[QGIS Commit] r11632 - trunk/qgis/doc
svn_qgis at osgeo.org
Fri Sep 11 20:28:03 EDT 2009
Author: timlinux
Date: 2009-09-11 20:28:02 -0400 (Fri, 11 Sep 2009)
New Revision: 11632
trunk/qgis/doc/index.html
Updated change history
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html 2009-09-12 00:21:04 UTC (rev 11631)
+++ trunk/qgis/doc/index.html 2009-09-12 00:28:02 UTC (rev 11632)
@@ -21,15 +21,47 @@
<!-- This documentation describes the Quantum GIS (QGIS) application. More
information on QGIS is available on the web page at http://qgis.org. -->
-<h2>Whats new in Version 1.2.0?</h2>
+<h2>Whats new in Version 1.3.0 'Mimas'?</h2>
<p>
Please note that this is a release in our 'cutting edge' release series. As
such it contains new features and extends the programmatic interface over
-QGIS 1.0.x and QGIS 1.1.0. If stability and long term support is more important to you
-then cool new and untested features, we recommend that you use a copy
-of QGIS from our stable 1.0.x release series.
+QGIS 1.0.x and QGIS 1.2.0. If an unchanging user interface, programmatic API
+and long term support is more important to you then cool new and untested
+features, we recommend that you use a copy of QGIS from our Long Term Support
+(LTS)1.0.x release series.
</p>
<p>
+This release includes over 30 bug fixes and several useful new features:
+</p>
+<p>OSM plugin & provider updates:</p>
+<ul>
+ <li>new OSM style files</li>
+ <li>new icons</li>
+ <li>dialog text updated and completed</li>
+ <li>"Saving OSM into file" functionality was improvements</li>
+ <li>fixed some problems with encoding... ascii to utf-8</li>
+ <li>all OSM layers are automatically removed after disabling OSM plugin in plugin manager</li>
+ <li>other OSM related bugfixes</li>
+</ul>
+<p>Other notable features and improvements in this release</p>
+<ul>
+ <li>Marker size is now configurable when editing a layer</li>
+ <li>Incorporation of the analysis library into the mainstream release</li>
+ <li>Identify features across multiple layers</li>
+ <li>Added a new plugin for carrying out raster terrain analysis (computing slope
+ <li>aspect, steepness etc)</li>
+ <li>A reshape tool to apply to line/polygon geometries. The part of a geometry
+ <li>between the first and last intersection of the reshape line will be replaced</li>
+ <li>Added snapping to current layer in measure dialog</li>
+ <li>Added ability to select the primary key for views.</li>
+ <li>Zoom to a coordinate by entering it in the status bar coordinate display.</li>
+</ul>
+<h2>Whats new in Version 1.2.0?</h2>
+<p>
This release includes over 140 bug fixes and enhancements
over the QGIS 1.1.0 release. In addition we have added
the following new features:
@@ -140,13 +172,6 @@
<h2>Whats new in Version 1.1.0?</h2>
<p>
-Please note that this is a release in our 'unstable' release series. As
-such it contains new features and extends the programmatic interface over
-QGIS 1.0.x. If stability and long term support is more important to you
-</p>
-<p>
This release includes many bug fixes and enchancements
over the QGIS 1.0.0 release. In addition we have added
