[QGIS Commit] r12262 - in trunk/qgis: python/core src/core src/core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Nov 26 08:56:09 EST 2009
Author: mhugent
Date: 2009-11-26 08:56:08 -0500 (Thu, 26 Nov 2009)
New Revision: 12262
   trunk/qgis/python/core/qgscomposeritem.sip
   trunk/qgis/python/core/qgscomposerpicture.sip
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/core/composer/qgscomposeritem.cpp
   trunk/qgis/src/core/composer/qgscomposeritem.h
   trunk/qgis/src/core/composer/qgscomposermap.cpp
   trunk/qgis/src/core/composer/qgscomposermap.h
   trunk/qgis/src/core/composer/qgscomposerpicture.cpp
   trunk/qgis/src/core/composer/qgscomposerpicture.h
   trunk/qgis/src/core/composer/qgscomposershape.cpp
   trunk/qgis/src/core/composer/qgscomposershape.h
Keep shape and composer picture size during rotation. Adapt the item size instead
Modified: trunk/qgis/python/core/qgscomposeritem.sip
--- trunk/qgis/python/core/qgscomposeritem.sip	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/python/core/qgscomposeritem.sip	2009-11-26 13:56:08 UTC (rev 12262)
@@ -145,7 +145,7 @@
     double rotation() const;
   public slots:
-    void setRotation( double r);
+    virtual void setRotation( double r);
   protected:
@@ -200,6 +200,13 @@
     bool cornerPointOnRotatedAndScaledRect( double& x, double& y, double width, double height ) const;
     /**Returns a point on the line from startPoint to directionPoint that is a certain distance away from the starting point*/
     QPointF pointOnLineWithDistance( const QPointF& startPoint, const QPointF& directionPoint, double distance ) const;
+    /**Calculates width / height of the bounding box of a rotated rectangle (mRotation)*/
+    void sizeChangedByRotation(double& width, double& height);
+    /**Rotates a point / vector
+        @param angle rotation angle in degrees, counterclockwise
+        @param x in/out: x coordinate before / after the rotation
+        @param y in/out: y cooreinate before / after the rotation*/
+    void rotate( double angle, double& x, double& y ) const;
     signals:
      /**Is emitted on rotation change to notify north arrow pictures*/
Modified: trunk/qgis/python/core/qgscomposerpicture.sip
--- trunk/qgis/python/core/qgscomposerpicture.sip	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/python/core/qgscomposerpicture.sip	2009-11-26 13:56:08 UTC (rev 12262)
@@ -41,7 +41,10 @@
     /**True if the rotation is taken from a map item*/
     bool useRotationMap() const;
+    public slots:
+    virtual void setRotation( double r );
   signals:
     /**Tell the configuration widget that the settings need to be updated*/
     void settingsChanged();
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/CMakeLists.txt	2009-11-26 13:56:08 UTC (rev 12262)
@@ -202,6 +202,7 @@
 composer/qgscomposerscalebar.h
 composer/qgscomposeritemgroup.h
+composer/qgscomposershape.h
 composer/qgscomposition.h
 composer/qgslegendmodel.h
 symbology/qgsmarkercatalogue.h
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-11-26 13:56:08 UTC (rev 12262)
@@ -948,3 +948,50 @@
   double scaleFactor = distance / length;
   return QPointF( startPoint.x() + dx * scaleFactor, startPoint.y() + dy * scaleFactor );
+void QgsComposerItem::sizeChangedByRotation( double& width, double& height )
+  if ( mRotation == 0.0 )
+    return;
+  //vector to p1
+  double x1 = -width / 2.0;
+  double y1 = -height / 2.0;
+  rotate( mRotation, x1, y1 );
+  //vector to p2
+  double x2 = width / 2.0;
+  double y2 = -height / 2.0;
+  rotate( mRotation, x2, y2 );
+  //vector to p3
+  double x3 = width / 2.0;
+  double y3 = height / 2.0;
+  rotate( mRotation, x3, y3 );
+  //vector to p4
+  double x4 = -width / 2.0;
+  double y4 = height / 2.0;
+  rotate( mRotation, x4, y4 );
+  //double midpoint
+  QPointF midpoint( width / 2.0, height / 2.0 );
+  QPolygonF rotatedRectPoly;
+  rotatedRectPoly << QPointF( midpoint.x() + x1, midpoint.y() + y1 );
+  rotatedRectPoly << QPointF( midpoint.x() + x2, midpoint.y() + y2 );
+  rotatedRectPoly << QPointF( midpoint.x() + x3, midpoint.y() + y3 );
+  rotatedRectPoly << QPointF( midpoint.x() + x4, midpoint.y() + y4 );
+  QRectF boundingRect = rotatedRectPoly.boundingRect();
+  width = boundingRect.width();
+  height = boundingRect.height();
+void QgsComposerItem::rotate( double angle, double& x, double& y ) const
+  double rotToRad = angle * M_PI / 180.0;
+  double xRot, yRot;
+  xRot = x * cos( rotToRad ) - y * sin( rotToRad );
+  yRot = x * sin( rotToRad ) + y * cos( rotToRad );
+  x = xRot;
+  y = yRot;
Modified: trunk/qgis/src/core/composer/qgscomposeritem.h
--- trunk/qgis/src/core/composer/qgscomposeritem.h	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposeritem.h	2009-11-26 13:56:08 UTC (rev 12262)
@@ -172,7 +172,7 @@
     double rotation() const {return mRotation;}
   public slots:
-    void setRotation( double r );
   protected:
@@ -245,12 +245,21 @@
     @note: this function was introduced in version 1.2*/
     double horizontalViewScaleFactor() const;
+    //some utility functions
     /**Calculates width and hight of the picture (in mm) such that it fits into the item frame with the given rotation*/
     bool imageSizeConsideringRotation( double& width, double& height ) const;
     /**Calculates corner point after rotation and scaling*/
+    void sizeChangedByRotation( double& width, double& height );
   signals:
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp	2009-11-26 13:56:08 UTC (rev 12262)
@@ -1383,24 +1383,3 @@
     return Bottom;
-void QgsComposerMap::rotate( double angle, double& x, double& y ) const
-  double rotToRad = angle * M_PI / 180.0;
-  double xRot, yRot;
-  xRot = x * cos( rotToRad ) - y * sin( rotToRad );
-  yRot = x * sin( rotToRad ) + y * cos( rotToRad );
-  x = xRot;
-  y = yRot;
-#if 0
-QPointF QgsComposerMap::pointOnLineWithDistance( const QPointF& startPoint, const QPointF& directionPoint, double distance ) const
-  double dx = directionPoint.x() - startPoint.x();
-  double dy = directionPoint.y() - startPoint.y();
-  double length = sqrt( dx * dx + dy * dy );
-  double scaleFactor = distance / length;
-  return QPointF( startPoint.x() + dx * scaleFactor, startPoint.y() + dy * scaleFactor );
-#endif //0
Modified: trunk/qgis/src/core/composer/qgscomposermap.h
--- trunk/qgis/src/core/composer/qgscomposermap.h	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposermap.h	2009-11-26 13:56:08 UTC (rev 12262)
@@ -381,15 +381,6 @@
     QPointF mapToItemCoords( const QPointF& mapCoords ) const;
     /**Returns the item border of a point (in item coordinates)*/
     Border borderForLineCoord( const QPointF& p ) const;
-    /**Rotates a point / vector
-        @param angle rotation angle in degrees, counterclockwise
-        @param x in/out: x coordinate before / after the rotation
-        @param y in/out: y cooreinate before / after the rotation*/
-    void rotate( double angle, double& x, double& y ) const;
-#if 0
-    /**Returns a point on the line from startPoint to directionPoint that is a certain distance away from the starting point*/
-    QPointF pointOnLineWithDistance( const QPointF& startPoint, const QPointF& directionPoint, double distance ) const;
-#endif //0
 #endif
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.cpp
--- trunk/qgis/src/core/composer/qgscomposerpicture.cpp	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.cpp	2009-11-26 13:56:08 UTC (rev 12262)
@@ -30,11 +30,12 @@
 QgsComposerPicture::QgsComposerPicture( QgsComposition *composition ): QgsComposerItem( composition ), mMode( Unknown ), \
     mSvgCacheUpToDate( false ), mCachedDpi( 0 ), mCachedRotation( 0 ), mCachedViewScaleFactor( -1 ), mRotationMap( 0 )
+  mPictureWidth = rect().width();
 QgsComposerPicture::QgsComposerPicture(): QgsComposerItem( 0 ), mMode( Unknown ), mSvgCacheUpToDate( false ), mCachedRotation( 0 ), mCachedViewScaleFactor( -1 ), mRotationMap( 0 )
+  mPictureHeight = rect().height();
 QgsComposerPicture::~QgsComposerPicture()
@@ -61,8 +62,8 @@
   if ( mMode != Unknown )
-    double rectPixelWidth = rect().width() * newDpi / 25.4;
-    double rectPixelHeight = rect().height() * newDpi / 25.4;
+    double rectPixelWidth = /*rect().width()*/mPictureWidth * newDpi / 25.4;
+    double rectPixelHeight = /*rect().height()*/ mPictureHeight * newDpi / 25.4;
     QRectF boundRect;
     if ( mMode == SVG )
@@ -75,11 +76,8 @@
     double boundRectWidthMM = boundRect.width() / newDpi * 25.4;
     double boundRectHeightMM = boundRect.height() / newDpi * 25.4;
-    double rotatedBoundImageWidth = boundRect.width();
-    double rotatedBoundImageHeight = boundRect.height();
-    imageSizeConsideringRotation( rotatedBoundImageWidth, rotatedBoundImageHeight );
-    double rotatedBoundImageWidthMM = rotatedBoundImageWidth / newDpi * 25.4;
-    double rotatedBoundImageHeightMM = rotatedBoundImageHeight / newDpi * 25.4;
+    double boundImageWidth = boundRect.width();
+    double boundImageHeight = boundRect.height();
     if ( mMode == SVG )
@@ -88,20 +86,20 @@
         //make nicer preview
         if ( mComposition && mComposition->plotStyle() == QgsComposition::Preview )
-          rotatedBoundImageWidth *= std::min( viewScaleFactor, 10.0 );
-          rotatedBoundImageHeight *= std::min( viewScaleFactor, 10.0 );
+          boundImageWidth *= std::min( viewScaleFactor, 10.0 );
+          boundImageHeight *= std::min( viewScaleFactor, 10.0 );
-        mImage = QImage( rotatedBoundImageWidth, rotatedBoundImageHeight, QImage::Format_ARGB32 );
+        mImage = QImage( boundImageWidth, boundImageHeight, QImage::Format_ARGB32 );
         updateImageFromSvg();
     painter->save();
-    painter->translate( boundRectWidthMM / 2.0, boundRectHeightMM / 2.0 );
+    painter->translate( rect().width() / 2.0, rect().height() / 2.0 );
     painter->rotate( mRotation );
-    painter->translate( -rotatedBoundImageWidthMM / 2.0, -rotatedBoundImageHeightMM / 2.0 );
+    painter->translate( -boundRectWidthMM / 2.0, -boundRectHeightMM / 2.0 );
-    painter->drawImage( QRectF( 0, 0, rotatedBoundImageWidthMM,  rotatedBoundImageHeightMM ), mImage, QRectF( 0, 0, mImage.width(), mImage.height() ) );
+    painter->drawImage( QRectF( 0, 0, boundRectWidthMM,  boundRectHeightMM ), mImage, QRectF( 0, 0, mImage.width(), mImage.height() ) );
     painter->restore();
@@ -186,6 +184,24 @@
 QRectF QgsComposerPicture::boundedSVGRect( double deviceWidth, double deviceHeight )
   double imageToSvgRatio;
+  if ( deviceWidth / mDefaultSvgSize.width() > deviceHeight / mDefaultSvgSize.height() )
+    imageToSvgRatio = deviceHeight / mDefaultSvgSize.height();
+    double width = mDefaultSvgSize.width() * imageToSvgRatio;
+    return QRectF( 0, 0, width, deviceHeight );
+  else
+    imageToSvgRatio = deviceWidth / mDefaultSvgSize.width();
+    double height = mDefaultSvgSize.height() * imageToSvgRatio;
+    return QRectF( 0, 0, deviceWidth, height );
+#if 0
+QRectF QgsComposerPicture::boundedSVGRect( double deviceWidth, double deviceHeight )
+  double imageToSvgRatio;
   if ( deviceWidth / mDefaultSvgSize.width() < deviceHeight / mDefaultSvgSize.height() )
@@ -199,6 +215,7 @@
+#endif //0
 void QgsComposerPicture::updateImageFromSvg()
@@ -216,9 +233,32 @@
   mSvgCacheUpToDate = false;
   QgsComposerItem::setSceneRect( rectangle );
+  //consider to change size of the shape if the rectangle changes width and/or height
+  double newPictureWidth = rectangle.width();
+  double newPictureHeight = rectangle.height();
+  imageSizeConsideringRotation( newPictureWidth, newPictureHeight );
+  mPictureWidth = newPictureWidth;
+  mPictureHeight = newPictureHeight;
   emit settingsChanged();
+void QgsComposerPicture::setRotation( double r )
+  //adapt rectangle size
+  double width = mPictureWidth;
+  double height = mPictureHeight;
+  sizeChangedByRotation( width, height );
+  //adapt scene rect to have the same center and the new width / height
+  double x = transform().dx() + rect().width() / 2.0 - width / 2.0;
+  double y = transform().dy() + rect().height() / 2.0 - height / 2.0;
+  QgsComposerItem::setSceneRect( QRectF( x, y, width, height ) );
+  QgsComposerItem::setRotation( r );
 void QgsComposerPicture::setRotationMap( int composerMapId )
   if ( !mComposition )
@@ -260,6 +300,8 @@
   QDomElement composerPictureElem = doc.createElement( "ComposerPicture" );
   composerPictureElem.setAttribute( "file", QgsProject::instance()->writePath( mSourceFile.fileName() ) );
+  composerPictureElem.setAttribute( "pictureWidth", mPictureWidth );
+  composerPictureElem.setAttribute( "pictureHeight", mPictureHeight );
   if ( !mRotationMap )
     composerPictureElem.setAttribute( "mapId", -1 );
@@ -281,6 +323,9 @@
     return false;
+  mPictureWidth = itemElem.attribute( "pictureWidth", "10" ).toDouble();
+  mPictureHeight = itemElem.attribute( "pictureHeight", "10" ).toDouble();
   QDomNodeList composerItemList = itemElem.elementsByTagName( "ComposerItem" );
   if ( composerItemList.size() > 0 )
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.h
--- trunk/qgis/src/core/composer/qgscomposerpicture.h	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.h	2009-11-26 13:56:08 UTC (rev 12262)
@@ -39,7 +39,7 @@
     QString pictureFile() const;
     /**Sets this items bound in scene coordinates such that 1 item size units
-       corresponds to 1 scene size unit*/
+       corresponds to 1 scene size unit and resizes the svg symbol / image*/
     void setSceneRect( const QRectF& rectangle );
     /** stores state in Dom node
@@ -60,6 +60,10 @@
     bool useRotationMap() const {return mRotationMap;}
+  public slots:
+    /**Sets the rotation and adapts the item rect*/
   private:
     enum Mode //SVG or raster graphic format
@@ -94,8 +98,11 @@
     QSize mDefaultSvgSize;
     /**Map that sets the rotation (or 0 if this picture uses map independent rotation)*/
     const QgsComposerMap* mRotationMap;
+    /**Width of the picture (in mm)*/
+    double mPictureWidth;
+    /**Height of the picture (in mm)*/
+    double mPictureHeight;
   signals:
Modified: trunk/qgis/src/core/composer/qgscomposershape.cpp
--- trunk/qgis/src/core/composer/qgscomposershape.cpp	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposershape.cpp	2009-11-26 13:56:08 UTC (rev 12262)
@@ -26,6 +26,8 @@
 QgsComposerShape::QgsComposerShape( qreal x, qreal y, qreal width, qreal height, QgsComposition* composition ): QgsComposerItem( x, y, width, height, composition ), mShape( Ellipse )
+  mShapeWidth = width;
+  mShapeHeight = height;
   initGraphicsSettings();
@@ -44,7 +46,6 @@
   double width = rect().width();
   double height = rect().height();
-  imageSizeConsideringRotation( width, height );
   painter->save();
   painter->setRenderHint( QPainter::Antialiasing );
@@ -53,23 +54,23 @@
-  painter->translate( -width / 2.0, -height / 2.0 );
+  painter->translate( -mShapeWidth / 2.0, -mShapeHeight / 2.0 );
   double halfPenWidth = mPen.widthF() / 2.0;
   switch ( mShape )
     case Ellipse:
-      painter->drawEllipse( QRectF( halfPenWidth, halfPenWidth , width - mPen.widthF(), height - mPen.widthF() ) );
+      painter->drawEllipse( QRectF( halfPenWidth, halfPenWidth , mShapeWidth - mPen.widthF(), mShapeHeight - mPen.widthF() ) );
       break;
     case Rectangle:
-      painter->drawRect( QRectF( halfPenWidth, halfPenWidth , width - mPen.widthF(), height - mPen.widthF() ) );
+      painter->drawRect( QRectF( halfPenWidth, halfPenWidth , mShapeWidth - mPen.widthF(), mShapeHeight - mPen.widthF() ) );
       break;
     case Triangle:
       QPolygonF triangle;
-      triangle << QPointF( halfPenWidth, height - halfPenWidth );
-      triangle << QPointF( width - halfPenWidth, height - halfPenWidth );
-      triangle << QPointF( width / 2.0, halfPenWidth );
+      triangle << QPointF( halfPenWidth, mShapeHeight - halfPenWidth );
+      triangle << QPointF( mShapeWidth - halfPenWidth, mShapeHeight - halfPenWidth );
+      triangle << QPointF( mShapeWidth / 2.0, halfPenWidth );
       painter->drawPolygon( triangle );
       break;
@@ -89,6 +90,8 @@
   composerShapeElem.setAttribute( "shapeType", mShape );
   composerShapeElem.setAttribute( "outlineWidth", mPen.widthF() );
   composerShapeElem.setAttribute( "transparentFill", mBrush.style() == Qt::NoBrush );
+  composerShapeElem.setAttribute( "shapeWidth", mShapeWidth );
+  composerShapeElem.setAttribute( "shapeHeight", mShapeHeight );
   QDomElement outlineColorElem = doc.createElement( "OutlineColor" );
   outlineColorElem.setAttribute( "red", mPen.color().red() );
   outlineColorElem.setAttribute( "green", mPen.color().green() );
@@ -108,6 +111,8 @@
 bool QgsComposerShape::readXML( const QDomElement& itemElem, const QDomDocument& doc )
   mShape = QgsComposerShape::Shape( itemElem.attribute( "shapeType", "0" ).toInt() );
+  mShapeWidth = itemElem.attribute( "shapeWidth", "10" ).toDouble();
+  mShapeHeight = itemElem.attribute( "shapeHeight", "10" ).toDouble();
   mPen.setWidthF( itemElem.attribute( "outlineWidth", "0.4" ).toDouble() );
   //transparent fill
@@ -215,3 +220,30 @@
   setPen( QPen( QColor( 255, 255, 255, 0 ) ) );
   setBrush( QBrush( QColor( 255, 255, 255, 0 ) ) );
+void QgsComposerShape::setRotation( double r )
+  double width = mShapeWidth;
+  double height = mShapeHeight;
+void QgsComposerShape::setSceneRect( const QRectF& rectangle )
+  QgsComposerItem::setSceneRect( rectangle );
+  double newShapeWidth = rectangle.width();
+  double newShapeHeight = rectangle.height();
+  imageSizeConsideringRotation( newShapeWidth, newShapeHeight );
+  mShapeWidth = newShapeWidth;
+  mShapeHeight = newShapeHeight;
Modified: trunk/qgis/src/core/composer/qgscomposershape.h
--- trunk/qgis/src/core/composer/qgscomposershape.h	2009-11-26 08:21:22 UTC (rev 12261)
+++ trunk/qgis/src/core/composer/qgscomposershape.h	2009-11-26 13:56:08 UTC (rev 12262)
@@ -23,6 +23,7 @@
 /**A composer items that draws common shapes (ellipse, triangle, rectangle)*/
 class CORE_EXPORT QgsComposerShape: public QgsComposerItem
+    Q_OBJECT
   public:
     enum Shape
@@ -62,7 +63,15 @@
     bool transparentFill() const;
     void setTransparentFill( bool transparent );
+    /**Sets this items bound in scene coordinates such that 1 item size units
+     corresponds to 1 scene size unit. Also, the shape is scaled*/
+    void setSceneRect( const QRectF& rectangle );
+  public slots:
+    /**Sets item rotation and resizes item bounds such that the shape always has the same size*/
   private:
     /**Ellipse, rectangle or triangle*/
     Shape mShape;
@@ -70,6 +79,8 @@
     QPen mPen;
     /**Shape fill*/
     QBrush mBrush;
+    double mShapeWidth;
+    double mShapeHeight;
     /**Apply default graphics settings*/
     void initGraphicsSettings();
More information about the QGIS-commit mailing list
