[QGIS Commit] r12198 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Nov 19 12:22:22 EST 2009
Author: jef
Date: 2009-11-19 12:22:21 -0500 (Thu, 19 Nov 2009)
New Revision: 12198
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsattributeeditor.cpp
hopefully restore Qt 4.3 compability
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-11-19 17:16:28 UTC (rev 12197)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-11-19 17:22:21 UTC (rev 12198)
@@ -4879,7 +4879,11 @@
 #endif
   QString version = QString( "%1.%2.%3" ).arg( QGis::QGIS_VERSION_INT / 10000 ).arg( QGis::QGIS_VERSION_INT / 100 % 100 ).arg( QGis::QGIS_VERSION_INT % 100 );
   QgsDebugMsg( QString( "load library %1 (%2)" ).arg( pythonlibName ).arg( version ) );
+#if QT_VERSION >= 0x040400
   QLibrary pythonlib( pythonlibName, version );
+#else
+  QLibrary pythonlib( pythonlibName );
+#endif
   // It's necessary to set these two load hints, otherwise Python library won't work correctly
   // see http://lists.kde.org/?l=pykde&m=117190116820758&w=2
   pythonlib.setLoadHints( QLibrary::ResolveAllSymbolsHint | QLibrary::ExportExternalSymbolsHint );
Modified: trunk/qgis/src/app/qgsattributeeditor.cpp
--- trunk/qgis/src/app/qgsattributeeditor.cpp	2009-11-19 17:16:28 UTC (rev 12197)
+++ trunk/qgis/src/app/qgsattributeeditor.cpp	2009-11-19 17:22:21 UTC (rev 12198)
@@ -25,7 +25,6 @@
 #include <QPushButton>
 #include <QLineEdit>
 #include <QTextEdit>
-#include <QPlainTextEdit>
 #include <QFileDialog>
 #include <QComboBox>
 #include <QCheckBox>
@@ -33,6 +32,10 @@
 #include <QCompleter>
 #include <QHBoxLayout>
+#include <QPlainTextEdit>
+#endif
 void QgsAttributeEditor::selectFileName( void )
   QPushButton *pb = qobject_cast<QPushButton *>( sender() );
@@ -259,17 +262,26 @@
       QLineEdit *le = NULL;
       QTextEdit *te = NULL;
       QPlainTextEdit *pte = NULL;
+#endif
       if ( editor )
         le = qobject_cast<QLineEdit *>( editor );
         te = qobject_cast<QTextEdit *>( editor );
         pte = qobject_cast<QPlainTextEdit *>( editor );
+#endif
       else if ( editType == QgsVectorLayer::TextEdit )
         pte = new QPlainTextEdit( parent );
+#else
+        te = new QTextEdit( parent );
+        te->setAcceptRichText( false );
+#endif
       else
@@ -307,14 +319,18 @@
       if ( te )
         te->setAcceptRichText( true );
+#endif
         myWidget = te;
+#if QT_VERSION < 0x040400
       if ( pte )
         myWidget = pte;
+#endif
     break;
@@ -390,7 +406,11 @@
   QTextEdit *te = qobject_cast<QTextEdit *>( widget );
   if ( te )
     text = te->toHtml();
+#else
+    text = te->toPlainText();
+#endif
     modified = te->document()->isModified();
     if ( text == "NULL" )
@@ -398,6 +418,7 @@
   QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( widget );
   if ( pte )
@@ -408,6 +429,7 @@
       text = QString::null;
+#endif
   QComboBox *cb = qobject_cast<QComboBox *>( widget );
   if ( cb )
@@ -574,9 +596,14 @@
       QLineEdit *le = qobject_cast<QLineEdit *>( editor );
       QTextEdit *te = qobject_cast<QTextEdit *>( editor );
       QPlainTextEdit *pte = qobject_cast<QPlainTextEdit *>( editor );
       if ( !le && !te && !pte )
         return false;
+#else
+      if ( !le && !te )
+        return false;
+#endif
       QString text;
       if ( value.isNull() )
@@ -589,10 +616,15 @@
       if ( le )
         le->setText( text );
       if ( te )
         te->setHtml( text );
       if ( pte )
         pte->setPlainText( text );
+#else
+      if ( te )
+        te->setPlainText( text );
+#endif
     break;
More information about the QGIS-commit mailing list
