[QGIS Commit] r11681 - in trunk/qgis/src: app app/attributetable
core ui
svn_qgis at osgeo.org
Sat Sep 19 18:56:54 EDT 2009
Author: jef
Date: 2009-09-19 18:56:53 -0400 (Sat, 19 Sep 2009)
New Revision: 11681
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsattributedialog.cpp
trunk/qgis/src/app/qgsattributedialog.h
trunk/qgis/src/app/qgsattributeeditor.cpp
trunk/qgis/src/app/qgsattributetypedialog.cpp
trunk/qgis/src/app/qgsidentifyresults.cpp
trunk/qgis/src/app/qgsidentifyresults.h
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/ui/qgsattributetypeedit.ui
trunk/qgis/src/ui/qgsidentifyresultsbase.ui
vector editing update:
- show mapped value instead of attribute value for value maps in attribute table and identify results.
- alternating background color in identify results
- allow hiding of attributes
- add actions (including edit action) into identify results
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -34,9 +34,30 @@
mLastRow = NULL;
mLayer = theLayer;
mFeatureCount = mLayer->pendingFeatureCount();
- mFieldCount = mLayer->pendingFields().size();
- mAttributes = mLayer->pendingAllAttributesList();
+ mFieldCount = 0;
+ mAttributes.clear();
+ mValueMaps.clear();
+ for ( QgsFieldMap::const_iterator it = theLayer->pendingFields().constBegin(); it != theLayer->pendingFields().end(); it++ )
+ switch ( mLayer->editType( it.key() ) )
+ case QgsVectorLayer::Hidden:
+ continue;
+ case QgsVectorLayer::ValueMap:
+ mValueMaps.insert( it.key(), &mLayer->valueMap( it.key() ) );
+ break;
+ default:
+ break;
+ mFieldCount++;
+ mAttributes << it.key();
connect( mLayer, SIGNAL( layerModified( bool ) ), this, SLOT( layerModified( bool ) ) );
//connect(mLayer, SIGNAL(attributeAdded(int)), this, SLOT( attributeAdded(int)));
//connect(mLayer, SIGNAL(attributeDeleted(int)), this, SLOT( attributeDeleted(int)));
@@ -173,7 +194,7 @@
// QgsDebugMsg(QString("%1, %2").arg(mFeatureCount).arg(mLayer->pendingFeatureCount() -1));
- mLayer->select( QgsAttributeList(), QgsRectangle(), false );
+ mLayer->select( mAttributes, QgsRectangle(), false );
// preallocate data before inserting
mRowIdMap.reserve( pendingFeatureCount + 50 );
@@ -187,7 +208,7 @@
// not needed when we have featureAdded signal
mFeatureCount = pendingFeatureCount;
+ mFieldCount = mAttributes.size();
if ( ins )
@@ -369,7 +390,7 @@
if ( !mLastRow )
return QVariant( "ERROR" );
- QVariant &val = ( *mLastRow )[ mAttributes[index.column()] ];
+ const QVariant &val = ( *mLastRow )[ mAttributes[index.column()] ];
if ( val.isNull() )
@@ -384,6 +405,11 @@
+ if ( role == Qt::DisplayRole && mValueMaps.contains( index.column() ) )
+ return mValueMaps[ index.column()]->key( val.toString(), QString( "(%1)" ).arg( val.toString() ) );
// force also numeric data for EditRole to be strings
// otherwise it creates spinboxes instead of line edits
// (probably not what we do want)
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-09-19 22:56:53 UTC (rev 11681)
@@ -188,6 +188,7 @@
mutable QgsAttributeMap *mLastRow;
QgsAttributeList mAttributes;
+ QMap< int, const QMap<QString, QVariant> * > mValueMaps;
QList<QgsAttributeTableIdColumnPair> mSortList;
QHash<int, int> mIdRowMap;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -3667,9 +3667,6 @@
QgsDebugMsg( "unable to load project " + fileName );
- else
catch ( QgsIOException & io_exception )
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsattributedialog.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -43,7 +43,8 @@
const QgsFieldMap &theFieldMap = vl->pendingFields();
- if ( theFieldMap.isEmpty() ) return;
+ if ( theFieldMap.isEmpty() )
+ return;
QgsAttributeMap myAttributes = mpFeature->attributeMap();
@@ -64,8 +65,6 @@
mypScrollArea->setWidgetResizable( true );
QGridLayout * mypInnerLayout = new QGridLayout( mypInnerFrame );
int index = 0;
for ( QgsAttributeMap::const_iterator it = myAttributes.begin();
it != myAttributes.end();
@@ -77,6 +76,10 @@
QString myFieldName = vl->attributeDisplayName( it.key() );
int myFieldType = field.type();
+ QWidget *myWidget = QgsAttributeEditor::createAttributeEditor( 0, vl, it.key(), it.value() );
+ if ( !myWidget )
+ continue;
QLabel * mypLabel = new QLabel();
mypInnerLayout->addWidget( mypLabel, index, 0 );
if ( myFieldType == QVariant::Int )
@@ -93,9 +96,8 @@
mypLabel->setText( myFieldName + tr( " (txt)" ) );
- QWidget *myWidget = QgsAttributeEditor::createAttributeEditor( 0, vl, it.key(), it.value() );
mypInnerLayout->addWidget( myWidget, index, 1 );
+ mpIndizes << it.key();
mpWidgets << myWidget;
++index;
@@ -124,8 +126,9 @@
QVariant value;
- if ( QgsAttributeEditor::retrieveValue( mpWidgets.value( myIndex ), mLayer, it.key(), value ) )
- mpFeature->changeAttribute( it.key(), value );
+ int idx = mpIndizes.value( myIndex );
+ if ( QgsAttributeEditor::retrieveValue( mpWidgets.value( myIndex ), mLayer, idx, value ) )
+ mpFeature->changeAttribute( idx, value );
++myIndex;
Modified: trunk/qgis/src/app/qgsattributedialog.h
--- trunk/qgis/src/app/qgsattributedialog.h 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsattributedialog.h 2009-09-19 22:56:53 UTC (rev 11681)
@@ -55,6 +55,7 @@
private:
QString mSettingsPath;
QList<QWidget *> mpWidgets;
+ QList<int> mpIndizes;
QgsVectorLayer *mLayer;
QgsFeature * mpFeature;
Modified: trunk/qgis/src/app/qgsattributeeditor.cpp
--- trunk/qgis/src/app/qgsattributeeditor.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsattributeeditor.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -228,6 +228,10 @@
break;
+ myWidget = NULL;
+ break;
case QgsVectorLayer::FileName:
QLineEdit *le = new QLineEdit();
@@ -252,6 +256,9 @@
bool QgsAttributeEditor::retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value )
+ if ( !widget )
+ return false;
const QgsField &theField = vl->pendingFields()[idx];
QgsVectorLayer::EditType editType = vl->editType( idx );
bool modified = false;
@@ -349,6 +356,9 @@
bool QgsAttributeEditor::setValue( QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
+ if ( !editor )
+ return false;
const QgsField &field = vl->pendingFields()[idx];
QVariant::Type myFieldType = field.type();
@@ -362,7 +372,8 @@
QComboBox *cb = dynamic_cast<QComboBox *>( editor );
if ( cb == NULL )
return false;
- int idx = cb->findText( value.toString() );
+ int idx = cb->findData( value );
if ( idx < 0 )
return false;
Modified: trunk/qgis/src/app/qgsattributetypedialog.cpp
--- trunk/qgis/src/app/qgsattributetypedialog.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsattributetypedialog.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -226,6 +226,10 @@
setPage( 7 );
break;
+ setPage( 8 );
+ break;
case QgsVectorLayer::LineEdit:
setPage( 0 );
break;
@@ -501,6 +505,9 @@
case 7:
mEditType = QgsVectorLayer::Immutable;
break;
+ case 8:
+ mEditType = QgsVectorLayer::Hidden;
+ break;
default:
mEditType = QgsVectorLayer::LineEdit;
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -27,6 +27,7 @@
#include "qgsgeometry.h"
#include "qgsattributedialog.h"
#include "qgsmapcanvas.h"
+#include "qgsattributeaction.h"
#include <QCloseEvent>
#include <QLabel>
@@ -59,14 +60,19 @@
// layer [userrole: QgsMapLayer]
// feature: displayfield|displayvalue [userrole: fid]
-// derived attributes
+// derived attributes (if any) [userrole: "derived"]
// name value
+// actions (if any) [userrole: "actions"]
+// edit [userrole: "edit"]
+// action [userrole: "action", idx]
// name value
// name value
// name value
// feature
// name value
+// action
// name value
QgsIdentifyResults::QgsIdentifyResults( QgsMapCanvas *canvas, QWidget *parent, Qt::WFlags f )
@@ -99,6 +105,9 @@
connect( lstResults, SIGNAL( currentItemChanged( QTreeWidgetItem*, QTreeWidgetItem* ) ),
this, SLOT( handleCurrentItemChanged( QTreeWidgetItem*, QTreeWidgetItem* ) ) );
+ connect( lstResults, SIGNAL( itemClicked( QTreeWidgetItem*, int ) ),
+ this, SLOT( itemClicked( QTreeWidgetItem*, int ) ) );
QgsIdentifyResults::~QgsIdentifyResults()
@@ -108,11 +117,10 @@
QTreeWidgetItem *QgsIdentifyResults::layerItem( QObject *layer )
- QTreeWidgetItem *item;
for ( int i = 0; i < lstResults->topLevelItemCount(); i++ )
- item = lstResults->topLevelItem( i );
+ QTreeWidgetItem *item = lstResults->topLevelItem( i );
if ( item->data( 0, Qt::UserRole ).value<QObject*>() == layer )
return item;
@@ -126,6 +134,7 @@
const QMap<QString, QString> &derivedAttributes )
QTreeWidgetItem *layItem = layerItem( layer );
+ QgsVectorLayer *vlayer = dynamic_cast<QgsVectorLayer*>( layer );
if ( layItem == 0 )
@@ -133,11 +142,18 @@
layItem->setData( 0, Qt::UserRole, QVariant::fromValue( dynamic_cast<QObject*>( layer ) ) );
lstResults->addTopLevelItem( layItem );
- connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
if ( vlayer )
+ connect( vlayer, SIGNAL( layerDeleted() ), this, SLOT( layerDestroyed() ) );
connect( vlayer, SIGNAL( featureDeleted( int ) ), this, SLOT( featureDeleted( int ) ) );
+ connect( vlayer, SIGNAL( editingStarted() ), this, SLOT( addEditAction() ) );
+ connect( vlayer, SIGNAL( editingStopped() ), this, SLOT( removeEditAction() ) );
+ else
+ connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
QTreeWidgetItem *featItem = new QTreeWidgetItem( QStringList() << displayField << displayValue );
@@ -151,6 +167,7 @@
if ( derivedAttributes.size() >= 0 )
QTreeWidgetItem *derivedItem = new QTreeWidgetItem( QStringList() << tr( "(Derived)" ) );
+ derivedItem->setData( 0, Qt::UserRole, "derived" );
featItem->addChild( derivedItem );
for ( QMap< QString, QString>::const_iterator it = derivedAttributes.begin(); it != derivedAttributes.end(); it++ )
@@ -159,6 +176,31 @@
+ if ( vlayer && (vlayer->actions()->size() > 0 || vlayer->isEditable() ) )
+ QTreeWidgetItem *actionItem = new QTreeWidgetItem( QStringList() << tr( "(Actions)" ) );
+ actionItem->setData( 0, Qt::UserRole, "actions" );
+ featItem->addChild( actionItem );
+ QTreeWidgetItem *twi;
+ if ( vlayer->isEditable() )
+ addEditAction( actionItem );
+ for ( int i = 0; i < vlayer->actions()->size(); i++ )
+ QgsAttributeAction::aIter iter = vlayer->actions()->retrieveAction( i );
+ twi = new QTreeWidgetItem( QStringList() << "" << iter->name() );
+ twi->setIcon( 0, QgisApp::getThemeIcon( "/mAction.png" ) );
+ twi->setData( 0, Qt::UserRole, "action" );
+ twi->setData( 0, Qt::UserRole + 1, QVariant::fromValue( i ) );
+ actionItem->addChild( twi );
layItem->addChild( featItem );
@@ -177,12 +219,17 @@
if ( layItem->childCount() == 1 )
QgsVectorLayer *layer = dynamic_cast<QgsVectorLayer *>( layItem->data( 0, Qt::UserRole ).value<QObject *>() );
- if ( layer && layer->isEditable() )
+ if ( layer )
- // if this is the only feature, it's on a vector layer and that layer is editable:
- // don't show the edit dialog instead of the results window
- editFeature( featItem );
- return;
+ highlightFeature( featItem );
+ if ( layer->isEditable() )
+ // if this is the only feature, it's on a vector layer and that layer is editable:
+ // don't show the edit dialog instead of the results window
+ editFeature( featItem );
+ return;
@@ -209,6 +256,90 @@
close();
+void QgsIdentifyResults::addEditAction( QTreeWidgetItem *item )
+ QTreeWidgetItem *editItem = new QTreeWidgetItem( QStringList() << "" << tr( "Edit feature" ) );
+ editItem->setIcon( 0, QgisApp::getThemeIcon( "/mIconEditable.png" ) );
+ editItem->setData( 0, Qt::UserRole, "edit" );
+ item->addChild( editItem );
+void QgsIdentifyResults::addOrRemoveEditAction( bool addItem )
+ QTreeWidgetItem *layItem = layerItem( sender() );
+ for ( int i = 0; i < layItem->childCount(); i++ )
+ QTreeWidgetItem *featItem = layItem->child( i );
+ QTreeWidgetItem *actionsItem = 0;
+ for ( int j = 0; j < featItem->childCount(); j++ )
+ QTreeWidgetItem *attrItem = featItem->child( j );
+ if ( attrItem->childCount() == 0 || attrItem->data( 0, Qt::UserRole ).toString() != "actions" )
+ continue;
+ actionsItem = attrItem;
+ break;
+ if ( addItem )
+ if( !actionsItem )
+ actionsItem = new QTreeWidgetItem( QStringList() << tr( "(Actions)" ) );
+ actionsItem->setData( 0, Qt::UserRole, "actions" );
+ featItem->addChild( actionsItem );
+ addEditAction( actionsItem );
+ else if( actionsItem )
+ for ( int k = 0; k < actionsItem->childCount(); k++ )
+ QTreeWidgetItem *editItem = actionsItem->child( k );
+ if ( editItem->data( 0, Qt::UserRole ).toString() != "edit" )
+ continue;
+ delete editItem;
+ if( actionsItem->childCount()==0 )
+ delete actionsItem;
+ break;
+ else
+ QgsDebugMsg( "actions item not found" );
+void QgsIdentifyResults::addEditAction()
+ addOrRemoveEditAction( true );
+void QgsIdentifyResults::removeEditAction()
+ addOrRemoveEditAction( false );
+void QgsIdentifyResults::itemClicked( QTreeWidgetItem *item, int column )
+ if ( item->data( 0, Qt::UserRole ).toString() == "edit" )
+ editFeature( item );
+ else if ( item->data( 0, Qt::UserRole ).toString() == "action" )
+ doAction( item, item->data( 0, Qt::UserRole + 1 ).toInt() );
// Popup (create if necessary) a context menu that contains a list of
// actions that can be applied to the data in the identify results
// dialog box.
@@ -235,19 +366,29 @@
a = mActionPopup->addAction( tr( "Edit feature" ) );
a->setEnabled( true );
- a->setData( QVariant::fromValue( -4 ) );
+ a->setData( QVariant::fromValue( -6 ) );
a = mActionPopup->addAction( tr( "Zoom to feature" ) );
- a->setData( QVariant::fromValue( -3 ) );
+ a->setData( QVariant::fromValue( -5 ) );
a = mActionPopup->addAction( tr( "Copy attribute value" ) );
- a->setData( QVariant::fromValue( -2 ) );
+ a->setData( QVariant::fromValue( -4 ) );
a = mActionPopup->addAction( tr( "Copy feature attributes" ) );
+ a->setData( QVariant::fromValue( -3 ) );
+ mActionPopup->addSeparator();
+ a = mActionPopup->addAction( tr( "Expand all" ) );
+ a->setEnabled( true );
+ a->setData( QVariant::fromValue( -2 ) );
+ a = mActionPopup->addAction( tr( "Collapse all" ) );
a->setData( QVariant::fromValue( -1 ) );
QgsAttributeAction *actions = vlayer->actions();
@@ -310,36 +451,50 @@
if ( action < 0 )
- if ( action == -4 )
+ switch ( action )
- editFeature( item );
- else if ( action == -3 )
- zoomToFeature( item );
- else
- QClipboard *clipboard = QApplication::clipboard();
- QString text;
+ case -6:
+ break;
- if ( action == -2 )
+ case -5:
+ zoomToFeature( item );
+ break;
+ case -4:
+ case -3:
- text = item->data( 1, Qt::DisplayRole ).toString();
- else
- std::vector< std::pair<QString, QString> > attributes;
- retrieveAttributes( item, attributes );
+ QClipboard *clipboard = QApplication::clipboard();
+ QString text;
- for ( std::vector< std::pair<QString, QString> >::iterator it = attributes.begin(); it != attributes.end(); it++ )
+ if ( action == -4 )
- text += QString( "%1: %2\n" ).arg( it->first ).arg( it->second );
+ text = item->data( 1, Qt::DisplayRole ).toString();
+ else
+ std::vector< std::pair<QString, QString> > attributes;
+ retrieveAttributes( item, attributes );
+ for ( std::vector< std::pair<QString, QString> >::iterator it = attributes.begin(); it != attributes.end(); it++ )
+ text += QString( "%1: %2\n" ).arg( it->first ).arg( it->second );
+ QgsDebugMsg( QString( "set clipboard: %1" ).arg( text ) );
+ clipboard->setText( text );
+ break;
- QgsDebugMsg( QString( "set clipboard: %1" ).arg( text ) );
- clipboard->setText( text );
+ case -2:
+ lstResults->expandAll();
+ break;
+ case -1:
+ lstResults->collapseAll();
+ break;
else
@@ -356,6 +511,11 @@
void QgsIdentifyResults::clear()
+ for ( int i = 0; i < lstResults->topLevelItemCount(); i++ )
+ disconnectLayer( lstResults->topLevelItem( i )->data( 0, Qt::UserRole ).value<QObject *>() );
lstResults->clear();
clearRubberBand();
@@ -431,7 +591,7 @@
if ( item->parent()->parent()->parent() )
- // derived attribute item
+ // derived or action attribute item
featItem = item->parent()->parent();
else
@@ -508,12 +668,15 @@
void QgsIdentifyResults::layerDestroyed()
- if ( mRubberBandLayer == sender() )
+ QObject *theSender = sender();
+ if ( mRubberBandLayer == theSender )
clearRubberBand();
- delete layerItem( sender() );
+ disconnectLayer( theSender );
+ delete layerItem( theSender );
if ( lstResults->topLevelItemCount() == 0 )
@@ -521,6 +684,25 @@
+void QgsIdentifyResults::disconnectLayer( QObject *layer )
+ if ( !layer )
+ return;
+ QgsVectorLayer *vlayer = dynamic_cast<QgsVectorLayer *>( layer );
+ if ( vlayer )
+ disconnect( vlayer, SIGNAL( layerDeleted() ), this, SLOT( layerDestroyed() ) );
+ disconnect( vlayer, SIGNAL( featureDeleted( int ) ), this, SLOT( featureDeleted( int ) ) );
+ disconnect( vlayer, SIGNAL( editingStarted() ), this, SLOT( addEditAction() ) );
+ disconnect( vlayer, SIGNAL( editingStopped() ), this, SLOT( removeEditAction() ) );
+ else
+ disconnect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
void QgsIdentifyResults::featureDeleted( int fid )
Modified: trunk/qgis/src/app/qgsidentifyresults.h
--- trunk/qgis/src/app/qgsidentifyresults.h 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsidentifyresults.h 2009-09-19 22:56:53 UTC (rev 11681)
@@ -93,6 +93,12 @@
//! sends signal if current feature id has changed
void handleCurrentItemChanged( QTreeWidgetItem *current, QTreeWidgetItem *previous );
+ /* Item in tree was clicked */
+ void itemClicked( QTreeWidgetItem *lvi, int column );
+ void addEditAction();
+ void removeEditAction();
private:
QMenu *mActionPopup;
QgsVectorLayer *mRubberBandLayer;
@@ -107,6 +113,9 @@
QTreeWidgetItem *layerItem( QObject *layer );
QTreeWidgetItem *retrieveAttributes( QTreeWidgetItem *item, std::vector< std::pair<QString, QString> > &attributes );
void clearRubberBand();
+ void addEditAction( QTreeWidgetItem * );
+ void addOrRemoveEditAction( bool addItem );
+ void disconnectLayer( QObject *object );
void setColumnText( int column, const QString & label );
void expandColumnsToFit();
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -111,7 +111,7 @@
QgsMapLayer *layer = mCanvas->layer( i );
emit identifyProgress( i, mCanvas->layerCount() );
- emit identifyMessage( tr("Identifying on %1...").arg( layer->name() ) );
+ emit identifyMessage( tr( "Identifying on %1..." ).arg( layer->name() ) );
if ( noIdentifyLayerIdList.contains( layer->getLayerID() ) )
continue;
@@ -125,7 +125,7 @@
emit identifyProgress( mCanvas->layerCount(), mCanvas->layerCount() );
- emit identifyMessage( tr("Identifying done.") );
+ emit identifyMessage( tr( "Identifying done." ) );
disconnect( this, SIGNAL( identifyProgress( int, int ) ), QgisApp::instance(), SLOT( showProgress( int, int ) ) );
disconnect( this, SIGNAL( identifyMessage( QString ) ), QgisApp::instance(), SLOT( showStatusMessage( QString ) ) );
@@ -243,15 +243,29 @@
for ( QgsAttributeMap::const_iterator it = attr.begin(); it != attr.end(); ++it )
- QString attributeName = layer->attributeDisplayName( it.key() );
+ QString attributeName = layer->attributeDisplayName( it.key() );
+ QString attributeValue = it->isNull() ? "NULL" : it->toString();
+ switch ( layer->editType( it.key() ) )
+ continue;
+ attributeValue = layer->valueMap( it.key() ).key( it->toString(), QString( "(%1)" ).arg( it->toString() ) );
+ break;
+ default:
+ break;
if ( fields[it.key()].name() == layer->displayField() )
displayField = attributeName;
- displayValue = it->toString();
+ displayValue = attributeValue;
- attributes.insert( attributeName, it->isNull() ? "NULL" : it->toString() );
+ attributes.insert( attributeName, attributeValue );
// Calculate derived attributes and insert:
@@ -294,6 +308,8 @@
derivedAttributes.insert( "Y", str );
+ derivedAttributes.insert( tr( "feature id" ), fid < 0 ? tr( "new feature" ) : QString::number( fid ) );
mResults->addFeature( layer, fid, displayField, displayValue, attributes, derivedAttributes );
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -557,6 +557,7 @@
editTypeMap.insert( QgsVectorLayer::FileName, tr( "File name" ) );
editTypeMap.insert( QgsVectorLayer::Enumeration, tr( "Enumeration" ) );
editTypeMap.insert( QgsVectorLayer::Immutable, tr( "Immutable" ) );
+ editTypeMap.insert( QgsVectorLayer::Hidden, tr( "Hidden" ) );
QString QgsVectorLayerProperties::editTypeButtonText( QgsVectorLayer::EditType type )
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-09-19 22:56:53 UTC (rev 11681)
@@ -787,7 +787,7 @@
p.setPen( QColor( 50, 100, 120, 200 ) );
p.setBrush( QColor( 200, 200, 210, 120 ) );
- p.drawEllipse( x-m, y-m, m*2+1, m*2+1 );
+ p.drawEllipse( x - m, y - m, m*2 + 1, m*2 + 1 );
else if ( type == QgsVectorLayer::Cross )
@@ -3499,7 +3499,7 @@
transformPoint( x, y, &renderContext.mapToPixel(), renderContext.coordinateTransform() );
if ( std::abs( x ) > QgsClipper::MAX_X ||
- std::abs( y ) > QgsClipper::MAX_Y )
+ std::abs( y ) > QgsClipper::MAX_Y )
break;
@@ -3695,7 +3695,7 @@
const QgsFieldMap &fields = pendingFields();
// FIXME: throw an exception!?
- if ( fields.contains( idx ) )
+ if ( !fields.contains( idx ) )
QgsDebugMsg( QString( "field %1 not found" ).arg( idx ) );
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2009-09-19 22:56:53 UTC (rev 11681)
@@ -75,7 +75,8 @@
SliderRange,
FileName,
Enumeration,
- Immutable /*The attribute value should not be changed in the attribute form*/
+ Immutable, /*The attribute value should not be changed in the attribute form*/
+ Hidden /*The attribute value should not be shown in the attribute form @added in 1.4 */
struct RangeData
Modified: trunk/qgis/src/ui/qgsattributetypeedit.ui
--- trunk/qgis/src/ui/qgsattributetypeedit.ui 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/ui/qgsattributetypeedit.ui 2009-09-19 22:56:53 UTC (rev 11681)
@@ -56,15 +56,20 @@
<string>Immutable</string>
</property>
</item>
+ <item>
+ <property name="text">
+ <string>Hidden</string>
+ </property>
+ </item>
</widget>
</item>
<item>
<widget class="QStackedWidget" name="stackedWidget">
<property name="currentIndex">
- <number>5</number>
+ <number>0</number>
</property>
<widget class="QWidget" name="lineEditPage">
- <layout class="QVBoxLayout" name="verticalLayout_9">
+ <layout class="QVBoxLayout" name="verticalLayout_1">
<item>
<widget class="QLabel" name="lineEditLabel">
@@ -432,7 +437,7 @@
<item>
<widget class="QLabel" name="immutableLabel">
- <string>Immutable attribute is read-only - user is not able to modify the contents.</string>
+ <string>An immutable attribute is read-only - the user is not able to modify the contents.</string>
</property>
<property name="wordWrap">
<bool>true</bool>
@@ -454,6 +459,33 @@
</item>
</layout>
</widget>
+ <widget class="QWidget" name="hiddenPage">
+ <layout class="QVBoxLayout" name="verticalLayout_9">
+ <item>
+ <widget class="QLabel" name="hiddenLabel">
+ <string>A hidden attribute will be invisible - the user is not able to see it's contents.</string>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="verticalSpacer_7">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>304</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
<item>
Modified: trunk/qgis/src/ui/qgsidentifyresultsbase.ui
--- trunk/qgis/src/ui/qgsidentifyresultsbase.ui 2009-09-19 13:02:49 UTC (rev 11680)
+++ trunk/qgis/src/ui/qgsidentifyresultsbase.ui 2009-09-19 22:56:53 UTC (rev 11681)
@@ -1,64 +1,73 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsIdentifyResultsBase</class>
- <widget class="QDialog" name="QgsIdentifyResultsBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsIdentifyResultsBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
- <width>281</width>
+ <width>301</width>
<height>316</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Identify Results</string>
</property>
- <layout class="QVBoxLayout" >
- <property name="margin" >
+ <layout class="QVBoxLayout">
+ <property name="spacing">
+ <number>6</number>
+ </property>
+ <property name="margin">
<number>9</number>
</property>
- <property name="spacing" >
- <number>6</number>
- </property>
<item>
- <widget class="QTreeWidget" name="lstResults" >
- <property name="lineWidth" >
+ <widget class="QTreeWidget" name="lstResults">
+ <property name="lineWidth">
<number>2</number>
</property>
- <property name="sortingEnabled" >
+ <property name="alternatingRowColors">
<bool>true</bool>
</property>
+ <property name="sortingEnabled">
+ <bool>true</bool>
+ </property>
+ <column>
+ <string notr="true">1</string>
+ </property>
+ </column>
</widget>
</item>
<item>
- <layout class="QHBoxLayout" >
+ <layout class="QHBoxLayout">
+ </property>
<number>0</number>
</property>
- </property>
<item>
- <widget class="QPushButton" name="buttonHelp" >
- <property name="text" >
+ <widget class="QPushButton" name="buttonHelp">
<string>Help</string>
</property>
- <property name="shortcut" >
+ <property name="shortcut">
<string>F1</string>
</property>
- <property name="autoDefault" >
+ <property name="autoDefault">
<bool>true</bool>
</property>
</widget>
</item>
<item>
<spacer>
- <property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
- <property name="sizeType" >
+ <property name="sizeType">
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" >
<size>
<width>20</width>
<height>0</height>
@@ -67,14 +76,14 @@
</spacer>
</item>
<item>
- <widget class="QPushButton" name="buttonCancel" >
+ <widget class="QPushButton" name="buttonCancel">
<string>Close</string>
</property>
<string/>
</property>
<bool>true</bool>
</property>
</widget>
@@ -83,7 +92,7 @@
</item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
<resources/>
<connections/>
</ui>
