[QGIS Commit] r11626 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 11 17:56:44 EDT 2009
Author: jef
Date: 2009-09-11 17:56:44 -0400 (Fri, 11 Sep 2009)
New Revision: 11626
   trunk/qgis/src/app/qgsidentifyresults.cpp
   trunk/qgis/src/ui/qgsoptionsbase.ui
multi layer identify:
- restore editing, if one feature is identified on a editable vector layer
- expand just the first feature on the first layer
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp	2009-09-11 21:47:21 UTC (rev 11625)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp	2009-09-11 21:56:44 UTC (rev 11626)
@@ -54,6 +54,7 @@
       deleteLater();
 // Tree hierachy
 // layer [userrole: QgsMapLayer]
@@ -124,13 +125,13 @@
                                      const QMap<QString, QString> &attributes,
                                      const QMap<QString, QString> &derivedAttributes )
-  QTreeWidgetItem *item = layerItem( layer );
+  QTreeWidgetItem *layItem = layerItem( layer );
-  if ( item == 0 )
+  if ( layItem == 0 )
-    item = new QTreeWidgetItem( QStringList() << layer->name() << tr( "Layer" ) );
-    item->setData( 0, Qt::UserRole, QVariant::fromValue( dynamic_cast<QObject*>( layer ) ) );
-    lstResults->addTopLevelItem( item );
+    layItem = new QTreeWidgetItem( QStringList() << layer->name() << tr( "Layer" ) );
+    layItem->setData( 0, Qt::UserRole, QVariant::fromValue( dynamic_cast<QObject*>( layer ) ) );
+    lstResults->addTopLevelItem( layItem );
     connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
@@ -158,9 +159,7 @@
-  item->addChild( featItem );
-  item->setExpanded( true );
-  featItem->setExpanded( true );
+  layItem->addChild( featItem );
 // Call to show the dialog box.
@@ -170,6 +169,28 @@
   lstResults->sortItems( 0, Qt::AscendingOrder );
   expandColumnsToFit();
+  if ( lstResults->topLevelItemCount() > 0 )
+    QTreeWidgetItem *layItem = lstResults->topLevelItem( 0 );
+    QTreeWidgetItem *featItem = layItem->child( 0 );
+    if ( layItem->childCount() == 1 )
+      QgsVectorLayer *layer = dynamic_cast<QgsVectorLayer *>( layItem->data( 0, Qt::UserRole ).value<QObject *>() );
+      if ( layer && layer->isEditable() )
+        // if this is the only feature, it's on a vector layer and that layer is editable:
+        // don't show the edit dialog instead of the results window
+        editFeature( featItem );
+        return;
+    // expand first layer and feature
+    featItem->setExpanded( true );
+    layItem->setExpanded( true );
   QDialog::show();
 // Slot called when user clicks the Close button
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui	2009-09-11 21:47:21 UTC (rev 11625)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui	2009-09-11 21:56:44 UTC (rev 11626)
@@ -13,7 +13,9 @@
    <string>QGIS Options</string>
   </property>
   <property name="windowIcon" >
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
   <property name="sizeGripEnabled" >
    <bool>true</bool>
More information about the QGIS-commit mailing list
