[QGIS Commit] r11823 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Oct 20 15:24:51 EDT 2009
Author: macho
Date: 2009-10-20 15:24:51 -0400 (Tue, 20 Oct 2009)
New Revision: 11823
   trunk/qgis/i18n/qgis_nl.ts
translation update: nl by richard
Modified: trunk/qgis/i18n/qgis_nl.ts
--- trunk/qgis/i18n/qgis_nl.ts	2009-10-20 09:49:39 UTC (rev 11822)
+++ trunk/qgis/i18n/qgis_nl.ts	2009-10-20 19:24:51 UTC (rev 11823)
@@ -2045,57 +2045,57 @@
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="78"/>
         <source>Show type description</source>
-        <translation type="unfinished"></translation>
+        <translation>Tone type-omschrijving</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="81"/>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="84"/>
         <source>Shows brief description of selected relation type.</source>
+        <translation>Toon korte beschrijving van geselecteerde type relatie.</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="135"/>
         <source>Generate tags</source>
+        <translation>Tags genereren</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="138"/>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="141"/>
         <source>Fills tag table with tags that are typical for relation of specified type.</source>
+        <translation>Tabel vullen met tags typisch voor dit soort relaties.</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="151"/>
         <source>Remove all selected tags</source>
+        <translation>Verwijder de geselecteerde tags</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="154"/>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="157"/>
         <source>Removes all selected tags.</source>
+        <translation>Verwijdert alle geselecteerde tags.</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="205"/>
         <source>Select member on map</source>
+        <translation>Selecteer onderdeel op de kaart</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="208"/>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="211"/>
         <source>Starts process of selecting next relation member on map.</source>
+        <translation>Volgende relatie-onderdeel selectie starten.</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="224"/>
         <source>Remove all selected members</source>
+        <translation>Alle geselecteerde onderdelen verwijderen</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="227"/>
         <location filename="../python/plugins/osm/ui_files/OsmAddRelationDlg.ui" line="230"/>
         <source>Removes all selected members.</source>
+        <translation>Verwijdert alle geselecteerde onderdelen.</translation>
     </message>
 </context>
 <context>
@@ -2437,21 +2437,21 @@
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="103"/>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="106"/>
         <source>Identify feature</source>
+        <translation>Objecten Identificeren</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="134"/>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="137"/>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="140"/>
         <source>Move feature</source>
+        <translation>Kaartobject verplaatsen</translation>
     </message>
     <message>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="419"/>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="422"/>
         <location filename="../python/plugins/osm/ui_files/OsmFeatureDW.ui" line="425"/>
         <source>Remove this feature</source>
+        <translation>Object verwijderen</translation>
     </message>
 </context>
 <context>
@@ -4545,17 +4545,17 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2059"/>
         <source>Whats new in Version 1.3.0?</source>
+        <translation>Wat is er nieuw in Versie 1.3.0?</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2062"/>
         <source>Please note that this is a release in our &apos;cutting edge&apos; release series. As such it contains new features and extends the programmatic interface over QGIS 1.0.x and QGIS 1.2.0. If an unchanging user interface, programmatic API and long term support is more important to you then cool new and untested features, we recommend that you use a copy of QGIS from our Long Term Support (LTS)1.0.x release series.</source>
+        <translation>Let op: dit is een release uit onze &apos;haantje-de-voorste&apos;-releases. Daarom bevat het nieuwe features en uitbreidingen van de programmeerinterface ten opzichte van QGIS 1.0.x en QGIS 1.1.0. Als stabiliteit en langetermijn ondersteuning belangrijker is voor u dan vette nieuwe en ongeteste features, dan raden wij u aan om een kopie van QGIS uit de stabiele 1.0.x versie te gebruiken.</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2071"/>
         <source>This release includes over 30 bug fixes and enhancements over the QGIS 1.2.0 release. In addition we have added the following new features:</source>
+        <translation>Deze release bevat meer dan 40 verbeteringen ten opzicht van de 1.2.0 versie. Verder zijn de volgende nieuwe functionaliteiten toegevoegd (engels):</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2074"/>
@@ -4581,7 +4581,7 @@
   &lt;li&gt;Added ability to select the primary key for views.&lt;/li&gt;
   &lt;li&gt;Zoom to a coordinate by entering it in the status bar coordinate display.&lt;/li&gt;
 &lt;/ul&gt;</source>
+        <translation></translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="5165"/>
@@ -6200,7 +6200,7 @@
         <location filename="../src/app/qgisapp.cpp" line="744"/>
         <location filename="../src/app/qgisapp.cpp" line="746"/>
         <source>Rotate Point Symbols</source>
+        <translation>Puntsymbolen Roteren</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="774"/>
@@ -6739,7 +6739,7 @@
     <message>
         <location filename="../src/ui/qgsabout.ui" line="202"/>
         <source>Contributors</source>
+        <translation>Meewerkenden</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsabout.ui" line="230"/>
@@ -6870,7 +6870,7 @@
     <message>
         <location filename="../src/app/qgsabout.cpp" line="294"/>
         <source>Qt Image Plugin Search Paths	&lt;br&gt;</source>
+        <translation>Qt-Image Plugin zoekpaden		&lt;br&gt;</translation>
     </message>
     <message>
         <source>Qt Image Plugin Search Paths&lt;br&gt;</source>
@@ -7454,12 +7454,12 @@
     <message>
         <location filename="../src/ui/qgsattributetabledialog.ui" line="46"/>
         <source>Unselect all</source>
+        <translation>Deselecteer alles</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsattributetabledialog.ui" line="68"/>
         <source>Move selection to top</source>
+        <translation>Verplaats selectie naar boven</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsattributetabledialog.ui" line="83"/>
@@ -7826,7 +7826,7 @@
     <message>
         <location filename="../src/ui/qgsattributetypeedit.ui" line="61"/>
         <source>Hidden</source>
-        <translation type="unfinished">Verborgen</translation>
+        <translation>Verborgen</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsattributetypeedit.ui" line="76"/>
@@ -7922,12 +7922,12 @@
     <message>
         <location filename="../src/ui/qgsattributetypeedit.ui" line="440"/>
         <source>An immutable attribute is read-only - the user is not able to modify the contents.</source>
+        <translation>Een &apos;alleen-lezen&apos; attribuut - de gebruiker kan de inhoud niet aanpassen of veranderen.</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsattributetypeedit.ui" line="467"/>
         <source>A hidden attribute will be invisible - the user is not able to see it&apos;s contents.</source>
+        <translation>Een verborgen attribuut is onzichtbaar - de gebruiker kan de inhoud ervan niet zien.</translation>
     </message>
     <message>
         <source>Immutable attribute is read-only - user is not able to modify the contents.</source>
@@ -11171,44 +11171,44 @@
         <location filename="../src/app/qgsfieldcalculator.cpp" line="86"/>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="325"/>
         <source>Double</source>
-        <translation type="unfinished">Double</translation>
+        <translation>Double</translation>
     </message>
     <message>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="26"/>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="90"/>
         <source>Integer</source>
-        <translation type="unfinished">Integer</translation>
+        <translation>Integer</translation>
     </message>
     <message>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="27"/>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="94"/>
         <source>String</source>
-        <translation type="unfinished">String</translation>
+        <translation>String</translation>
     </message>
     <message>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="57"/>
         <source>Syntax error</source>
+        <translation>Syntax fout</translation>
     </message>
     <message>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="104"/>
         <source>Provider error</source>
+        <translation>Provider fout</translation>
     </message>
     <message>
         <source>Could not add the new field to the provider.</source>
+        <translation>Het toevoegen van een nieuw veld aan de provider is mislukt.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsfieldcalculator.cpp" line="168"/>
         <source>Error</source>
-        <translation type="unfinished">Fout</translation>
+        <translation>Fout</translation>
     </message>
     <message>
         <source>An error occured while evaluating the calculation string.</source>
+        <translation>Er is een fout opgetreden bij het evalueren van de berekenings-tekst.</translation>
     </message>
 </context>
 <context>
@@ -11216,142 +11216,142 @@
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="13"/>
         <source>Field calculator</source>
+        <translation>Veld berekening</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="19"/>
         <source>Update existing field</source>
+        <translation>Bestaande velden vernieuwen</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="29"/>
         <source>Only update selected features</source>
+        <translation>Alleen de geselecteerde objecten</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="36"/>
         <source>New field</source>
+        <translation>Nieuw veld</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="42"/>
         <source>Output field name:</source>
+        <translation>Naam voor veld:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="52"/>
         <source>Output field type:</source>
+        <translation>Type voor veld:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="62"/>
         <source>Output field width:</source>
+        <translation>Veldbreedte:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="72"/>
         <source>Output field precision:</source>
+        <translation>Precisie voor veld:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="85"/>
         <source>Fields</source>
-        <translation type="unfinished">Velden</translation>
+        <translation>Velden</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="97"/>
         <source>Values</source>
-        <translation type="unfinished">Waarden</translation>
+        <translation>Waarden</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="106"/>
         <source>Sample</source>
-        <translation type="unfinished">Voorbeeld</translation>
+        <translation>Voorbeeld</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="113"/>
         <source>All</source>
-        <translation type="unfinished">Alles</translation>
+        <translation>Alles</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="123"/>
         <source>Operators</source>
-        <translation type="unfinished">Operatoren</translation>
+        <translation>Operatoren</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="129"/>
         <source>+</source>
-        <translation type="unfinished">+</translation>
+        <translation>+</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="136"/>
         <source>*</source>
-        <translation type="unfinished">*</translation>
+        <translation>*</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="143"/>
         <source>sqrt</source>
+        <translation>wortel</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="150"/>
         <source>sin</source>
+        <translation>sin</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="157"/>
         <source>tan</source>
+        <translation>tan</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="164"/>
         <source>acos</source>
+        <translation>acos</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="171"/>
         <source>(</source>
+        <translation>(</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="178"/>
         <source>-</source>
-        <translation type="unfinished">-</translation>
+        <translation>-</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="185"/>
         <source>/</source>
-        <translation type="unfinished">/</translation>
+        <translation>/</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="192"/>
         <source>^</source>
+        <translation>^</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="199"/>
         <source>cos</source>
+        <translation>cos</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="206"/>
         <source>asin</source>
+        <translation>asin</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="213"/>
         <source>atan</source>
+        <translation>atan</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="220"/>
         <source>)</source>
-        <translation type="unfinished">)</translation>
+        <translation>))</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsfieldcalculatorbase.ui" line="230"/>
         <source>Field calculator expression:</source>
+        <translation>Expressie voor veldberekening:</translation>
     </message>
 </context>
 <context>
@@ -15743,7 +15743,7 @@
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="90"/>
         <source>Identify Results</source>
-        <translation type="unfinished">Identificatieresultaten</translation>
+        <translation>Identificatieresultaten</translation>
     </message>
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="141"/>
@@ -15754,7 +15754,7 @@
         <location filename="../src/app/qgsidentifyresults.cpp" line="181"/>
         <location filename="../src/app/qgsidentifyresults.cpp" line="291"/>
         <source>(Actions)</source>
+        <translation>(Acties)</translation>
     </message>
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="261"/>
@@ -15780,12 +15780,12 @@
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="386"/>
         <source>Expand all</source>
+        <translation>Alles uitklappen</translation>
     </message>
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="390"/>
         <source>Collapse all</source>
+        <translation>Alles inklappen</translation>
     </message>
     <message>
         <location filename="../src/app/qgsidentifyresults.cpp" line="831"/>
@@ -17298,12 +17298,12 @@
     <message>
         <location filename="../src/app/qgsmaptoolidentify.cpp" line="311"/>
         <source>feature id</source>
+        <translation>Object-id</translation>
     </message>
     <message>
         <source>new feature</source>
+        <translation>Nieuw kaartobject</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolidentify.cpp" line="338"/>
@@ -17439,27 +17439,27 @@
     <message>
         <location filename="../src/app/qgsmaptoolrotatepointsymbols.cpp" line="92"/>
         <source>No point feature</source>
+        <translation>Geen puntobject</translation>
     </message>
     <message>
         <source>No point feature was detected at the clicked position. Please click closer to the feature or enhance the search tolerance under Settings-&gt;Options-&gt;Digitizing-&gt;Serch radius for vertex edits</source>
+        <translation>Geen puntobjecten gevonden op deze positie. Klik dichterbij het object of verhoog de (zoekk)tolerantie onder: Bewerken-&gt;Opties-&gt;Digitaliseren-&gt;Zoekradius voor hoek-aanpassingen</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolrotatepointsymbols.cpp" line="106"/>
         <source>No rotation Attributes</source>
+        <translation>Geen rotatie-Attributen</translation>
     </message>
     <message>
         <source>The active point layer does not have a rotation attribute</source>
+        <translation>De aktieve puntlaag heeft geen rotatie-attribuut</translation>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolrotatepointsymbols.cpp" line="185"/>
         <source>Rotate symbol</source>
+        <translation>Roteer symbool</translation>
     </message>
 </context>
 <context>
@@ -18486,22 +18486,22 @@
     <message>
         <location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="31"/>
         <source>Text data</source>
+        <translation>Tekst-data</translation>
     </message>
     <message>
         <location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="32"/>
         <source>Whole number</source>
+        <translation>Geheel getal</translation>
     </message>
     <message>
         <location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="33"/>
         <source>Decimal number</source>
+        <translation>Decimaal getal</translation>
     </message>
     <message>
         <location filename="../src/app/qgsnewvectorlayerdialog.cpp" line="36"/>
         <source>ESRI Shapefile</source>
+        <translation>ESRI-shape gegevens</translation>
     </message>
 </context>
 <context>
@@ -18509,82 +18509,82 @@
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="13"/>
         <source>New Vector Layer</source>
-        <translation type="unfinished">Nieuwe Vectorlaag</translation>
+        <translation>Nieuwe Vectorlaag</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="25"/>
         <source>File format</source>
-        <translation type="unfinished">Bestandsformaat</translation>
+        <translation>Bestandsformaat</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="42"/>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="91"/>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="205"/>
         <source>Type</source>
-        <translation type="unfinished">Type</translation>
+        <translation>Type</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="48"/>
         <source>Point</source>
-        <translation type="unfinished">Punt</translation>
+        <translation>Punt</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="55"/>
         <source>Line</source>
-        <translation type="unfinished">Lijn</translation>
+        <translation>Lijn</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="62"/>
         <source>Polygon</source>
-        <translation type="unfinished">Polygoon</translation>
+        <translation>Polygoon</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="72"/>
         <source>New attribute</source>
+        <translation>Nieuw attribuut</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="78"/>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="200"/>
         <source>Name</source>
-        <translation type="unfinished">Naam</translation>
+        <translation>Naam</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="104"/>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="210"/>
         <source>Width</source>
-        <translation type="unfinished">Breedte</translation>
+        <translation>Breedte</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="117"/>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="215"/>
         <source>Precision</source>
-        <translation type="unfinished">Precisie</translation>
+        <translation>Precisie</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="156"/>
         <source>Add attribute to list</source>
+        <translation>Attribuut toevoegen aan lijst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="162"/>
         <source>Add to attributes list</source>
+        <translation>Toevoegen aan attributenlijst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="178"/>
         <source>Attributes list</source>
+        <translation>Attributenlijst</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="242"/>
         <source>Delete selected attribute</source>
-        <translation type="unfinished">Verwijder geselecteerde attribuut</translation>
+        <translation>Verwijder geselecteerde attribuut</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="245"/>
         <source>Removed selected attribute</source>
+        <translation>Verwijder het geselecteerde attribuut</translation>
     </message>
 </context>
 <context>
@@ -18790,17 +18790,17 @@
     <message>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="186"/>
         <source>Whole number (integer)</source>
+        <translation>Geheel getal (integer)</translation>
     </message>
     <message>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="187"/>
         <source>Decimal number (real)</source>
+        <translation>Decimaal getal (real)</translation>
     </message>
     <message>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="188"/>
         <source>Text (string)</source>
+        <translation>Tekst (string)</translation>
     </message>
 </context>
 <context>
@@ -19377,7 +19377,7 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="944"/>
         <source>Marker size</source>
-        <translation type="unfinished">Markergrootte</translation>
+        <translation>Markergrootte</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="1084"/>
@@ -19533,7 +19533,7 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="237"/>
         <source>Open identify results in a dock window (QGIS restart required)</source>
+        <translation>Identificeer-resulaten naar een &apos;dock-window&apos; (QGIS herstart vereist)</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="251"/>
@@ -19797,12 +19797,12 @@
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="791"/>
         <source>Default snapping tolerance</source>
+        <translation>Standaard &apos;snapping&apos;-tolerantie</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="821"/>
         <source>Search radius for vertex edits</source>
+        <translation>Zoekradius voor hoekpuntaanpassingen</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="858"/>
@@ -21989,52 +21989,52 @@
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="231"/>
         <source>Whole number (smallint - 16bit)</source>
+        <translation>Geheel getal (smallint - 16bit)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="232"/>
         <source>Whole number (integer 32bit)</source>
+        <translation>Geheel getal (smallint - 32bit)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="233"/>
         <source>Whole number (integer 64bit)</source>
+        <translation>Geheel getal (smallint - 64bit)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="234"/>
         <source>Decimal number (numeric)</source>
+        <translation>Decimaal getal (numeriek)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="235"/>
         <source>Decimal number (decimal)</source>
+        <translation>Decimaal getal (decimaal)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="238"/>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="239"/>
         <source>Decimal number (double)</source>
+        <translation>Decimaal getal (double)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="242"/>
         <source>Text, fixed length (char)</source>
+        <translation>Tekst, vaste lengte (char)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="243"/>
         <source>Text, variable length (varchar)</source>
+        <translation>Tekst, variabele lengte (varchar)</translation>
     </message>
     <message>
         <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="244"/>
         <source>Text (text)</source>
+        <translation>Tekst (text)</translation>
     </message>
 </context>
 <context>
@@ -22230,17 +22230,17 @@
     <message>
         <location filename="../src/ui/qgsprojectpropertiesbase.ui" line="145"/>
         <source>absolute</source>
+        <translation>absoluut</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsprojectpropertiesbase.ui" line="150"/>
         <source>relative</source>
+        <translation>relatief</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsprojectpropertiesbase.ui" line="158"/>
         <source>Save paths</source>
+        <translation>Paden opslaan</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsprojectpropertiesbase.ui" line="245"/>
@@ -25105,17 +25105,17 @@
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="103"/>
         <source>Binary object (BLOB)</source>
+        <translation>Binair object (BLOB)</translation>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="105"/>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="106"/>
     </message>
     <message>
         <location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="230"/>
@@ -25214,7 +25214,7 @@
     <message>
         <location filename="../src/app/qgsspatialitesourceselect.cpp" line="293"/>
         <source>@</source>
+        <translation>@</translation>
     </message>
     <message>
         <source> @ </source>
@@ -26600,7 +26600,7 @@
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="562"/>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="749"/>
@@ -26892,7 +26892,7 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="547"/>
     </message>
 </context>
 <context>
More information about the QGIS-commit mailing list
