[QGIS Commit] r13253 - in trunk/qgis/src: gui ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 5 13:20:30 EDT 2010
Author: jef
Date: 2010-04-05 13:20:30 -0400 (Mon, 05 Apr 2010)
New Revision: 13253
   trunk/qgis/src/gui/qgsprojectionselector.cpp
   trunk/qgis/src/gui/qgsprojectionselector.h
   trunk/qgis/src/ui/qgsprojectionselectorbase.ui
use list instead of buttons for popular/recent projections
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp	2010-04-05 17:19:07 UTC (rev 13252)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp	2010-04-05 17:20:30 UTC (rev 13253)
@@ -34,7 +34,6 @@
 const int NAME_COLUMN = 0;
 const int AUTHID_COLUMN = 1;
 const int QGIS_CRS_ID_COLUMN = 2;
-const int POPULAR_CRSES = 3;
 QgsProjectionSelector::QgsProjectionSelector( QWidget* parent, const char * name, Qt::WFlags fl )
     : QWidget( parent, fl )
@@ -47,7 +46,6 @@
   setupUi( this );
   connect( lstCoordinateSystems, SIGNAL( currentItemChanged( QTreeWidgetItem*, QTreeWidgetItem* ) ),
            this, SLOT( coordinateSystemSelected( QTreeWidgetItem* ) ) );
-  connect( leSearch, SIGNAL( returnPressed() ), pbnFind, SLOT( animateClick() ) );
   // Get the full path name to the sqlite3 spatial reference database.
   mSrsDatabaseFileName = QgsApplication::srsDbFilePath();
@@ -55,13 +53,17 @@
   lstCoordinateSystems->header()->resizeSection( QGIS_CRS_ID_COLUMN, 0 );
   lstCoordinateSystems->header()->setResizeMode( QGIS_CRS_ID_COLUMN, QHeaderView::Fixed );
+  lstRecent->header()->setResizeMode( AUTHID_COLUMN, QHeaderView::Stretch );
+  lstRecent->header()->resizeSection( QGIS_CRS_ID_COLUMN, 0 );
+  lstRecent->header()->setResizeMode( QGIS_CRS_ID_COLUMN, QHeaderView::Fixed );
   cbxAuthority->addItem( tr( "All" ) );
   cbxAuthority->addItems( authorities() );
   // Read settings from persistent storage
   QSettings settings;
   mRecentProjections = settings.value( "/UI/recentProjections" ).toStringList();
-  /*** The reading (above) of internal id from persistent storage should be removed sometims in the future */
+  /*** The reading (above) of internal id from persistent storage should be removed sometime in the future */
   /*** This is kept now for backwards compatibility */
   QStringList projectionsEpsg  = settings.value( "/UI/recentProjectionsEpsg" ).toStringList();
@@ -135,10 +137,13 @@
 void QgsProjectionSelector::resizeEvent( QResizeEvent * theEvent )
   lstCoordinateSystems->header()->resizeSection( NAME_COLUMN, theEvent->size().width() - 240 );
   lstCoordinateSystems->header()->resizeSection( AUTHID_COLUMN, 240 );
+  lstRecent->header()->resizeSection( NAME_COLUMN, theEvent->size().width() - 240 );
+  lstRecent->header()->resizeSection( AUTHID_COLUMN, 240 );
 void QgsProjectionSelector::showEvent( QShowEvent * theEvent )
@@ -171,44 +176,9 @@
     applyAuthIDSelection();
-  // Update buttons
-  pbnPopular1->setDisabled( true );
-  pbnPopular2->setDisabled( true );
-  pbnPopular3->setDisabled( true );
-  pbnPopular4->setDisabled( true );
-  pbnPopular1->hide();
-  pbnPopular2->hide();
-  pbnPopular3->hide();
-  pbnPopular4->hide();
+  for ( int i = mRecentProjections.size() - 1; i >= 0; i-- )
+    insertRecent( mRecentProjections.at( i ).toLong() );
-  if ( mRecentProjections.size() > 0 )
-    pbnPopular1->setText( getCrsIdName( mRecentProjections.at( 0 ).toLong() ) );
-    pbnPopular1->setDisabled( false );
-    pbnPopular1->show();
-  if ( mRecentProjections.size() > 1 )
-    pbnPopular2->setText( getCrsIdName( mRecentProjections.at( 1 ).toLong() ) );
-    pbnPopular2->setDisabled( false );
-    pbnPopular2->show();
-  if ( mRecentProjections.size() > 2 )
-    pbnPopular3->setText( getCrsIdName( mRecentProjections.at( 2 ).toLong() ) );
-    pbnPopular3->setDisabled( false );
-    pbnPopular3->show();
-  if ( mRecentProjections.size() > 3 )
-    pbnPopular4->setText( getCrsIdName( mRecentProjections.at( 3 ).toLong() ) );
-    pbnPopular4->setDisabled( false );
-    pbnPopular4->show();
   // Pass up the inheritance hierarchy
   QWidget::showEvent( theEvent );
@@ -347,26 +317,20 @@
-QString QgsProjectionSelector::getCrsIdName( long theCrsId )
+void QgsProjectionSelector::insertRecent( long theCrsId )
-  QString retvalue( "" );
-  if ( mProjListDone && mUserProjListDone )
-    QString myCRSIDString = QString::number( theCrsId );
+  if ( !mProjListDone || !mUserProjListDone )
+    return;
-    QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems( myCRSIDString, Qt::MatchExactly | Qt::MatchRecursive, QGIS_CRS_ID_COLUMN );
+  QList<QTreeWidgetItem*> nodes = lstCoordinateSystems->findItems( QString::number( theCrsId ), Qt::MatchExactly | Qt::MatchRecursive, QGIS_CRS_ID_COLUMN );
-    if ( nodes.count() > 0 )
-      retvalue = nodes.first()->text( NAME_COLUMN );
-      if ( nodes.first()->text( AUTHID_COLUMN ) != "" )
-        retvalue += " " + nodes.first()->text( AUTHID_COLUMN );
-  return retvalue;
+  if ( nodes.count() == 0 )
+    return;
+  lstRecent->insertTopLevelItem( 0, new QTreeWidgetItem( lstRecent, QStringList()
+                                 << nodes.first()->text( NAME_COLUMN )
+                                 << nodes.first()->text( AUTHID_COLUMN )
+                                 << nodes.first()->text( QGIS_CRS_ID_COLUMN ) ) );
 void QgsProjectionSelector::applyAuthIDSelection()
@@ -889,6 +853,8 @@
     QString myProjString = selectedProj4String();
     lstCoordinateSystems->scrollToItem( theItem );
     teProjection->setText( myProjString );
+    lstRecent->clearSelection();
   else
@@ -920,26 +886,11 @@
     hideDeprecated( lstCoordinateSystems->topLevelItem( i ) );
-void QgsProjectionSelector::on_pbnPopular1_clicked()
+void QgsProjectionSelector::on_lstRecent_currentItemChanged( QTreeWidgetItem *current, QTreeWidgetItem *previous )
-  setSelectedCrsId( mRecentProjections.at( 0 ).toLong() );
+  setSelectedCrsId( current->text( QGIS_CRS_ID_COLUMN ).toLong() );
-void QgsProjectionSelector::on_pbnPopular2_clicked()
-  setSelectedCrsId( mRecentProjections.at( 1 ).toLong() );
-void QgsProjectionSelector::on_pbnPopular3_clicked()
-  setSelectedCrsId( mRecentProjections.at( 2 ).toLong() );
-void QgsProjectionSelector::on_pbnPopular4_clicked()
-  setSelectedCrsId( mRecentProjections.at( 3 ).toLong() );
 void QgsProjectionSelector::on_pbnFind_clicked()
   QgsDebugMsg( "pbnFind..." );
Modified: trunk/qgis/src/gui/qgsprojectionselector.h
--- trunk/qgis/src/gui/qgsprojectionselector.h	2010-04-05 17:19:07 UTC (rev 13252)
+++ trunk/qgis/src/gui/qgsprojectionselector.h	2010-04-05 17:20:30 UTC (rev 13253)
@@ -110,13 +110,9 @@
     void setOgcWmsCrsFilter( QSet<QString> crsFilter );
     void on_pbnFind_clicked();
+    void on_lstRecent_currentItemChanged( QTreeWidgetItem *, QTreeWidgetItem * );
     void on_cbxHideDeprecated_stateChanged();
-    void on_pbnPopular1_clicked();
-    void on_pbnPopular2_clicked();
-    void on_pbnPopular3_clicked();
-    void on_pbnPopular4_clicked();
   protected:
     /** Used to ensure the projection list view is actually populated */
     void showEvent( QShowEvent * theEvent );
@@ -201,8 +197,8 @@
     long getLargestCRSIDMatch( QString theSql );
-    //! Returns name from CRS Id
-    QString getCrsIdName( long theCrsId );
+    //! add recently used CRS
+    void insertRecent( long theCrsId );
     //! Has the Projection List been populated?
     bool mProjListDone;
Modified: trunk/qgis/src/ui/qgsprojectionselectorbase.ui
--- trunk/qgis/src/ui/qgsprojectionselectorbase.ui	2010-04-05 17:19:07 UTC (rev 13252)
+++ trunk/qgis/src/ui/qgsprojectionselectorbase.ui	2010-04-05 17:20:30 UTC (rev 13253)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>374</width>
-    <height>464</height>
+    <width>590</width>
+    <height>358</height>
    </rect>
   </property>
   <property name="sizePolicy">
@@ -65,18 +65,6 @@
      </property>
     </widget>
    </item>
-   <item row="3" column="0">
-    <widget class="QPushButton" name="pbnPopular1"/>
-   </item>
-   <item row="4" column="0">
-    <widget class="QPushButton" name="pbnPopular2"/>
-   </item>
-   <item row="5" column="0">
-    <widget class="QPushButton" name="pbnPopular3"/>
-   </item>
-   <item row="6" column="0">
-    <widget class="QPushButton" name="pbnPopular4"/>
-   </item>
    <item row="0" column="0">
     <widget class="QTreeWidget" name="lstCoordinateSystems">
      <property name="alternatingRowColors">
@@ -116,67 +104,144 @@
      <property name="title">
       <string>Search</string>
      </property>
-     <layout class="QGridLayout">
-      <item row="1" column="1">
-       <widget class="QComboBox" name="cbxMode">
+     <layout class="QVBoxLayout" name="verticalLayout">
+      <item>
+       <layout class="QHBoxLayout" name="horizontalLayout_2">
         <item>
-         <property name="text">
-          <string>ID</string>
-         </property>
+         <widget class="QLabel" name="label">
+          <property name="text">
+           <string>Authority</string>
+          </property>
+         </widget>
         </item>
         <item>
-          <string>Name</string>
-         </property>
+         <widget class="QComboBox" name="cbxAuthority"/>
         </item>
-       </widget>
+        <item>
+         <widget class="QLabel" name="label_2">
+           <string>Search for</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QComboBox" name="cbxMode">
+          <item>
+            <string>ID</string>
+           </property>
+          </item>
+          <item>
+            <string>Name</string>
+           </property>
+          </item>
+         </widget>
+        </item>
+        <item>
+         <spacer name="horizontalSpacer">
+          <property name="orientation">
+           <enum>Qt::Horizontal</enum>
+          </property>
+          <property name="sizeHint" stdset="0">
+           <size>
+            <width>40</width>
+            <height>20</height>
+           </size>
+          </property>
+         </spacer>
+        </item>
+        <item>
+         <widget class="QCheckBox" name="cbxHideDeprecated">
+           <string>Hide deprecated CRSs</string>
+          </property>
+         </widget>
+        </item>
+       </layout>
       </item>
-      <item row="0" column="0">
-       <widget class="QLabel" name="label">
-         <string>Authority</string>
-        </property>
-       </widget>
+      <item>
+       <layout class="QHBoxLayout" name="horizontalLayout">
+        <item>
+         <widget class="QLineEdit" name="leSearch"/>
+        </item>
+        <item>
+         <widget class="QPushButton" name="pbnFind">
+          <property name="maximumSize">
+           <size>
+            <width>100</width>
+            <height>16777215</height>
+           </size>
+          </property>
+           <string>Find</string>
+          </property>
+          <property name="default">
+           <bool>true</bool>
+          </property>
+         </widget>
+        </item>
+       </layout>
       </item>
-      <item row="0" column="1">
-       <widget class="QComboBox" name="cbxAuthority"/>
-      </item>
-      <item row="1" column="0">
-       <widget class="QLabel" name="label_2">
-         <string>Search for</string>
-        </property>
-       </widget>
-      </item>
-      <item row="0" column="2">
-       <widget class="QLineEdit" name="leSearch"/>
-      </item>
-      <item row="0" column="3">
-       <widget class="QPushButton" name="pbnFind">
-        <property name="maximumSize">
-         <size>
-          <width>100</width>
-          <height>16777215</height>
-         </size>
-        </property>
-         <string>Find</string>
-        </property>
-        <property name="default">
-         <bool>true</bool>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="2" colspan="2">
-       <widget class="QCheckBox" name="cbxHideDeprecated">
-         <string>Hide deprecated CRSs</string>
-        </property>
-       </widget>
-      </item>
      </layout>
     </widget>
    </item>
+   <item row="3" column="0">
+    <widget class="QLabel" name="label_3">
+      <string>Recently used coordinate references systems</string>
+     </property>
+    </widget>
+   </item>
+   <item row="4" column="0">
+    <widget class="QTreeWidget" name="lstRecent">
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+     <property name="minimumSize">
+      <size>
+       <width>0</width>
+       <height>105</height>
+      </size>
+     </property>
+      <size>
+       <width>16777215</width>
+      </size>
+     </property>
+     <property name="alternatingRowColors">
+      <bool>true</bool>
+     </property>
+     <property name="rootIsDecorated">
+      <bool>false</bool>
+     </property>
+     <property name="uniformRowHeights">
+      <bool>true</bool>
+     </property>
+     <property name="columnCount">
+      <number>3</number>
+     </property>
+     <column>
+       <string>Coordinate Reference System</string>
+      </property>
+     </column>
+     <column>
+       <string>Authority ID</string>
+      </property>
+     </column>
+     <column>
+      </property>
+     </column>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
More information about the QGIS-commit mailing list
