[QGIS Commit] r12239 - in trunk/qgis/src: app python
svn_qgis at osgeo.org
Tue Nov 24 08:14:46 EST 2009
Author: jef
Date: 2009-11-24 08:14:44 -0500 (Tue, 24 Nov 2009)
New Revision: 12239
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/python/qgspythonutilsimpl.cpp
trunk/qgis/src/python/qgspythonutilsimpl.h
[FEATURE] include ~/.qgis/python and project directory in python path
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-11-24 08:47:33 UTC (rev 12238)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-11-24 13:14:44 UTC (rev 12239)
@@ -1801,6 +1801,12 @@
connect( mActionUndo, SIGNAL( triggered() ), mUndoWidget, SLOT( undo() ) );
connect( mActionRedo, SIGNAL( triggered() ), mUndoWidget, SLOT( redo() ) );
connect( mUndoWidget, SIGNAL( undoStackChanged() ), this, SLOT( updateUndoActions() ) );
+ connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument & ) ),
+ this, SLOT( projectChanged( const QDomDocument & ) ) );
+ connect( QgsProject::instance(), SIGNAL( writeProject( QDomDocument & ) ),
+ this, SLOT( projectChanged( QDomDocument & ) ) );
void QgisApp::createCanvas()
@@ -4465,10 +4471,10 @@
mMapCanvas->setRenderFlag( false );
QMap<QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
- for ( QMap<QString, QgsMapLayer*>::iterator it = layers.begin(); it!=layers.end(); it++ )
+ for ( QMap<QString, QgsMapLayer*>::iterator it = layers.begin(); it != layers.end(); it++ )
QgsVectorLayer *vl = qobject_cast<QgsVectorLayer *>( it.value() );
- if( !vl )
+ if ( !vl )
continue;
vl->removeSelection();
@@ -6459,8 +6465,35 @@
void QgisApp::runPythonString( const QString &expr )
- if ( mPythonUtils )
+ if ( mPythonUtils && mPythonUtils->isEnabled() )
mPythonUtils->runStringUnsafe( expr );
+// add project directory to python path
+void QgisApp::projectChanged( const QDomDocument &doc )
+ QgsProject *project = qobject_cast<QgsProject*>( sender() );
+ if ( !project )
+ return;
+ QFileInfo fi( project->fileName() );
+ if ( !fi.exists() )
+ return;
+ static QString prevProjectDir = QString::null;
+ if ( prevProjectDir == fi.canonicalPath() )
+ return;
+ QString expr;
+ if ( !prevProjectDir.isNull() )
+ expr = QString( "sys.path.remove('%1'); " ).arg( prevProjectDir );
+ prevProjectDir = fi.canonicalPath();
+ expr += QString( "sys.path.append('%1')" ).arg( prevProjectDir );
+ runPythonString( expr );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-11-24 08:47:33 UTC (rev 12238)
+++ trunk/qgis/src/app/qgisapp.h 2009-11-24 13:14:44 UTC (rev 12239)
@@ -59,6 +59,8 @@
class QgsUndoWidget;
class QgsVectorLayer;
+class QDomDocument;
#include <QMainWindow>
#include <QToolBar>
#include <QAbstractSocket>
@@ -631,6 +633,9 @@
void showStyleManagerV2();
+ //! project changed
+ void projectChanged( const QDomDocument & );
signals:
/** emitted when a key is pressed and we want non widget sublasses to be able
to pick up on this (e.g. maplayer) */
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-11-24 08:47:33 UTC (rev 12238)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-11-24 13:14:44 UTC (rev 12239)
@@ -59,7 +59,7 @@
// expect that bindings are installed locally, so add the path to modules
// also add path to plugins
- runString( "sys.path = [\"" + pythonPath() + "\", \"" + homePluginsPath() + "\", \"" + pluginsPath() + "\"] + sys.path" );
+ runString( "sys.path = [\"" + pythonPath() + "\", \"" + homePythonPath() + "\", \"" + homePluginsPath() + "\", \"" + pluginsPath() + "\"] + sys.path" );
// import SIP
if ( !runString( "from sip import wrapinstance, unwrapinstance",
@@ -412,9 +412,14 @@
return pythonPath() + "/plugins";
+QString QgsPythonUtilsImpl::homePythonPath()
+ return QgsApplication::qgisSettingsDirPath() + "/python";
QString QgsPythonUtilsImpl::homePluginsPath()
- return QgsApplication::qgisSettingsDirPath() + "/python/plugins";
+ return homePythonPath() + "/plugins";
QStringList QgsPythonUtilsImpl::pluginList()
Modified: trunk/qgis/src/python/qgspythonutilsimpl.h
--- trunk/qgis/src/python/qgspythonutilsimpl.h 2009-11-24 08:47:33 UTC (rev 12238)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h 2009-11-24 13:14:44 UTC (rev 12239)
@@ -89,6 +89,9 @@
//! return current path for python plugins
QString pluginsPath();
+ //! return current path for python in home directory
+ QString homePythonPath();
//! return current path for home directory python plugins
QString homePluginsPath();
