[QGIS Commit] r11758 - trunk/qgis/src/app
svn_qgis at osgeo.org
Tue Oct 6 13:49:36 EDT 2009
Author: mhugent
Date: 2009-10-06 13:49:35 -0400 (Tue, 06 Oct 2009)
New Revision: 11758
trunk/qgis/src/app/qgsfieldcalculator.cpp
trunk/qgis/src/app/qgsfieldcalculator.h
Field calculator: read available types from the provider (similar to QgsAddAttrDialog)
Modified: trunk/qgis/src/app/qgsfieldcalculator.cpp
--- trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-05 13:34:10 UTC (rev 11757)
+++ trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-06 17:49:35 UTC (rev 11758)
@@ -16,17 +16,16 @@
#include "qgsfieldcalculator.h"
#include "qgssearchtreenode.h"
#include "qgssearchstring.h"
+#include "qgsvectordataprovider.h"
#include "qgsvectorlayer.h"
#include <QMessageBox>
QgsFieldCalculator::QgsFieldCalculator( QgsVectorLayer* vl ): QDialog(), mVectorLayer( vl )
setupUi( this );
- mOutputFieldTypeComboBox->addItem( tr( "Whole number (integer)" ), "Integer" );
- mOutputFieldTypeComboBox->addItem( tr( "Decimal number (double)" ), "Double" );
- mOutputFieldTypeComboBox->addItem( tr( "Text (string)" ), "String" );
populateFields();
+ populateOutputFieldTypes();
//default values for field width and precision
mOuputFieldWidthSpinBox->setValue( 10 );
@@ -82,24 +81,12 @@
else
//create new field
- QgsField newField( mOutputFieldNameLineEdit->text() );
- int index = mOutputFieldTypeComboBox->currentIndex();
- if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "Double" )
- newField.setType( QVariant::Double );
- else if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "Integer" )
- newField.setType( QVariant::Int );
- else if ( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole ) == "String" )
- newField.setType( QVariant::String );
+ QgsField newField( mOutputFieldNameLineEdit->text(),
+ ( QVariant::Type ) mOutputFieldTypeComboBox->itemData( mOutputFieldTypeComboBox->currentIndex(), Qt::UserRole ).toInt(),
+ mOutputFieldTypeComboBox->itemData( mOutputFieldTypeComboBox->currentIndex(), Qt::UserRole + 1 ).toString(),
+ mOuputFieldWidthSpinBox->value(),
+ mOutputFieldPrecisionSpinBox->value() );
- newField.setLength( mOuputFieldWidthSpinBox->value() );
- newField.setPrecision( mOutputFieldPrecisionSpinBox->value() );
if ( !mVectorLayer->addAttribute( newField ) )
QMessageBox::critical( 0, tr( "Provider error" ), tr( "Could not add the new field to the provider." ) );
@@ -200,6 +187,36 @@
+void QgsFieldCalculator::populateOutputFieldTypes()
+ if ( !mVectorLayer )
+ return;
+ QgsVectorDataProvider* provider = mVectorLayer->dataProvider();
+ if ( !provider )
+ return;
+ mOutputFieldTypeComboBox->blockSignals( true );
+ const QList< QgsVectorDataProvider::NativeType > &typelist = provider->nativeTypes();
+ for ( int i = 0; i < typelist.size(); i++ )
+ mOutputFieldTypeComboBox->addItem( typelist[i].mTypeDesc );
+ mOutputFieldTypeComboBox->setItemData( i, static_cast<int>( typelist[i].mType ), Qt::UserRole );
+ mOutputFieldTypeComboBox->setItemData( i, typelist[i].mTypeName, Qt::UserRole + 1 );
+ mOutputFieldTypeComboBox->setItemData( i, typelist[i].mMinLen, Qt::UserRole + 2 );
+ mOutputFieldTypeComboBox->setItemData( i, typelist[i].mMaxLen, Qt::UserRole + 3 );
+ mOutputFieldTypeComboBox->setItemData( i, typelist[i].mMinPrec, Qt::UserRole + 4 );
+ mOutputFieldTypeComboBox->setItemData( i, typelist[i].mMaxPrec, Qt::UserRole + 5 );
+ mOutputFieldTypeComboBox->blockSignals( false );
+ mOutputFieldTypeComboBox->setCurrentIndex( 0 );
+ on_mOutputFieldTypeComboBox_activated( 0 );
void QgsFieldCalculator::on_mUpdateExistingFieldCheckBox_stateChanged( int state )
if ( state == Qt::Checked )
@@ -321,16 +338,23 @@
setOkButtonState();
-void QgsFieldCalculator::on_mOutputFieldTypeComboBox_currentIndexChanged( const QString& text )
+void QgsFieldCalculator::on_mOutputFieldTypeComboBox_activated( int index )
- if ( text == tr( "Double" ) )
- mOutputFieldPrecisionSpinBox->setEnabled( true );
- else
- mOutputFieldPrecisionSpinBox->setEnabled( false );
+ mOuputFieldWidthSpinBox->setMinimum( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole + 2 ).toInt() );
+ mOuputFieldWidthSpinBox->setMaximum( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole + 3 ).toInt() );
+ mOuputFieldWidthSpinBox->setEnabled( mOuputFieldWidthSpinBox->minimum() < mOuputFieldWidthSpinBox->maximum() );
+ if ( mOuputFieldWidthSpinBox->value() < mOuputFieldWidthSpinBox->minimum() )
+ mOuputFieldWidthSpinBox->setValue( mOuputFieldWidthSpinBox->minimum() );
+ if ( mOuputFieldWidthSpinBox->value() > mOuputFieldWidthSpinBox->maximum() )
+ mOuputFieldWidthSpinBox->setValue( mOuputFieldWidthSpinBox->maximum() );
+ mOutputFieldPrecisionSpinBox->setMinimum( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole + 4 ).toInt() );
+ mOutputFieldPrecisionSpinBox->setMaximum( mOutputFieldTypeComboBox->itemData( index, Qt::UserRole + 5 ).toInt() );
+ mOutputFieldPrecisionSpinBox->setEnabled( mOutputFieldPrecisionSpinBox->minimum() < mOutputFieldPrecisionSpinBox->maximum() );
+ if ( mOutputFieldPrecisionSpinBox->value() < mOutputFieldPrecisionSpinBox->minimum() )
+ mOutputFieldPrecisionSpinBox->setValue( mOutputFieldPrecisionSpinBox->minimum() );
+ if ( mOutputFieldPrecisionSpinBox->value() > mOutputFieldPrecisionSpinBox->maximum() )
+ mOutputFieldPrecisionSpinBox->setValue( mOutputFieldPrecisionSpinBox->maximum() );
void QgsFieldCalculator::getFieldValues( int limit )
Modified: trunk/qgis/src/app/qgsfieldcalculator.h
--- trunk/qgis/src/app/qgsfieldcalculator.h 2009-10-05 13:34:10 UTC (rev 11757)
+++ trunk/qgis/src/app/qgsfieldcalculator.h 2009-10-06 17:49:35 UTC (rev 11758)
@@ -52,12 +52,15 @@
void on_mAllPushButton_clicked();
void on_mOutputFieldNameLineEdit_textChanged( const QString& text );
void on_mExpressionTextEdit_textChanged();
- void on_mOutputFieldTypeComboBox_currentIndexChanged( const QString& text );
+ void on_mOutputFieldTypeComboBox_activated( int index );
private:
//default constructor forbidden
QgsFieldCalculator();
+ /**Inserts existing fields into the combo box*/
void populateFields();
+ /**Inserts the types supported by the provider into the combo box*/
+ void populateOutputFieldTypes();
/**Gets field values and inserts them into mValueListWidget
@limit 0: get all feature, != 0 stop after getting limit values*/
void getFieldValues( int limit );
