[QGIS Commit] r12259 - in trunk/qgis: i18n src/app src/core src/providers/ogr src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 25 17:37:45 EST 2009
Author: jef
Date: 2009-11-25 17:37:43 -0500 (Wed, 25 Nov 2009)
New Revision: 12259
   trunk/qgis/i18n/qgis_de.ts
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp
   trunk/qgis/src/app/qgsnewvectorlayerdialog.h
   trunk/qgis/src/core/qgsvectorfilewriter.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui
[FEATURE] allow specification of CRS when creating shape files (also fixes #2123)
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/i18n/qgis_de.ts	2009-11-25 22:37:43 UTC (rev 12259)
@@ -14768,8 +14768,8 @@
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="245"/>
-        <source>Removed selected attribute</source>
-        <translation>Gewähltes Attribute gelöscht</translation>
+        <source>Remove selected attribute</source>
+        <translation type="unfinished">Gewähltes Attribut löschen</translation>
     </message>
 </context>
 <context>
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-11-25 22:37:43 UTC (rev 12259)
@@ -1802,11 +1802,11 @@
   connect( mActionRedo, SIGNAL( triggered() ), mUndoWidget, SLOT( redo() ) );
   connect( mUndoWidget, SIGNAL( undoStackChanged() ), this, SLOT( updateUndoActions() ) );
+  // Monitor change of project path
   connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument & ) ),
            this, SLOT( projectChanged( const QDomDocument & ) ) );
   connect( QgsProject::instance(), SIGNAL( writeProject( QDomDocument & ) ),
            this, SLOT( projectChanged( QDomDocument & ) ) );
 void QgisApp::createCanvas()
@@ -3209,16 +3209,15 @@
     return;
-  QGis::WkbType geometrytype;
-  QString fileformat;
   QgsNewVectorLayerDialog geomDialog( this );
   if ( geomDialog.exec() == QDialog::Rejected )
     return;
-  geometrytype = geomDialog.selectedType();
-  fileformat = geomDialog.selectedFileFormat();
+  QGis::WkbType geometrytype = geomDialog.selectedType();
+  QString fileformat = geomDialog.selectedFileFormat();
+  int crsId = geomDialog.selectedCrsId();
   QgsDebugMsg( QString( "New file format will be: %1" ).arg( fileformat ) );
   std::list<std::pair<QString, QString> > attributes;
@@ -3286,27 +3285,14 @@
     QgsDebugMsg( "ogr provider loaded" );
     typedef bool ( *createEmptyDataSourceProc )( const QString&, const QString&, const QString&, QGis::WkbType,
-        const std::list<std::pair<QString, QString> >& );
+        const std::list<std::pair<QString, QString> >&, const QgsCoordinateReferenceSystem * );
     createEmptyDataSourceProc createEmptyDataSource = ( createEmptyDataSourceProc ) cast_to_fptr( myLib->resolve( "createEmptyDataSource" ) );
     if ( createEmptyDataSource )
-#if 0
-      if ( geometrytype == QGis::WKBPoint )
-        createEmptyDataSource( fileName, fileformat, enc, QGis::WKBPoint, attributes );
-      else if ( geometrytype == QGis::WKBLineString )
-        createEmptyDataSource( fileName, fileformat, enc, QGis::WKBLineString, attributes );
-      else if ( geometrytype == QGis::WKBPolygon )
-        createEmptyDataSource( fileName, fileformat, enc, QGis::WKBPolygon, attributes );
-#endif
       if ( geometrytype != QGis::WKBUnknown )
-        createEmptyDataSource( fileName, fileformat, enc, geometrytype, attributes );
+        QgsCoordinateReferenceSystem srs( crsId, QgsCoordinateReferenceSystem::InternalCrsId );
+        createEmptyDataSource( fileName, fileformat, enc, geometrytype, attributes, &srs );
       else
Modified: trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp
--- trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp	2009-11-25 22:37:43 UTC (rev 12259)
@@ -20,8 +20,11 @@
 #include "qgsapplication.h"
 #include "qgisapp.h" // <- for theme icons
 #include "qgslogger.h"
+#include "qgscoordinatereferencesystem.h"
+#include "qgsgenericprojectionselector.h"
 #include <QPushButton>
 QgsNewVectorLayerDialog::QgsNewVectorLayerDialog( QWidget *parent, Qt::WFlags fl )
     : QDialog( parent, fl )
@@ -48,6 +51,12 @@
   mOkButton = buttonBox->button( QDialogButtonBox::Ok );
   mOkButton->setEnabled( false );
+  QgsCoordinateReferenceSystem srs;
+  srs.validate();
+  mCrsId = srs.srsid();
+  leSpatialRefSys->setText( srs.toProj4() );
 QgsNewVectorLayerDialog::~QgsNewVectorLayerDialog()
@@ -76,6 +85,11 @@
   return QGis::WKBUnknown;
+int QgsNewVectorLayerDialog::selectedCrsId() const
+  return mCrsId;
 void QgsNewVectorLayerDialog::on_mAddAttributeButton_clicked()
   QString myName = mNameEdit->text();
@@ -100,6 +114,23 @@
+void QgsNewVectorLayerDialog::on_pbnChangeSpatialRefSys_clicked()
+  QgsGenericProjectionSelector *mySelector = new QgsGenericProjectionSelector( this );
+  mySelector->setMessage();
+  mySelector->setSelectedCrsId( pbnChangeSpatialRefSys->text().toInt() );
+  if ( mySelector->exec() )
+    mCrsId = mySelector->selectedCrsId();
+    leSpatialRefSys->setText( mySelector->selectedProj4String() );
+  else
+    QApplication::restoreOverrideCursor();
+  delete mySelector;
 void QgsNewVectorLayerDialog::attributes( std::list<std::pair<QString, QString> >& at ) const
   QTreeWidgetItemIterator it( mAttributeView );
Modified: trunk/qgis/src/app/qgsnewvectorlayerdialog.h
--- trunk/qgis/src/app/qgsnewvectorlayerdialog.h	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/app/qgsnewvectorlayerdialog.h	2009-11-25 22:37:43 UTC (rev 12259)
@@ -37,15 +37,19 @@
     void attributes( std::list<std::pair<QString, QString> >& at ) const;
     /**Returns the file format for storage*/
     QString selectedFileFormat() const;
+    /**Returns the selected crs id*/
+    int selectedCrsId() const;
   protected slots:
     void on_mAddAttributeButton_clicked();
     void on_mRemoveAttributeButton_clicked();
     void on_mTypeBox_currentIndexChanged( int index );
+    void on_pbnChangeSpatialRefSys_clicked();
     void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
   private:
     QPushButton *mOkButton;
+    int mCrsId;
 #endif //qgsnewvectorlayerdialog_H
Modified: trunk/qgis/src/core/qgsvectorfilewriter.cpp
--- trunk/qgis/src/core/qgsvectorfilewriter.cpp	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/core/qgsvectorfilewriter.cpp	2009-11-25 22:37:43 UTC (rev 12259)
@@ -95,12 +95,27 @@
   // datasource created, now create the output layer
-  QString layerName = shapefileName.left( shapefileName.indexOf( ".shp" ) );
+  QString layerName = shapefileName.left( shapefileName.lastIndexOf( ".shp", Qt::CaseInsensitive ) );
   OGRwkbGeometryType wkbType = static_cast<OGRwkbGeometryType>( geometryType );
   mLayer = OGR_DS_CreateLayer( mDS, QFile::encodeName( layerName ).data(), ogrRef, wkbType, NULL );
   if ( srs )
+    if ( shapefileName != layerName )
+      QFile prjFile( layerName + ".prj" );
+      if ( prjFile.open( QIODevice::WriteOnly ) )
+        QTextStream prjStream( &prjFile );
+        prjStream << srs->toWkt().toLocal8Bit().data() << endl;
+        prjFile.close();
+      else
+        QgsDebugMsg( "Couldn't open file " + layerName + ".prj" );
     OSRDestroySpatialReference( ogrRef );
@@ -344,8 +359,8 @@
     // This means we shouldn't transform, use source CRS as output (if defined)
     outputCRS = &layer->srs();
-  QgsVectorFileWriter* writer = new QgsVectorFileWriter( shapefileName,
-      fileEncoding, provider->fields(), provider->geometryType(), outputCRS );
+  QgsVectorFileWriter* writer =
+    new QgsVectorFileWriter( shapefileName, fileEncoding, provider->fields(), provider->geometryType(), outputCRS );
   // check whether file creation was successful
   WriterError err = writer->hasError();
@@ -394,26 +409,6 @@
     delete ct;
-  // Ohh, a great Hack-fest starts!
-  // Overwrite the .prj file created by QGsVectorFileWrite().
-  // This might break progrmas that relies on ESRI style .prf-files.
-  // The 'CT-params' (e.g. +towgs84) does not get stripped in this way
-  QRegExp regExp( ".shp$" );
-  QString prjName = shapefileName;
-  prjName.replace( regExp, QString( "" ) );
-  prjName.append( QString( ".prj" ) );
-  QFile prjFile( prjName );
-  if ( !prjFile.open( QIODevice::WriteOnly ) )
-    QgsDebugMsg( "Couldn't open file " + prjName );
-    return NoError; // For now
-  QTextStream prjStream( & prjFile );
-  prjStream << destCRS->toWkt() << endl;
-  prjFile.close();
   return NoError;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2009-11-25 22:37:43 UTC (rev 12259)
@@ -1453,7 +1453,8 @@
                                        const QString& format,
                                        const QString& encoding,
                                        QGis::WkbType vectortype,
-                                       const std::list<std::pair<QString, QString> >& attributes )
+                                       const std::list<std::pair<QString, QString> > &attributes,
+                                       const QgsCoordinateReferenceSystem *srs = NULL )
   QgsDebugMsg( QString( "Creating empty vector layer with format: %1" ).arg( format ) );
   OGRSFDriverH driver;
@@ -1473,8 +1474,17 @@
   //consider spatial reference system
   OGRSpatialReferenceH reference = NULL;
   QgsCoordinateReferenceSystem mySpatialRefSys;
-  mySpatialRefSys.validate();
+  if ( srs )
+    mySpatialRefSys = *srs;
+  else
+    mySpatialRefSys.validate();
   QString myWkt = mySpatialRefSys.toWkt();
   if ( !myWkt.isNull()  &&  myWkt.length() != 0 )
@@ -1576,6 +1586,22 @@
   OGR_DS_Destroy( dataSource );
+  if ( uri.endsWith( ".shp", Qt::CaseInsensitive ) )
+    QString layerName = uri.left( uri.length() - 4 );
+      prjStream << myWkt.toLocal8Bit().data() << endl;
+      prjFile.close();
+    else
   QgsDebugMsg( QString( "GDAL Version number %1" ).arg( GDAL_VERSION_NUM ) );
 #if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1310
   if ( reference )
Modified: trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui
--- trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui	2009-11-25 15:13:19 UTC (rev 12258)
+++ trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui	2009-11-25 22:37:43 UTC (rev 12259)
@@ -1,64 +1,65 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsNewVectorLayerDialogBase</class>
- <widget class="QDialog" name="QgsNewVectorLayerDialogBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsNewVectorLayerDialogBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>364</width>
+    <width>444</width>
     <height>488</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>New Vector Layer</string>
   </property>
-  <property name="modal" >
+  <property name="modal">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QLabel" name="mFileFormatLabel" >
-     <property name="enabled" >
+  <layout class="QGridLayout">
+   <item row="0" column="0">
+    <widget class="QLabel" name="mFileFormatLabel">
+     <property name="enabled">
       <bool>true</bool>
      </property>
-     <property name="text" >
+     <property name="text">
       <string>File format</string>
      </property>
-     <property name="buddy" >
+     <property name="buddy">
       <cstring>mFileFormatComboBox</cstring>
      </property>
     </widget>
    </item>
-   <item row="0" column="1" >
-    <widget class="QComboBox" name="mFileFormatComboBox" >
+   <item row="0" column="1" colspan="2">
+    <widget class="QComboBox" name="mFileFormatComboBox">
       <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2" >
-    <widget class="QGroupBox" name="buttonGroup1" >
-     <property name="title" >
+   <item row="1" column="0" colspan="3">
+    <widget class="QGroupBox" name="buttonGroup1">
+     <property name="title">
       <string>Type</string>
      </property>
-       <widget class="QRadioButton" name="mPointRadioButton" >
+     <layout class="QHBoxLayout" name="horizontalLayout">
+      <item>
+       <widget class="QRadioButton" name="mPointRadioButton">
          <string>Point</string>
         </property>
        </widget>
       </item>
-       <widget class="QRadioButton" name="mLineRadioButton" >
+      <item>
+       <widget class="QRadioButton" name="mLineRadioButton">
          <string>Line</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="2" >
-       <widget class="QRadioButton" name="mPolygonRadioButton" >
+      <item>
+       <widget class="QRadioButton" name="mPolygonRadioButton">
          <string>Polygon</string>
         </property>
        </widget>
@@ -66,163 +67,125 @@
      </layout>
     </widget>
    </item>
-   <item row="2" column="0" colspan="2" >
-    <widget class="QGroupBox" name="groupBox" >
+   <item row="4" column="0" colspan="3">
+    <widget class="QGroupBox" name="groupBox">
       <string>New attribute</string>
      </property>
-       <widget class="QLabel" name="textLabel1" >
+       <widget class="QLabel" name="textLabel1">
          <string>Name</string>
         </property>
          <cstring>mNameEdit</cstring>
         </property>
        </widget>
       </item>
-      <item row="0" column="1" colspan="4" >
-       <widget class="QLineEdit" name="mNameEdit" />
+      <item row="0" column="1" colspan="4">
+       <widget class="QLineEdit" name="mNameEdit"/>
       </item>
-      <item row="1" column="0" >
-       <widget class="QLabel" name="textLabel2" >
+      <item row="1" column="0">
+       <widget class="QLabel" name="textLabel2">
         </property>
          <cstring>mTypeBox</cstring>
         </property>
        </widget>
       </item>
-      <item row="1" column="1" colspan="4" >
-       <widget class="QComboBox" name="mTypeBox" />
+      <item row="1" column="1" colspan="4">
+       <widget class="QComboBox" name="mTypeBox"/>
       </item>
-      <item row="2" column="0" >
-       <widget class="QLabel" name="label" >
+      <item row="2" column="0">
+       <widget class="QLabel" name="label">
          <string>Width</string>
         </property>
          <cstring>mWidth</cstring>
         </property>
        </widget>
       </item>
-      <item row="2" column="1" colspan="2" >
-       <widget class="QLineEdit" name="mWidth" />
+      <item row="2" column="1" colspan="2">
+       <widget class="QLineEdit" name="mWidth"/>
       </item>
-      <item row="2" column="3" >
-       <widget class="QLabel" name="label_2" >
+      <item row="2" column="3">
+       <widget class="QLabel" name="label_2">
          <string>Precision</string>
         </property>
          <cstring>mPrecision</cstring>
         </property>
        </widget>
       </item>
-      <item row="2" column="4" >
-       <widget class="QLineEdit" name="mPrecision" >
-        <property name="sizePolicy" >
-         <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+      <item row="2" column="4">
+       <widget class="QLineEdit" name="mPrecision">
+        <property name="sizePolicy">
+         <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
           <horstretch>0</horstretch>
           <verstretch>0</verstretch>
          </sizepolicy>
         </property>
        </widget>
       </item>
-      <item row="3" column="0" colspan="2" >
-       <spacer>
-        <property name="orientation" >
-         <enum>Qt::Horizontal</enum>
-        </property>
-        <property name="sizeHint" >
-         <size>
-          <width>121</width>
-          <height>20</height>
-         </size>
-        </property>
-       </spacer>
-      </item>
-      <item row="3" column="2" colspan="3" >
-       <widget class="QToolButton" name="mAddAttributeButton" >
-         <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
-          <horstretch>0</horstretch>
-          <verstretch>0</verstretch>
-         </sizepolicy>
-        </property>
-        <property name="toolTip" >
-         <string>Add attribute to list</string>
-        </property>
-        <property name="layoutDirection" >
-         <enum>Qt::LeftToRight</enum>
-        </property>
-         <string>Add to attributes list</string>
-        </property>
-        <property name="icon" >
-         <iconset>../../images/themes/default/mActionNewAttribute.png</iconset>
-        </property>
-        <property name="toolButtonStyle" >
-         <enum>Qt::ToolButtonTextBesideIcon</enum>
-        </property>
-       </widget>
-      </item>
      </layout>
     </widget>
    </item>
-    <widget class="QGroupBox" name="groupBox_2" >
+   <item row="6" column="0" colspan="3">
+    <widget class="QGroupBox" name="groupBox_2">
       <string>Attributes list</string>
      </property>
-      <item row="0" column="0" colspan="2" >
-       <widget class="QTreeWidget" name="mAttributeView" >
+      <item row="2" column="0" colspan="2">
+       <widget class="QTreeWidget" name="mAttributeView">
          </sizepolicy>
         </property>
-        <property name="alternatingRowColors" >
+        <property name="alternatingRowColors">
          <bool>true</bool>
         </property>
-        <property name="rootIsDecorated" >
+        <property name="rootIsDecorated">
          <bool>false</bool>
         </property>
-        <property name="columnCount" >
+        <property name="columnCount">
          <number>4</number>
         </property>
         <column>
          </property>
         </column>
         <column>
          </property>
         </column>
         <column>
          </property>
         </column>
         <column>
          </property>
         </column>
        </widget>
       </item>
+      <item row="3" column="0">
        <spacer>
+        <property name="orientation">
         </property>
+        <property name="sizeHint" stdset="0">
          <size>
           <width>121</width>
           <height>20</height>
@@ -230,44 +193,114 @@
         </property>
        </spacer>
       </item>
-      <item row="1" column="1" >
-       <widget class="QToolButton" name="mRemoveAttributeButton" >
+      <item row="3" column="1">
+       <widget class="QToolButton" name="mRemoveAttributeButton">
+         <sizepolicy hsizetype="MinimumExpanding" vsizetype="Fixed">
          </sizepolicy>
         </property>
+        <property name="toolTip">
          <string>Delete selected attribute</string>
         </property>
-         <string>Removed selected attribute</string>
+         <string>Remove selected attribute</string>
         </property>
-         <iconset>../../images/themes/default/mActionDeleteAttribute.png</iconset>
+        <property name="icon">
+         <iconset>
+          <normaloff>../../images/themes/default/mActionDeleteAttribute.png</normaloff>../../images/themes/default/mActionDeleteAttribute.png</iconset>
         </property>
+        <property name="toolButtonStyle">
         </property>
        </widget>
       </item>
+       <spacer name="horizontalSpacer">
+         <enum>Qt::Horizontal</enum>
+        </property>
+         <size>
+          <width>40</width>
+          <height>20</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="1" column="1">
+       <widget class="QToolButton" name="mAddAttributeButton">
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+         <string>Add attribute to list</string>
+        </property>
+        <property name="layoutDirection">
+         <enum>Qt::LeftToRight</enum>
+        </property>
+         <string>Add to attributes list</string>
+        </property>
+         <iconset>
+          <normaloff>../../images/themes/default/mActionNewAttribute.png</normaloff>../../images/themes/default/mActionNewAttribute.png</iconset>
+        </property>
+         <enum>Qt::ToolButtonTextBesideIcon</enum>
+        </property>
+       </widget>
+      </item>
      </layout>
     </widget>
    </item>
-   <item row="4" column="0" colspan="2" >
-    <widget class="QDialogButtonBox" name="buttonBox" >
+   <item row="7" column="0" colspan="3">
+    <widget class="QDialogButtonBox" name="buttonBox">
      </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
+    <widget class="QLabel" name="label_3">
+      <string>CRS ID</string>
+     </property>
+      <cstring>leSpatialRefSys</cstring>
+     </property>
+    </widget>
+   </item>
+    <widget class="QLineEdit" name="leSpatialRefSys">
+     <property name="readOnly">
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="2">
+    <widget class="QPushButton" name="pbnChangeSpatialRefSys">
+      <string>Specify the coordinate reference system of the layer's geometry.</string>
+     </property>
+     <property name="whatsThis">
+     </property>
+      <string>Specify CRS</string>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <tabstops>
   <tabstop>mFileFormatComboBox</tabstop>
   <tabstop>mPointRadioButton</tabstop>
@@ -277,7 +310,6 @@
   <tabstop>mTypeBox</tabstop>
   <tabstop>mWidth</tabstop>
   <tabstop>mPrecision</tabstop>
-  <tabstop>mAddAttributeButton</tabstop>
   <tabstop>mAttributeView</tabstop>
   <tabstop>mRemoveAttributeButton</tabstop>
   <tabstop>buttonBox</tabstop>
@@ -290,11 +322,11 @@
    <receiver>QgsNewVectorLayerDialogBase</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>349</x>
      <y>400</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>387</x>
      <y>304</y>
     </hint>
@@ -306,11 +338,11 @@
    <slot>reject()</slot>
    <hints>
      <x>275</x>
      <y>400</y>
     </hint>
      <x>242</x>
      <y>308</y>
     </hint>
More information about the QGIS-commit mailing list
