[QGIS Commit] r12213 - trunk/qgis/src/plugins/scale_bar
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 20 15:37:24 EST 2009
Author: timlinux
Date: 2009-11-20 15:37:15 -0500 (Fri, 20 Nov 2009)
New Revision: 12213
   trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
Dont use form layout use grid layout (for  #2121)
Modified: trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
--- trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-11-20 20:35:26 UTC (rev 12212)
+++ trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-11-20 20:37:15 UTC (rev 12213)
@@ -20,169 +20,162 @@
   </property>
   <layout class="QGridLayout" name="gridLayout">
    <item row="0" column="0">
-    <layout class="QFormLayout" name="formLayout">
-     <property name="fieldGrowthPolicy">
-      <enum>QFormLayout::AllNonFixedFieldsGrow</enum>
+    <widget class="QLabel" name="textLabel1_2">
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Preferred" vsizetype="Minimum">
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
      </property>
-     <item row="0" column="0">
-      <widget class="QLabel" name="textLabel1_2">
-       <property name="sizePolicy">
-        <sizepolicy hsizetype="Preferred" vsizetype="Minimum">
-         <horstretch>0</horstretch>
-         <verstretch>0</verstretch>
-        </sizepolicy>
-       </property>
-       <property name="text">
-        <string>Placement</string>
-       </property>
-       <property name="buddy">
-        <cstring>cboPlacement</cstring>
-       </property>
-      </widget>
+     <property name="text">
+      <string>Placement</string>
+     </property>
+     <property name="buddy">
+      <cstring>cboPlacement</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="1">
+    <widget class="QComboBox" name="cboPlacement">
+      <sizepolicy hsizetype="Minimum" vsizetype="Minimum">
+      </sizepolicy>
+     </property>
+     <item>
+       <string>Top Left</string>
+      </property>
      </item>
-     <item row="0" column="1">
-      <widget class="QComboBox" name="cboPlacement">
-        <sizepolicy hsizetype="Minimum" vsizetype="Minimum">
-        </sizepolicy>
-       </property>
-       <item>
-         <string>Top Left</string>
-        </property>
-       </item>
-       <item>
-         <string>Top Right</string>
-        </property>
-       </item>
-       <item>
-         <string>Bottom Left</string>
-        </property>
-       </item>
-       <item>
-         <string>Bottom Right</string>
-        </property>
-       </item>
-      </widget>
+     <item>
+       <string>Top Right</string>
+      </property>
      </item>
-     <item row="1" column="0">
-      <widget class="QLabel" name="textLabel1">
-        </sizepolicy>
-       </property>
-        <string>Scale bar style</string>
-       </property>
-        <cstring>cboStyle</cstring>
-       </property>
-      </widget>
+     <item>
+       <string>Bottom Left</string>
+      </property>
      </item>
-     <item row="1" column="1">
-      <widget class="QComboBox" name="cboStyle">
-        </sizepolicy>
-       </property>
-       <property name="toolTip">
-        <string>Select the style of the scale bar</string>
-       </property>
-       <item>
-         <string>Tick Down</string>
-        </property>
-       </item>
-       <item>
-         <string>Tick Up</string>
-        </property>
-       </item>
-       <item>
-         <string>Box</string>
-        </property>
-       </item>
-       <item>
-         <string>Bar</string>
-        </property>
-       </item>
-      </widget>
+     <item>
+       <string>Bottom Right</string>
+      </property>
      </item>
-     <item row="2" column="0">
-      <widget class="QLabel" name="textLabel1_3_2">
-        </sizepolicy>
-       </property>
-        <string>Colour of bar</string>
-       </property>
-        <cstring>pbnChangeColour</cstring>
-       </property>
-      </widget>
+    </widget>
+   </item>
+   <item row="1" column="0">
+    <widget class="QLabel" name="textLabel1">
+      </sizepolicy>
+     </property>
+      <string>Scale bar style</string>
+     </property>
+      <cstring>cboStyle</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="1" column="1">
+    <widget class="QComboBox" name="cboStyle">
+      </sizepolicy>
+     </property>
+     <property name="toolTip">
+      <string>Select the style of the scale bar</string>
+     </property>
+     <item>
+       <string>Tick Down</string>
+      </property>
      </item>
-     <item row="2" column="1">
-      <widget class="QgsColorButton" name="pbnChangeColour">
-        </sizepolicy>
-       </property>
-        <string>Click to select the colour</string>
-       </property>
-       <property name="whatsThis">
-       </property>
-        <string/>
-       </property>
-      </widget>
+     <item>
+       <string>Tick Up</string>
+      </property>
      </item>
-     <item row="3" column="0">
-      <widget class="QLabel" name="textLabel1_3">
-        </sizepolicy>
-       </property>
-        <string>Size of bar</string>
-       </property>
-        <cstring>spnSize</cstring>
-       </property>
-      </widget>
+     <item>
+       <string>Box</string>
+      </property>
      </item>
-     <item row="3" column="1">
-      <widget class="QSpinBox" name="spnSize">
-        </sizepolicy>
-       </property>
-      </widget>
+     <item>
+       <string>Bar</string>
+      </property>
      </item>
-    </layout>
+    </widget>
    </item>
+   <item row="2" column="0">
+    <widget class="QLabel" name="textLabel1_3_2">
+      </sizepolicy>
+     </property>
+      <string>Colour of bar</string>
+     </property>
+      <cstring>pbnChangeColour</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="2" column="1">
+    <widget class="QgsColorButton" name="pbnChangeColour">
+      </sizepolicy>
+     </property>
+      <string>Click to select the colour</string>
+     </property>
+     <property name="whatsThis">
+     </property>
+      <string/>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="0">
+    <widget class="QLabel" name="textLabel1_3">
+      </sizepolicy>
+     </property>
+      <string>Size of bar</string>
+     </property>
+      <cstring>spnSize</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="1">
+    <widget class="QSpinBox" name="spnSize">
+      </sizepolicy>
+     </property>
+    </widget>
+   </item>
+   <item row="4" column="0" colspan="2">
     <widget class="QCheckBox" name="chkEnable">
@@ -198,7 +191,7 @@
      </property>
     </widget>
    </item>
+   <item row="5" column="0" colspan="2">
     <widget class="QCheckBox" name="chkSnapping">
@@ -214,7 +207,7 @@
      </property>
     </widget>
    </item>
+   <item row="6" column="0" colspan="2">
     <widget class="QDialogButtonBox" name="buttonBox">
      <property name="orientation">
       <enum>Qt::Horizontal</enum>
More information about the QGIS-commit mailing list
