[QGIS Commit] r11826 - trunk/qgis/tests/src/core
svn_qgis at osgeo.org
Wed Oct 21 18:43:43 EDT 2009
Author: timlinux
Date: 2009-10-21 18:43:41 -0400 (Wed, 21 Oct 2009)
New Revision: 11826
Added:
trunk/qgis/tests/src/core/testqgspoint.cpp
trunk/qgis/tests/src/core/CMakeLists.txt
Added unit test for QgsPoint
Modified: trunk/qgis/tests/src/core/CMakeLists.txt
--- trunk/qgis/tests/src/core/CMakeLists.txt 2009-10-21 14:59:44 UTC (rev 11825)
+++ trunk/qgis/tests/src/core/CMakeLists.txt 2009-10-21 22:43:41 UTC (rev 11826)
@@ -319,3 +319,25 @@
ADD_TEST(qgis_coordinatereferencesystemtest ${CMAKE_INSTALL_PREFIX}/bin/qgis_coordinatereferencesystemtest)
ENDIF (APPLE)
+# testqgspoint
+SET(qgis_pointtest_SRCS testqgspoint.cpp ${util_SRCS})
+SET(qgis_pointtest_MOC_CPPS testqgspoint.cpp)
+QT4_WRAP_CPP(qgis_pointtest_MOC_SRCS ${qgis_pointtest_MOC_CPPS})
+ADD_CUSTOM_TARGET(qgis_pointtestmoc ALL DEPENDS ${qgis_pointtest_MOC_SRCS})
+ADD_EXECUTABLE(qgis_pointtest ${qgis_pointtest_SRCS})
+ADD_DEPENDENCIES(qgis_pointtest qgis_pointtestmoc)
+TARGET_LINK_LIBRARIES(qgis_pointtest ${QT_LIBRARIES} qgis_core)
+SET_TARGET_PROPERTIES(qgis_pointtest
+ PROPERTIES INSTALL_RPATH ${QGIS_LIB_DIR}
+ INSTALL_RPATH_USE_LINK_PATH true)
+IF (APPLE)
+ # For Mac OS X, the executable must be at the root of the bundle's executable folder
+ INSTALL(TARGETS qgis_pointtest RUNTIME DESTINATION ${CMAKE_INSTALL_PREFIX})
+ ADD_TEST(qgis_pointtest ${CMAKE_INSTALL_PREFIX}/qgis_pointtest)
+ELSE (APPLE)
+ INSTALL(TARGETS qgis_pointtest RUNTIME DESTINATION ${CMAKE_INSTALL_PREFIX}/bin)
+ ADD_TEST(qgis_pointtest ${CMAKE_INSTALL_PREFIX}/bin/qgis_pointtest)
+ENDIF (APPLE)
Added: trunk/qgis/tests/src/core/testqgspoint.cpp
--- trunk/qgis/tests/src/core/testqgspoint.cpp (rev 0)
+++ trunk/qgis/tests/src/core/testqgspoint.cpp 2009-10-21 22:43:41 UTC (rev 11826)
@@ -0,0 +1,137 @@
+ test_template.cpp
+ Date : Sun Sep 16 12:22:23 AKDT 2007
+ Copyright : (C) 2007 by Gary E. Sherman
+ Email : sherman at mrcc dot com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include <QtTest>
+#include <QObject>
+#include <QString>
+#include <QObject>
+#include <QApplication>
+#include <QFileInfo>
+#include <QDir>
+#include <QDesktopServices>
+#include <iostream>
+//qgis includes...
+#include <qgsapplication.h>
+#include <qgsgeometry.h>
+//header for class being tested
+#include <qgspoint.h>
+class TestQgsPoint: public QObject
+ Q_OBJECT;
+ private slots:
+ void initTestCase();// will be called before the first testfunction is executed.
+ void cleanupTestCase();// will be called after the last testfunction was executed.
+ void init();// will be called before each testfunction is executed.
+ void cleanup();// will be called after every testfunction.
+ void toString();
+ void toDegreesMinutesSeconds();
+ void wellKnownText();
+ void sqrDist();
+ void multiply();
+ void onSegment();
+ private:
+ QgsPoint mPoint1;
+ QgsPoint mPoint2;
+ QgsPoint mPoint3;
+ QgsPoint mPoint4;
+ QString mReport;
+void TestQgsPoint::init()
+ // Reset / reinitialise the geometries before each test is run
+ mPoint1 = QgsPoint( 20.0, -20.0 );
+ mPoint2 = QgsPoint( -80.0, 20.0 );
+ mPoint3 = QgsPoint( -80.0, -20.0 );
+ mPoint4 = QgsPoint( 80.0, 20.0 );
+void TestQgsPoint::cleanup()
+ // will be called after every testfunction.
+void TestQgsPoint::initTestCase()
+ // Runs once before any tests are run
+ // init QGIS's paths - true means that all path will be inited from prefix
+ QString qgisPath = QCoreApplication::applicationDirPath();
+ QgsApplication::setPrefixPath( INSTALL_PREFIX, true );
+ QgsApplication::showSettings();
+ mReport += "<h1>Point Tests</h1>\n";
+void TestQgsPoint::cleanupTestCase()
+ // Runs once after all tests are run
+ QString myReportFile = QDir::tempPath() + QDir::separator() + "qgspointtest.html";
+ QFile myFile( myReportFile );
+ if ( myFile.open( QIODevice::WriteOnly ) )
+ QTextStream myQTextStream( &myFile );
+ myQTextStream << mReport;
+ myFile.close();
+ QDesktopServices::openUrl( "file://" + myReportFile );
+void TestQgsPoint::toString()
+ mReport += "<p>Testing toString()</p>";
+ mReport += "<p>" + mPoint1.toString( 2 ) + "</p>";
+ mReport += "<p>" + mPoint2.toString( 2 ) + "</p>";
+ mReport += "<p>" + mPoint3.toString( 2 ) + "</p>";
+ mReport += "<p>" + mPoint4.toString( 2 ) + "</p>";
+ QVERIFY( mPoint1.toString( 2 ) == QString("20.00,-20.00") );
+void TestQgsPoint::toDegreesMinutesSeconds()
+ mReport += "<p>Testing toDegreesMinutesSecods()</p>";
+ mReport += "<p>" + mPoint1.toDegreesMinutesSeconds( 2 ) + "</p>";
+ mReport += "<p>" + mPoint2.toDegreesMinutesSeconds( 2 ) + "</p>";
+ mReport += "<p>" + mPoint3.toDegreesMinutesSeconds( 2 ) + "</p>";
+ mReport += "<p>" + mPoint4.toDegreesMinutesSeconds( 2 ) + "</p>";
+ QVERIFY( mPoint4.toString( 2 ) == QString("80°0'0.00\"E,20°0'0.00\"N") );
+void TestQgsPoint::wellKnownText()
+void TestQgsPoint::sqrDist()
+void TestQgsPoint::multiply()
+void TestQgsPoint::onSegment()
+QTEST_MAIN(TestQgsPoint)
+#include "moc_testqgspoint.cxx"
