[QGIS Commit] r13259 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 5 21:40:18 EDT 2010
Author: jef
Date: 2010-04-05 21:40:18 -0400 (Mon, 05 Apr 2010)
New Revision: 13259
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
ogr provider: update layer extent after feature deletion and debugging improvements
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2010-04-06 01:39:06 UTC (rev 13258)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2010-04-06 01:40:18 UTC (rev 13259)
@@ -51,6 +51,26 @@
   + GDALVersionInfo( "RELEASE_NAME" )
+class QgsCPLErrorHandler
+    static void CPL_STDCALL showError( CPLErr errClass, int errNo, const char *msg )
+      QgsDebugMsg( QString( "OGR[%1] error %2: %3" ).arg( errClass ).arg( errNo ).arg( msg ) );
+  public:
+    QgsCPLErrorHandler()
+      CPLPushErrorHandler( showError );
+    ~QgsCPLErrorHandler()
+      CPLPopErrorHandler();
 QgsOgrProvider::QgsOgrProvider( QString const & uri )
     : QgsVectorDataProvider( uri ),
     ogrDataSource( 0 ),
@@ -60,6 +80,8 @@
     ogrDriver( 0 ),
     featuresCounted( -1 )
+  QgsCPLErrorHandler handler;
   QgsApplication::registerOgrDrivers();
   // set the selection rectangle pointer to 0
@@ -122,9 +144,7 @@
   QgsDebugMsg( "mLayerName: " + mLayerName );
   QgsDebugMsg( "mSubsetString: " + mSubsetString );
   CPLSetConfigOption( "OGR_ORGANIZE_POLYGONS", "ONLY_CCW" );  // "SKIP" returns MULTIPOLYGONs for multiringed POLYGONs
-  CPLPushErrorHandler( CPLQuietErrorHandler );
   ogrDataSource = OGROpen( QFile::encodeName( mFilePath ).constData(), TRUE, &ogrDriver );
-  CPLPopErrorHandler();
   if ( ogrDataSource == NULL )
@@ -196,6 +216,8 @@
 bool QgsOgrProvider::setSubsetString( QString theSQL )
   if ( theSQL == mSubsetString && featuresCounted >= 0 )
     return true;
@@ -208,6 +230,7 @@
     QString sql = QString( "SELECT * FROM %1 WHERE %2" )
                   .arg( quotedIdentifier( OGR_FD_GetName( OGR_L_GetLayerDefn( ogrOrigLayer ) ) ) )
                   .arg( mSubsetString );
+    QgsDebugMsg( QString( "SQL: %1" ).arg( sql ) );
     ogrLayer = OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).constData(), NULL, NULL );
     if ( !ogrLayer )
@@ -937,9 +960,12 @@
 bool QgsOgrProvider::createSpatialIndex()
   QString layerName = OGR_FD_GetName( OGR_L_GetLayerDefn( ogrOrigLayer ) );
   QString sql = QString( "CREATE SPATIAL INDEX ON %1" ).arg( quotedIdentifier( layerName ) );  // quote the layer name so spaces are handled
   OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), OGR_L_GetSpatialFilter( ogrOrigLayer ), "" );
   QFileInfo fi( mFilePath );     // to get the base name
@@ -950,6 +976,8 @@
 bool QgsOgrProvider::deleteFeatures( const QgsFeatureIds & id )
   bool returnvalue = true;
   for ( QgsFeatureIds::const_iterator it = id.begin(); it != id.end(); ++it )
@@ -966,17 +994,19 @@
-  QFileInfo fi( dataSourceUri() );     // to get the base name
   QString sql = QString( "REPACK %1" ).arg( layerName );   // don't quote the layer name as it works with spaces in the name and won't work if the name is quoted
   OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, NULL );
   featuresCounted = OGR_L_GetFeatureCount( ogrLayer, TRUE ); //new feature count
+  OGR_L_GetExtent( ogrOrigLayer, ( OGREnvelope * ) extent_, TRUE );
   return returnvalue;
 bool QgsOgrProvider::deleteFeature( int id )
-  OGRErr res = OGR_L_DeleteFeature( ogrLayer, id );
-  return ( res == OGRERR_NONE );
+  return OGR_L_DeleteFeature( ogrLayer, id ) == OGRERR_NONE;
 int QgsOgrProvider::capabilities() const
More information about the QGIS-commit mailing list
