[QGIS Commit] r11761 - trunk/qgis/src/app/attributetable
svn_qgis at osgeo.org
Tue Oct 6 17:43:34 EDT 2009
Author: jef
Date: 2009-10-06 17:43:33 -0400 (Tue, 06 Oct 2009)
New Revision: 11761
trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h
trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
remove redundancies in QgsAttributeTableMemoryModel and QgsAttributeTableModel
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h 2009-10-06 21:43:33 UTC (rev 11761)
@@ -17,7 +17,7 @@
#define QGSATTRIBUTETABLEDELEGATE_H
#include <QItemDelegate>
-#include "qgsvectorlayer.h"
class QPainter;
class QgsVectorLayer;
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-06 21:43:33 UTC (rev 11761)
@@ -218,7 +218,7 @@
void QgsAttributeTableDialog::on_cbxShowSelectedOnly_toggled( bool theFlag )
- mFilterModel->mHideUnselected = theFlag;
+ mFilterModel->setHideUnselected( theFlag );
mFilterModel->invalidate();
//TODO: weird
//mModel->changeLayout();
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-06 21:43:33 UTC (rev 11761)
@@ -24,9 +24,6 @@
#include "ui_qgsattributetabledialog.h"
-class QgsMapLayer;
-class QgsVectorLayer;
#include "qgsvectorlayer.h" //QgsFeatureIds
class QDialogButtonBox;
Modified: trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h 2009-10-06 21:43:33 UTC (rev 11761)
@@ -20,15 +20,12 @@
#include <QSortFilterProxyModel>
#include <QModelIndex>
-//QGIS Includes
-#include "qgsvectorlayer.h" //QgsAttributeList
class QgsAttributeTableModel;
+class QgsVectorLayer;
class QgsAttributeTableFilterModel: public QSortFilterProxyModel
public:
- bool mHideUnselected;
* Constructor
* @param theLayer initializing layer pointer
@@ -46,6 +43,8 @@
QgsVectorLayer *layer() const { return mLayer; }
QgsAttributeTableModel *tableModel() const { return reinterpret_cast<QgsAttributeTableModel*>( sourceModel() ); }
+ void setHideUnselected( bool theFlag ) { mHideUnselected = theFlag; }
protected:
* Returns true if the source row will be accepted
@@ -55,6 +54,7 @@
bool filterAcceptsRow( int sourceRow, const QModelIndex &sourceParent ) const;
private:
QgsVectorLayer* mLayer;
+ bool mHideUnselected;
#endif
Modified: trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.cpp 2009-10-06 21:43:33 UTC (rev 11761)
@@ -46,92 +46,18 @@
loadLayer();
-QVariant QgsAttributeTableMemoryModel::data( const QModelIndex &index, int role ) const
+bool QgsAttributeTableMemoryModel::featureAtId( int fid )
- if ( !index.isValid() || ( role != Qt::TextAlignmentRole && role != Qt::DisplayRole && role != Qt::EditRole ) )
- return QVariant();
- QVariant::Type fldType = mLayer->pendingFields()[ mAttributes[index.column()] ].type();
- bool fldNumeric = ( fldType == QVariant::Int || fldType == QVariant::Double );
- if ( role == Qt::TextAlignmentRole )
+ if ( mFeatureMap.contains( fid ) )
- if ( fldNumeric )
- return QVariant( Qt::AlignRight );
- else
- return QVariant( Qt::AlignLeft );
+ mFeat = mFeatureMap[ fid ];
+ return true;
- // if we don't have the row in current cache, load it from layer first
- if ( mLastRowId != rowToId( index.row() ) )
+ else
- //bool res = mLayer->featureAtId(rowToId(index.row()), mFeat, false, true);
- bool res = mFeatureMap.contains( rowToId( index.row() ) );
- if ( !res )
- return QVariant( "ERROR" );
- mLastRowId = rowToId( index.row() );
- mFeat = mFeatureMap[rowToId( index.row() )];
- mLastRow = ( QgsAttributeMap * ) & mFeat.attributeMap();
- if ( !mLastRow )
- QVariant &val = ( *mLastRow )[ mAttributes[index.column()] ];
- if ( val.isNull() )
- // if the value is NULL, show that in table, but don't show "NULL" text in editor
- if ( role == Qt::EditRole )
- else
- return QVariant( "NULL" );
- // force also numeric data for EditRole to be strings
- // otherwise it creates spinboxes instead of line edits
- // (probably not what we do want)
- if ( fldNumeric && role == Qt::EditRole )
- return val.toString();
- // convert to QString from some other representation
- // this prevents displaying greater numbers in exponential format
-bool QgsAttributeTableMemoryModel::setData( const QModelIndex &index, const QVariant &value, int role )
- if ( !index.isValid() || role != Qt::EditRole )
+ QgsDebugMsg( QString( "feature %1 not loaded" ).arg( fid ) );
return false;
- if ( !mLayer->isEditable() )
- return false;
- if ( res )
-// QgsDebugMsg(mFeatureMap[rowToId(index.row())].id());
- mFeatureMap[rowToId( index.row() )].changeAttribute( mAttributes[ index.column()], value );
- // propagate back to the layer
- mLayer->beginEditCommand( tr( "Attribute changed" ) );
- mLayer->changeAttributeValue( rowToId( index.row() ), mAttributes[ index.column()], value, true );
- mLayer->endEditCommand();
- if ( !mLayer->isModified() )
- return false;
- emit dataChanged( index, index );
- return true;
void QgsAttributeTableMemoryModel::featureDeleted( int fid )
@@ -150,22 +76,6 @@
QgsAttributeTableModel::featureAdded( fid );
-#if 0
-void QgsAttributeTableMemoryModel::attributeAdded( int idx )
- QgsDebugMsg( "entered." );
- loadLayer();
- reload( index( 0, 0 ), index( rowCount(), columnCount() ) );
-void QgsAttributeTableMemoryModel::attributeDeleted( int idx )
- loadLayer();
-#endif
void QgsAttributeTableMemoryModel::layerDeleted()
Modified: trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2009-10-06 21:43:33 UTC (rev 11761)
@@ -57,22 +57,6 @@
private slots:
- * Launched when attribute has been added
- * @param idx attribute index
- //virtual void attributeAdded (int idx);
- * Launched when attribute has been deleted
- //virtual void attributeDeleted (int idx);
- * Launched when layer has been modified
- * Rebuilds the model
- * @param onlyGeometry true if only geometry has changed
- //virtual void layerModified(bool onlyGeometry);
* Launched when attribute value has been changed
* @param fid feature id
@@ -82,19 +66,13 @@
private:
- * Returns data on the given index
- * @param index model index
- * @param role data role
+ * load feature fid into mFeat
+ * @param fid feature id
+ * @return feature exists
- virtual QVariant data( const QModelIndex &index, int role ) const;
+ virtual bool featureAtId( int fid );
- * Updates data on given index
- * @param value new data value
- virtual bool setData( const QModelIndex &index, const QVariant &value, int role );
* Loads the layer into the model
virtual void loadLayer();
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-10-06 21:43:33 UTC (rev 11761)
@@ -68,6 +68,11 @@
loadLayer();
+bool QgsAttributeTableModel::featureAtId( int fid )
+ return mLayer->featureAtId( fid, mFeat, false, true );
void QgsAttributeTableModel::featureDeleted( int fid )
@@ -361,6 +366,11 @@
QVariant QgsAttributeTableModel::data( const QModelIndex &index, int role ) const
+ return (( QgsAttributeTableModel * ) this )->data( index, role );
+QVariant QgsAttributeTableModel::data( const QModelIndex &index, int role )
return QVariant();
@@ -378,7 +388,7 @@
- bool res = mLayer->featureAtId( rowToId( index.row() ), mFeat, false, true );
+ bool res = featureAtId( rowToId( index.row() ) );
if ( !res )
@@ -429,12 +439,13 @@
return false;
if ( res )
- mLastRow = ( QgsAttributeMap * )( &( mFeat.attributeMap() ) );
+ mLastRow = ( QgsAttributeMap * ) & mFeat.attributeMap();
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-10-06 20:53:22 UTC (rev 11760)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-10-06 21:43:33 UTC (rev 11761)
@@ -22,9 +22,8 @@
#include <QObject>
#include <QHash>
-//QGIS Includes
-#include "qgsfeature.h" //QgsAttributeMap
+#include "qgsfeature.h" // QgsAttributeMap
+#include "qgsvectorlayer.h" // QgsAttributeList
#include "qgsattributetableidcolumnpair.h"
class QgsAttributeTableModel: public QAbstractTableModel
@@ -203,6 +202,14 @@
+ QVariant data( const QModelIndex &index, int role );
