[QGIS Commit] r13261 - trunk/qgis/src/core
svn_qgis at osgeo.org
Tue Apr 6 05:52:39 EDT 2010
Author: jef
Date: 2010-04-06 05:52:38 -0400 (Tue, 06 Apr 2010)
New Revision: 13261
trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
trunk/qgis/src/core/qgscoordinatereferencesystem.h
followup r13227
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2010-04-06 09:14:23 UTC (rev 13260)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2010-04-06 09:52:38 UTC (rev 13261)
@@ -208,7 +208,7 @@
is_geo integer NOT NULL);
- QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name||':'||auth_id,is_geo from tbl_srs where " + expression + "='" + value + "'";
+ QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name||':'||auth_id,is_geo from tbl_srs where " + expression + "=" + quotedValue( value );
myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.toUtf8().length(), &myPreparedStatement, &myTail );
// XXX Need to free memory from the error msg if one is set
if ( myResult == SQLITE_OK && sqlite3_step( myPreparedStatement ) == SQLITE_ROW )
@@ -343,14 +343,14 @@
// *** Matching on descriptions feels iffy. Different projs can have same description. Homann ***
// if ( !mDescription.trimmed().isEmpty() )
- // myRecord = getRecord( "select * from tbl_srs where description='" + mDescription.trimmed() + "'" );
+ // myRecord = getRecord( "select * from tbl_srs where description=" + quotedValue( mDescription.trimmed() ) );
* - if the above does not match perform a whole text search on proj4 string (if not null)
// QgsDebugMsg( "wholetext match on name failed, trying proj4string match" );
- myRecord = getRecord( "select * from tbl_srs where parameters='" + theProj4String.trimmed() + "'" );
+ myRecord = getRecord( "select * from tbl_srs where parameters=" + quotedValue( theProj4String.trimmed() ) );
if ( !myRecord.empty() )
mySrsId = myRecord["srs_id"].toLong();
@@ -394,7 +394,7 @@
myStart2 = myLat2RegExp.indexIn( theProj4String, myStart2 );
theProj4StringModified.replace( myStart2 + LAT_PREFIX_LEN, myLength2 - LAT_PREFIX_LEN, lat1Str );
QgsDebugMsg( "trying proj4string match with swapped lat_1,lat_2" );
- myRecord = getRecord( "select * from tbl_srs where parameters='" + theProj4StringModified.trimmed() + "'" );
+ myRecord = getRecord( "select * from tbl_srs where parameters=" + quotedValue( theProj4StringModified.trimmed() ) );
// Success! We have found the proj string by swapping the lat_1 and lat_2
@@ -435,39 +435,39 @@
if ( mIsValidFlag )
// but the proj.4 parsed string might already be in our database
- myRecord = getRecord( "select * from tbl_srs where parameters='" + toProj4() + "'" );
+ myRecord = getRecord( "select * from tbl_srs where parameters=" + quotedValue( toProj4() ) );
if ( myRecord.empty() )
- // It's not, so try to add it
- QgsDebugMsg( "Projection appears to be valid. Save to database!" );
- mIsValidFlag = saveAsUserCRS();
+ // It's not, so try to add it
+ QgsDebugMsg( "Projection appears to be valid. Save to database!" );
+ mIsValidFlag = saveAsUserCRS();
- if ( mIsValidFlag )
- // but validate that it's there afterwards
+ if ( mIsValidFlag )
+ // but validate that it's there afterwards
- // take the srid from the record
- mySrsId = myRecord["srs_id"].toLong();
- QgsDebugMsg( "proj4string match search for srsid returned srsid: " + QString::number( mySrsId ) );
- if ( mySrsId > 0 )
- createFromSrsId( mySrsId );
- else
- QgsDebugMsg( QString( "invalid srid %1 found" ).arg( mySrsId ) );
- mIsValidFlag = false;
+ // take the srid from the record
+ mySrsId = myRecord["srs_id"].toLong();
+ QgsDebugMsg( "proj4string match search for srsid returned srsid: " + QString::number( mySrsId ) );
+ if ( mySrsId > 0 )
+ createFromSrsId( mySrsId );
+ else
+ QgsDebugMsg( QString( "invalid srid %1 found" ).arg( mySrsId ) );
+ mIsValidFlag = false;
else
- QgsDebugMsg( "Couldn't find newly added proj string?" );
+ QgsDebugMsg( "Couldn't find newly added proj string?" );
@@ -802,8 +802,9 @@
int myResult;
// Set up the query to retrieve the projection information needed to populate the list
- QString mySql = QString( "select srs_id,parameters from tbl_srs where projection_acronym='" +
- mProjectionAcronym + "' and ellipsoid_acronym='" + mEllipsoidAcronym + "'" );
+ QString mySql = QString( "select srs_id,parameters from tbl_srs where projection_acronym=%1 and ellipsoid_acronym=%2" )
+ .arg( quotedValue( mProjectionAcronym ) )
+ .arg( quotedValue( mEllipsoidAcronym ) );
// Get the full path name to the sqlite3 spatial reference database.
QString myDatabaseFileName = QgsApplication::srsDbFilePath();
@@ -815,7 +816,7 @@
- // XXX Need to free memory from the error msg if one is set
+// XXX Need to free memory from the error msg if one is set
if ( myResult == SQLITE_OK )
@@ -854,7 +855,7 @@
@@ -1233,21 +1234,21 @@
if ( getRecordCount() == 0 )
mySql = "insert into tbl_srs (srs_id,description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ("
- + QString::number( USER_CRS_START_ID ) + ",'"
- + sqlSafeString( myName ) + "','"
- + projectionAcronym() + "','"
- + ellipsoidAcronym() + "','"
- + sqlSafeString( toProj4() )
+ + QString::number( USER_CRS_START_ID )
+ + "," + quotedValue( myName )
+ + "," + quotedValue( projectionAcronym() )
+ + "," + quotedValue( ellipsoidAcronym() )
+ + "," + quotedValue( toProj4() )
+ "',0)"; // <-- is_geo shamelessly hard coded for now
else
- mySql = "insert into tbl_srs (description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ('"
- + "',0)"; // <-- is_geo shamelessly hard coded for now
+ mySql = "insert into tbl_srs (description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ("
+ + quotedValue( myName )
+ + ",0)"; // <-- is_geo shamelessly hard coded for now
sqlite3 *myDatabase;
const char *myTail;
@@ -1305,34 +1306,8 @@
return myRecordCount;
-const QString QgsCoordinateReferenceSystem::sqlSafeString( const QString theSQL )
+QString QgsCoordinateReferenceSystem::quotedValue( QString value )
- QString myRetval;
- QChar *it = ( QChar * )theSQL.unicode();
- for ( int i = 0; i < theSQL.length(); i++ )
- if ( *it == '\"' )
- myRetval += "\\\"";
- else if ( *it == '\'' )
- myRetval += "\\'";
- else if ( *it == '\\' )
- myRetval += "\\\\";
- else if ( *it == '%' )
- myRetval += "\\%";
- else
- myRetval += *it;
- it++;
- return myRetval;
+ value.replace( "'", "''" );
+ return value.prepend( "'" ).append( "'" );
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.h
--- trunk/qgis/src/core/qgscoordinatereferencesystem.h 2010-04-06 09:14:23 UTC (rev 13260)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.h 2010-04-06 09:52:38 UTC (rev 13261)
@@ -405,8 +405,8 @@
//! Helper for getting number of user CRS already in db
long getRecordCount();
- //! Helper for sql-safin strings
- const QString sqlSafeString( const QString theSQL );
+ //! Helper for sql-safe value quoting
+ QString quotedValue( QString value );
void *mCRS;
