[QGIS Commit] r11743 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri Oct 2 17:18:26 EDT 2009
Author: timlinux
Date: 2009-10-02 17:18:25 -0400 (Fri, 02 Oct 2009)
New Revision: 11743
trunk/qgis/src/app/qgsfieldcalculator.cpp
trunk/qgis/src/ui/qgsfieldcalculatorbase.ui
Field Calculator: HIG compliance and use user friendly names for data types
Modified: trunk/qgis/src/app/qgsfieldcalculator.cpp
--- trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-02 16:56:59 UTC (rev 11742)
+++ trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-02 21:18:25 UTC (rev 11743)
@@ -22,9 +22,9 @@
QgsFieldCalculator::QgsFieldCalculator( QgsVectorLayer* vl ): QDialog(), mVectorLayer( vl )
setupUi( this );
- mOutputFieldTypeComboBox->addItem( tr( "Double" ) );
- mOutputFieldTypeComboBox->addItem( tr( "Integer" ) );
- mOutputFieldTypeComboBox->addItem( tr( "String" ) );
+ mOutputFieldTypeComboBox->addItem( tr( "Whole number (integer)" ), "Integer" );
+ mOutputFieldTypeComboBox->addItem( tr( "Decimal number (double)" ), "Double" );
+ mOutputFieldTypeComboBox->addItem( tr( "Text (string)" ), "String" );
populateFields();
@@ -83,15 +83,16 @@
//create new field
QgsField newField( mOutputFieldNameLineEdit->text() );
- if ( mOutputFieldTypeComboBox->currentText() == tr( "Double" ) )
+ int index = mOutputFieldTypeComboBox->currentIndex();
+ if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "Double" )
newField.setType( QVariant::Double );
- else if ( mOutputFieldTypeComboBox->currentText() == tr( "Integer" ) )
+ else if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "Integer" )
newField.setType( QVariant::Int );
- else if ( mOutputFieldTypeComboBox->currentText() == tr( "String" ) )
+ else if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "String" )
newField.setType( QVariant::String );
Modified: trunk/qgis/src/ui/qgsfieldcalculatorbase.ui
--- trunk/qgis/src/ui/qgsfieldcalculatorbase.ui 2009-10-02 16:56:59 UTC (rev 11742)
+++ trunk/qgis/src/ui/qgsfieldcalculatorbase.ui 2009-10-02 21:18:25 UTC (rev 11743)
@@ -12,7 +12,7 @@
<property name="windowTitle" >
<string>Field calculator</string>
</property>
- <layout class="QGridLayout" name="gridLayout_5" >
+ <layout class="QGridLayout" >
<item row="0" column="0" >
<widget class="QCheckBox" name="mUpdateExistingFieldCheckBox" >
<property name="text" >
@@ -35,12 +35,15 @@
<property name="title" >
<string>New field</string>
</property>
- <layout class="QGridLayout" name="gridLayout_3" >
<widget class="QLabel" name="mFieldNameLabel" >
- <string>Output field name:</string>
+ <string>Output field name</string>
</property>
+ <property name="buddy" >
+ <cstring>mOutputFieldNameLineEdit</cstring>
+ </property>
</widget>
</item>
<item row="0" column="1" colspan="3" >
@@ -49,8 +52,11 @@
<item row="1" column="0" >
<widget class="QLabel" name="mOutputFieldTypeLabel" >
- <string>Output field type:</string>
+ <string>Output field type</string>
</property>
+ <cstring>mOutputFieldTypeComboBox</cstring>
+ </property>
</widget>
</item>
<item row="1" column="1" colspan="3" >
@@ -59,8 +65,11 @@
<item row="2" column="0" >
<widget class="QLabel" name="mOutputFieldWidthLabel" >
- <string>Output field width:</string>
+ <string>Output field width</string>
</property>
+ <cstring>mOuputFieldWidthSpinBox</cstring>
+ </property>
</widget>
</item>
<item row="2" column="1" >
@@ -69,8 +78,11 @@
<item row="2" column="2" >
<widget class="QLabel" name="mOutputFieldPrecisionLabel" >
- <string>Output field precision:</string>
+ <string>Output field precision</string>
</property>
+ <cstring>mOutputFieldPrecisionSpinBox</cstring>
+ </property>
</widget>
</item>
<item row="2" column="3" >
@@ -84,7 +96,7 @@
<string>Fields</string>
</property>
- <layout class="QGridLayout" name="gridLayout_4" >
<widget class="QListWidget" name="mFieldsListWidget" />
</item>
@@ -96,7 +108,7 @@
<string>Values</string>
</property>
- <layout class="QGridLayout" name="gridLayout_2" >
<item row="0" column="0" colspan="2" >
<widget class="QListWidget" name="mValueListWidget" />
</item>
@@ -122,7 +134,7 @@
<string>Operators</string>
</property>
- <layout class="QGridLayout" name="gridLayout" >
<widget class="QPushButton" name="mPlusPushButton" >
@@ -227,20 +239,23 @@
<item row="5" column="0" colspan="2" >
<widget class="QLabel" name="mFieldCalculatorExpressionLabel" >
- <string>Field calculator expression:</string>
+ <string>Field calculator expression</string>
</property>
+ <cstring>mExpressionTextEdit</cstring>
+ </property>
</widget>
</item>
<item row="6" column="0" colspan="3" >
<widget class="QTextEdit" name="mExpressionTextEdit" />
</item>
- <item row="7" column="0" colspan="2" >
+ <item row="7" column="0" colspan="3" >
<widget class="QDialogButtonBox" name="mButtonBox" >
<property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
<property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
