[QGIS Commit] r13250 - in trunk/qgis: debian python/core src/app src/core src/providers/spatialite src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 5 13:16:27 EDT 2010
Author: jef
Date: 2010-04-05 13:16:25 -0400 (Mon, 05 Apr 2010)
New Revision: 13250
   trunk/qgis/debian/control.sid
   trunk/qgis/python/core/qgsapplication.sip
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsnewspatialitelayerdialog.cpp
   trunk/qgis/src/app/qgsnewspatialitelayerdialog.h
   trunk/qgis/src/app/qgsspatialitesourceselect.cpp
   trunk/qgis/src/app/qgsspatialitesridsdialog.cpp
   trunk/qgis/src/app/qgsspatialitesridsdialog.h
   trunk/qgis/src/core/qgsapplication.h
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
   trunk/qgis/src/ui/qgsnewspatialitelayerdialogbase.ui
spatialite improvements:
- support geometry column name
- remove unnecessary id field
- fix windows build
- better identifier quoting and utf-8 support
- update python binding
- fix some translation strings
Modified: trunk/qgis/debian/control.sid
--- trunk/qgis/debian/control.sid	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/debian/control.sid	2010-04-05 17:16:25 UTC (rev 13250)
@@ -8,7 +8,7 @@
  sharutils, sip4 (>= 4.5), libqt4-core (>=4.4.0), libqt4-dev (>=4.4.0), libqt4-gui (>=4.4.0),
  libqt4-sql (>=4.4.0), python-qt4 (>=4.1.0), python-qt4-dev (>=4.1.0),
  python-sip4-dev (>= 4.5.0), libfontconfig1-dev, libxi-dev, libxrandr-dev, libxrender-dev, libice-dev,
- libsm-dev, pyqt4-dev-tools, libqwt5-qt4-dev
+ libsm-dev, pyqt4-dev-tools, libqwt5-qt4-dev, libspatialite-dev
 Build-Conflicts: libqgis-dev, qgis-dev
 Standards-Version: 3.8.4
 XS-Python-Version: current
Modified: trunk/qgis/python/core/qgsapplication.sip
--- trunk/qgis/python/core/qgsapplication.sip	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/python/core/qgsapplication.sip	2010-04-05 17:16:25 UTC (rev 13250)
@@ -133,6 +133,10 @@
     //! Returns the path to the master qgis.db file.
     static const QString qgisMasterDbFilePath();
+    //! Returns the path to the spatialite template db file.
+    //! @note added in 1.5
+    static const QString qgisSpatialiteDbTemplatePath();
     //! Returns the path to the settings directory in user's home dir
     static const QString qgisSettingsDirPath();
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-04-05 17:16:25 UTC (rev 13250)
@@ -213,6 +213,11 @@
 #include "postgres/qgspgsourceselect.h"
 #endif
 #ifdef HAVE_SPATIALITE
+extern "C"
+#include <sqlite3.h>
+#include <spatialite.h>
 #include "qgsspatialitesourceselect.h"
 #include "qgsnewspatialitelayerdialog.h"
 #endif
@@ -937,15 +942,15 @@
   // Layer Menu Items
-  mActionNewVectorLayer = new QAction( getThemeIcon( "mActionNewVectorLayer.png" ), tr( "New Vector Layer (shapefile)..." ), this );
-  shortcuts->registerAction( mActionNewVectorLayer, tr( "Ctrl+Shift+N", "Create a New Vector Layer (shapefile)" ) );
-  mActionNewVectorLayer->setStatusTip( tr( "Create a New Vector Layer (shapefile)" ) );
+  mActionNewVectorLayer = new QAction( getThemeIcon( "mActionNewVectorLayer.png" ), tr( "New Shapefile Layer..." ), this );
+  shortcuts->registerAction( mActionNewVectorLayer, tr( "Ctrl+Shift+N", "Create a New Shapefile layer" ) );
+  mActionNewVectorLayer->setStatusTip( tr( "Create a New Shapefile layer" ) );
   connect( mActionNewVectorLayer, SIGNAL( triggered() ), this, SLOT( newVectorLayer() ) );
-  mActionNewSpatialiteLayer = new QAction( getThemeIcon( "mActionNewVectorLayer.png" ), tr( "New Spatialite Layer ..." ), this );
-  shortcuts->registerAction( mActionNewSpatialiteLayer, tr( "Ctrl+Shift+S", "Create a New Spatialite Layer " ) );
-  mActionNewSpatialiteLayer->setStatusTip( tr( "Create a New Spatialite Layer " ) );
+  mActionNewSpatialiteLayer = new QAction( getThemeIcon( "mActionNewVectorLayer.png" ), tr( "New SpatiaLite Layer ..." ), this );
+  shortcuts->registerAction( mActionNewSpatialiteLayer, tr( "Ctrl+Shift+S", "Create a New SpatiaLite Layer " ) );
+  mActionNewSpatialiteLayer->setStatusTip( tr( "Create a New SpatiaLite Layer " ) );
   connect( mActionNewSpatialiteLayer, SIGNAL( triggered() ), this, SLOT( newSpatialiteLayer() ) );
 #endif
@@ -1420,13 +1425,13 @@
   mLayerMenu = menuBar()->addMenu( tr( "&Layer" ) );
-  QMenu *newLayerMenu = mLayerMenu->addMenu( tr( "New ") );
+  QMenu *newLayerMenu = mLayerMenu->addMenu( tr( "New" ) );
   newLayerMenu->addAction( mActionNewVectorLayer );
   newLayerMenu->addAction( mActionNewSpatialiteLayer );
 #else
   mLayerMenu->addAction( mActionNewVectorLayer );
 #endif
   mLayerMenu->addAction( mActionAddOgrLayer );
   mLayerMenu->addAction( mActionAddRasterLayer );
 #ifdef HAVE_POSTGRESQL
@@ -3097,6 +3102,18 @@
   addVectorLayers( fileNames, enc, "file" );
+static QString quotedIdentifier( QString id )
+  id.replace( "\"", "\"\"" );
+  return id.prepend( "\"" ).append( "\"" );
+static QString quotedValue( QString value )
+  value.replace( "'", "''" );
+  return value.prepend( "'" ).append( "'" );
 void QgisApp::newSpatialiteLayer()
   if ( mMapCanvas && mMapCanvas->isDrawing() )
@@ -3115,6 +3132,7 @@
   QString crsId = spatialiteDialog.selectedCrsId();
   QString databaseName = spatialiteDialog.databaseName();
   QString newLayerName = spatialiteDialog.layerName();
+  QString newGeometryColumn = spatialiteDialog.geometryColumn();
   //QgsDebugMsg( QString( "New file format will be: %1" ).arg( fileformat ) );
   // Get the list containing the name/type pairs for each attribute
@@ -3122,188 +3140,95 @@
   // Build up the sql statement for creating the table
-  QString sql = QString("create table %1 (id integer primary key autoincrement").arg(newLayerName);
+  QString sql = QString( "create table %1(" ).arg( quotedIdentifier( newLayerName ) );
   // iterate through the field names and add them to the create statement
   // (use indexed access since this is just as fast as iterators
-  for ( int i = 0; i < items->size(); ++i )
+  for ( int i = 0; i < items->size(); ++i )
-    QStringList field = items->at(i);
-    sql += QString(", %1 %2").arg(field.at(0)).arg(field.at(1));
+    QStringList field = items->at( i );
+    if ( i > 0 )
+      sql += ",";
+    sql += QString( "%1 %2" ).arg( quotedIdentifier( field.at( 0 ) ) ).arg( field.at( 1 ) );
   // complete the create table statement
   sql += ")";
-  std::cout << "Creating table in database " << databaseName.toUtf8().data() << std::endl;
-  std::cout << sql.toUtf8().data() << std::endl; // OK
+  QgsDebugMsg( QString( "Creating table in database %1" ).arg( databaseName ) );
+  QgsDebugMsg( sql ); // OK
-  QString sqlAddGeom = QString("select AddGeometryColumn('%1', 'geom', %2, '%3', 2)").arg(newLayerName).arg(crsId).arg(geometrytype);
-  std::cout << sqlAddGeom.toUtf8().data() << std::endl; // OK
-  QString sqlCreateIndex = QString("select CreateSpatialIndex('%1', 'geom')").arg(newLayerName);
-  std::cout << sqlCreateIndex.toUtf8().data() << std::endl; // OK
+  QString sqlAddGeom = QString( "select AddGeometryColumn(%1,%2,%3,%4,2)" )
+                       .arg( quotedValue( newLayerName ) )
+                       .arg( quotedValue( newGeometryColumn ) )
+                       .arg( crsId )
+                       .arg( quotedValue( geometrytype ) );
+  QgsDebugMsg( sqlAddGeom ); // OK
+  QString sqlCreateIndex = QString( "select CreateSpatialIndex(%1,%2)" ).arg( quotedValue( newLayerName ) ).arg( quotedValue( newGeometryColumn ) );
+  QgsDebugMsg( sqlCreateIndex ); // OK
+  spatialite_init( 0 );
   sqlite3 *db;
   int rc = sqlite3_open( databaseName.toUtf8(), &db );
   if ( rc != SQLITE_OK )
-    QMessageBox::warning( this, "Spatialite Database", tr( "Unable to open the database: %1").arg(databaseName ) );
+    QMessageBox::warning( this,
+                          tr( "SpatiaLite Database" ),
+                          tr( "Unable to open the database: %1" ).arg( databaseName ) );
   else
     char * errmsg;
-    rc = sqlite3_exec( db, sql.toUtf8(), NULL, NULL, &errmsg);
+    rc = sqlite3_exec( db, sql.toUtf8(), NULL, NULL, &errmsg );
-      QMessageBox::warning( this, tr( "Error deleting bookmark" ),
-          tr( "Failed to create the Spatialite table %1. The database returned:\n%2" ).arg( newLayerName ).arg( errmsg ) );
+                            tr( "Error Creating SpatiaLite Table" ),
+                            tr( "Failed to create the SpatiaLite table %1. The database returned:\n%2" ).arg( newLayerName ).arg( errmsg ) );
       sqlite3_free( errmsg );
     else
       // create the geometry column and the spatial index
-      rc = sqlite3_exec( db, sqlAddGeom.toUtf8(), NULL, NULL, &errmsg);
+      rc = sqlite3_exec( db, sqlAddGeom.toUtf8(), NULL, NULL, &errmsg );
-        QMessageBox::warning( this, tr( "Error Creating Geometry Column" ),
-            tr( "Failed to create the geometry column. The database returned:\n%1" ).arg( errmsg ) );
+                              tr( "Error Creating Geometry Column" ),
+                              tr( "Failed to create the geometry column. The database returned:\n%1" ).arg( errmsg ) );
       else
-      // create the spatial index
-      rc = sqlite3_exec( db, sqlCreateIndex.toUtf8(), NULL, NULL, &errmsg);
-      if ( rc != SQLITE_OK )
-        QMessageBox::warning( this, tr( "Error Creating Spatial Index" ),
-            tr( "Failed to create the spatial index. The database returned:\n%1" ).arg( errmsg ) );
-        sqlite3_free( errmsg );
+        // create the spatial index
+        rc = sqlite3_exec( db, sqlCreateIndex.toUtf8(), NULL, NULL, &errmsg );
+        if ( rc != SQLITE_OK )
+                                tr( "Error Creating Spatial Index" ),
+                                tr( "Failed to create the spatial index. The database returned:\n%1" ).arg( errmsg ) );
+          sqlite3_free( errmsg );
-  bool haveLastUsedFilter = false; // by default, there is no last
-  // used filter
-  QString enc;
-  QString fileName;
-  QSettings settings;         // where we keep last used filter in
-  // persistent state
-  haveLastUsedFilter = settings.contains( "/UI/lastVectorFileFilter" );
-  QString lastUsedFilter = settings.value( "/UI/lastVectorFileFilter",
-                           QVariant( QString::null ) ).toString();
-  QString lastUsedDir = settings.value( "/UI/lastVectorFileFilterDir",
-                                        "." ).toString();
-  QgsDebugMsg( "Saving vector file dialog without filters: " );
-  QgsEncodingFileDialog* openFileDialog = new QgsEncodingFileDialog( this,
-      tr( "Save As" ), lastUsedDir, "", QString( "" ) );
-  // allow for selection of more than one file
-  openFileDialog->setFileMode( QFileDialog::AnyFile );
-  openFileDialog->setAcceptMode( QFileDialog::AcceptSave );
-  openFileDialog->setConfirmOverwrite( true );
-  if ( haveLastUsedFilter )     // set the filter to the last one used
-    openFileDialog->selectFilter( lastUsedFilter );
-  int res;
-  while (( res = openFileDialog->exec() ) == QDialog::Accepted )
-    fileName = openFileDialog->selectedFiles().first();
-    if ( fileformat == "ESRI Shapefile" )
-      if ( !isValidShapeFileName( fileName ) )
-        fileName += ".shp";
+        QgsVectorLayer *layer = new QgsVectorLayer( QString( "dbname=%1 table=%2(%3) sql=" )
+            .arg( databaseName )
+            .arg( newLayerName )
+            .arg( newGeometryColumn ), newLayerName, "spatialite" );
+        if ( layer->isValid() )
+          // register this layer with the central layers registry
+          QgsMapLayerRegistry::instance()->addMapLayer( layer );
+        else
+          QgsDebugMsg( newLayerName + " is an invalid layer - not loaded" );
+          QMessageBox::critical( this, tr( "Invalid Layer" ), tr( "%1 is an invalid layer and cannot be loaded." ).arg( newLayerName ) );
+          delete layer;
-        QMessageBox::information( this,
-                                  tr( "New Shapefile" ),
-                                  tr( "Shapefiles must end on .shp" ) );
-        continue;
-    break;
-  if ( res == QDialog::Rejected )
-    delete openFileDialog;
-    return;
-  enc = openFileDialog->encoding();
-  // If the file exists, delete it otherwise we'll end up loading that
-  // file, which can cause problems (e.g., if the file contains
-  // linestrings, but we're wanting to create points, we'll end up
-  // with a linestring file).
-    QgsVectorFileWriter::deleteShapeFile( fileName );
-  else
-    QFile::remove( fileName );
-  settings.setValue( "/UI/lastVectorFileFilter", openFileDialog->selectedFilter() );
-  settings.setValue( "/UI/lastVectorFileFilterDir", openFileDialog->directory().absolutePath() );
-  //try to create the new layer with OGRProvider instead of QgsVectorFileWriter
-  QgsProviderRegistry * pReg = QgsProviderRegistry::instance();
-  QString ogrlib = pReg->library( "ogr" );
-  // load the data provider
-  QLibrary* myLib = new QLibrary( ogrlib );
-  bool loaded = myLib->load();
-  if ( loaded )
-    QgsDebugMsg( "ogr provider loaded" );
-    typedef bool ( *createEmptyDataSourceProc )( const QString&, const QString&, const QString&, QGis::WkbType,
-        const std::list<std::pair<QString, QString> >&, const QgsCoordinateReferenceSystem * );
-    createEmptyDataSourceProc createEmptyDataSource = ( createEmptyDataSourceProc ) cast_to_fptr( myLib->resolve( "createEmptyDataSource" ) );
-    if ( createEmptyDataSource )
-      if ( geometrytype != QGis::WKBUnknown )
-        QgsCoordinateReferenceSystem srs( crsId, QgsCoordinateReferenceSystem::InternalCrsId );
-        createEmptyDataSource( fileName, fileformat, enc, geometrytype, attributes, &srs );
-      else
-        QgsDebugMsg( "geometry type not recognised" );
-        return;
-    else
-      QgsDebugMsg( "Resolving newEmptyDataSource(...) failed" );
-  //then add the layer to the view
-  QStringList fileNames;
-  fileNames.append( fileName );
-  //todo: the last parameter will change accordingly to layer type
-  addVectorLayers( fileNames, enc, "file" );
 void QgisApp::fileOpen()
@@ -5026,6 +4951,7 @@
     mActionPluginSeparator2 = mPluginMenu->addSeparator();
     mPluginMenu->addAction( mActionShowPythonDialog );
     std::cout << "Python support ENABLED :-) " << std::endl; // OK
Modified: trunk/qgis/src/app/qgsnewspatialitelayerdialog.cpp
--- trunk/qgis/src/app/qgsnewspatialitelayerdialog.cpp	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgsnewspatialitelayerdialog.cpp	2010-04-05 17:16:25 UTC (rev 13250)
@@ -18,20 +18,14 @@
 /* $Id$ */
-extern "C"
-#include <spatialite/sqlite3.h>
-#include <spatialite/gaiageo.h>
-#include <spatialite.h>
 #include "qgsspatialitesridsdialog.h"
 #include "qgsapplication.h"
 #include "qgisapp.h" // <- for theme icons
 #include "qgslogger.h"
-//#include <sqlite3.h>
 #include <QPushButton>
 #include <QSettings>
 #include <QLineEdit>
@@ -66,10 +60,9 @@
     ++it;
   settings.endGroup();
-  mApplyButton = buttonBox->button( QDialogButtonBox::Apply );
-  mApplyButton->setEnabled( false );
-  mApplyButton->setDefault( true );
-  connect( buttonBox->button( QDialogButtonBox::Apply ), SIGNAL( clicked() ), this, SLOT( apply() ) );
+  mOkButton = buttonBox->button( QDialogButtonBox::Ok );
+  mOkButton->setEnabled( false );
+  mOkButton->setDefault( true );
   // Set the SRID box to a default of WGS84
   leSRID->setText( "4326" );
@@ -85,17 +78,17 @@
 void QgsNewSpatialiteLayerDialog::createNewDb()
 //  QMessageBox::information( 0, tr( "Spatialite Layer" ), tr( "Create new db clicked" ) );
-  QString fileName = QFileDialog::getSaveFileName(this, tr("New Spatialite Database File"),
-      tr("Spatialite (*.sqlite *.db )"));
+  QString fileName = QFileDialog::getSaveFileName( this, tr( "New SpatiaLite Database File" ),
+                     tr( "SpatiaLite (*.sqlite *.db )" ) );
   if ( !fileName.isEmpty() )
     mDatabaseComboBox->insertItem( 0, fileName );
-    mDatabaseComboBox->setCurrentIndex(0);
+    mDatabaseComboBox->setCurrentIndex( 0 );
     createDb();
     needNewDb = true;
 void QgsNewSpatialiteLayerDialog::on_mTypeBox_currentIndexChanged( int index )
@@ -136,6 +129,9 @@
     return "MULTIPOLYGON";
+  Q_ASSERT( "no type selected" == 0 );
+  return "";
 QString QgsNewSpatialiteLayerDialog::selectedCrsId() const
@@ -143,67 +139,11 @@
   return leSRID->text();
-void QgsNewSpatialiteLayerDialog::apply()
-  // Check to see if the db exists and if not create it
-  createDb();
-  // Init spatialite
-  spatialite_init( 0 );
-  QString newLayerName = leLayerName->text();
-  int rc = sqlite3_open_v2( mDatabaseComboBox->currentText().toUtf8(), &db, SQLITE_OPEN_READWRITE, NULL );
-    QMessageBox::warning( this, "Spatialite Database", tr( "Unable to open the database"));
-  else
-    char * errmsg;
-    QString sql = QString("CREATE TABLE %1 (id integer primary key autoincrement, name text)").arg( newLayerName );
-      QMessageBox::warning( this, tr( "Error Creating Table" ),
-          tr( "Failed to create the Spatialite table. The database returned:\n%1" ).arg( errmsg ) );
-    else
-      // get the geometry type
-      QString geomType = selectedType();
-      // create the geometry column and the spatial index
-      sql = QString("select AddGeometryColumn('%1', 'geom', %2, '%3', 2)").arg( newLayerName ).arg( leSRID->text() ).arg( geomType );
-      else
-        sql = QString("select CreateSpatialIndex('%1', 'geom')").arg( newLayerName );
-        else
-          QMessageBox::information( 0, tr( "Spatialite Layer" ), tr( "Layer created" ) );
 void QgsNewSpatialiteLayerDialog::on_leLayerName_textChanged( QString text )
-  if ( leLayerName->text().length() > 0 && mAttributeView->topLevelItemCount() > 0)
+  if ( leLayerName->text().length() > 0 && mAttributeView->topLevelItemCount() > 0 )
-    mApplyButton->setEnabled( true );
+    mOkButton->setEnabled( true );
@@ -214,10 +154,10 @@
     QString myName = mNameEdit->text();
     //use userrole to avoid translated type string
     QString myType = mTypeBox->itemData( mTypeBox->currentIndex(), Qt::UserRole ).toString();
-    mAttributeView->addTopLevelItem( new QTreeWidgetItem( QStringList() << myName << myType  ) );
+    mAttributeView->addTopLevelItem( new QTreeWidgetItem( QStringList() << myName << myType ) );
     if ( mAttributeView->topLevelItemCount() > 0  && leLayerName->text().length() > 0 )
     mNameEdit->clear();
@@ -228,7 +168,7 @@
   delete mAttributeView->currentItem();
   if ( mAttributeView->topLevelItemCount() == 0 )
@@ -238,11 +178,11 @@
      int rc = sqlite3_open( mDatabaseComboBox->currentText().toUtf8().data(), &db );
-     QMessageBox::warning( this, "Spatialite Database", tr( "Unable to open the database: %1").arg(mDatabaseComboBox->currentText() ) );
+     QMessageBox::warning( this, tr( "Spatialite Database" ), tr( "Unable to open the database: %1").arg(mDatabaseComboBox->currentText() ) );
   // set the SRID from a list returned from the selected Spatialite database
-  QgsSpatialiteSridsDialog *sridDlg = new QgsSpatialiteSridsDialog(this);
+  QgsSpatialiteSridsDialog *sridDlg = new QgsSpatialiteSridsDialog( this );
   if ( sridDlg->load( mDatabaseComboBox->currentText() ) )
     if ( sridDlg->exec() )
@@ -255,7 +195,7 @@
-// Create a QList of QStringList objects that define the layer attributes.
+// Create a QList of QStringList objects that define the layer attributes.
 // Each QStringList contains the field name and its type.
 QList<QStringList> * QgsNewSpatialiteLayerDialog::attributes() const
@@ -267,8 +207,8 @@
     QStringList items;
     items << item->text( 0 );
     items << item->text( 1 );
-    list->append(items);
+    list->append( items );
     //QString type = QString( "%1;%2;%3" ).arg( item->text( 1 ) ).arg( item->text( 2 ) ).arg( item->text( 3 ) );
     //at.push_back( std::make_pair( item->text( 0 ), type ) );
     //QgsDebugMsg( QString( "appending %1//%2" ).arg( item->text( 0 ) ).arg( type ) );
@@ -286,6 +226,12 @@
   return leLayerName->text();
+QString QgsNewSpatialiteLayerDialog::geometryColumn() const
+  return leGeometryColumn->text();
 bool QgsNewSpatialiteLayerDialog::createDb()
   QFile newDb( mDatabaseComboBox->currentText() );
@@ -298,28 +244,24 @@
     QFileInfo fullPath = QFileInfo( mDatabaseComboBox->currentText() );
     QDir path = fullPath.dir();
-    qWarning("making this dir: %s", path.absolutePath().toUtf8().data());
+    qWarning( "making this dir: %s", path.absolutePath().toUtf8().data() );
     // Must be sure there is destination directory ~/.qgis
     QDir().mkpath( path.absolutePath( ) );
-    qWarning("Copying %s ", spatialiteTemplate.toUtf8().data());
-    qWarning("to %s", newDb.fileName().toUtf8().data());
+    qWarning( "Copying %s ", spatialiteTemplate.toUtf8().data() );
+    qWarning( "to %s", newDb.fileName().toUtf8().data() );
     //now copy the template db file into the chosen location
-    bool isDbFileCopied = spatialiteTemplateDb.copy( newDb.fileName() );
-    if ( !isDbFileCopied )
+    if ( !spatialiteTemplateDb.copy( newDb.fileName() ) )
-      // QMessageBox::warning( this, "Spatialite Database", tr( "Unable to copy the template database to your new location" ));
+      QMessageBox::warning( 0, tr( "SpatiaLite Database" ), tr( "Could not copy the template database to new location" ) );
       return false;
     else
-      QMessageBox::information( 0, tr( "Spatialite Database" ), tr( "Created new database!" ) );
+      QMessageBox::information( 0, tr( "SpatiaLite Database" ), tr( "Created new database!" ) );
-    return true;
+  return true;
Modified: trunk/qgis/src/app/qgsnewspatialitelayerdialog.h
--- trunk/qgis/src/app/qgsnewspatialitelayerdialog.h	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgsnewspatialitelayerdialog.h	2010-04-05 17:16:25 UTC (rev 13250)
@@ -1,7 +1,7 @@
                          QgsNewSpatialiteLayerDialog.h  -  description
-    begin                : 2010-03-19
+    begin                : 2010-03-19
     copyright            : (C) 2010 by Gary Sherman
     email                : gsherman at mrcc.com
@@ -17,18 +17,18 @@
 /* $Id$ */
 #ifndef qgsnewspatialitelayerdialog_H
 #define qgsnewspatialitelayerdialog_H
-#include <sqlite3.h>
-extern "C"
-#include <spatialite/headers/spatialite.h>
 #include "ui_qgsnewspatialitelayerdialogbase.h"
 #include "qgisgui.h"
 #include "qgscontexthelp.h"
 #include "qgis.h"
+extern "C"
 class QgsNewSpatialiteLayerDialog: public QDialog, private Ui::QgsNewSpatialiteLayerDialogBase
     Q_OBJECT
@@ -45,6 +45,8 @@
     QString databaseName() const;
     /**Returns the layer name to be created */
     QString layerName() const;
+    /**Returns the geometry column name */
+    QString geometryColumn() const;
     /**Returns the selected crs id*/
     QString selectedCrsId() const;
     /** Create a new database */
@@ -57,11 +59,11 @@
     void on_pbnFindSRID_clicked();
     void on_leLayerName_textChanged( QString text );
     void createNewDb();
-    void apply();
     void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
   private:
-    QPushButton *mApplyButton;
+    QPushButton *mOkButton;
     int mCrsId;
     sqlite3 *db;
     bool needNewDb;
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.cpp	2010-04-05 17:16:25 UTC (rev 13250)
@@ -300,7 +300,7 @@
   QString myFile = QFileDialog::getOpenFileName( this,
                    tr( "Choose a SpatiaLite/SQLite DB to open" ),
-                   lastUsedDir, QObject::tr( "SQLite DB (*.sqlite);;All files (*.*)" ) );
+                   lastUsedDir, QObject::tr( "SQLite DB (*.sqlite *.db);;All files (*.*)" ) );
   if ( myFile.isEmpty() )
     return;
@@ -507,8 +507,8 @@
     for ( i = 1; i <= rows; i++ )
-      QString tableName = results[( i * columns ) + 0];
-      QString column = results[( i * columns ) + 1];
+      QString tableName = QString::fromUtf8( results[( i * columns ) + 0] );
+      QString column = QString::fromUtf8( results[( i * columns ) + 1] );
       QString type = results[( i * columns ) + 2];
       if ( isDeclaredHidden( handle, tableName, column ) )
         continue;
@@ -534,8 +534,8 @@
           continue;
@@ -561,8 +561,8 @@
           continue;
Modified: trunk/qgis/src/app/qgsspatialitesridsdialog.cpp
--- trunk/qgis/src/app/qgsspatialitesridsdialog.cpp	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgsspatialitesridsdialog.cpp	2010-04-05 17:16:25 UTC (rev 13250)
@@ -19,7 +19,7 @@
 #include <QMessageBox>
 QgsSpatialiteSridsDialog::QgsSpatialiteSridsDialog( QWidget *parent, Qt::WFlags fl )
-  : QDialog( parent, fl )
+    : QDialog( parent, fl )
   setupUi( this );
   db = 0;
@@ -29,13 +29,13 @@
 QgsSpatialiteSridsDialog::~QgsSpatialiteSridsDialog()
-    sqlite3_close( db );
+  sqlite3_close( db );
 QString QgsSpatialiteSridsDialog::selectedSrid()
-  return twSrids->currentItem()->text(0);
+  return twSrids->currentItem()->text( 0 );
-bool QgsSpatialiteSridsDialog::load(QString dbName)
+bool QgsSpatialiteSridsDialog::load( QString dbName )
   mDbName = dbName;
   bool status = true;
@@ -44,43 +44,43 @@
     int rc = sqlite3_open_v2( dbName.toUtf8(), &db, SQLITE_OPEN_READONLY, NULL );
+      QMessageBox::warning( this, tr( "SpatiaLite Database" ), tr( "Unable to open the database" ) );
       return false;
-    // load up the srid table
-    // prepare the sql statement
-    const char *pzTail;
-    sqlite3_stmt *ppStmt;
-    QString sql = "select auth_srid, auth_name, ref_sys_name from spatial_ref_sys order by srid asc";
+  // load up the srid table
+  // prepare the sql statement
+  const char *pzTail;
+  sqlite3_stmt *ppStmt;
+  QString sql = "select auth_srid, auth_name, ref_sys_name from spatial_ref_sys order by srid asc";
-    int rc = sqlite3_prepare( db, sql.toUtf8(), sql.toUtf8().length(), &ppStmt, &pzTail );
-    // XXX Need to free memory from the error msg if one is set
-    if ( rc == SQLITE_OK )
+  int rc = sqlite3_prepare( db, sql.toUtf8(), sql.toUtf8().length(), &ppStmt, &pzTail );
+  // XXX Need to free memory from the error msg if one is set
+  if ( rc == SQLITE_OK )
+    // get the first row of the result set
+    while ( sqlite3_step( ppStmt ) == SQLITE_ROW )
-      // get the first row of the result set
-      while ( sqlite3_step( ppStmt ) == SQLITE_ROW )
-        QTreeWidgetItem *item = new QTreeWidgetItem( twSrids );
-        // srid
-        item->setText (0, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 0 ) ) );
-        item->setText (1, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 1 ) ) );
-        // name
-        item->setText( 2, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 2 ) ) );
-        // proj4 text
-        item->setText( 3, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 3 ) ) );
+      QTreeWidgetItem *item = new QTreeWidgetItem( twSrids );
+      // srid
+      item->setText( 0, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 0 ) ) );
+      item->setText( 1, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 1 ) ) );
+      // name
+      item->setText( 2, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 2 ) ) );
+      // proj4 text
+      item->setText( 3, QString::fromUtf8(( const char * )sqlite3_column_text( ppStmt, 3 ) ) );
-      twSrids->sortByColumn( 0, Qt::AscendingOrder );
-    else
-      // XXX query failed -- warn the user some how
-      QMessageBox::warning(0, "Error",  QString( "Failed to load SRIDS: %1" ).arg( sqlite3_errmsg( db ) ) );
-      status = false;
-    // close the statement
-    sqlite3_finalize( ppStmt );
+    twSrids->sortByColumn( 0, Qt::AscendingOrder );
+  else
+    // XXX query failed -- warn the user some how
+    QMessageBox::warning( 0, tr( "Error" ),  tr( "Failed to load SRIDS: %1" ).arg( sqlite3_errmsg( db ) ) );
+    status = false;
+  // close the statement
+  sqlite3_finalize( ppStmt );
   return status;
 void QgsSpatialiteSridsDialog::on_pbnFilter_clicked()
@@ -102,7 +102,7 @@
       search = "ref_sys_name";
-    QString sql = QString("select auth_srid, auth_name, ref_sys_name from spatial_ref_sys where %1 like '%").arg(search) + leSearch->text() + QString("%' order by srid asc");
+    QString sql = QString( "select auth_srid, auth_name, ref_sys_name from spatial_ref_sys where %1 like '%" ).arg( search ) + leSearch->text() + QString( "%' order by srid asc" );
     //QMessageBox::information(0, "Sql", sql);
@@ -116,8 +116,8 @@
         // srid
         // name
         // proj4 text
@@ -129,7 +129,7 @@
     else
Modified: trunk/qgis/src/app/qgsspatialitesridsdialog.h
--- trunk/qgis/src/app/qgsspatialitesridsdialog.h	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/app/qgsspatialitesridsdialog.h	2010-04-05 17:16:25 UTC (rev 13250)
@@ -23,20 +23,24 @@
 #include "qgis.h"
+extern "C"
-class QgsSpatialiteSridsDialog: public QDialog, private Ui::QgsSpatialiteSridsDialogBase
+class QgsSpatialiteSridsDialog: public QDialog, private Ui::QgsSpatialiteSridsDialogBase
-  Q_OBJECT
-public:
-  QgsSpatialiteSridsDialog( QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
-  ~QgsSpatialiteSridsDialog();
-  bool load(QString dbName);
-  QString selectedSrid();
-public slots:
-  void on_pbnFilter_clicked();
-private:
-  sqlite3 *db;
-  QString mDbName;
+    Q_OBJECT
+  public:
+    QgsSpatialiteSridsDialog( QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags );
+    ~QgsSpatialiteSridsDialog();
+    bool load( QString dbName );
+    QString selectedSrid();
+  public slots:
+    void on_pbnFilter_clicked();
+  private:
+    sqlite3 *db;
+    QString mDbName;
 #endif //QgsSpatialiteSridsDialog_H
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/core/qgsapplication.h	2010-04-05 17:16:25 UTC (rev 13250)
@@ -90,6 +90,7 @@
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-04-05 17:16:25 UTC (rev 13250)
@@ -14,8 +14,6 @@
-#include <cassert>
 #include <qgis.h>
 #include <qgsapplication.h>
 #include <qgsfeature.h>
@@ -41,8 +39,14 @@
 QMap < QString, QgsSpatiaLiteProvider::SqliteHandles * >QgsSpatiaLiteProvider::SqliteHandles::handles;
-QgsSpatiaLiteProvider::QgsSpatiaLiteProvider( QString const &uri ): QgsVectorDataProvider( uri ),
-    geomType( QGis::WKBUnknown ), sqliteHandle( NULL ), sqliteStatement( NULL ), mSrid( -1 ), spatialIndexRTree( false ), spatialIndexMbrCache( false )
+QgsSpatiaLiteProvider::QgsSpatiaLiteProvider( QString const &uri )
+    : QgsVectorDataProvider( uri )
+    , geomType( QGis::WKBUnknown )
+    , sqliteHandle( NULL )
+    , sqliteStatement( NULL )
+    , mSrid( -1 )
+    , spatialIndexRTree( false )
+    , spatialIndexMbrCache( false )
   QgsDataSourceURI anUri = QgsDataSourceURI( uri );
@@ -69,7 +73,7 @@
     numberFeatures = 0;
     valid = false;
-    QgsLogger::critical( "Invalid SpatiaLite layer" );
+    QgsDebugMsg( "Invalid SpatiaLite layer" );
     closeDb();
     return;
@@ -90,7 +94,7 @@
     numberFeatures = 0;
     valid = false;
     closeDb();
     return;
@@ -99,7 +103,7 @@
     numberFeatures = 0;
     valid = false;
     closeDb();
     return;
@@ -109,7 +113,7 @@
     valid = false;
     return;
   //fill type names into sets
@@ -171,7 +175,9 @@
         if ( strcasecmp( type, "int" ) == 0 ||
              strcasecmp( type, "integer" ) == 0 ||
              strcasecmp( type, "bigint" ) == 0 ||
-             strcasecmp( type, "smallint" ) == 0 || strcasecmp( type, "tinyint" ) == 0 || strcasecmp( type, "boolean" ) == 0 )
+             strcasecmp( type, "smallint" ) == 0 ||
+             strcasecmp( type, "tinyint" ) == 0 ||
+             strcasecmp( type, "boolean" ) == 0 )
           fieldType = QVariant::Int;
@@ -200,9 +206,7 @@
   // unexpected error
   if ( errMsg != NULL )
-    QString error = "loadFields() SQL error: ";
-    error = errMsg;
-    QgsLogger::critical( error );
+    QgsDebugMsg( QString( "SQL error: %1" ).arg( QString::fromUtf8( errMsg ) ) );
     sqlite3_free( errMsg );
@@ -223,22 +227,20 @@
     const QgsField & fld = field( *it );
     const QString & fieldname = fld.name();
-    sql += ", \"";
-    sql += fieldname;
-    sql += "\"";
+    sql += "," + quotedIdentifier( fieldname );
   if ( fetchGeometry )
-    sql += QString( ", AsBinary(\"%1\")" ).arg( mGeometryColumn );
+    sql += QString( ", AsBinary(%1)" ).arg( quotedIdentifier( mGeometryColumn ) );
-  sql += QString( " FROM \"%1\" WHERE ROWID = %2" ).arg( mTableName ).arg( featureId );
+  sql += QString( " FROM %1 WHERE ROWID = %2" ).arg( quotedIdentifier( mTableName ) ).arg( featureId );
   if ( sqlite3_prepare_v2( sqliteHandle, sql.toUtf8().constData(), -1, &stmt, NULL ) != SQLITE_OK )
     // some error occurred
-    QString errCause = sqlite3_errmsg( sqliteHandle );
-    QString msg = tr( "SQLite error: %1\n\nSQL: %2" ).arg( sql ).arg( errCause );
-    QgsLogger::critical( msg );
+    QgsDebugMsg( QString( "SQLite error: %1\n\nSQL: %2" )
+                 .arg( sql )
+                 .arg( QString::fromUtf8( sqlite3_errmsg( sqliteHandle ) ) ) );
     return false;
@@ -314,7 +316,7 @@
         if ( mFetchGeom )
-          QString geoCol = QString( "AsBinary(\"%1\")" ).arg( mGeometryColumn );
+          QString geoCol = QString( "AsBinary(%1)" ).arg( quotedIdentifier( mGeometryColumn ) );
           if ( strcasecmp( geoCol.toUtf8().constData(), sqlite3_column_name( stmt, ic ) ) == 0 )
             if ( sqlite3_column_type( stmt, ic ) == SQLITE_BLOB )
@@ -339,9 +341,7 @@
   else
     // some unexpected error occurred
-    QString error = "sqlite3_step() error: ";
-    error += sqlite3_errmsg( sqliteHandle );
+    QgsDebugMsg( QString( "sqlite3_step() error: %1" ).arg( QString::fromUtf8( sqlite3_errmsg( sqliteHandle ) ) ) );
     sqlite3_finalize( stmt );
     return false;
@@ -355,13 +355,13 @@
   feature.setValid( false );
   if ( !valid )
-    QgsLogger::critical( "Read attempt on an invalid SpatiaLite data source" );
+    QgsDebugMsg( "Read attempt on an invalid SpatiaLite data source" );
     return false;
   if ( sqliteStatement == NULL )
-    QgsLogger::critical( "Invalid current SQLite statement" );
+    QgsDebugMsg( "Invalid current SQLite statement" );
     return false;
@@ -438,7 +438,7 @@
         if ( mFetchGeom )
           if ( strcasecmp( geoCol.toUtf8().constData(), sqlite3_column_name( sqliteStatement, ic ) ) == 0 )
             if ( sqlite3_column_type( sqliteStatement, ic ) == SQLITE_BLOB )
@@ -463,9 +463,7 @@
   else
     sqlite3_finalize( sqliteStatement );
     sqliteStatement = NULL;
     return false;
@@ -512,7 +510,7 @@
   if ( !valid )
     return;
@@ -528,15 +526,13 @@
-    sql += ", \"";
-    sql += fieldname;
-    sql += "\"";
-  sql += QString( " FROM \"%1\"" ).arg( mTableName );
+  sql += QString( " FROM %1" ).arg( quotedIdentifier( mTableName ) );
   QString whereClause;
@@ -551,7 +547,7 @@
                     arg( QString::number( rect.xMinimum(), 'f', 6 ) ).
                     arg( QString::number( rect.yMinimum(), 'f', 6 ) ).
                     arg( QString::number( rect.xMaximum(), 'f', 6 ) ).arg( QString::number( rect.yMaximum(), 'f', 6 ) );
-      whereClause += QString( "Intersects(\"%1\", BuildMbr(%2)) AND " ).arg( mGeometryColumn ).arg( mbr );
+      whereClause += QString( "Intersects(%1, BuildMbr(%2)) AND " ).arg( quotedIdentifier( mGeometryColumn ) ).arg( mbr );
     if ( mVShapeBased )
@@ -560,7 +556,7 @@
-      whereClause += QString( "MbrIntersects(\"%1\", BuildMbr(%2))" ).arg( mGeometryColumn ).arg( mbr );
+      whereClause += QString( "MbrIntersects(%1, BuildMbr(%2))" ).arg( quotedIdentifier( mGeometryColumn ) ).arg( mbr );
     else
@@ -572,7 +568,7 @@
         mbrFilter += QString( "ymin <= %1 AND " ).arg( QString::number( rect.yMaximum(), 'f', 6 ) );
         mbrFilter += QString( "ymax >= %1" ).arg( QString::number( rect.yMinimum(), 'f', 6 ) );
         QString idxName = QString( "idx_%1_%2" ).arg( mIndexTable ).arg( mIndexGeometry );
-        whereClause += QString( "ROWID IN (SELECT pkid FROM \"%1\" WHERE %2)" ).arg( idxName ).arg( mbrFilter );
+        whereClause += QString( "ROWID IN (SELECT pkid FROM %1 WHERE %2)" ).arg( quotedIdentifier( idxName ) ).arg( mbrFilter );
       else if ( spatialIndexMbrCache )
@@ -582,7 +578,7 @@
         QString idxName = QString( "cache_%1_%2" ).arg( mIndexTable ).arg( mIndexGeometry );
-        whereClause += QString( "ROWID IN (SELECT rowid FROM \"%1\" WHERE mbr = FilterMbrIntersects(%2))" ).arg( idxName ).arg( mbr );
+        whereClause += QString( "ROWID IN (SELECT rowid FROM %1 WHERE mbr = FilterMbrIntersects(%2))" ).arg( quotedIdentifier( idxName ) ).arg( mbr );
       else
@@ -591,7 +587,7 @@
@@ -617,9 +613,7 @@
   if ( sqlite3_prepare_v2( sqliteHandle, sql.toUtf8().constData(), -1, &sqliteStatement, NULL ) != SQLITE_OK )
+    QgsDebugMsg( QString( "SQLite error: %1\n\nSQL: %2" ).arg( sql ).arg( QString::fromUtf8( sqlite3_errmsg( sqliteHandle ) ) ) );
@@ -752,9 +746,7 @@
   // unexpected error
-    QString error = "minValue() SQL error: ";
-    error = errMsg;
   return QVariant( QString::null );
@@ -810,9 +802,7 @@
   // unexpected error
-    QString error = "maxValue() SQL error: ";
-    error = errMsg;
@@ -822,7 +812,6 @@
 void QgsSpatiaLiteProvider::uniqueValues( int index, QList < QVariant > &uniqueValues, int limit )
   sqlite3_stmt *stmt = NULL;
-  char *errMsg = NULL;
   QString sql;
   QString txt;
@@ -847,9 +836,7 @@
     return;
@@ -885,28 +872,15 @@
     else
-      // some unexpected error occurred
-      const char *err = sqlite3_errmsg( sqliteHandle );
-      int len = strlen( err );
-      errMsg = ( char * ) sqlite3_malloc( len + 1 );
-      strcpy( errMsg, err );
-      goto abort;
+      QgsDebugMsg( QString( "SQL error:\n%1\n%2" ).arg( sql ).arg( QString::fromUtf8( sqlite3_errmsg( sqliteHandle ) ) ) );
+      sqlite3_finalize( stmt );
+      return;
   return;
-abort:
-  QString msg = QString( "getUniqueValues SQL error:\n%1\n" ).arg( sql );
-  if ( errMsg )
-    msg += errMsg;
-    sqlite3_free( errMsg );
-  else
-    msg += "unknown cause";
 bool QgsSpatiaLiteProvider::addFeatures( QgsFeatureList & flist )
@@ -932,13 +906,17 @@
   if ( !mPrimaryKey.isEmpty() )
-    sql = QString( "INSERT INTO \"%1\" (\"%2\", \"%3\"" ).
-          arg( mTableName ).arg( mPrimaryKey ).arg( mGeometryColumn );
-    values = QString( ") VALUES (NULL, GeomFromWKB(?, %1)" ).arg( mSrid );
+    sql = QString( "INSERT INTO %1(%2,%3" )
+          .arg( quotedIdentifier( mTableName ) )
+          .arg( quotedIdentifier( mPrimaryKey ) )
+          .arg( quotedIdentifier( mGeometryColumn ) );
+    values = QString( ") VALUES (NULL, GeomFromWKB(?,%1)" ).arg( mSrid );
   else
-    sql = QString( "INSERT INTO \"%1\" (\"%2\"" ).arg( mTableName ).arg( mGeometryColumn );
+    sql = QString( "INSERT INTO %1(%2" )
     values = QString( ") VALUES (GeomFromWKB(?, %1)" ).arg( mSrid );
@@ -952,10 +930,8 @@
     if ( fieldname.isEmpty() || fieldname == mGeometryColumn || fieldname == mPrimaryKey )
       continue;
-    sql += ", \"";
-    sql += fieldname;
-    sql += "\"";
-    values += ", ?";
+    values += ",?";
   sql += values;
@@ -965,9 +941,7 @@
+    QgsDebugMsg( QString( "SQLite error: %1\n\nSQL: %2" ).arg( sql ).arg( sqlite3_errmsg( sqliteHandle ) ) );
     return false;
@@ -1061,15 +1035,11 @@
   return true;
 abort:
-  QString msg = QString( "addFeatures SQL error:\n%1\n" ).arg( sql );
+  QgsDebugMsg( QString( "SQL error:\n%1\n%2" ).arg( sql ).arg( errMsg ? QString::fromUtf8( errMsg ) : "unknown cause" ) );
   if ( errMsg )
-    msg += errMsg;
-  else
   if ( toCommit )
@@ -1095,15 +1065,13 @@
   toCommit = true;
-  sql = QString( "DELETE FROM \"%1\" WHERE ROWID = ?" ).arg( mTableName );
+  sql = QString( "DELETE FROM %1 WHERE ROWID=?" ).arg( quotedIdentifier( mTableName ) );
   // SQLite prepared statement
     return false;
@@ -1144,15 +1112,11 @@
   return true;
 abort:
-  QString msg = QString( "deleteFeatures SQL error:\n%1\n" ).arg( sql );
   if ( errMsg )
-    msg += errMsg;
-  else
   if ( toCommit )
@@ -1204,15 +1168,11 @@
   return true;
 abort:
-  QString msg = QString( "addAttributes SQL error:\n%1\n" ).arg( sql );
   if ( errMsg )
-    msg += errMsg;
-  else
   if ( toCommit )
@@ -1245,7 +1205,7 @@
     if ( fid < 0 )
       continue;
-    QString sql = QString( "UPDATE \"%1\" SET " ).arg( mTableName );
+    QString sql = QString( "UPDATE %1 SET " ).arg( quotedIdentifier( mTableName ) );
     bool first = true;
     const QgsAttributeMap & attrs = iter.value();
@@ -1270,17 +1230,17 @@
       if ( type == QVariant::Invalid )
         // binding a NULL value
-        sql += QString( "\"%1\"=NULL" ).arg( fieldName );
+        sql += QString( "%1=NULL" ).arg( quotedIdentifier( fieldName ) );
       else if ( type == QVariant::Int || type == QVariant::Double )
         // binding a NUMERIC value
-        sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( siter->toString() );
+        sql += QString( "%1=%2" ).arg( quotedIdentifier( fieldName ) ).arg( siter->toString() );
       else
         // binding a TEXT value
-        sql += QString( "\"%1\"=%2" ).arg( fieldName ).arg( quotedValue( siter->toString() ) );
+        sql += QString( "%1=%2" ).arg( quotedIdentifier( fieldName ) ).arg( quotedValue( siter->toString() ) );
     sql += QString( " WHERE ROWID=%1" ).arg( fid );
@@ -1303,15 +1263,11 @@
   return true;
 abort:
-  QString msg = QString( "changeAttributeValues SQL error:\n%1\n" ).arg( sql );
   if ( errMsg )
-    msg += errMsg;
-  else
   if ( toCommit )
@@ -1338,16 +1294,16 @@
   toCommit = true;
   sql =
-    QString( "UPDATE \"%1\" SET \"%2\" = GeomFromWKB(?, %3) WHERE ROWID = ?" ).
-    arg( mTableName ).arg( mGeometryColumn ).arg( mSrid );
+    QString( "UPDATE %1 SET %2=GeomFromWKB(?, %3) WHERE ROWID = ?" )
+    .arg( mSrid );
     return false;
@@ -1393,15 +1349,11 @@
   return true;
 abort:
   if ( errMsg )
-    msg += errMsg;
-  else
   if ( toCommit )
@@ -1474,10 +1426,9 @@
   if ( sqlite3_open_v2( dbPath.toUtf8().constData(), &sqlite_handle, SQLITE_OPEN_READWRITE, NULL ) )
     // failure
-    QString errCause = sqlite3_errmsg( sqlite_handle );
-    QString msg = tr( "Failure while connecting to: %1\n\n%2" ).arg( dbPath ).arg( errCause );
+    QgsDebugMsg( QString( "Failure while connecting to: %1\n%2" )
+                 .arg( dbPath )
+                 .arg( QString::fromUtf8( sqlite3_errmsg( sqlite_handle ) ) ) );
     return NULL;
@@ -1485,10 +1436,7 @@
   if ( checkMetadata( sqlite_handle ) == false )
     // failure
-    QString errCause = tr( "invalid metadata tables" );
+    QgsDebugMsg( QString( "Failure while connecting to: %1\n\ninvalid metadata tables" ).arg( dbPath ) );
     sqlite3_close( sqlite_handle );
     return NULL;
@@ -1514,8 +1462,8 @@
   for ( i = handles.begin(); i != handles.end() && i.value() != handle; i++ )
-  assert( i.value() == handle );
-  assert( i.value()->ref > 0 );
+  Q_ASSERT( i.value() == handle );
+  Q_ASSERT( i.value()->ref > 0 );
   if ( --i.value()->ref == 0 )
@@ -1536,6 +1484,12 @@
+QString QgsSpatiaLiteProvider::quotedIdentifier( QString id ) const
 QString QgsSpatiaLiteProvider::quotedValue( QString value ) const
   if ( value.isNull() )
@@ -1563,16 +1517,24 @@
   QString sql = QString( "SELECT read_only FROM geometry_columns "
                          "LEFT JOIN geometry_columns_auth "
                          "USING (f_table_name, f_geometry_column) "
-                         "WHERE f_table_name=%1 and f_geometry_column=%2" ).arg( quotedValue( mTableName ) ).
-                arg( quotedValue( mGeometryColumn ) );
+                         "WHERE f_table_name=%1 and f_geometry_column=%2" )
+                .arg( quotedValue( mTableName ) )
+                .arg( quotedValue( mGeometryColumn ) );
   ret = sqlite3_get_table( sqliteHandle, sql.toUtf8().constData(), &results, &rows, &columns, &errMsg );
   if ( ret != SQLITE_OK )
-    goto error;
-  if ( rows < 1 )
-  else
+    if ( errMsg && strcmp( errMsg, "no such table: geometry_columns_auth" ) == 0 )
+      sqlite3_free( errMsg );
+      sql = QString( "SELECT 0 FROM geometry_columns WHERE f_table_name=%1 and f_geometry_column=%2" )
+      ret = sqlite3_get_table( sqliteHandle, sql.toUtf8().constData(), &results, &rows, &columns, &errMsg );
+  if ( ret == SQLITE_OK && rows == 1 )
     mTableBased = true;
     mReadOnly = false;
@@ -1585,6 +1547,12 @@
     count++;
+  if ( errMsg )
+    QgsDebugMsg( QString( "sqlite error %1 [%2]" ).arg( sql ).arg( errMsg ) );
+    errMsg = 0;
   sqlite3_free_table( results );
 // checking if this one is a View-based layer
@@ -1593,16 +1561,18 @@
-  if ( ret != SQLITE_OK )
-    goto error;
-  if ( rows < 1 )
-  else
     mViewBased = true;
     mReadOnly = true;
     count++;
+  if ( errMsg )
+    errMsg = 0;
 // checking if this one is a VirtualShapefile-based layer
@@ -1611,34 +1581,22 @@
-    goto error;
-  if ( rows < 1 )
-  else
     mVShapeBased = true;
     mReadOnly = true;
     count++;
-  sqlite3_free_table( results );
-// cheching for validity
-  if ( count != 1 )
-    return false;
-  return true;
-error:
-  // unexpected error
-  if ( errMsg != NULL )
+  if ( errMsg )
-    QString errCause = errMsg;
-    QString msg = QString( "checkLayerType SQL error: %1\n\n%2" ).arg( sql ).arg( errCause );
+    errMsg = 0;
-  return false;
+  sqlite3_free_table( results );
+// checking for validity
+  return count == 1;
 bool QgsSpatiaLiteProvider::getGeometryDetails()
@@ -1729,9 +1687,7 @@
   // unexpected error
-    QString msg = QString( "getTableGeometryDetails SQL error: %1\n\n%2" ).arg( sql ).arg( errCause );
+    QgsDebugMsg( QString( "SQL error: %1\n\n%2" ).arg( sql ).arg( errMsg ? QString::fromUtf8( errMsg ) : "unknown cause" ) );
   return false;
@@ -1814,9 +1770,7 @@
   // unexpected error
-    QString msg = QString( "getViewGeometryDetails SQL error: %1\n\n%2" ).arg( sql ).arg( errCause );
   return false;
@@ -1886,9 +1840,7 @@
   // unexpected error
-    QString msg = QString( "getVShapeGeometryDetails SQL error: %1\n\n%2" ).arg( sql ).arg( errCause );
   return false;
@@ -1925,9 +1877,7 @@
   // unexpected error
-    QString msg = QString( "getSridDetails SQL error: %1\n\n%2" ).arg( sql ).arg( errCause );
   return false;
@@ -1976,9 +1926,7 @@
   // unexpected error
-    QString error = "getTableSummary() SQL error: ";
-    error = errMsg;
   return false;
@@ -1990,7 +1938,7 @@
   if ( it == attributeFields.constEnd() )
-    QgsLogger::critical( "Field " + QString::number( index ) + " not found." );
+    QgsDebugMsg( QString( "Field %1 not found." ).arg( index ) );
   return it.value();
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h	2010-04-05 17:16:25 UTC (rev 13250)
@@ -356,6 +356,7 @@
     //void sqliteOpen();
     void closeDb();
+    QString quotedIdentifier( QString id ) const;
     QString quotedValue( QString value ) const;
     bool checkLayerType();
     bool getGeometryDetails();
Modified: trunk/qgis/src/ui/qgsnewspatialitelayerdialogbase.ui
--- trunk/qgis/src/ui/qgsnewspatialitelayerdialogbase.ui	2010-04-05 14:14:45 UTC (rev 13249)
+++ trunk/qgis/src/ui/qgsnewspatialitelayerdialogbase.ui	2010-04-05 17:16:25 UTC (rev 13250)
@@ -403,7 +403,7 @@
       <enum>Qt::Horizontal</enum>
      </property>
      <property name="standardButtons">
-      <set>QDialogButtonBox::Apply|QDialogButtonBox::Close|QDialogButtonBox::Help</set>
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
More information about the QGIS-commit mailing list
