[QGIS Commit] r11764 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Oct 7 10:16:18 EDT 2009
Author: micha
Date: 2009-10-07 10:16:17 -0400 (Wed, 07 Oct 2009)
New Revision: 11764
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
Added explanation for identifying multiple layers
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-10-07 11:58:29 UTC (rev 11763)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-10-07 14:16:17 UTC (rev 11764)
@@ -730,10 +730,9 @@
points according to a defined ellipsoid. To configure this, choose menu option
\mainmenuopt{Settings} > \dropmenuopt{Options},
click on the \tab{Map tools} tab and choose the appropriate ellipsoid. The tool then allows you to
-click points on the map. Each segment-length shows up in the measure-window and additionally the total
-length is printed. To stop measuring click your right mouse button. \\
+click points on the map. Each segment-length as well as the total shows up in the measure-window. To stop measuring click your right mouse button. \\
\includegraphics[width=0.7cm]{mActionMeasureArea} Areas can also be measured.
-The window shows the accumulated area-size in the measure window
+In the measure window the accumulated area-size appears \\
In addition, the measuring tool will snap to the currently selected layer, provided that layer has its snapping tolerance set. (See Section~\ref{snapping_tolerance}). So if you want to measure exactly along a line feature, or around a polygon feature, first set its snapping tolerance, then select the layer. Now, when using the measuring tools, each mouse click (within the tolerance setting) will snap to that layer.
\begin{figure}[h]
@@ -778,6 +777,15 @@
you can select \checkbox{Warn when opening a project file saved with an older
version of QGIS}.
+\minisec{Project Properties}
+In the properties window for the project (under \nix{\mainmenuopt{File} > \dropmenuopt{Project Properties}} or \win{\mainmenuopt{Settings} > \dropmenuopt{Project Properties} } you set project specific options. These include:
+\begin{itemize}
+ \item In the \tab{General} tab the Project title, units, and the option to save relative paths to layers. In addition the topological editing, and snapping options are set here.
+\item The \tab{CRS} Coordinate Reference System tab enables you to choose the CRS for this project, and to enable on-the-fly reprojection of vector layers when displaying layers from a different CRS.
+\item With the third \tab{Identifiable layers} tab you set (or disable) which layers will respond to the identify tool. (See the Map tools paragraph from the \ref{subsec:gui_options} section to enable identifying of multiple layers.)
+\end{itemize}
\subsection{Output}\label{sec:output}\index{output!save as image!print composer!quick print}
There are several ways to generate output from your QGIS session.
We have discussed one already in Section \ref{sec:projects}: saving as a project file.
@@ -791,8 +799,7 @@
\end{itemize}
-\subsection{GUI Options}
-\label{subsec:gui_options}
+\subsection{GUI Options}\label{subsec:gui_options}
\includegraphics[width=0.7cm,clip=true]{mActionOptions}
Some basic options for QGIS
can be selected using the \dialog{Options} dialog. Select the
@@ -829,6 +836,7 @@
\minisec{Map tools Tab}
\begin{itemize}
+\item The Mode setting determines which layers will be shown by the Identify tool. By switching to \usertext{Top down} instead of \usertext{Current layer} then attributes for all identifiable layers (See the Project properties section under: \ref{sec:projects} to set which layers are identifiable) will be show with the Identify tool.
\item Define Search Radius as a percentage of the map width
\item Define Ellipsoid for distance calculations
\item Define Rubberband Color for Measure Tools
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2009-10-07 11:58:29 UTC (rev 11763)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2009-10-07 14:16:17 UTC (rev 11764)
@@ -1001,7 +1001,8 @@
Properties\dots}. In the \tab{General} tab, section \classname{Digitize} you
can click on \button{Snapping options\dots} to enable and adjust snapping
mode and tolerance on a layer basis (see Figure~\ref{fig:snappingoptions}).
-\end{enumerate}. Note that this layer based snapping overrides the global snapping option set in the Digitizing tab. So if you need to edit one layer, and snap its vertices to another layer, then enable snapping only on the \usertext{snap to} layer, then decrease the global snapping tolerance to a smaller value. Furthermore, snapping will never occur to a layer which is not checked in the snapping options dialog, regardless of the global snapping tolerance. So be sure to mark the checkbox for those layers that you need to snap to.
+\end{enumerate}
+Note that this layer based snapping overrides the global snapping option set in the Digitizing tab. So if you need to edit one layer, and snap its vertices to another layer, then enable snapping only on the \usertext{snap to} layer, then decrease the global snapping tolerance to a smaller value. Furthermore, snapping will never occur to a layer which is not checked in the snapping options dialog, regardless of the global snapping tolerance. So be sure to mark the checkbox for those layers that you need to snap to.
\begin{figure}[H]
\begin{center}
