[QGIS Commit] r13280 - trunk/qgis/doc
svn_qgis at osgeo.org
Thu Apr 8 01:20:37 EDT 2010
Author: gsherman
Date: 2010-04-08 01:20:36 -0400 (Thu, 08 Apr 2010)
New Revision: 13280
trunk/qgis/doc/INSTALL.t2t
A few changes to the Mac build section from jctull
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t 2010-04-08 02:43:31 UTC (rev 13279)
+++ trunk/qgis/doc/INSTALL.t2t 2010-04-08 05:20:36 UTC (rev 13280)
@@ -649,8 +649,22 @@
sudo make install
-Make sure to use the qwt install path from the Qwt build above.
+Make sure to use the qwt install path from the Qwt build above.
+If you run into a problem with the configure script not finding qmake, you may need to edit configure.py and change this line:
+qmake = os.path.join(configuration.qt_dir, 'bin', 'qmake')
+to:
+qmake = os.path.join(configuration.qt_dir, 'usr', 'bin', 'qmake')
+Finally, if you run into problems with the library not being properly linked after you build qgis, you may need to fix that as follows and then rebuild qgis:
+sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
__Snow Leopard note__
If using Qt Carbon, you need to specify which architectures to build, otherwise
