[QGIS Commit] r13300 - in trunk/qgis/src: app app/composer core ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Apr 11 11:02:09 EDT 2010
Author: jef
Date: 2010-04-11 11:02:09 -0400 (Sun, 11 Apr 2010)
New Revision: 13300
   trunk/qgis/src/app/composer/qgscomposermanager.cpp
   trunk/qgis/src/app/composer/qgscomposermanager.h
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/ui/qgscomposermanagerbase.ui
remove Qt 4.5 dependency and fix a warning
Modified: trunk/qgis/src/app/composer/qgscomposermanager.cpp
--- trunk/qgis/src/app/composer/qgscomposermanager.cpp	2010-04-11 14:12:20 UTC (rev 13299)
+++ trunk/qgis/src/app/composer/qgscomposermanager.cpp	2010-04-11 15:02:09 UTC (rev 13300)
@@ -24,10 +24,25 @@
 #include <QListWidgetItem>
 #include <QMessageBox>
-QgsComposerManager::QgsComposerManager( QgisApp* app, QWidget * parent, Qt::WindowFlags f ): QDialog( parent, f ), mQgisApp( app )
+QgsComposerManager::QgsComposerManager( QWidget * parent, Qt::WindowFlags f ): QDialog( parent, f )
+  QPushButton *pb;
   setupUi( this );
   connect( mButtonBox, SIGNAL( rejected() ), this, SLOT( close() ) );
+  pb = new QPushButton( tr( "&Show" ) );
+  mButtonBox->addButton( pb, QDialogButtonBox::ActionRole );
+  connect( pb, SIGNAL( clicked() ), this, SLOT( show_clicked() ) );
+  pb = new QPushButton( tr( "&Remove" ) );
+  connect( pb, SIGNAL( clicked() ), this, SLOT( remove_clicked() ) );
+  pb = new QPushButton( tr( "Re&name" ) );
+  connect( pb, SIGNAL( clicked() ), this, SLOT( rename_clicked() ) );
   initialize();
@@ -38,12 +53,7 @@
 void QgsComposerManager::initialize()
-  if ( !mQgisApp )
-    return;
-  QSet<QgsComposer*> composers = mQgisApp->printComposers();
+  QSet<QgsComposer*> composers = QgisApp::instance()->printComposers();
   QSet<QgsComposer*>::const_iterator it = composers.constBegin();
   for ( ; it != composers.constEnd(); ++it )
@@ -51,6 +61,18 @@
     item->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable );
     mItemComposerMap.insert( item, *it );
+  mTemplate->addItem( tr( "Empty composer" ) );
+  QMap<QString, QString> templateMap = defaultTemplates();
+  if ( templateMap.size() > 0 )
+    QMap<QString, QString>::const_iterator templateIt = templateMap.constBegin();
+    for ( ; templateIt != templateMap.constEnd(); ++templateIt )
+      mTemplate->addItem( templateIt.key(), templateIt.value() );
 QMap<QString, QString> QgsComposerManager::defaultTemplates() const
@@ -75,51 +97,18 @@
 void QgsComposerManager::on_mAddButton_clicked()
-  if ( !mQgisApp )
-    return;
-  QMap<QString, QString> templateMap = defaultTemplates();
-  QString composerTemplate;
   QgsComposer* newComposer = 0;
-  if ( templateMap.size() > 0 )
-    //show template dialog
-    QStringList templateNameList;
-    templateNameList.append( tr( "Empty composer" ) );
-    QMap<QString, QString>::const_iterator templateIt = templateMap.constBegin();
-    for ( ; templateIt != templateMap.constEnd(); ++templateIt )
-      templateNameList.append( templateIt.key() );
-    QInputDialog templateDialog;
-    templateDialog.setLabelText( tr( "Select a composer template" ) );
-    templateDialog.setComboBoxItems( templateNameList );
-    if ( templateDialog.exec() == QDialog::Rejected )
-      return;
-    QMap<QString, QString>::const_iterator selectedTemplate = templateMap.find( templateDialog.textValue() );
-    if ( selectedTemplate != templateMap.constEnd() )
-      composerTemplate = selectedTemplate.value();
-  newComposer = mQgisApp->createNewComposer();
+  newComposer = QgisApp::instance()->createNewComposer();
   if ( !newComposer )
     return;
-  if ( !composerTemplate.isEmpty() ) //create composer from template
+  if ( mTemplate->currentIndex() > 0 )
     QDomDocument templateDoc;
-    QFile templateFile( composerTemplate );
+    QFile templateFile( mTemplate->itemData( mTemplate->currentIndex() ).toString() );
     if ( templateFile.open( QIODevice::ReadOnly ) )
       if ( templateDoc.setContent( &templateFile, false ) )
@@ -134,13 +123,8 @@
   mItemComposerMap.insert( item, newComposer );
-void QgsComposerManager::on_mRemoveButton_clicked()
+void QgsComposerManager::remove_clicked()
-  if ( !mQgisApp )
-    return;
   QListWidgetItem* item = mComposerListWidget->currentItem();
   if ( !item )
@@ -157,7 +141,7 @@
   QMap<QListWidgetItem*, QgsComposer*>::iterator it = mItemComposerMap.find( item );
   if ( it != mItemComposerMap.end() )
-    mQgisApp->deleteComposer( it.value() );
+    QgisApp::instance()->deleteComposer( it.value() );
   mItemComposerMap.remove( item );
   mComposerListWidget->removeItemWidget( item );
@@ -165,13 +149,8 @@
   delete( mComposerListWidget->takeItem( mComposerListWidget->row( item ) ) );
-void QgsComposerManager::on_mShowPushButton_clicked()
+void QgsComposerManager::show_clicked()
-  if ( !mQgisApp )
-    return;
   if ( !item )
@@ -215,7 +194,7 @@
       return;
-    c = mQgisApp->createNewComposer();
+    c = QgisApp::instance()->createNewComposer();
     c->setTitle( it.key()->text() );
     if ( c )
@@ -236,7 +215,7 @@
 #endif //0
-void QgsComposerManager::on_mRenamePushButton_clicked()
+void QgsComposerManager::rename_clicked()
   if ( !item )
Modified: trunk/qgis/src/app/composer/qgscomposermanager.h
--- trunk/qgis/src/app/composer/qgscomposermanager.h	2010-04-11 14:12:20 UTC (rev 13299)
+++ trunk/qgis/src/app/composer/qgscomposermanager.h	2010-04-11 15:02:09 UTC (rev 13300)
@@ -19,7 +19,6 @@
 #include "ui_qgscomposermanagerbase.h"
-class QgisApp;
 class QListWidgetItem;
 class QgsComposer;
@@ -29,12 +28,11 @@
     Q_OBJECT
   public:
-    QgsComposerManager( QgisApp* app, QWidget * parent = 0, Qt::WindowFlags f = 0 );
+    QgsComposerManager( QWidget * parent = 0, Qt::WindowFlags f = 0 );
     ~QgsComposerManager();
   private:
-    QgisApp* mQgisApp;
     /**Stores the relation between items and composer pointers. A 0 pointer for the composer means that
       this composer needs to be created from a default template*/
     QMap<QListWidgetItem*, QgsComposer*> mItemComposerMap;
@@ -47,9 +45,9 @@
   private slots:
     void on_mAddButton_clicked();
-    void on_mRemoveButton_clicked();
-    void on_mShowPushButton_clicked();
-    void on_mRenamePushButton_clicked();
+    void remove_clicked();
+    void show_clicked();
+    void rename_clicked();
     void on_mComposerListWidget_itemChanged( QListWidgetItem * item );
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-04-11 14:12:20 UTC (rev 13299)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-04-11 15:02:09 UTC (rev 13300)
@@ -3561,7 +3561,7 @@
 void QgisApp::showComposerManager()
-  QgsComposerManager m( this, 0 );
+  QgsComposerManager m;
   m.exec();
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2010-04-11 14:12:20 UTC (rev 13299)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2010-04-11 15:02:09 UTC (rev 13300)
@@ -5528,7 +5528,7 @@
   double x, y;
-  for ( int i = 0; i < ( nCoords - 1 ); ++i )
+  for ( unsigned int i = 0; i < ( nCoords - 1 ); ++i )
     GEOSCoordSeq_getX( bBoxCoordSeq, i, &x );
     if ( x > 180 || x < -180 )
Modified: trunk/qgis/src/ui/qgscomposermanagerbase.ui
--- trunk/qgis/src/ui/qgscomposermanagerbase.ui	2010-04-11 14:12:20 UTC (rev 13299)
+++ trunk/qgis/src/ui/qgscomposermanagerbase.ui	2010-04-11 15:02:09 UTC (rev 13300)
@@ -1,72 +1,42 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsComposerManagerBase</class>
- <widget class="QDialog" name="QgsComposerManagerBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsComposerManagerBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
     <width>346</width>
-    <height>203</height>
+    <height>195</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Composer manager</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout" >
-   <item rowspan="5" row="0" column="0" >
-    <widget class="QListWidget" name="mComposerListWidget" />
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0" rowspan="3" colspan="2">
+    <widget class="QListWidget" name="mComposerListWidget"/>
    </item>
-   <item row="0" column="1" >
-    <widget class="QPushButton" name="mShowPushButton" >
-     <property name="text" >
-      <string>Show</string>
+   <item row="4" column="0" colspan="2">
+    <widget class="QDialogButtonBox" name="mButtonBox">
+     <property name="orientation">
+      <enum>Qt::Horizontal</enum>
      </property>
-    </widget>
-   </item>
-   <item row="1" column="1" >
-    <widget class="QPushButton" name="mRemoveButton" >
-      <string>Remove</string>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Close</set>
      </property>
     </widget>
    </item>
-   <item row="2" column="1" >
-    <widget class="QPushButton" name="mRenamePushButton" >
-      <string>Rename</string>
-     </property>
-    </widget>
+   <item row="3" column="0">
+    <widget class="QComboBox" name="mTemplate"/>
    </item>
-   <item row="3" column="1" >
-    <widget class="QPushButton" name="mAddButton" >
+   <item row="3" column="1">
+    <widget class="QPushButton" name="mAddButton">
+     <property name="text">
       <string>Add</string>
      </property>
     </widget>
    </item>
-   <item row="4" column="1" >
-    <spacer name="verticalSpacer" >
-     <property name="orientation" >
-      <enum>Qt::Vertical</enum>
-     </property>
-     <property name="sizeHint" stdset="0" >
-      <size>
-       <width>20</width>
-       <height>50</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
-   <item row="5" column="0" colspan="2" >
-    <widget class="QDialogButtonBox" name="mButtonBox" >
-      <enum>Qt::Horizontal</enum>
-     </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Close</set>
-     </property>
-    </widget>
-   </item>
   </layout>
  </widget>
  <resources/>
@@ -77,11 +47,11 @@
    <receiver>QgsComposerManagerBase</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>251</x>
      <y>193</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>157</x>
      <y>274</y>
     </hint>
@@ -93,11 +63,11 @@
    <slot>reject()</slot>
    <hints>
      <x>251</x>
      <y>193</y>
     </hint>
      <x>286</x>
      <y>274</y>
     </hint>
More information about the QGIS-commit mailing list
