[QGIS Commit] r13285 - trunk/qgis/doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Apr 8 09:47:53 EDT 2010
Author: kyngchaos
Date: 2010-04-08 09:47:52 -0400 (Thu, 08 Apr 2010)
New Revision: 13285
   trunk/qgis/doc/INSTALL.t2t
r13280 - restore part not dealing with PyQt
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2010-04-08 13:33:11 UTC (rev 13284)
+++ trunk/qgis/doc/INSTALL.t2t	2010-04-08 13:47:52 UTC (rev 13285)
@@ -651,6 +651,11 @@
 Make sure to use the qwt install path from the Qwt build above.
+Finally, if you run into problems with the library not being properly linked after you build qgis, you may need to fix that as follows and then rebuild qgis (this is not needed when bundling all Qt/PyQt related components, which is recommended, and default in the Xcode build):
+sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
 __Snow Leopard note__
 If using Qt Carbon, you need to specify which architectures to build, otherwise
More information about the QGIS-commit mailing list
