[QGIS Commit] r11812 - trunk/qgis/ms-windows
svn_qgis at osgeo.org
Thu Oct 15 18:02:28 EDT 2009
Author: timlinux
Date: 2009-10-15 18:02:27 -0400 (Thu, 15 Oct 2009)
New Revision: 11812
trunk/qgis/ms-windows/QGIS-Installer.nsi
trunk/qgis/ms-windows/plugins.nsh
trunk/qgis/ms-windows/ui.nsh
Added RequestExecutionLevel option to make the installer behave better under Vista and Win 7. Updated reg entries for toolbars etc
Modified: trunk/qgis/ms-windows/QGIS-Installer.nsi
--- trunk/qgis/ms-windows/QGIS-Installer.nsi 2009-10-15 15:02:01 UTC (rev 11811)
+++ trunk/qgis/ms-windows/QGIS-Installer.nsi 2009-10-15 22:02:27 UTC (rev 11812)
@@ -15,8 +15,8 @@
;Version variables
-!define RELEASE_VERSION_NUMBER "1.3.0"
-!define RELEASE_VERSION_NAME "Mimas"
+!define RELEASE_VERSION_NUMBER "1.4.0"
+!define RELEASE_VERSION_NAME "Trunk-Test-Build"
!define RELEASE_SVN_REVISION "11639"
!define RELEASE_BINARY_REVISION "0"
@@ -27,6 +27,9 @@
; Added by Tim to get optimal compression
SetCompressor /SOLID lzma
+; Added by Tim to allow priveledge elevation in vista
+RequestExecutionLevel admin
;Don't modify the following lines
Modified: trunk/qgis/ms-windows/plugins.nsh
--- trunk/qgis/ms-windows/plugins.nsh 2009-10-15 15:02:01 UTC (rev 11811)
+++ trunk/qgis/ms-windows/plugins.nsh 2009-10-15 22:02:27 UTC (rev 11812)
@@ -22,5 +22,9 @@
WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "spitplugin" "true"
WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "wfsplugin" "true"
WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "grassplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "diagramoverlay" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "oracleplugin" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "evis" "true"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\Plugins" "rasterterrainplugin" "true"
############################### reg2nsis end #################################
Modified: trunk/qgis/ms-windows/ui.nsh
--- trunk/qgis/ms-windows/ui.nsh 2009-10-15 15:02:01 UTC (rev 11811)
+++ trunk/qgis/ms-windows/ui.nsh 2009-10-15 22:02:27 UTC (rev 11812)
@@ -7,12 +7,16 @@
# Please don't remove this header. #
-WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "state" 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
-WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "geometry" 400042007900740065004100720072006100790028000100d900d000cb000000010000000000ff00ff00ff00fc00ff00ff00ff00fc00000000000400b800000000000300220000000000000030000000000000004300000000000200af0000000000020022000000000000000000020000002900
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "state" 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
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "geometry" 400042007900740065004100720072006100790028000100d900d000cb000000010000000000ff00ff00ff00fc00ff00ff00ff00fc000000000006008300000000000300760000000000000000000000000000001400000000000400b40000000000010091000000000000000000020000002900
WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastVectorFileFilter" "[OGR] ESRI Shapefiles (*.shp *.SHP)"
-WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastVectorFileFilterDir" "C:/Program Files/Quantum GIS/gisdata/ecape"
WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "encoding" "System"
-WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastRasterFileFilter" "GeoTIFF (*.tif *.TIF)"
-WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastRasterFileFilterDir" "C:/Program Files/Quantum GIS/gisdata/ecape"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastRasterFileFilter" "SAR_CEOS, CEOS, JAXAPALSAR, ELAS, AIG, OGDI, MEM, BSB, DIMAP, AirSAR, RS2, HDF4, HDF4Image, ISIS3, ISIS2, PDS, ERS, L1B, FIT, WCS, WMS, INGR, COSAR, TSX, DOQ1, DOQ2, ENVI, EHdr, GenBin, PAux, MFF2, FujiBAS, GSC, FAST, LAN, CPG, IDA, NDF, EIR, DIPEx, HTTP, HDF5Image and all other files (*)"
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "recentProjections" 33003400350032000000330033003400340000000000
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastSaveAsImageFilter" "jpg format (*.jpg *.JPG);;"
+WriteRegStr HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "lastSaveAsImageDir" "C:/tmp"
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "recentProjectionsEpsg" 34003300320036000000340032003100310000000000
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "recentProjectionsProj4" 2b00700072006f006a003d006c006f006e0067006c006100740020002b0065006c006c00700073003d005700470053003800340020002b0064006100740075006d003d005700470053003800340020002b006e006f005f00640065006600730000002b00700072006f006a003d006c006f006e0067006c006100740020002b0065006c006c00700073003d00620065007300730065006c0020002b006e006f005f00640065006600730000000000
+WriteRegBin HKEY_CURRENT_USER "Software\QuantumGIS\QGIS\UI" "recentProjectsList" 43003a002f0044006f00630075006d0065006e0074007300200061006e0064002000530065007400740069006e00670073002f00410064006d0069006e006900730074007200610074006f0072002f006700690064006100740061002f004c0061006e00640063006f007600650072002f006c0061006e00640063006f007600650072002e0071006700730000000000
