[QGIS Commit] r11786 - in trunk/qgis: i18n
src/plugins/delimited_text src/plugins/spit
svn_qgis at osgeo.org
Fri Oct 9 16:55:07 EDT 2009
Author: jef
Date: 2009-10-09 16:55:06 -0400 (Fri, 09 Oct 2009)
New Revision: 11786
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
trunk/qgis/src/plugins/spit/qgsspit.cpp
german translation update and minor fixes
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-10-09 16:01:57 UTC (rev 11785)
+++ trunk/qgis/i18n/qgis_de.ts 2009-10-09 20:55:06 UTC (rev 11786)
@@ -8368,7 +8368,7 @@
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="13"/>
<source>Field calculator</source>
- <translation>Feld-rechner</translation>
+ <translation>Feldrechner</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="19"/>
@@ -8388,122 +8388,122 @@
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="42"/>
<source>Output field name:</source>
- <translation type="unfinished"></translation>
+ <translation>Ausgabefeldname:</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="52"/>
<source>Output field type:</source>
+ <translation>Ausgabefeldtyp:</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="62"/>
<source>Output field width:</source>
+ <translation>Ausgabefeldbreite:</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="72"/>
<source>Output field precision:</source>
+ <translation>Ausgabefeldgenauigkeit:</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="85"/>
<source>Fields</source>
- <translation type="unfinished">Felder</translation>
+ <translation>Felder</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="97"/>
<source>Values</source>
- <translation type="unfinished">Werte</translation>
+ <translation>Werte</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="106"/>
<source>Sample</source>
- <translation type="unfinished">Stichprobe</translation>
+ <translation>Stichprobe</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="113"/>
<source>All</source>
- <translation type="unfinished">Alle</translation>
+ <translation>Alle</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="123"/>
<source>Operators</source>
- <translation type="unfinished">Operatoren</translation>
+ <translation>Operatoren</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="129"/>
<source>+</source>
+ <translation>+</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="136"/>
<source>*</source>
- <translation type="unfinished">*</translation>
+ <translation>*</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="143"/>
<source>sqrt</source>
+ <translation>sqrt</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="150"/>
<source>sin</source>
+ <translation>sin</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="157"/>
<source>tan</source>
+ <translation>tan</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="164"/>
<source>acos</source>
+ <translation>acos</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="171"/>
<source>(</source>
+ <translation>(</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="178"/>
<source>-</source>
- <translation type="unfinished">-</translation>
+ <translation>-</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="185"/>
<source>/</source>
+ <translation>/</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="192"/>
<source>^</source>
+ <translation>^</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="199"/>
<source>cos</source>
+ <translation>cos</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="206"/>
<source>asin</source>
+ <translation>asin</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="213"/>
<source>atan</source>
+ <translation>atan</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="220"/>
<source>)</source>
+ <translation>)</translation>
</message>
<message>
<location filename="../src/ui/qgsfieldcalculatorbase.ui" line="230"/>
<source>Field calculator expression:</source>
+ <translation>Feldrechnerausdruck:</translation>
</message>
</context>
<context>
@@ -14402,22 +14402,22 @@
<message>
<location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="31"/>
<source>Text data</source>
+ <translation>Text</translation>
</message>
<message>
<location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="32"/>
<source>Whole number</source>
+ <translation>Ganzzahl</translation>
</message>
<message>
<location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="33"/>
<source>Decimal number</source>
+ <translation>Dezimalzahl</translation>
</message>
<message>
<location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="36"/>
<source>ESRI Shapefile</source>
+ <translation>ESRI-Shapedatei</translation>
</message>
</context>
<context>
@@ -14425,82 +14425,82 @@
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="13"/>
<source>New Vector Layer</source>
- <translation type="unfinished">Neuer Vektorlayer</translation>
+ <translation>Neuer Vektorlayer</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="25"/>
<source>File format</source>
- <translation type="unfinished">Dateiformat</translation>
+ <translation>Dateiformat</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="42"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="91"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="205"/>
<source>Type</source>
- <translation type="unfinished">Typ</translation>
+ <translation>Typ</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="48"/>
<source>Point</source>
- <translation type="unfinished">Punkt</translation>
+ <translation>Punkt</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="55"/>
<source>Line</source>
- <translation type="unfinished">Linie</translation>
+ <translation>Linie</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="62"/>
<source>Polygon</source>
- <translation type="unfinished">Polygon</translation>
+ <translation>Polygon</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="72"/>
<source>New attribute</source>
+ <translation>Neues Attribut</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="78"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="200"/>
<source>Name</source>
- <translation type="unfinished">Name</translation>
+ <translation>Name</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="104"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="210"/>
<source>Width</source>
- <translation type="unfinished">Breite</translation>
+ <translation>Breite</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="117"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="215"/>
<source>Precision</source>
- <translation type="unfinished">Genauigkeit</translation>
+ <translation>Genauigkeit</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="156"/>
<source>Add attribute to list</source>
+ <translation>Attribut der Liste hinzufügen</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="162"/>
<source>Add to attributes list</source>
+ <translation>Der Attributliste hinzufügen</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="178"/>
<source>Attributes list</source>
+ <translation>Attributliste</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="242"/>
<source>Delete selected attribute</source>
- <translation type="unfinished">Gewähltes Attribut löschen</translation>
+ <translation>Gewähltes Attribut löschen</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="245"/>
<source>Removed selected attribute</source>
+ <translation>Gewähltes Attribute gelöscht</translation>
</message>
</context>
<context>
@@ -14691,17 +14691,17 @@
<message>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="186"/>
<source>Whole number (integer)</source>
+ <translation>Ganzzahl (integer)</translation>
</message>
<message>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="187"/>
<source>Decimal number (real)</source>
+ <translation>Dezimalzahl (real)</translation>
</message>
<message>
<location filename="../src/providers/ogr/qgsogrprovider.cpp" line="188"/>
<source>Text (string)</source>
+ <translation>Text (string)</translation>
</message>
</context>
<context>
@@ -15546,12 +15546,12 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="791"/>
<source>Default snapping tolerance</source>
+ <translation>Voreingestellte Fangtoleranz</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="821"/>
<source>Search radius for vertex edits</source>
+ <translation>Suchradius für Knickpunktbearbeitung</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="973"/>
@@ -17257,52 +17257,52 @@
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="231"/>
<source>Whole number (smallint - 16bit)</source>
+ <translation>Kleine Ganzzahl (16bit)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="232"/>
<source>Whole number (integer 32bit)</source>
+ <translation>Ganzzahl (32bit)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="233"/>
<source>Whole number (integer 64bit)</source>
+ <translation>Ganzzahl (64bit)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="234"/>
<source>Decimal number (numeric)</source>
+ <translation>Dezimalzahl (numeric)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="235"/>
<source>Decimal number (decimal)</source>
+ <translation>Dezimalzahl (decimal)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="238"/>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="239"/>
<source>Decimal number (double)</source>
+ <translation>Dezimalzahl (double)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="242"/>
<source>Text, fixed length (char)</source>
+ <translation>Text, feste Länge (char)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="243"/>
<source>Text, variable length (varchar)</source>
+ <translation>Text, variable Länge (varchar)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="244"/>
<source>Text (text)</source>
+ <translation>Text, unbegrenze Länge (text)</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1037"/>
@@ -17677,17 +17677,17 @@
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="145"/>
<source>absolute</source>
+ <translation>Absolut</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="150"/>
<source>relative</source>
+ <translation>Relativ</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="158"/>
<source>Save paths</source>
+ <translation>Pfade speichern</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="229"/>
@@ -20258,17 +20258,17 @@
<message>
<location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="103"/>
<source>Binary object (BLOB)</source>
+ <translation>Binärobjekt (BLOB)</translation>
</message>
<message>
<location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="105"/>
</message>
<message>
<location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="106"/>
</message>
<message>
<location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="230"/>
@@ -20367,7 +20367,7 @@
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="293"/>
<source>@</source>
+ <translation>@</translation>
</message>
<message>
<source> @ </source>
@@ -21750,7 +21750,7 @@
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="547"/>
</message>
</context>
<context>
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui 2009-10-09 16:01:57 UTC (rev 11785)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui 2009-10-09 20:55:06 UTC (rev 11786)
@@ -164,7 +164,7 @@
<item row="5" column="0" colspan="2" >
<widget class="QLabel" name="label_2" >
<property name="text" >
- <string>Delimeter type</string>
+ <string>Delimiter type</string>
</property>
<property name="buddy" >
<cstring>delimiterPlain</cstring>
Modified: trunk/qgis/src/plugins/spit/qgsspit.cpp
--- trunk/qgis/src/plugins/spit/qgsspit.cpp 2009-10-09 16:01:57 UTC (rev 11785)
+++ trunk/qgis/src/plugins/spit/qgsspit.cpp 2009-10-09 20:55:06 UTC (rev 11786)
@@ -467,8 +467,7 @@
- QString schemaSql = QString( "select nspname from pg_namespace where has_schema_privilege(nspname, 'CREATE')" )
- .arg( QgsPgUtil::quotedValue( username ) );
+ QString schemaSql = "select nspname from pg_namespace where has_schema_privilege(nspname, 'CREATE')";
PGresult *schemas = PQexec( conn, schemaSql.toUtf8() );
// get the schema names
if ( PQresultStatus( schemas ) == PGRES_TUPLES_OK )
