[QGIS Commit] r13257 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 5 21:38:37 EDT 2010
Author: jef
Date: 2010-04-05 21:38:36 -0400 (Mon, 05 Apr 2010)
New Revision: 13257
   trunk/qgis/src/core/qgsvectorlayer.cpp
fix crash when added features were deleted
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2010-04-05 22:42:59 UTC (rev 13256)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2010-04-06 01:38:36 UTC (rev 13257)
@@ -70,7 +70,6 @@
 #include "qgsvectordataprovider.h"
 #include "qgsvectorlayerundocommand.h"
 #include "qgsvectoroverlay.h"
-#include "qgslogger.h"
 #include "qgsmaplayerregistry.h"
 #include "qgsclipper.h"
 #include "qgsproject.h"
@@ -365,7 +364,7 @@
     catch ( QgsCsException &e )
       Q_UNUSED( e );
-      QgsLogger::critical( "Error projecting label locations, caught in " + QString( __FILE__ ) + ", line " + QString( __LINE__ ) );
+      QgsDebugMsg( "Error projecting label locations" );
     if ( mRendererV2 )
@@ -373,9 +372,7 @@
       mRendererV2->stopRender( rendererContext );
-#ifdef QGISDEBUG
-    QgsLogger::debug( "Total features processed", featureCount, 1, __FILE__, __FUNCTION__, __LINE__ );
-#endif
+    QgsDebugMsg( QString( "Total features processed %1" ).arg( featureCount ) );
     // XXX Something in our draw event is triggering an additional draw event when resizing [TE 01/26/06]
     // XXX Calling this will begin processing the next draw event causing image havoc and recursion crashes.
@@ -768,10 +765,8 @@
     catch ( const QgsCsException &cse )
-      QString msg( "Failed to transform a point while drawing a feature of type '"
-                   + fet.typeName() + "'. Ignoring this feature." );
-      msg += cse.what();
-      QgsLogger::warning( msg );
+      QgsDebugMsg( QString( "Failed to transform a point while drawing a feature of type '%1'. Ignoring this feature. %2" )
+                   .arg( fet.typeName() ).arg( cse.what() ) );
 #ifndef Q_WS_MAC
     ++featureCount;
@@ -898,10 +893,8 @@
 #ifndef Q_WS_MAC
         ++featureCount;
@@ -1090,16 +1083,14 @@
     catch ( QgsCsException &cse )
-                   + fet.typeName() + "'. Rendering stopped." );
+      QgsDebugMsg( QString( "Failed to transform a point while drawing a feature of type '%1'. Rendering stopped. %2" )
       return false;
   else
-    QgsLogger::warning( "QgsRenderer is null in QgsVectorLayer::draw()" );
+    QgsDebugMsg( "QgsRenderer is null" );
   if ( mEditable )
@@ -1392,18 +1383,18 @@
   if ( !mDataProvider )
-    QgsLogger::warning( " QgsVectorLayer::featureCount() invoked with null mDataProvider" );
+    QgsDebugMsg( "invoked with null mDataProvider" );
     return 0;
   return mDataProvider->featureCount();
-} // QgsVectorLayer::featureCount
 long QgsVectorLayer::updateFeatureCount() const
-    QgsLogger::warning( " QgsVectorLayer::updateFeatureCount() invoked with null mDataProvider" );
     return 0;
   return mDataProvider->updateFeatureCount();
@@ -1414,7 +1405,7 @@
   mLayerExtent.setMinimal();
-    QgsLogger::warning( " QgsVectorLayer::updateExtents() invoked with null mDataProvider" );
   if ( mDeletedFeatureIds.isEmpty() && mChangedGeometries.isEmpty() )
@@ -1461,7 +1452,7 @@
   if ( ! mDataProvider )
-    QgsLogger::warning( " QgsVectorLayer::subsetString() invoked with null mDataProvider" );
     return 0;
   return mDataProvider->subsetString();
@@ -1471,7 +1462,7 @@
-    QgsLogger::warning( " QgsVectorLayer::setSubsetString() invoked with null mDataProvider" );
     return false;
@@ -1611,7 +1602,7 @@
             if ( !found )
-              QgsLogger::warning( QString( "No attributes for the added feature %1 found" ).arg( f.id() ) );
+              QgsDebugMsg( QString( "No attributes for the added feature %1 found" ).arg( f.id() ) );
           else
@@ -1712,7 +1703,7 @@
         if ( !found )
       else
@@ -3379,23 +3370,24 @@
     if ( mAddedFeatures.size() > 0 )
-      for ( QgsFeatureList::iterator iter = mAddedFeatures.begin(); iter != mAddedFeatures.end(); ++iter )
+      for ( int i = 0; i < mAddedFeatures.size(); i++ )
-        if ( mDeletedFeatureIds.contains( iter->id() ) )
+        QgsFeature &f = mAddedFeatures[i];
+        if ( mDeletedFeatureIds.contains( f.id() ) )
-          mDeletedFeatureIds.remove( iter->id() );
+          mDeletedFeatureIds.remove( f.id() );
-          if ( mChangedGeometries.contains( iter->id() ) )
-            mChangedGeometries.remove( iter->id() );
+          if ( mChangedGeometries.contains( f.id() ) )
+            mChangedGeometries.remove( f.id() );
-          mAddedFeatures.erase( iter );
+          mAddedFeatures.removeAt( i-- );
           continue;
-          iter->setGeometry( mChangedGeometries.take( iter->id() ) );
+          f.setGeometry( mChangedGeometries.take( f.id() ) );
More information about the QGIS-commit mailing list
