[QGIS Commit] r11715 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org
Sat Sep 26 11:40:24 EDT 2009
Author: mhugent
Date: 2009-09-26 11:40:24 -0400 (Sat, 26 Sep 2009)
New Revision: 11715
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/app/composer/qgscomposer.h
Show cached content of composer maps in screen resolution after loading from project file
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2009-09-26 09:34:17 UTC (rev 11714)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2009-09-26 15:40:24 UTC (rev 11715)
@@ -65,7 +65,7 @@
#include <QSizeGrip>
#include "qgslogger.h"
-QgsComposer::QgsComposer( QgisApp *qgis ): QMainWindow()
+QgsComposer::QgsComposer( QgisApp *qgis ): QMainWindow(), mFirstPaint( true )
setupUi( this );
setupTheme();
@@ -300,6 +300,27 @@
+void QgsComposer::paintEvent( QPaintEvent* event )
+ QMainWindow::paintEvent( event );
+ //The cached content of the composer maps need to be recreated it is the first paint event of the composer after reading from XML file.
+ //Otherwise the resolution of the composer map is not suitable for screen
+ if ( mFirstPaint )
+ QMap<QgsComposerItem*, QWidget*>::iterator it = mItemWidgetMap.begin();
+ for ( ; it != mItemWidgetMap.constEnd(); ++it )
+ QgsComposerMap* cm = dynamic_cast<QgsComposerMap*>( it.key() );
+ if ( cm )
+ cm->cache();
+ cm->update();
+ mFirstPaint = false;
void QgsComposer::activate()
raise();
@@ -1352,3 +1373,5 @@
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2009-09-26 09:34:17 UTC (rev 11714)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2009-09-26 15:40:24 UTC (rev 11715)
@@ -224,6 +224,10 @@
void setSelectionTool();
+ protected:
+ void paintEvent( QPaintEvent* event );
private slots:
//! Raise, unminimize and activate this window
@@ -283,6 +287,9 @@
QAction *mWindowAction;
#endif
+ /**False if first paint already happened (used to create cache of composer maps for screen resolution after reading from project files)*/
+ bool mFirstPaint;
//! Help context id
static const int context_id = 985715179;
