[QGIS Commit] r11700 - in trunk/qgis/src: app core/renderer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Sep 22 10:02:18 EDT 2009
Author: mhugent
Date: 2009-09-22 10:02:13 -0400 (Tue, 22 Sep 2009)
New Revision: 11700
   trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp
   trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h
   trunk/qgis/src/app/qgspointrotationitem.cpp
   trunk/qgis/src/app/qgspointrotationitem.h
   trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
Show point symbol in rotation preview and a little arrow. Also fixed a bug in QgsSingleSymbolRenderer::clone
Modified: trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp
--- trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp	2009-09-22 11:38:59 UTC (rev 11699)
+++ trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp	2009-09-22 14:02:13 UTC (rev 11700)
@@ -26,7 +26,7 @@
 QgsMapToolRotatePointSymbols::QgsMapToolRotatePointSymbols( QgsMapCanvas* canvas ): QgsMapToolEdit( canvas ), \
     mActiveLayer( 0 ), mFeatureNumber( 0 ), mCurrentMouseAzimut( 0.0 ), mCurrentRotationFeature( 0.0 ), \
-    mRotating( false ), mRotationItem( 0 ), mCtrlPressed(false)
+    mRotating( false ), mRotationItem( 0 ), mCtrlPressed( false )
@@ -123,13 +123,13 @@
   mCurrentRotationFeature = attIt.value().toDouble();
-  createPixmapItem();
+  createPixmapItem( pointFeature );
   if ( mRotationItem )
     mRotationItem->setPointLocation( snapResults.at( 0 ).snappedVertex );
   mCurrentMouseAzimut = calculateAzimut( e->pos() );
-  setPixmapItemRotation( (int)(mCurrentMouseAzimut) );
+  setPixmapItemRotation(( int )( mCurrentMouseAzimut ) );
   mRotating = true;
@@ -165,17 +165,17 @@
   //if shift-modifier is pressed, round to 15 degrees
   int displayValue;
-  if(e->modifiers() & Qt::ControlModifier)
+  if ( e->modifiers() & Qt::ControlModifier )
-    displayValue = roundTo15Degrees(mCurrentRotationFeature);
+    displayValue = roundTo15Degrees( mCurrentRotationFeature );
     mCtrlPressed = true;
   else
-    displayValue = (int)(mCurrentRotationFeature);
+    displayValue = ( int )( mCurrentRotationFeature );
     mCtrlPressed = false;
-  setPixmapItemRotation(displayValue);
+  setPixmapItemRotation( displayValue );
 void QgsMapToolRotatePointSymbols::canvasReleaseEvent( QMouseEvent * e )
@@ -187,13 +187,13 @@
     //write mCurrentRotationFeature to all rotation attributes of feature (mFeatureNumber)
     int rotation;
-    if(mCtrlPressed) //round to 15 degrees
+    if ( mCtrlPressed ) //round to 15 degrees
-      rotation = roundTo15Degrees(mCurrentRotationFeature);
+      rotation = roundTo15Degrees( mCurrentRotationFeature );
     else
-      rotation = (int)mCurrentRotationFeature;
+      rotation = ( int )mCurrentRotationFeature;
     QList<int>::const_iterator it = mCurrentRotationAttributes.constBegin();
@@ -255,15 +255,51 @@
   int dx = mousePos.x() - mSnappedPoint.x();
   int dy = mousePos.y() - mSnappedPoint.y();
-  return 180 - atan2( (double) dx, (double) dy ) * 180.0 / M_PI;
+  return 180 - atan2(( double ) dx, ( double ) dy ) * 180.0 / M_PI;
-void QgsMapToolRotatePointSymbols::createPixmapItem()
+void QgsMapToolRotatePointSymbols::createPixmapItem( QgsFeature& f )
-  delete mRotationItem;
-  mRotationItem = new QgsPointRotationItem( mCanvas );
-  mRotationItem->setSymbol( QgsApplication::defaultThemePath() + "mActionArrowUp.png" );
-  mCanvas->scene()->addItem( mRotationItem );
+  if ( !mCanvas )
+    return;
+  if ( mActiveLayer && mActiveLayer->renderer() )
+    //get the image that is used for that symbol, but without point rotation
+    QImage pointImage;
+    //copy renderer
+    QgsRenderer* r = mActiveLayer->renderer()->clone();
+    //set all symbol fields of the cloned renderer to -1. Very ugly but necessary
+    QList<QgsSymbol*> symbolList( r->symbols() );
+    QList<QgsSymbol*>::iterator it = symbolList.begin();
+    for ( ; it != symbolList.end(); ++it )
+      ( *it )->setRotationClassificationField( -1 );
+    //get reference to current render context
+    QgsMapRenderer* mapRenderer = mCanvas->mapRenderer();
+    if ( !mapRenderer )
+      delete r;
+      return;
+    QgsRenderContext* renderContext = mCanvas->mapRenderer()->rendererContext(); //todo: check if pointers are not 0
+    if ( !renderContext )
+      delete r;
+      return;
+    r->renderFeature( *renderContext, f, &pointImage, false );
+    mRotationItem = new QgsPointRotationItem( mCanvas );
+    mRotationItem->setSymbol( pointImage );
+    delete r;
 void QgsMapToolRotatePointSymbols::setPixmapItemRotation( double rotation )
@@ -272,9 +308,9 @@
   mRotationItem->update();
-int QgsMapToolRotatePointSymbols::roundTo15Degrees(double n)
+int QgsMapToolRotatePointSymbols::roundTo15Degrees( double n )
-  int m = (int)(n / 15.0 + 0.5);
-  return (m * 15);
+  int m = ( int )( n / 15.0 + 0.5 );
+  return ( m * 15 );
Modified: trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h
--- trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h	2009-09-22 11:38:59 UTC (rev 11699)
+++ trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h	2009-09-22 14:02:13 UTC (rev 11700)
@@ -17,6 +17,7 @@
 #define QGSMAPTOOLROTATEPOINTSYMBOLS_H
 #include "qgsmaptooledit.h"
+#include "qgsfeature.h"
 class QgsPointRotationItem;
@@ -61,12 +62,12 @@
     void drawArrow( double azimut ) const;
     /**Calculates the azimut between mousePos and mSnappedPoint*/
     double calculateAzimut( const QPoint& mousePos );
-    /**Create item that shows rotation to the user*/
-    void createPixmapItem();
+    /**Create item with the point symbol for a specific feature. This will be used to show the rotation to the user*/
+    void createPixmapItem( QgsFeature& f );
     /**Sets the rotation of the pixmap item*/
     void setPixmapItemRotation( double rotation );
     /**Rounds value to 15 degree integer (used if ctrl pressed)*/
-    static int roundTo15Degrees(double n);
+    static int roundTo15Degrees( double n );
 #endif // QGSMAPTOOLROTATEPOINTSYMBOLS_H
Modified: trunk/qgis/src/app/qgspointrotationitem.cpp
--- trunk/qgis/src/app/qgspointrotationitem.cpp	2009-09-22 11:38:59 UTC (rev 11699)
+++ trunk/qgis/src/app/qgspointrotationitem.cpp	2009-09-22 14:02:13 UTC (rev 11700)
@@ -53,7 +53,7 @@
   double h, dAngel;
   if ( mPixmap.width() > 0 && mPixmap.height() > 0 )
-    h = sqrt( (double) mPixmap.width() * mPixmap.width() + mPixmap.height() * mPixmap.height() ) / 2; //the half of the item diagonal
+    h = sqrt(( double ) mPixmap.width() * mPixmap.width() + mPixmap.height() * mPixmap.height() ) / 2; //the half of the item diagonal
     dAngel = acos( mPixmap.width() / ( h * 2 ) ) * 180 / M_PI; //the diagonal angel of the original rect
     x = h * cos(( mRotation - dAngel ) * M_PI / 180 );
     y = h * sin(( mRotation - dAngel ) * M_PI / 180 );
@@ -69,7 +69,7 @@
   QFontMetricsF fm( mFont );
   painter->fillRect( mPixmap.width(), 0, mItemSize.width() - mPixmap.width(), mItemSize.height(), QColor( Qt::white ) );
   painter->setFont( mFont );
-  painter->drawText( mPixmap.width(), mPixmap.height() / 2.0 + fm.height() / 2.0, QString::number( mRotation) );
+  painter->drawText( mPixmap.width(), mPixmap.height() / 2.0 + fm.height() / 2.0, QString::number( mRotation ) );
 void QgsPointRotationItem::setPointLocation( const QgsPoint& p )
@@ -78,10 +78,24 @@
   setPos( transformedPoint.x() - mPixmap.width() / 2.0, transformedPoint.y() - mPixmap.height() / 2.0 );
-void QgsPointRotationItem::setSymbol( const QString& symbolPath )
+void QgsPointRotationItem::setSymbol( const QImage& symbolImage )
-  mPixmap = QPixmap( symbolPath );
+  mPixmap = QPixmap::fromImage( symbolImage );
+  //draw arrow
+  QPainter p( &mPixmap );
+  QPen pen;
+  pen.setWidth( 1 );
+  pen.setColor( QColor( Qt::red ) );
+  p.setPen( pen );
+  int halfItemWidth = mPixmap.width() / 2;
+  int quarterItemHeight = mPixmap.height() / 4;
+  p.drawLine( halfItemWidth, mPixmap.height(), halfItemWidth, 0 );
+  p.drawLine( halfItemWidth, 0, mPixmap.width() / 4, quarterItemHeight );
+  p.drawLine( halfItemWidth, 0, mPixmap.width() * 0.75, quarterItemHeight );
+  //set item size
   mItemSize.setWidth( mPixmap.width() + fm.width( "360" ) );
   double pixmapHeight = mPixmap.height();
   double fontHeight = fm.height();
Modified: trunk/qgis/src/app/qgspointrotationitem.h
--- trunk/qgis/src/app/qgspointrotationitem.h	2009-09-22 11:38:59 UTC (rev 11699)
+++ trunk/qgis/src/app/qgspointrotationitem.h	2009-09-22 14:02:13 UTC (rev 11700)
@@ -36,8 +36,8 @@
     Units are degrees, starting from north direction, clockwise direction*/
     void setSymbolRotation( int r ) {mRotation = r;}
-    /**Sets a symbol from image file*/
-    void setSymbol( const QString& symbolPath );
+    /**Sets rotation symbol from image (takes ownership)*/
+    void setSymbol( const QImage& symbolImage );
   private:
     QgsPointRotationItem();
Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2009-09-22 11:38:59 UTC (rev 11699)
+++ trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2009-09-22 14:02:13 UTC (rev 11700)
@@ -72,6 +72,15 @@
     for ( QMap<QString, QgsSymbol *>::const_iterator it = other.mSymbols.begin(); it != other.mSymbols.end(); it++ )
       mSymbols[ it.key()] = new QgsSymbol( *it.value() );
+    if ( mSymbols.size() > 0 )
+      mSymbol0 = mSymbols[0];
+    else
+      mSymbol0 = 0;
   updateSymbolAttributes();
   return *this;
More information about the QGIS-commit mailing list
