[QGIS Commit] r11862 - in trunk/qgis/src: app app/attributetable ui
svn_qgis at osgeo.org
Wed Oct 28 09:27:17 EDT 2009
Author: mhugent
Date: 2009-10-28 09:27:15 -0400 (Wed, 28 Oct 2009)
New Revision: 11862
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
trunk/qgis/src/app/qgsdelattrdialog.cpp
trunk/qgis/src/app/qgsdelattrdialog.h
trunk/qgis/src/ui/qgsattributetabledialog.ui
Possibility to add/remove attributes also in attribute table. Small modification to attribute table such that adding / removing columns is visible
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-28 13:27:15 UTC (rev 11862)
@@ -28,6 +28,8 @@
#include <qgssearchtreenode.h>
#include "qgisapp.h"
+#include "qgsaddattrdialog.h"
+#include "qgsdelattrdialog.h"
#include "qgssearchquerybuilder.h"
#include "qgslogger.h"
#include "qgsmapcanvas.h"
@@ -88,11 +90,18 @@
mInvertSelectionButton->setIcon( getThemeIcon( "/mActionInvertSelection.png" ) );
mToggleEditingButton->setIcon( getThemeIcon( "/mActionToggleEditing.png" ) );
mOpenFieldCalculator->setIcon( getThemeIcon( "/mActionCalculateField.png" ) );
+ mAddAttribute->setIcon( getThemeIcon( "/mActionNewAttribute.png" ) );
+ mRemoveAttribute->setIcon( getThemeIcon( "/mActionDeleteAttribute.png" ) );
// toggle editing
bool canChangeAttributes = mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::ChangeAttributeValues;
+ bool canAddAttributes = mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::AddAttributes;
+ bool canDeleteAttributes = mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::DeleteAttributes;
mToggleEditingButton->setCheckable( true );
mToggleEditingButton->setEnabled( canChangeAttributes );
mOpenFieldCalculator->setEnabled( canChangeAttributes && mLayer->isEditable() );
+ mAddAttribute->setEnabled( canAddAttributes && mLayer->isEditable() );
+ mRemoveAttribute->setEnabled( canDeleteAttributes && mLayer->isEditable() );
// info from table to application
connect( this, SIGNAL( editingToggled( QgsMapLayer * ) ), QgisApp::instance(), SLOT( toggleEditing( QgsMapLayer * ) ) );
@@ -526,7 +535,11 @@
mToggleEditingButton->blockSignals( false );
// (probably reload data if user stopped editing - possible revert)
mModel->reload( mModel->index( 0, 0 ), mModel->index( mModel->rowCount(), mModel->columnCount() ) );
@@ -555,6 +568,68 @@
+void QgsAttributeTableDialog::on_mAddAttribute_clicked()
+ if ( !mLayer )
+ return;
+ QgsAddAttrDialog dialog( mLayer->dataProvider(), this );
+ if ( dialog.exec() == QDialog::Accepted )
+ mLayer->beginEditCommand( tr( "Attribute added" ) );
+ if ( mLayer->addAttribute( dialog.field() ) )
+ mLayer->endEditCommand();
+ else
+ QMessageBox::critical( 0, tr( "Attribute Error" ), tr( "The attribute could not be added to the layer" ) );
+ mLayer->destroyEditCommand();
+void QgsAttributeTableDialog::on_mRemoveAttribute_clicked()
+ if ( !mLayer )
+ return;
+ QgsDelAttrDialog dialog( mLayer );
+ QList<int> attributes = dialog.selectedAttributes();
+ if ( attributes.size() < 1 )
+ return;
+ mLayer->beginEditCommand( tr( "Deleted attribute" ) );
+ bool deleted = false;
+ QList<int>::const_iterator it = attributes.constBegin();
+ for ( ; it != attributes.constEnd(); ++it )
+ if ( mLayer->deleteAttribute( *it ) )
+ deleted = true;
+ if ( deleted )
+ else
+ QMessageBox::critical( 0, tr( "Attribute Error" ), tr( "The attribute(s) could not be deleted" ) );
void QgsAttributeTableDialog::on_mOpenFieldCalculator_clicked()
QgsFieldCalculator calc( mLayer );
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-28 13:27:15 UTC (rev 11862)
@@ -132,6 +132,10 @@
* Starts editing mode
void startEditing();
+ /**Opens dialog to add new attribute*/
+ void on_mAddAttribute_clicked();
+ /**Opens dialog to remove attribute*/
+ void on_mRemoveAttribute_clicked();
* Opens field calculator dialog
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-10-28 13:27:15 UTC (rev 11862)
@@ -34,30 +34,9 @@
mLastRow = NULL;
mLayer = theLayer;
mFeatureCount = mLayer->pendingFeatureCount();
+ loadAttributes();
- mFieldCount = 0;
- mAttributes.clear();
- mValueMaps.clear();
- for ( QgsFieldMap::const_iterator it = theLayer->pendingFields().constBegin(); it != theLayer->pendingFields().end(); it++ )
- switch ( mLayer->editType( it.key() ) )
- case QgsVectorLayer::Hidden:
- continue;
- case QgsVectorLayer::ValueMap:
- mValueMaps.insert( it.key(), &mLayer->valueMap( it.key() ) );
- break;
- default:
- break;
- mFieldCount++;
- mAttributes << it.key();
connect( mLayer, SIGNAL( layerModified( bool ) ), this, SLOT( layerModified( bool ) ) );
//connect(mLayer, SIGNAL(attributeAdded(int)), this, SLOT( attributeAdded(int)));
//connect(mLayer, SIGNAL(attributeDeleted(int)), this, SLOT( attributeDeleted(int)));
@@ -168,11 +147,66 @@
if ( onlyGeometry )
return;
+ loadAttributes();
loadLayer();
emit modelChanged();
emit headerDataChanged( Qt::Horizontal, 0, columnCount() - 1 );
+void QgsAttributeTableModel::loadAttributes()
+ if ( !mLayer )
+ return;
+ bool ins = false, rm = false;
+ int pendingFieldCount = mLayer->pendingFields().size();
+ if ( mFieldCount < pendingFieldCount )
+ ins = true;
+ beginInsertColumns( QModelIndex(), mFieldCount, pendingFieldCount - 1 );
+ else if ( pendingFieldCount < mFieldCount )
+ rm = true;
+ beginRemoveColumns( QModelIndex(), pendingFieldCount, mFieldCount - 1 );
+ mFieldCount = 0;
+ mAttributes.clear();
+ mValueMaps.clear();
+ for ( QgsFieldMap::const_iterator it = mLayer->pendingFields().constBegin(); it != mLayer->pendingFields().end(); it++ )
+ switch ( mLayer->editType( it.key() ) )
+ case QgsVectorLayer::Hidden:
+ continue;
+ case QgsVectorLayer::ValueMap:
+ mValueMaps.insert( it.key(), &mLayer->valueMap( it.key() ) );
+ break;
+ default:
+ break;
+ mFieldCount++;
+ mAttributes << it.key();
+ if ( ins )
+ endInsertColumns();
+ else if ( rm )
+ endRemoveColumns();
void QgsAttributeTableModel::loadLayer()
QgsDebugMsg( "entered." );
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-10-28 13:27:15 UTC (rev 11862)
@@ -203,6 +203,11 @@
virtual void loadLayer();
+ * Gets mFieldCount, mAttributes and mValueMaps
+ virtual void loadAttributes();
* load feature fid into mFeat
* @param fid feature id
* @return feature exists
Modified: trunk/qgis/src/app/qgsdelattrdialog.cpp
--- trunk/qgis/src/app/qgsdelattrdialog.cpp 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/qgsdelattrdialog.cpp 2009-10-28 13:27:15 UTC (rev 11862)
@@ -17,31 +17,32 @@
#include "qgsfield.h"
-#include <QHeaderView>
+#include "qgsvectorlayer.h"
-QgsDelAttrDialog::QgsDelAttrDialog( QHeaderView* header ): QDialog()
+QgsDelAttrDialog::QgsDelAttrDialog( const QgsVectorLayer* vl ): QDialog()
setupUi( this );
- //insert attribute names into the QListView
- if ( header )
+ if ( vl )
listBox2->clear();
- QAbstractItemModel *model = header->model();
- for ( int i = 1;i < header->count();++i )
+ const QgsFieldMap layerAttributes = vl->pendingFields();
+ QgsFieldMap::const_iterator attIt = layerAttributes.constBegin();
+ for ( ; attIt != layerAttributes.constEnd(); ++attIt )
- listBox2->addItem( model->headerData( i, Qt::Horizontal ).toString() );
+ QListWidgetItem* item = new QListWidgetItem( attIt.value().name(), listBox2 );
+ item->setData( Qt::UserRole, attIt.key() );
-const std::list<QString>* QgsDelAttrDialog::selectedAttributes()
+QList<int> QgsDelAttrDialog::selectedAttributes()
- mSelectedItems.clear();
- QListIterator<QListWidgetItem *> selection( listBox2->selectedItems() );
- while ( selection.hasNext() )
+ QList<int> selectionList;
+ QList<QListWidgetItem *> selection = listBox2->selectedItems();
+ QList<QListWidgetItem *>::const_iterator itemIter = selection.constBegin();
+ for ( ; itemIter != selection.constEnd(); ++itemIter )
- mSelectedItems.push_back( selection.next()->text() );
+ selectionList.push_back(( *itemIter )->data( Qt::UserRole ).toInt() );
- return &mSelectedItems;
+ return selectionList;
Modified: trunk/qgis/src/app/qgsdelattrdialog.h
--- trunk/qgis/src/app/qgsdelattrdialog.h 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/app/qgsdelattrdialog.h 2009-10-28 13:27:15 UTC (rev 11862)
@@ -22,16 +22,15 @@
#include <QDialog>
#include <list>
-class QHeaderView;
+class QgsVectorLayer;
class QgsDelAttrDialog: public QDialog, private Ui::QgsDelAttrDialogBase
Q_OBJECT
public:
- QgsDelAttrDialog( QHeaderView* header );
- const std::list<QString>* selectedAttributes();
- protected:
- std::list<QString> mSelectedItems;
+ QgsDelAttrDialog( const QgsVectorLayer* vl );
+ /**Returns the selected attribute indices*/
+ QList<int> selectedAttributes();
#endif
Modified: trunk/qgis/src/ui/qgsattributetabledialog.ui
--- trunk/qgis/src/ui/qgsattributetabledialog.ui 2009-10-28 00:51:34 UTC (rev 11861)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui 2009-10-28 13:27:15 UTC (rev 11862)
@@ -6,23 +6,14 @@
<rect>
<x>0</x>
<y>0</y>
- <width>623</width>
+ <width>646</width>
<height>570</height>
</rect>
</property>
<property name="windowTitle">
<string>Attribute Table</string>
</property>
- <layout class="QGridLayout">
- <property name="horizontalSpacing">
- <number>2</number>
- </property>
- <property name="verticalSpacing">
- <number>0</number>
- </property>
- <property name="margin">
- </property>
+ <layout class="QGridLayout" name="gridLayout">
<item row="0" column="0">
<widget class="QgsAttributeTableView" name="mView">
<property name="alternatingRowColors">
@@ -31,7 +22,7 @@
</widget>
</item>
<item row="1" column="0">
- <layout class="QHBoxLayout">
+ <layout class="QHBoxLayout" name="horizontalLayout">
<item>
<widget class="QToolButton" name="mRemoveSelectionButton">
<property name="toolTip">
@@ -180,6 +171,46 @@
</widget>
</item>
<item>
+ <widget class="QToolButton" name="mAddAttribute">
+ <property name="toolTip">
+ <string>New column</string>
+ </property>
+ <property name="text">
+ <string/>
+ </property>
+ <property name="icon">
+ <iconset>
+ <normaloff>../../images/themes/default/mActionNewAttribute.png</normaloff>../../images/themes/default/mActionNewAttribute.png</iconset>
+ </property>
+ <property name="iconSize">
+ <size>
+ <width>18</width>
+ <height>18</height>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mRemoveAttribute">
+ <string>Delete column</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionDeleteAttribute.png</normaloff>../../images/themes/default/mActionDeleteAttribute.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QToolButton" name="mOpenFieldCalculator">
<string>Open field calculator</string>
