      <string>Restore Default Style</string>
+      <string>Save As Default</string>
      </property>
     </widget>
    </item>
-   <item row="1" column="1">
-    <widget class="QPushButton" name="pbnSaveDefaultStyle">
+   <item row="2" column="0">
+    <widget class="QPushButton" name="pbnLoadDefaultStyle">
-      <string>Save As Default</string>
+      <string>Restore Default Style</string>
      </property>
     </widget>
    </item>
-   <item row="1" column="2">
+   <item row="2" column="3">
     <widget class="QPushButton" name="pbnLoadStyle">
       <string>Load Style ...</string>
      </property>
     </widget>
    </item>
-   <item row="1" column="3">
+   <item row="2" column="4">
     <widget class="QPushButton" name="pbnSaveStyleAs">
       <string>Save Style ...</string>
      </property>
     </widget>
    </item>
-   <item row="2" column="0" colspan="4">
+   <item row="3" column="0" colspan="5">
     <widget class="QDialogButtonBox" name="buttonBox">
@@ -2035,8 +2056,8 @@
    <slot>reject()</slot>
    <hints>
     <hint type="sourcelabel">
-     <x>458</x>
-     <y>589</y>
+     <x>467</x>
+     <y>638</y>
     </hint>
     <hint type="destinationlabel">
      <x>3</x>
@@ -2044,5 +2065,21 @@
     </hint>
    </hints>
   </connection>
+  <connection>
+   <sender>listWidget</sender>
+   <signal>currentRowChanged(int)</signal>
+   <receiver>tabBar</receiver>
+   <slot>setCurrentIndex(int)</slot>
+   <hints>
+    <hint type="sourcelabel">
+     <x>110</x>
+     <y>52</y>
+    </hint>
+    <hint type="destinationlabel">
+     <x>736</x>
+     <y>11</y>
+    </hint>
+   </hints>
+  </connection>
  </connections>
 </ui>
More information about the QGIS-commit mailing list
