[QGIS Commit] r13221 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Thu Apr 1 08:58:05 EDT 2010
Author: jef
Date: 2010-04-01 08:58:04 -0400 (Thu, 01 Apr 2010)
New Revision: 13221
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
use other approach to avoid estimate_extents on not analyzed tables
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-01 12:53:58 UTC (rev 13220)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-01 12:58:04 UTC (rev 13221)
@@ -234,28 +234,6 @@
// Kick off the long running threads
-#ifdef POSTGRESQL_THREADS
- QgsDebugMsg( "About to touch mExtentThread" );
- mExtentThread.setConnInfo( mUri.connectionInfo );
- mExtentThread.setTableName( mTableName );
- mExtentThread.setSqlWhereClause( sqlWhereClause );
- mExtentThread.setGeometryColumn( geometryColumn );
- mExtentThread.setCallback( this );
- QgsDebugMsg( "About to start mExtentThread" );
- mExtentThread.start();
- QgsDebugMsg( "Main thread just dispatched mExtentThread" );
- QgsDebugMsg( "About to touch mCountThread" );
- mCountThread.setConnInfo( mUri.connectionInfo );
- mCountThread.setTableName( mTableName );
- mCountThread.setSqlWhereClause( sqlWhereClause );
- mCountThread.setGeometryColumn( geometryColumn );
- mCountThread.setCallback( this );
- QgsDebugMsg( "About to start mCountThread" );
- mCountThread.start();
- QgsDebugMsg( "Main thread just dispatched mCountThread" );
-#endif
//fill type names into sets
mNativeTypes
// integer types
@@ -292,25 +270,6 @@
QgsPostgresProvider::~QgsPostgresProvider()
- QgsDebugMsg( "About to wait for mExtentThread" );
- mExtentThread.wait();
- QgsDebugMsg( "Finished waiting for mExtentThread" );
- QgsDebugMsg( "About to wait for mCountThread" );
- mCountThread.wait();
- QgsDebugMsg( "Finished waiting for mCountThread" );
- // Make sure all events from threads have been processed
- // (otherwise they will get destroyed prematurely)
- QApplication::sendPostedEvents( this, QGis::ProviderExtentCalcEvent );
- QApplication::sendPostedEvents( this, QGis::ProviderCountCalcEvent );
-#endif
disconnectDb();
QgsDebugMsg( "deconstructing." );
@@ -2730,68 +2689,38 @@
return featuresCounted;
-// TODO: use the estimateExtents procedure of PostGIS and PostgreSQL 8
-// This tip thanks to #qgis irc nick "creeping"
void QgsPostgresProvider::calculateExtents()
- // get the approximate extent by retrieving the bounding box
- // of the first few items with a geometry
- QString sql = QString( "select box3d(%1) from %2 where " )
- .arg( quotedIdentifier( geometryColumn ) )
- .arg( mSchemaTableName );
- if ( sqlWhereClause.length() > 0 )
- sql += QString( "(%1) and " ).arg( sqlWhereClause );
- sql += QString( "not IsEmpty(%1) limit 5" ).arg( quotedIdentifier( geometryColumn ) );
- QgsDebugMsg( "Getting approximate extent using: '" + sql + "'" );
- Result result = connectionRO->PQexec( sql );
- // TODO: Guard against the result having no rows
- for ( int i = 0; i < PQntuples( result ); i++ )
- QString box3d = PQgetvalue( result, i, 0 );
- if ( 0 == i )
- // create the initial extent
- layerExtent = QgsPostGisBox3d( box3d );
- else
- // extend the initial extent
- QgsPostGisBox3d b = QgsPostGisBox3d( box3d );
- layerExtent.combineExtentWith( &b );
- QgsDebugMsg( QString( "After row %1, extent is %2" ).arg( i ).arg( layerExtent.toString() ) );
-#else // non-postgresql threads version
QString sql;
Result result;
QString ext;
// get the extents
- if (( mUseEstimatedMetadata || sqlWhereClause.isEmpty() ) && !connectionRO->hasNoExtentEstimate() )
+ if ( mUseEstimatedMetadata || sqlWhereClause.isEmpty() )
- result = connectionRO->PQexec( QString( "select estimated_extent(%1,%2,%3)" )
- .arg( quotedValue( mSchemaName ) )
- .arg( quotedValue( mTableName ) )
- .arg( quotedValue( geometryColumn ) ) );
- if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
+ // do stats exists?
+ sql = QString( "SELECT COUNT(*) FROM pg_stats WHERE schemaname=%1 AND tablename=%2 AND attname=%3" )
+ .arg( quotedValue( mSchemaName ) )
+ .arg( quotedValue( mTableName ) )
+ .arg( quotedValue( geometryColumn ) );
+ result = connectionRO->PQexec( sql );
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK && PQntuples( result ) == 1 )
- connectionRO->PQexecNR( "ROLLBACK" );
- connectionRO->setNoExtentEstimate();
+ if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
+ sql = QString( "select estimated_extent(%1,%2,%3)" )
+ ext = PQgetvalue( result, 0, 0 );
- else if ( PQntuples( result ) == 1 )
- ext = PQgetvalue( result, 0, 0 );
+ else
+ QgsDebugMsg( QString( "no column statistics for %1.%2.%3" ).arg( mSchemaName ).arg( mTableName ).arg( geometryColumn ) );
if ( ext.isEmpty() )
@@ -2810,7 +2739,7 @@
- QgsDebugMsg( "Getting extents using schema.table: " + sql );
+ QgsDebugMsg( "Got extents using: " + sql );
QRegExp rx( "\\((.+) (.+),(.+) (.+)\\)" );
if ( ext.contains( rx ) )
@@ -2826,7 +2755,6 @@
QgsDebugMsg( "extents query failed" );
-#endif
QgsDebugMsg( "Set extents to: " + layerExtent.toString() );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-04-01 12:53:58 UTC (rev 13220)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-04-01 12:58:04 UTC (rev 13221)
@@ -584,12 +584,11 @@
class Conn
public:
- Conn( PGconn *connection ) :
- ref( 1 ),
- openCursors( 0 ),
- conn( connection ),
- gotPostgisVersion( false ),
- mHasNoExtentEstimate( false )
+ Conn( PGconn *connection )
+ : ref( 1 )
+ , openCursors( 0 )
+ , conn( connection )
+ , gotPostgisVersion( false )
@@ -614,12 +613,6 @@
//! PostgreSQL version
int pgVersion() { return postgresqlVersion; }
- //! has PostGIS no extent estimate?
- bool hasNoExtentEstimate() { return mHasNoExtentEstimate; }
- //! PostGIS does not have a extent estimate
- void setNoExtentEstimate( bool flag = true ) { mHasNoExtentEstimate = flag; }
//! run a query and free result buffer
bool PQexecNR( QString query );
@@ -678,9 +671,6 @@
//! encode wkb in hex
bool mUseWkbHex;
- //! PostGIS doesn't have extent estimates
- bool mHasNoExtentEstimate;
static QMap<QString, Conn *> connectionsRW;
static QMap<QString, Conn *> connectionsRO;
static QMap<QString, QString> passwordCache;
