[QGIS Commit] r12256 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 25 07:24:33 EST 2009
Author: timlinux
Date: 2009-11-25 07:24:33 -0500 (Wed, 25 Nov 2009)
New Revision: 12256
   trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui
   trunk/qgis/src/ui/qgscomposershapewidgetbase.ui
Use spacer to push arrow and shape props to top of toolbox drawer
Modified: trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui	2009-11-25 12:16:08 UTC (rev 12255)
+++ trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui	2009-11-25 12:24:33 UTC (rev 12256)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>168</width>
-    <height>166</height>
+    <width>273</width>
+    <height>306</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -24,8 +24,8 @@
        <rect>
         <x>0</x>
         <y>0</y>
-        <width>150</width>
-        <height>122</height>
+        <width>255</width>
+        <height>256</height>
        </rect>
       </property>
       <attribute name="label">
@@ -60,6 +60,19 @@
          </property>
         </widget>
        </item>
+       <item row="4" column="0">
+        <spacer name="verticalSpacer">
+         <property name="orientation">
+          <enum>Qt::Vertical</enum>
+         </property>
+         <property name="sizeHint" stdset="0">
+          <size>
+           <width>20</width>
+           <height>40</height>
+          </size>
+         </property>
+        </spacer>
+       </item>
       </layout>
      </widget>
     </widget>
Modified: trunk/qgis/src/ui/qgscomposershapewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposershapewidgetbase.ui	2009-11-25 12:16:08 UTC (rev 12255)
+++ trunk/qgis/src/ui/qgscomposershapewidgetbase.ui	2009-11-25 12:24:33 UTC (rev 12256)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>219</width>
-    <height>236</height>
+    <width>285</width>
+    <height>427</height>
    </rect>
   </property>
@@ -24,8 +24,8 @@
        <rect>
         <x>0</x>
         <y>0</y>
-        <width>201</width>
-        <height>192</height>
+        <width>267</width>
+        <height>377</height>
        </rect>
       </property>
@@ -73,6 +73,19 @@
          </property>
         </widget>
        </item>
+       <item row="6" column="0">
+         </property>
+          <size>
+           <width>20</width>
+          </size>
+         </property>
+        </spacer>
+       </item>
       </layout>
      </widget>
     </widget>
More information about the QGIS-commit mailing list
