[QGIS Commit] r13340 - in trunk/qgis: . src/providers/postgres
svn_qgis at osgeo.org
Tue Apr 20 15:29:25 EDT 2010
Author: jef
Date: 2010-04-20 15:29:25 -0400 (Tue, 20 Apr 2010)
New Revision: 13340
trunk/qgis/CONTRIBUTORS
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
apply #2662. Thanks Giuseppe.
Modified: trunk/qgis/CONTRIBUTORS
--- trunk/qgis/CONTRIBUTORS 2010-04-20 19:25:32 UTC (rev 13339)
+++ trunk/qgis/CONTRIBUTORS 2010-04-20 19:29:25 UTC (rev 13340)
@@ -43,3 +43,4 @@
Andres Manz
Mark Baas
Jeremy Palmer
+Giuseppe Sucameli
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-20 19:25:32 UTC (rev 13339)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-20 19:29:25 UTC (rev 13340)
@@ -82,19 +82,34 @@
mTableName = mUri.table();
geometryColumn = mUri.geometryColumn();
sqlWhereClause = mUri.sql();
+ if ( mSchemaName.isEmpty() &&
+ mTableName.startsWith( "(select", Qt::CaseInsensitive ) &&
+ mTableName.endsWith( ")" ) )
+ isQuery = true;
+ mQuery = mTableName;
+ mTableName = "";
+ else
+ isQuery = false;
+ if ( !mSchemaName.isEmpty() )
+ mQuery += quotedIdentifier( mSchemaName ) + ".";
+ mQuery += quotedIdentifier( mTableName );
primaryKey = mUri.keyColumn();
mUseEstimatedMetadata = mUri.useEstimatedMetadata();
- // Keep a schema qualified table name for convenience later on.
- mSchemaTableName = mUri.quotedTablename();
- QgsDebugMsg( "Table name is " + mTableName );
- QgsDebugMsg( "SQL is " + sqlWhereClause );
QgsDebugMsg( "Connection info is " + mUri.connectionInfo() );
QgsDebugMsg( "Geometry column is: " + geometryColumn );
QgsDebugMsg( "Schema is: " + mSchemaName );
QgsDebugMsg( "Table name is: " + mTableName );
+ QgsDebugMsg( "Query is: " + mQuery );
+ QgsDebugMsg( "Where clause is: " + sqlWhereClause );
connectionRW = NULL;
connectionRO = Conn::connectDb( mUri.connectionInfo(), true );
@@ -104,107 +119,13 @@
return;
- QgsDebugMsg( "Checking for permissions on the relation" );
- // Check that we can read from the table (i.e., we have
- // select permission).
- QString sql = QString( "select * from %1 limit 1" ).arg( mSchemaTableName );
- Result testAccess = connectionRO->PQexec( sql );
- if ( PQresultStatus( testAccess ) != PGRES_TUPLES_OK )
+ if ( !hasSufficientPermsAndCapabilities() ) // check permissions and set capabilities
- showMessageBox( tr( "Unable to access relation" ),
- tr( "Unable to access the %1 relation.\nThe error message from the database was:\n%2.\nSQL: %3" )
- .arg( mSchemaTableName )
- .arg( QString::fromUtf8( PQresultErrorMessage( testAccess ) ) )
- .arg( sql ) );
valid = false;
disconnectDb();
return;
- if ( connectionRO->pgVersion() >= 80400 )
- sql = QString( "SELECT "
- "has_table_privilege(%1,'DELETE'),"
- "has_any_column_privilege(%1,'UPDATE'),"
- "has_column_privilege(%1,%2,'UPDATE'),"
- "has_table_privilege(%1,'INSERT'),"
- "current_schema()" )
- .arg( quotedValue( mSchemaTableName ) ).arg( quotedValue( geometryColumn ) );
- else
- "has_table_privilege(%1,'UPDATE'),"
- .arg( quotedValue( mSchemaTableName ) );
- testAccess = connectionRO->PQexec( sql );
- tr( "Unable to determine table access privileges for the %1 relation.\nThe error message from the database was:\n%2.\nSQL: %3" )
- .arg( sql ) );
- valid = false;
- disconnectDb();
- return;
- // postgres has fast access to features at id (thanks to primary key / unique index)
- // the latter flag is here just for compatibility
- enabledCapabilities = QgsVectorDataProvider::SelectAtId | QgsVectorDataProvider::SelectGeometryAtId;
- if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 0 ) ) == "t" )
- // DELETE
- enabledCapabilities |= QgsVectorDataProvider::DeleteFeatures;
- if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 1 ) ) == "t" )
- // UPDATE
- enabledCapabilities |= QgsVectorDataProvider::ChangeAttributeValues;
- if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 2 ) ) == "t" )
- // UPDATE
- enabledCapabilities |= QgsVectorDataProvider::ChangeGeometries;
- if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 3 ) ) == "t" )
- // INSERT
- enabledCapabilities |= QgsVectorDataProvider::AddFeatures;
- mCurrentSchema = QString::fromUtf8( PQgetvalue( testAccess, 0, 4 ) );
- if ( mCurrentSchema == mSchemaName )
- mUri.clearSchema();
- if ( mSchemaName == "" )
- mSchemaName = mCurrentSchema;
- sql = QString( "SELECT 1 FROM pg_class,pg_namespace WHERE "
- "pg_class.relnamespace=pg_namespace.oid AND "
- "pg_get_userbyid(relowner)=current_user AND "
- "relname=%1 AND nspname=%2" )
- .arg( quotedValue( mTableName ) )
- .arg( quotedValue( mSchemaName ) );
- if ( PQresultStatus( testAccess ) == PGRES_TUPLES_OK && PQntuples( testAccess ) == 1 )
- enabledCapabilities |= QgsVectorDataProvider::AddAttributes | QgsVectorDataProvider::DeleteAttributes;
if ( !getGeometryDetails() ) // gets srid and geometry type
// the table is not a geometry table
@@ -224,7 +145,12 @@
getPrimaryKey();
// load the field list
- loadFields();
+ if ( !loadFields() )
+ valid = false;
+ disconnectDb();
+ return;
// Set the postgresql message level so that we don't get the
// 'there is no transaction in progress' warning.
@@ -485,7 +411,7 @@
query += "," + fieldExpression( fld );
- query += " from " + mSchemaTableName;
+ query += " from " + mQuery;
if ( !whereClause.isEmpty() )
query += QString( " where %1" ).arg( whereClause );
@@ -675,7 +601,7 @@
QString fetch = QString( "fetch forward %1 from %2" ).arg( mFeatureQueueSize ).arg( cursorName );
if ( connectionRO->PQsendQuery( fetch ) == 0 ) // fetch features asynchronously
- QgsDebugMsg( "PQsendQuery failed (1)" );
+ QgsDebugMsg( "PQsendQuery failed" );
Result queryResult;
@@ -874,30 +800,34 @@
-void QgsPostgresProvider::loadFields()
+bool QgsPostgresProvider::loadFields()
- QgsDebugMsg( "Loading fields for table " + mTableName );
+ if ( !isQuery )
+ QgsDebugMsg( "Loading fields for table " + mTableName );
- // Get the relation oid for use in later queries
- QString sql = QString( "SELECT regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
- Result tresult = connectionRO->PQexec( sql );
- QString tableoid = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
+ // Get the relation oid for use in later queries
+ QString sql = QString( "SELECT regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
+ Result tresult = connectionRO->PQexec( sql );
+ QString tableoid = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
- // Get the table description
- sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=0" ).arg( tableoid );
- tresult = connectionRO->PQexec( sql );
- if ( PQntuples( tresult ) > 0 )
- mDataComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
+ // Get the table description
+ sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=0" ).arg( tableoid );
+ tresult = connectionRO->PQexec( sql );
+ if ( PQntuples( tresult ) > 0 )
+ mDataComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
// Populate the field vector for this layer. The field vector contains
// field name, type, length, and precision (if numeric)
- sql = QString( "select * from %1 limit 0" ).arg( mSchemaTableName );
+ QString sql = QString( "select * from %1 limit 0" ).arg( mQuery );
Result result = connectionRO->PQexec( sql );
+ QSet<QString> fields;
// The queries inside this loop could possibly be combined into one
// single query - this would make the code run faster.
attributeFields.clear();
for ( int i = 0; i < PQnfields( result ); i++ )
@@ -909,6 +839,7 @@
QString typOid = QString().setNum( fldtyp );
int fieldModifier = PQfmod( result, i );
QString fieldComment( "" );
+ int tableoid = PQftable( result, i );
sql = QString( "SELECT typname,typtype,typelem,typlen FROM pg_type WHERE oid=%1" ).arg( typOid );
// just oid; needs more work to support array type
@@ -921,18 +852,21 @@
QString fieldElem = QString::fromUtf8( PQgetvalue( oidResult, 0, 2 ) );
int fieldSize = QString::fromUtf8( PQgetvalue( oidResult, 0, 3 ) ).toInt();
- sql = QString( "SELECT attnum FROM pg_attribute WHERE attrelid=%1 AND attname=%2" )
- .arg( tableoid ).arg( quotedValue( fieldName ) );
+ if ( tableoid >= 0 )
+ sql = QString( "SELECT attnum FROM pg_attribute WHERE attrelid=%1 AND attname=%2" )
+ .arg( tableoid ).arg( quotedValue( fieldName ) );
- QString attnum = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
+ QString attnum = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
- sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=%2" )
- .arg( tableoid ).arg( attnum );
+ sql = QString( "SELECT description FROM pg_description WHERE objoid=%1 AND objsubid=%2" )
+ .arg( tableoid ).arg( attnum );
- fieldComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
+ fieldComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
QVariant::Type fieldType;
@@ -1003,10 +937,170 @@
continue;
+ if ( fields.contains( fieldName ) )
+ showMessageBox( tr( "Ambiguous field!" ),
+ tr( "Duplicate field %1 found\n" ).arg( fieldName ) );
+ return false;
+ fields << fieldName;
attributeFields.insert( i, QgsField( fieldName, fieldType, fieldTypeName, fieldSize, fieldModifier, fieldComment ) );
+ return true;
+bool QgsPostgresProvider::hasSufficientPermsAndCapabilities()
+ QgsDebugMsg( "Checking for permissions on the relation" );
+ Result testAccess;
+ if ( !isQuery )
+ // Check that we can read from the table (i.e., we have
+ // select permission).
+ QString sql = QString( "select * from %1 limit 1" ).arg( mQuery );
+ Result testAccess = connectionRO->PQexec( sql );
+ if ( PQresultStatus( testAccess ) != PGRES_TUPLES_OK )
+ showMessageBox( tr( "Unable to access relation" ),
+ tr( "Unable to access the %1 relation.\nThe error message from the database was:\n%2.\nSQL: %3" )
+ .arg( mQuery )
+ .arg( QString::fromUtf8( PQresultErrorMessage( testAccess ) ) )
+ .arg( sql ) );
+ return false;
+ if ( connectionRO->pgVersion() >= 80400 )
+ sql = QString( "SELECT "
+ "has_table_privilege(%1,'DELETE'),"
+ "has_any_column_privilege(%1,'UPDATE'),"
+ "has_column_privilege(%1,%2,'UPDATE'),"
+ "has_table_privilege(%1,'INSERT'),"
+ "current_schema()" )
+ .arg( quotedValue( mQuery ) ).arg( quotedValue( geometryColumn ) );
+ else
+ "has_table_privilege(%1,'UPDATE'),"
+ .arg( quotedValue( mQuery ) );
+ testAccess = connectionRO->PQexec( sql );
+ tr( "Unable to determine table access privileges for the %1 relation.\nThe error message from the database was:\n%2.\nSQL: %3" )
+ .arg( mQuery )
+ .arg( sql ) );
+ return false;
+ // postgres has fast access to features at id (thanks to primary key / unique index)
+ // the latter flag is here just for compatibility
+ enabledCapabilities = QgsVectorDataProvider::SelectAtId | QgsVectorDataProvider::SelectGeometryAtId;
+ if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 0 ) ) == "t" )
+ // DELETE
+ enabledCapabilities |= QgsVectorDataProvider::DeleteFeatures;
+ if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 1 ) ) == "t" )
+ // UPDATE
+ enabledCapabilities |= QgsVectorDataProvider::ChangeAttributeValues;
+ if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 2 ) ) == "t" )
+ // UPDATE
+ enabledCapabilities |= QgsVectorDataProvider::ChangeGeometries;
+ if ( QString::fromUtf8( PQgetvalue( testAccess, 0, 3 ) ) == "t" )
+ // INSERT
+ enabledCapabilities |= QgsVectorDataProvider::AddFeatures;
+ mCurrentSchema = QString::fromUtf8( PQgetvalue( testAccess, 0, 4 ) );
+ if ( mCurrentSchema == mSchemaName )
+ mUri.clearSchema();
+ if ( mSchemaName == "" )
+ mSchemaName = mCurrentSchema;
+ sql = QString( "SELECT 1 FROM pg_class,pg_namespace WHERE "
+ "pg_class.relnamespace=pg_namespace.oid AND "
+ "pg_get_userbyid(relowner)=current_user AND "
+ "relname=%1 AND nspname=%2" )
+ .arg( quotedValue( mTableName ) )
+ .arg( quotedValue( mSchemaName ) );
+ if ( PQresultStatus( testAccess ) == PGRES_TUPLES_OK && PQntuples( testAccess ) == 1 )
+ enabledCapabilities |= QgsVectorDataProvider::AddAttributes | QgsVectorDataProvider::DeleteAttributes;
+ else
+ // Check if the sql is a select query
+ if ( !mQuery.startsWith( "(select", Qt::CaseInsensitive ) &&
+ !mQuery.endsWith( ")" ) )
+ QgsDebugMsg( "The custom query is not a select query." );
+ //TODO show a message by showMessageBox()
+ return false;
+ // get a new alias for the subquery
+ int index = 0;
+ QString alias;
+ QRegExp regex;
+ do
+ alias = QString( "subQuery_%1" ).arg( QString::number( index++ ) );
+ QString pattern = QString( "(\\\"?)%1\\1" ).arg( QRegExp::escape( alias ) );
+ regex.setPattern( pattern );
+ regex.setCaseSensitivity( Qt::CaseInsensitive );
+ while ( mQuery.contains( regex ) );
+ // convert the custom query into a subquery
+ mQuery = QString( "%1 as %2" )
+ .arg( mQuery )
+ .arg( quotedIdentifier( alias ) );
+ showMessageBox( tr( "Unable execute the query" ),
+ tr( "Unable to execute the query.\nThe error message from the database was:\n%1.\nSQL: %2" )
+ .arg( sql ) );
+ return false;
+ return true;
QString QgsPostgresProvider::getPrimaryKey()
// If we find a database primary key we will set this to true. If it is a column which is serving
@@ -1017,247 +1111,251 @@
// can be used as a key into the table. Primary keys are always
// unique indices, so we catch them as well.
- QString sql = QString( "select indkey from pg_index where indisunique and indrelid=regclass(%1)::oid and indpred is null" )
+ QString sql;
+ if ( !isQuery )
+ sql = QString( "select indkey from pg_index where indisunique and indrelid=regclass(%1)::oid and indpred is null" )
- QgsDebugMsg( "Getting unique index using '" + sql + "'" );
+ QgsDebugMsg( "Getting unique index using '" + sql + "'" );
- Result pk = connectionRO->PQexec( sql );
+ Result pk = connectionRO->PQexec( sql );
- QgsDebugMsg( "Got " + QString::number( PQntuples( pk ) ) + " rows." );
+ QgsDebugMsg( "Got " + QString::number( PQntuples( pk ) ) + " rows." );
- QStringList log;
+ QStringList log;
- // if we got no tuples we ain't got no unique index :)
- if ( PQntuples( pk ) == 0 )
- QgsDebugMsg( "Relation has no unique index -- investigating alternatives" );
+ // if we got no tuples we ain't got no unique index :)
+ if ( PQntuples( pk ) == 0 )
+ QgsDebugMsg( "Relation has no unique index -- investigating alternatives" );
- // Two options here. If the relation is a table, see if there is
- // an oid column that can be used instead.
- // If the relation is a view try to find a suitable column to use as
- // the primary key.
+ // Two options here. If the relation is a table, see if there is
+ // an oid column that can be used instead.
+ // If the relation is a view try to find a suitable column to use as
+ // the primary key.
- sql = QString( "SELECT relkind FROM pg_class WHERE oid=regclass(%1)::oid" )
- Result tableType = connectionRO->PQexec( sql );
- QString type = QString::fromUtf8( PQgetvalue( tableType, 0, 0 ) );
+ sql = QString( "SELECT relkind FROM pg_class WHERE oid=regclass(%1)::oid" )
+ Result tableType = connectionRO->PQexec( sql );
+ QString type = QString::fromUtf8( PQgetvalue( tableType, 0, 0 ) );
- if ( type == "r" ) // the relation is a table
- QgsDebugMsg( "Relation is a table. Checking to see if it has an oid column." );
+ if ( type == "r" ) // the relation is a table
+ QgsDebugMsg( "Relation is a table. Checking to see if it has an oid column." );
- primaryKey = "";
+ primaryKey = "";
- // If there is an oid on the table, use that instead,
- // otherwise give up
- sql = QString( "SELECT attname FROM pg_attribute WHERE attname='oid' AND attrelid=regclass(%1)" )
+ // If there is an oid on the table, use that instead,
+ // otherwise give up
+ sql = QString( "SELECT attname FROM pg_attribute WHERE attname='oid' AND attrelid=regclass(%1)" )
- Result oidCheck = connectionRO->PQexec( sql );
+ Result oidCheck = connectionRO->PQexec( sql );
- if ( PQntuples( oidCheck ) != 0 )
- // Could warn the user here that performance will suffer if
- // oid isn't indexed (and that they may want to add a
- // primary key to the table)
- primaryKey = "oid";
- primaryKeyType = "int4";
- mIsDbPrimaryKey = true;
- else
- sql = QString( "SELECT attname FROM pg_attribute WHERE attname='ctid' AND attrelid=regclass(%1)" )
- Result ctidCheck = connectionRO->PQexec( sql );
- if ( PQntuples( ctidCheck ) == 1 )
+ if ( PQntuples( oidCheck ) != 0 )
- sql = QString( "SELECT max(substring(ctid::text from E'\\\\((\\\\d+),\\\\d+\\\\)')::integer) from %1" )
- .arg( mSchemaTableName );
+ // Could warn the user here that performance will suffer if
+ // oid isn't indexed (and that they may want to add a
+ // primary key to the table)
+ primaryKey = "oid";
+ primaryKeyType = "int4";
+ mIsDbPrimaryKey = true;
+ else
+ sql = QString( "SELECT attname FROM pg_attribute WHERE attname='ctid' AND attrelid=regclass(%1)" )
- int id = QString( PQgetvalue( ctidCheck, 0, 0 ) ).toInt();
+ sql = QString( "SELECT max(substring(ctid::text from E'\\\\((\\\\d+),\\\\d+\\\\)')::integer) from %1" )
+ .arg( mQuery );
- if ( id < 0x10000 )
+ Result ctidCheck = connectionRO->PQexec( sql );
+ if ( PQntuples( ctidCheck ) == 1 )
- // fallback to ctid
- primaryKey = "ctid";
- primaryKeyType = "tid";
+ int id = QString( PQgetvalue( ctidCheck, 0, 0 ) ).toInt();
+ if ( id < 0x10000 )
+ // fallback to ctid
+ primaryKey = "ctid";
+ primaryKeyType = "tid";
- if ( primaryKey.isEmpty() )
- showMessageBox( tr( "No suitable key column in table" ),
- tr( "The table has no column suitable for use as a key.\n\n"
- "Quantum GIS requires that the table either has a column of type\n"
- "int4 with a unique constraint on it (which includes the\n"
- "primary key), has a PostgreSQL oid column or has a ctid\n"
- "column with a 16bit block number.\n" ) );
- else
- mPrimaryKeyDefault = defaultValue( primaryKey ).toString();
- if ( mPrimaryKeyDefault.isNull() )
+ if ( primaryKey.isEmpty() )
- mPrimaryKeyDefault = QString( "max(%1)+1 from %2.%3" )
- .arg( quotedIdentifier( primaryKey ) )
- .arg( quotedIdentifier( mSchemaName ) )
- .arg( quotedIdentifier( mTableName ) );
+ showMessageBox( tr( "No suitable key column in table" ),
+ tr( "The table has no column suitable for use as a key.\n\n"
+ "Quantum GIS requires that the table either has a column of type\n"
+ "int4 with a unique constraint on it (which includes the\n"
+ "primary key), has a PostgreSQL oid column or has a ctid\n"
+ "column with a 16bit block number.\n" ) );
+ else
+ mPrimaryKeyDefault = defaultValue( primaryKey ).toString();
+ if ( mPrimaryKeyDefault.isNull() )
+ mPrimaryKeyDefault = QString( "max(%1)+1 from %2.%3" )
+ .arg( quotedIdentifier( primaryKey ) )
+ .arg( quotedIdentifier( mSchemaName ) )
+ .arg( quotedIdentifier( mTableName ) );
- else if ( type == "v" ) // the relation is a view
- if ( !primaryKey.isEmpty() )
+ else if ( type == "v" ) // the relation is a view
- // check last used candidate
- sql = QString( "select pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attname=%1 and attrelid=regclass(%2)" )
- .arg( quotedValue( primaryKey ) ).arg( quotedValue( mSchemaTableName ) );
+ if ( !primaryKey.isEmpty() )
+ // check last used candidate
+ sql = QString( "select pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attname=%1 and attrelid=regclass(%2)" )
+ .arg( quotedValue( primaryKey ) ).arg( quotedValue( mQuery ) );
- QgsDebugMsg( "checking candidate: " + sql );
+ QgsDebugMsg( "checking candidate: " + sql );
- Result result = connectionRO->PQexec( sql );
+ Result result = connectionRO->PQexec( sql );
- QString type;
- if ( PQresultStatus( result ) == PGRES_TUPLES_OK &&
- PQntuples( result ) == 1 )
- type = PQgetvalue( result, 0, 0 );
+ QString type;
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK &&
+ PQntuples( result ) == 1 )
+ type = PQgetvalue( result, 0, 0 );
+ // mPrimaryKeyDefault stays null and is retrieved later on demand
+ if (( type != "int4" && type != "oid" ) ||
+ !uniqueData( mQuery, primaryKey ) )
+ primaryKey = "";
- // mPrimaryKeyDefault stays null and is retrieved later on demand
- if (( type != "int4" && type != "oid" ) ||
- !uniqueData( mSchemaName, mTableName, primaryKey ) )
- primaryKey = "";
+ parseView();
- parseView();
+ else
+ QgsDebugMsg( "Unexpected relation type of '" + type + "'." );
- else
- QgsDebugMsg( "Unexpected relation type of '" + type + "'." );
- else // have some unique indices on the table. Now choose one...
- // choose which (if more than one) unique index to use
- std::vector<std::pair<QString, QString> > suitableKeyColumns;
- for ( int i = 0; i < PQntuples( pk ); ++i )
+ else // have some unique indices on the table. Now choose one...
- QString col = QString::fromUtf8( PQgetvalue( pk, i, 0 ) );
- QStringList columns = col.split( " ", QString::SkipEmptyParts );
- if ( columns.count() == 1 )
+ // choose which (if more than one) unique index to use
+ std::vector<std::pair<QString, QString> > suitableKeyColumns;
+ for ( int i = 0; i < PQntuples( pk ); ++i )
- // Get the column name and data type
- sql = QString( "select attname,pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attnum=%1 and attrelid=regclass(%2)" )
- .arg( col ).arg( quotedValue( mSchemaTableName ) );
- Result types = connectionRO->PQexec( sql );
- if ( PQntuples( types ) > 0 )
+ QString col = QString::fromUtf8( PQgetvalue( pk, i, 0 ) );
+ QStringList columns = col.split( " ", QString::SkipEmptyParts );
+ if ( columns.count() == 1 )
- QString columnName = QString::fromUtf8( PQgetvalue( types, 0, 0 ) );
- QString columnType = QString::fromUtf8( PQgetvalue( types, 0, 1 ) );
+ // Get the column name and data type
+ sql = QString( "select attname,pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attnum=%1 and attrelid=regclass(%2)" )
+ .arg( col ).arg( quotedValue( mQuery ) );
+ Result types = connectionRO->PQexec( sql );
- if ( columnType != "int4" )
- log.append( tr( "The unique index on column '%1' is unsuitable because Quantum GIS does not currently "
- "support non-int4 type columns as a key into the table.\n" ).arg( columnName ) );
+ if ( PQntuples( types ) > 0 )
+ QString columnName = QString::fromUtf8( PQgetvalue( types, 0, 0 ) );
+ QString columnType = QString::fromUtf8( PQgetvalue( types, 0, 1 ) );
+ if ( columnType != "int4" )
+ log.append( tr( "The unique index on column '%1' is unsuitable because Quantum GIS does not currently "
+ "support non-int4 type columns as a key into the table.\n" ).arg( columnName ) );
+ else
+ suitableKeyColumns.push_back( std::make_pair( columnName, columnType ) );
else
- suitableKeyColumns.push_back( std::make_pair( columnName, columnType ) );
+ //QgsDebugMsg( QString("name and type of %3. column of %1.%2 not found").arg(mSchemaName).arg(mTables).arg(col) );
else
- //QgsDebugMsg( QString("name and type of %3. column of %1.%2 not found").arg(mSchemaName).arg(mTables).arg(col) );
+ sql = QString( "select attname from pg_attribute, pg_type where atttypid=pg_type.oid and attnum in (%1) and attrelid=regclass(%2)::oid" )
+ .arg( col.replace( " ", "," ) )
+ QString colNames;
+ int numCols = PQntuples( types );
+ for ( int j = 0; j < numCols; ++j )
+ if ( j == numCols - 1 )
+ colNames += tr( "and " );
+ colNames += quotedValue( QString::fromUtf8( PQgetvalue( types, j, 0 ) ) );
+ if ( j < numCols - 2 )
+ colNames += ",";
+ log.append( tr( "The unique index based on columns %1 is unsuitable because Quantum GIS does not currently "
+ "support multiple columns as a key into the table.\n" ).arg( colNames ) );
+ // suitableKeyColumns now contains the name of columns (and their
+ // data type) that
+ // are suitable for use as a key into the table. If there is
+ // more than one we need to choose one. For the moment, just
+ // choose the first in the list.
+ if ( suitableKeyColumns.size() > 0 )
+ primaryKey = suitableKeyColumns[0].first;
+ primaryKeyType = suitableKeyColumns[0].second;
else
- sql = QString( "select attname from pg_attribute, pg_type where atttypid=pg_type.oid and attnum in (%1) and attrelid=regclass(%2)::oid" )
- .arg( col.replace( " ", "," ) )
+ sql = QString( "select attname from pg_attribute where attname='oid' and attrelid=regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
- QString colNames;
- int numCols = PQntuples( types );
- for ( int j = 0; j < numCols; ++j )
- if ( j == numCols - 1 )
- colNames += tr( "and " );
- colNames += quotedValue( QString::fromUtf8( PQgetvalue( types, j, 0 ) ) );
- if ( j < numCols - 2 )
- colNames += ",";
- log.append( tr( "The unique index based on columns %1 is unsuitable because Quantum GIS does not currently "
- "support multiple columns as a key into the table.\n" ).arg( colNames ) );
+ else
+ log.prepend( "There were no columns in the table that were suitable "
+ "as a qgis key into the table (either a column with a "
+ "unique index and type int4 or a PostgreSQL oid column.\n" );
- // suitableKeyColumns now contains the name of columns (and their
- // data type) that
- // are suitable for use as a key into the table. If there is
- // more than one we need to choose one. For the moment, just
- // choose the first in the list.
- if ( suitableKeyColumns.size() > 0 )
- primaryKey = suitableKeyColumns[0].first;
- primaryKeyType = suitableKeyColumns[0].second;
- else
- sql = QString( "select attname from pg_attribute where attname='oid' and attrelid=regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
+ // Either primaryKey has been set by the above code, or it
+ // hasn't. If not, present some info to the user to give them some
+ // idea of why not.
+ // Give some info to the user about why things didn't work out.
+ valid = false;
+ showMessageBox( tr( "Unable to find a key column" ), log );
else
- log.prepend( "There were no columns in the table that were suitable "
- "as a qgis key into the table (either a column with a "
- "unique index and type int4 or a PostgreSQL oid column.\n" );
- // Either primaryKey has been set by the above code, or it
- // hasn't. If not, present some info to the user to give them some
- // idea of why not.
- // Give some info to the user about why things didn't work out.
- valid = false;
- showMessageBox( tr( "Unable to find a key column" ), log );
- else
if ( !primaryKey.isNull() )
@@ -1436,7 +1534,7 @@
.arg( quotedValue( i->second.column ) );
- if ( PQntuples( result ) > 0 && uniqueData( mSchemaName, mTableName, i->first ) )
+ if ( PQntuples( result ) > 0 && uniqueData( mQuery, i->first ) )
// Got one. Use it.
key = i->first;
@@ -1451,7 +1549,7 @@
// exists). This is legacy support and could be removed in
// future.
i = suitable.find( "oid" );
- if ( i != suitable.end() && uniqueData( mSchemaName, mTableName, i->first ) )
+ if ( i != suitable.end() && uniqueData( mQuery, i->first ) )
key = i->first;
@@ -1466,7 +1564,7 @@
tableCols::const_iterator i = suitable.begin();
for ( ; i != suitable.end(); ++i )
- if ( uniqueData( mSchemaName, mTableName, i->first ) )
+ if ( uniqueData( mQuery, i->first ) )
key = i->first;
@@ -1503,17 +1601,15 @@
return key;
-bool QgsPostgresProvider::uniqueData( QString schemaName,
- QString tableName, QString colName )
+bool QgsPostgresProvider::uniqueData( QString query, QString colName )
// Check to see if the given column contains unique data
bool isUnique = false;
- QString sql = QString( "select count(distinct %1)=count(%1) from %2.%3" )
+ QString sql = QString( "select count(distinct %1)=count(%1) from %2" )
.arg( quotedIdentifier( colName ) )
- .arg( quotedIdentifier( schemaName ) )
- .arg( quotedIdentifier( tableName ) );
+ .arg( mQuery );
if ( !sqlWhereClause.isEmpty() )
@@ -1780,20 +1876,15 @@
// get the field name
const QgsField &fld = field( index );
- QString sql;
- if ( sqlWhereClause.isEmpty() )
+ QString sql = QString( "select min(%1) from %2" )
+ .arg( quotedIdentifier( fld.name() ) )
+ .arg( mQuery );
+ if ( !sqlWhereClause.isEmpty() )
- sql = QString( "select min(%1) from %2" )
- .arg( quotedIdentifier( fld.name() ) )
+ sql += QString( " where %1" ).arg( sqlWhereClause );
- else
- sql = QString( "select min(%1) from %2 where %3" )
- .arg( sqlWhereClause );
Result rmin = connectionRO->PQexec( sql );
return convertValue( fld.type(), QString::fromUtf8( PQgetvalue( rmin, 0, 0 ) ) );
@@ -1812,21 +1903,18 @@
- QString sql;
+ QString sql = QString( "select distinct %1 from %2" )
+ .arg( mQuery );
- sql = QString( "select distinct %1 from %2 order by %1" )
- else
- sql = QString( "select distinct %1 from %2 where %3 order by %1" )
+ sql += QString( " order by %1" )
+ .arg( quotedIdentifier( fld.name() ) );
if ( limit >= 0 )
sql += QString( " LIMIT %1" ).arg( limit );
@@ -1891,7 +1979,9 @@
bool QgsPostgresProvider::parseEnumRange( QStringList& enumValues, const QString& attributeName ) const
enumValues.clear();
- QString enumRangeSql = QString( "SELECT enum_range(%1) from %2 limit 1" ).arg( quotedIdentifier( attributeName ) ).arg( mSchemaTableName );
+ QString enumRangeSql = QString( "SELECT enum_range(%1) from %2 limit 1" )
+ .arg( quotedIdentifier( attributeName ) )
+ .arg( mQuery );
Result enumRangeRes = connectionRO->PQexec( enumRangeSql );
if ( PQresultStatus( enumRangeRes ) == PGRES_TUPLES_OK && PQntuples( enumRangeRes ) > 0 )
@@ -1979,20 +2069,15 @@
- QString sql;
+ QString sql = QString( "select max(%1) from %2" )
+ .arg( mQuery );
- sql = QString( "select max(%1) from %2" )
- else
- sql = QString( "select max(%1) from %2 where %3" )
Result rmax = connectionRO->PQexec( sql );
return convertValue( fld.type(), QString::fromUtf8( PQgetvalue( rmax, 0, 0 ) ) );
@@ -2151,6 +2236,9 @@
if ( flist.size() == 0 )
return true;
+ if ( isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2162,7 +2250,7 @@
// Prepare the INSERT statement
QString insert = QString( "INSERT INTO %1(%2" )
+ .arg( mQuery )
.arg( quotedIdentifier( geometryColumn ) ),
values = QString( ") VALUES (GeomFromWKB($1%1,%2)" )
.arg( connectionRW->useWkbHex() ? "" : "::bytea" )
@@ -2316,6 +2404,9 @@
bool returnvalue = true;
+ if ( isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2326,7 +2417,7 @@
for ( QgsFeatureIds::const_iterator it = id.begin(); it != id.end(); ++it )
QString sql = QString( "DELETE FROM %1 WHERE %2" )
- .arg( mSchemaTableName ).arg( whereClause( *it ) );
+ .arg( mQuery ).arg( whereClause( *it ) );
QgsDebugMsg( "delete sql: " + sql );
//send DELETE statement and do error handling
@@ -2354,6 +2445,9 @@
+ if ( isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2374,7 +2468,7 @@
QString sql = QString( "ALTER TABLE %1 ADD COLUMN %2 %3" )
+ .arg( mQuery )
.arg( quotedIdentifier( iter->name() ) )
.arg( type );
QgsDebugMsg( sql );
@@ -2388,7 +2482,7 @@
if ( !iter->comment().isEmpty() )
sql = QString( "COMMENT ON COLUMN %1.%2 IS %3" )
+ .arg( mQuery )
.arg( quotedValue( iter->comment() ) );
result = connectionRW->PQexec( sql );
@@ -2415,6 +2509,9 @@
+ if ( !isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2430,7 +2527,7 @@
QString column = field_it->name();
QString sql = QString( "ALTER TABLE %1 DROP COLUMN %2" )
+ .arg( mQuery )
.arg( quotedIdentifier( column ) );
//send sql statement and do error handling
@@ -2460,6 +2557,9 @@
+ if ( !isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2476,7 +2576,7 @@
if ( fid < 0 )
continue;
- QString sql = QString( "UPDATE %1 SET " ).arg( mSchemaTableName );
+ QString sql = QString( "UPDATE %1 SET " ).arg( mQuery );
bool first = true;
const QgsAttributeMap& attrs = iter.value();
@@ -2541,6 +2641,9 @@
QgsDebugMsg( "entering." );
+ if ( !isQuery )
+ return false;
if ( !connectRW() )
return false;
@@ -2552,7 +2655,7 @@
connectionRW->PQexecNR( "BEGIN" );
QString update = QString( "UPDATE %1 SET %2=GeomFromWKB($1%3,%4) WHERE %5=$2" )
+ .arg( mQuery )
.arg( srid )
@@ -2636,7 +2739,7 @@
sqlWhereClause = theSQL;
- if ( !mIsDbPrimaryKey && !uniqueData( mSchemaName, mTableName, primaryKey ) )
+ if ( !mIsDbPrimaryKey && !uniqueData( mQuery, primaryKey ) )
sqlWhereClause = prevWhere;
return false;
@@ -2663,15 +2766,15 @@
// a thread the task of getting the full count.
QString sql;
- if ( mUseEstimatedMetadata )
+ if ( !isQuery && mUseEstimatedMetadata )
- sql = QString( "select reltuples::int from pg_catalog.pg_class where oid=regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
+ sql = QString( "select reltuples::int from pg_catalog.pg_class where oid=regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
else
- sql = QString( "select count(*) from %1" ).arg( mSchemaTableName );
+ sql = QString( "select count(*) from %1" ).arg( mQuery );
- if ( sqlWhereClause.length() > 0 )
sql += " where " + sqlWhereClause;
@@ -2696,7 +2799,7 @@
QString ext;
// get the extents
- if ( mUseEstimatedMetadata || sqlWhereClause.isEmpty() )
+ if ( !isQuery && ( mUseEstimatedMetadata || sqlWhereClause.isEmpty() ) )
// do stats exists?
sql = QString( "SELECT COUNT(*) FROM pg_stats WHERE schemaname=%1 AND tablename=%2 AND attname=%3" )
@@ -2727,10 +2830,10 @@
sql = QString( "select extent(%1) from %2" )
+ .arg( mQuery );
- sql += QString( "where %1" ).arg( sqlWhereClause );
if ( PQresultStatus( result ) != PGRES_TUPLES_OK )
@@ -2823,15 +2926,50 @@
// version 7.4, binary cursors return data in XDR whereas previous versions
// return data in the endian of the server
- QString firstOid = QString( "select regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) );
- Result oidResult = connectionRO->PQexec( firstOid );
- // get the int value from a "normal" select
- QString oidValue = QString::fromUtf8( PQgetvalue( oidResult, 0, 0 ) );
+ QString oidValue;
+ QString query;
+ if ( isQuery )
+ Result res = connectionRO->PQexec( sql );
+ // loop through the returned fields to get a valid oid
+ int i;
+ for ( i = 0; i < PQnfields( res ); i++ )
+ int tableoid = PQftable( res, i );
+ oidValue = QString::number( tableoid );
+ break;
+ if ( i < PQnfields( res ) )
+ // get the table name
+ res = connectionRO->PQexec( QString( "SELECT relname FROM pg_class WHERE oid=%1" ).arg( oidValue ) );
+ query = QString::fromUtf8( PQgetvalue( res, 0, 0 ) );
+ else
+ QgsDebugMsg( "no oid found" );
+ return false;
+ else
+ QString firstOid = QString( "select regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
+ Result oidResult = connectionRO->PQexec( firstOid );
+ // get the int value from a "normal" select
+ oidValue = QString::fromUtf8( PQgetvalue( oidResult, 0, 0 ) );
QgsDebugMsg( "Creating binary cursor" );
// get the same value using a binary cursor
- connectionRO->openCursor( "oidcursor", QString( "select regclass(%1)::oid" ).arg( quotedValue( mSchemaTableName ) ) );
+ connectionRO->openCursor( "oidcursor", QString( "select regclass(%1)::oid" ).arg( quotedValue( query ) ) );
QgsDebugMsg( "Fetching a record and attempting to get check endian-ness" );
@@ -2861,31 +2999,38 @@
valid = false;
QStringList log;
- QString sql = QString( "select type,srid from geometry_columns"
- " where f_table_name=%1 and f_geometry_column=%2 and f_table_schema=%3" )
- .arg( quotedValue( geometryColumn ) )
+ Result result;
+ QString sql;
- QgsDebugMsg( "Getting geometry column: " + sql );
+ if ( !isQuery )
+ sql = QString( "select type,srid from geometry_columns"
+ " where f_table_name=%1 and f_geometry_column=%2 and f_table_schema=%3" )
+ .arg( quotedValue( geometryColumn ) )
+ QgsDebugMsg( "Getting geometry column: " + sql );
- QgsDebugMsg( "geometry column query returned " + QString::number( PQntuples( result ) ) );
- if ( PQntuples( result ) > 0 )
- fType = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
- srid = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
+ QgsDebugMsg( "geometry column query returned " + QString::number( PQntuples( result ) ) );
+ if ( PQntuples( result ) > 0 )
+ fType = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
+ srid = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
- else
+ if ( srid.isEmpty() || fType.isEmpty() )
// Didn't find what we need in the geometry_columns table, so
// get stuff from the relevant column instead. This may (will?)
// fail if there is no data in the relevant table.
- sql = QString( "select srid(%1),geometrytype(%1) from %2" )
+ sql = QString( "select srid(%1), geometrytype(%1) from %2" )
+ .arg( mQuery );
//it is possible that the where clause restricts the feature type
@@ -2921,16 +3066,16 @@
sql += QString( "(select %1 from %2 where %1 is not null limit %3) as t" )
+ .arg( mQuery )
.arg( sGeomTypeSelectLimit );
else
- sql += mSchemaTableName;
+ sql += mQuery;
- if ( mUri.sql() != "" )
- sql += " where " + mUri.sql();
+ sql += " where " + sqlWhereClause;
@@ -2967,7 +3112,7 @@
showMessageBox( tr( "Unknown geometry type" ),
tr( "Column %1 in %2 has a geometry type of %3, which Quantum GIS does not currently support." )
- .arg( geometryColumn ).arg( mSchemaTableName ).arg( fType ) );
+ .arg( geometryColumn ).arg( mQuery ).arg( fType ) );
valid = false;
@@ -2975,7 +3120,7 @@
log.prepend( tr( "Quantum GIS was unable to determine the type and srid of column %1 in %2. The database communication log was:\n%3" )
+ .arg( mQuery )
.arg( QString::fromUtf8( PQresultErrorMessage( result ) ) ) );
showMessageBox( tr( "Unable to get feature type and srid" ), log );
@@ -3040,6 +3185,10 @@
QgsDebugMsgLevel( err, 3 );
+ else
+ QgsDebugMsgLevel( QString( "Query failed: %1" ).arg( query ), 3 );
#endif
return res;
@@ -3081,13 +3230,22 @@
QString err = QString( "Query: %1 returned %2 [%3]" )
.arg( query )
.arg( errorStatus )
- .arg( PQresultErrorMessage( res ) );
+ .arg( QString::fromUtf8( PQresultErrorMessage( res ) ) );
#endif
if ( openCursors )
PQexecNR( "ROLLBACK" );
- QgsDebugMsg( QString( "Re-starting read-only transaction after errornous statement - state of %1 cursors lost" ).arg( openCursors ) );
+ QgsPostgresProvider::showMessageBox(
+ tr( "Query failed" ),
+ tr( "%1 cursor states lost.\nSQL: %2\nResult: %3 (%4)" )
+ .arg( openCursors )
+ .arg( query )
+ .arg( errorStatus )
+ .arg( QString::fromUtf8( PQresultErrorMessage( res ) ) ) );
+ openCursors = 0;
PQexecNR( "BEGIN READ ONLY" );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-04-20 19:25:32 UTC (rev 13339)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2010-04-20 19:29:25 UTC (rev 13340)
@@ -333,6 +333,8 @@
QString whereClause( int featureId ) const;
+ bool hasSufficientPermsAndCapabilities();
const QgsField &field( int index ) const;
/** Double quote a PostgreSQL identifier for placement in a SQL string.
@@ -349,7 +351,7 @@
/** Load the field list
- void loadFields();
+ bool loadFields();
/**Parses the enum_range of an attribute and inserts the possible values into a stringlist
@param enumValues the stringlist where the values are appended
@@ -383,14 +385,20 @@
* Flag indicating if the layer data source is a valid PostgreSQL layer
bool valid;
+ * provider references query (instead of a table)
+ bool isQuery;
* Name of the table with no schema
QString mTableName;
- * Name of the table with schema included
+ * Name of the table or subquery
- QString mSchemaTableName;
+ QString mQuery;
* Name of the schema
@@ -403,6 +411,7 @@
* SQL statement used to limit the features retrieved
QString sqlWhereClause;
* Primary key column for fetching features. If there is no primary key
* the oid is used to fetch features.
@@ -546,7 +555,7 @@
// A function that determines if the given schema.table.column
// contains unqiue entries
- bool uniqueData( QString schemaName, QString tableName, QString colName );
+ bool uniqueData( QString query, QString colName );
// Function that populates the given cols structure.
void findColumns( tableCols& cols );
